Everytime I re-run a workfile, I get several extra editing lines inbetween my own command lines. Have I missed something in my settings?
Best regards
Emilijan Vuletici
task:
Use DEplot to sketch a direction field for my_deq and the solution curve for the initial condition T(0) = 88 C. Assign your plot to my_plot.
*Note: my_deq is the differential equation
My input:
ODE2:=(Diff(T(t), t) = 1/59*(18-T(t)));
DEplot( ODE2, T(t), t=-4..4, {[T(0)=88]}, y=0..100);
Error Received:
Error, (in DEtools/DEplot/CheckInitial) the 'number' option must be specified before initial conditions
The only thing I can find about this error is the input isn't in the form of a differential equation... But I'm pretty sure it is.
Basically I have to find omega by solving determinant of the following matrix:
M := Matrix(4, 4, {(1, 1) = 0, (1, 2) = -1, (1, 3) = 0, (1, 4) = 1, (2, 1) = -EI*beta^3, (2, 2) = -m*omega^2, (2, 3) = EI*beta^3, (2, 4) = -m*omega^2, (3, 1) = EI*sin(147*beta)*beta+k_r*cos(147*beta)+I*c_r*omega*cos(147*beta), (3, 2) = EI*cos(147*beta)*beta-k_r*sin(147*beta)-I*c_r*omega*sin(147*beta), (3, 3) = -EI*sinh(147*beta)*beta+k_r*cosh(147*beta)+I*c_r*omega*cosh(147*beta), (3, 4) = -EI*cosh(147*beta)*beta+k_r*sinh(147*beta)+I*c_r*omega*sinh(147*beta), (4, 1) = -EI*cos(147*beta)*beta^3+sin(147*beta)*k_h, (4, 2) = EI*sin(147*beta)*beta^3+cos(147*beta)*k_h, (4, 3) = EI*cosh(147*beta)*beta^3+sinh(147*beta)*k_h, (4, 4) = EI*sinh(147*beta)*beta^3+cosh(147*beta)*k_h}):
The remaining values are:
beta=((5000/10^12)*(omega^2))^(1/4),k_r=3.33*10^10,k_h=1.62*10^9,c_r=3.14*10^9,m=350000,L=147,EI=10^12:
What is the proper way to deal with this problem numerically. Or maybe it is even possible to get a reasonable analytical expression?
Maple evaluates
Int(ln(1+x)/(1+x^2),x=0..1);
as
1/2*I*dilog(1/2+1/2*I)-1/2*I*dilog(1/2-1/2*I)+1/4*Pi*ln(2)-Catalan
It would be nice if Maple could simplify this to 1/8*Pi*ln(2). If you evalf the integral and use "identify" then Maple does return 1/8*Pi*ln(2).
MMa directly returns 1/8*Pi*ln(2), which seems preferable.
Hello everyone.
I have a vector field in 2d-cartesian coordinates which I would like to convert to a "normal" function, that is f(x, y) where when you put x and y in, you get the magnitude of the vector at that point.
Example vector field:
This one is very hard to handle by hand which is why I want to use Maple for it.
I tried VectorCalculus[Norm] but it gave me this:
my int is in below.
my_int.mw
my int has hyperbolic and trigonal parts thus when they are multiplied , Maple is not able to integrate!
Now, How can I solve this integral?
thank you for help
my int is:
eq1 := m*(diff(diff(w(x, t), t), t))+diff(diff(EIy*(diff(diff(w(x, t), x), x))+(EIz-EIy)*(diff(diff(w(x, t), x), x))*(theta(x)+phi(x, t))^2, x), x)-Pz = 0
l := 16; m := .75; EIy := 0.2e5; EIz := 0.400e7; GJ := 0.1e5; mj := .1; Pz := 5000; Mz := 0; theta := proc (x) options operator, arrow; 0 end proc
w := proc (x, t) options operator, arrow; q[1](t)*(cosh(1.8751*x/l)-cos(1.8751*x/l)+(-1)*.734096*(sinh(1.8751*x/l)-sin(1.8751*x/l)))+q[2](t)*(cosh(4.6941*x/l)-cos(4.6941*x/l)+(-1)*1.01847*(sinh(4.6941*x/l)-sin(4.6941*x/l)))+q[3](t)*(cosh(7.8548*x/l)-cos(7.8548*x/l)+(-1)*.999224*(sinh(7.8548*x/l)-sin(7.8548*x/l))) end proc
phi := proc (x, t) options operator, arrow; q[4](t)*sqrt(2)*sin(1.5708*x/l)+q[5](t)*sqrt(2)*sin(4.7124*x/l)+q[6](t)*sqrt(2)*sin(7.8540*x/l) end proc
f[1] := int(lhs(eq1)*(cosh(1.8751*x/l)-cos(1.8751*x/l)-.734096*(sinh(1.8751*x/l)-sin(1.8751*x/l))), x = 0 .. l)
hello, I put in the code:
> with(plots), with(ColorTools), with(LinearAlgebra), with(RandomTools), with(ExcelTools);
> A := `<|>`(`<,>`(1, 2, 0, 2, 3, 4, 3, 4, 7, 9, 5, 3, 4, 6, 7, 8, 3), `<,>`(0, 4, 7, 2, 2, 2, 4, 5, 6.5, 7, 5, 3, 2, 5, 9, 0, 1), `<,>`(1, 5, 2, 0, 4, 1, 2, 3, 4.3, 7, 8, 5, 3, 2, 9, 6, 4)); J := convert(Import("testB1.xlsx", "Cartesian", "E2:G18"), matrix);
Error, (in convert/matrix) expecting array, rtable or list
> B := matrix([[1], [.2], [.1], [.8], [.5], [.6], [.8], [.764], [.234], [0.4e-1], [.89], [.36], [.687], [.627], [.689], [.328], [.139]]); H := convert(Import("test.xlsx", "Cartesian", "D2:D18"), matrix);
> C := [seq(Color([H[i, 1], 0, 0]), i = 1 .. RowDimension(A))];
And i get the error message everytime I try import m data list and I dont understand why. Any help would be appreciated. Thank you
Jennifer
eq:=diff(y(x),x) - y(x)^2 - x*y(x) - x + 1;
r:=dsolve(eq,y(x));
latex(r);
Gives an error "(in fprintf) string expected for string format". The problem seems when the math contains "erf"? Both examples below fail with result that contains this.
Maple 18, on windows 7.
Another example:
eq:=diff(y(x),x) + a*y(x)*(y(x)-x) - 1;
r:=dsolve(eq,y(x));
latex(r);
Another example, which seems to fail for different reason
eq:=diff(y(x),x) + a*x*y(x)^3+b*y(x)^2;
r:=dsolve(eq,y(x));
latex(r);
I've been using a maple package (written by another author) on earlier versions of Maple.  Recently I have been trying to rewrite it so it's a bit more Maple 16+ friendly (since I've read that Maple is not forward-compatible). However, I have been experiencing similar strange behavior in both the original and my current version:
After saving the module to my personal library, I load with(MyPackage). Most functions work fine (all but a handful out of dozens).  However, some functions won't be recognized (e.g., Coproduct(...) will return itself Coproduct(...)).
HOWEVER, when I execute the code in the module in its own Maple worksheet, all functions are recognized and work perfectly.  I look at the difference in the code between the functions that work upon loading the package (using with(MyPackage) command in a separate sheet) and those that don't, and there is no difference.
I'm assuming I'll just have to cut and paste the hundreds of lines of code for my package into each sheet I'd like to use it in, since I haven't been able to find others experience this problem in the knowledge base.  I'm hoping someone will be able to help out, however.
hi all.
I have wrore the following program for optimization with bernstein and block pulse hybrid functions.
the program have some errors which i can't understand.
Bernestien1.mws
alias(C=binomial):
macro(LA= LinearAlgebra):
HybrFunc:=proc(N, M,  tj)               # N=Number of subintervals,  M=Number of functions in subintervals
local B, n, m;
global b;
for n from 1 to N do
for m from 0 to M-1 do
B := (i,m,t) -> C(m,i)*(1-t)^(m-i)*t^i:
b[n,m]:=unapply(piecewise(t>=(n-1)*tj/N and t<n*tj/N, B(m,2,N*t-(n-1)*tj), 0), t):
 od:od:
Array(1..N, 0..M-1, (n,m)->b[n,m](t)):
#convert(%,vector);
HybrFunc(3, 3, 1);
                                       # End Of Definition
g2(t):=t;            #*exp(t-1):                      # Any other function can be replaced here
g1(t):=add(add(c[n,m]*b[n,m](t), m=0..2), n=1..3);
Optimization[Minimize](sqrt(int((g2(t)-g1(t))^2, t=0.. 1)));
assign(op(%[2]));
plot([g2(t),g1(t)], t=0..1, 0..5, color=[blue,red],thickness=[1,3],discont, scaling=constrained);
Array(1 .. 3, 0 .. 2, {(1, 0) = piecewise(0 <= t and t < 1/3, (1-3*t)^2, 0), (1, 1) = piecewise(0 <= t and t < 1/3, (6*(1-3*t))*t, 0), (1, 2) = piecewise(0 <= t and t < 1/3, 9*t^2, 0), (2, 0) = piecewise(1/3 <= t and t < 2/3, (2-3*t)^2, 0), (2, 1) = piecewise(1/3 <= t and t < 2/3, (2*(2-3*t))*(3*t-1), 0), (2, 2) = piecewise(1/3 <= t and t < 2/3, (3*t-1)^2, 0), (3, 0) = piecewise(2/3 <= t and t < 1, (3-3*t)^2, 0), (3, 1) = piecewise(2/3 <= t and t < 1, (2*(3-3*t))*(3*t-2), 0), (3, 2) = piecewise(2/3 <= t and t < 1, (3*t-2)^2, 0)}, datatype = anything, storage = rectangular, order = Fortran_order)
g2(t) := t
"g1(t):=c[1,0] ({[[(1-3 t)^2,0<=t and t<1/3],[0,otherwise]])+c[1,1] ({[[6 (1-3 t) t,0<=t and t<1/3],[0,otherwise]])+c[1,2] ({[[9 t^2,0<=t and t<1/3],[0,otherwise]])+c[2,0] ({[[(2-3 t)^2,1/3<=t and t<2/3],[0,otherwise]])+c[2,1] ({[[2 (2-3 t) (3 t-1),1/3<=t and t<2/3],[0,otherwise]])+c[2,2] ({[[(3 t-1)^2,1/3<=t and t<2/3],[0,otherwise]])+c[3,0] ({[[(3-3 t)^2,2/3<=t and t<1],[0,otherwise]])+c[3,1] ({[[2 (3-3 t) (3 t-2),2/3<=t and t<1],[0,otherwise]])+c[3,2] ({[[(3 t-2)^2,2/3<=t and t<1],[0,otherwise]])"
Error, (in Optimization:-NLPSolve) complex value encountered
Error, invalid left hand side in assignment
Download Bernestien1.mws
 I'll be so grateful if any one can help me.
Mahmood   Dadkhah
Ph.D Candidate
can i compute this integral so that the answer does not have any complex part ? i just want the integral returns me real function or number .
 i also use evalf(int ... ) and evalf(Int ... ) and two different answers were given ! what is wrong ?
tnx for help in advance .
int(log(sec(x)+ tan(x)),x);
-I*ln(exp(I*x))*ln((-I*(exp(I*x))^2+I+2*exp(I*x))/((exp(I*x))^2+1))+(1/2)*Pi*ln(-I*(exp(I*x)-I))+I*dilog(-I*exp(I*x))+I*dilog(-I*(I+exp(I*x)))+I*ln(exp(I*x))*ln(-I*(I+exp(I*x)))
evalf(Int(log(sec(x)+ tan(x)),x=0..10));
3.493589070+16.61151993*I
evalf(int(log(sec(x)+ tan(x)),x=0..10));
7.035851984+23.35343547*I
Download integral.mw
Hi there,
I am trying to do a Fourier transform of the function
f(t) = 3*cos(2000*Pi*t)
I use Fourier transform definition to solve the following integral in Maple:
Int(3*cos(2000*Pi*t)*exp(-(I*2)*Pi*f*t), t = -infinity .. infinity)
I get the answer as "undefined".
The correct answer is:
(3/2)*delta(f+1000)+(3/2)*delta(f-1000)
Vhha
Is it possible to solve linear matrix inequality in Maple?
For example, using Matlab and yalmip we can easily
solve Lyapunov equation
    A'P + P * A <0, P> 0
Is it possible to solve this equation in the Maple?
hello
we have an exam next week and I want to know
how I can write (fordo) in maple for numerical integration
in different methods such as trapezoid , newton cotes and so on.
Is it possible to solve piecewise differential equations directly instead of separating the pieces and solving them separately.
like for example if i have a two dimensional function f(t,x) whose dynamics is as follows:
dynamics:= piecewise((t,x) in D1, pde1, pde2); where D1 is some region in (t,x)-plane
now is it possible to solve this system with one pde call numerically?
pde(dynamics, boundary conditions, numeric); doesnot work
First 1403 1404 1405 1406 1407 1408 1409 Last Page 1405 of 2429
