How can I get the Automorphism Group of a group G as a Permutationgroup?
Best regards
Kurt Ewald
this is the second time I'm writing.
I posted this question in June http://www.mapleprimes.com/questions/201781-System-Of-Parametric-Equations.
This time I have  a similar problem because I'm trying to find a solution for a parametric system of equations but the number of equations and parameters is much bigger and using the tips you gave me last time I couldn't reach any result.
Here is the system:
1) alpha[1]=v*a*u*b ;
2) alpha[2]=v*a*u*(1-b);
3) alpha[3]= v*z*c*(1-a) ;
4) alpha[4]=v*z*(1-a)*(1-c) ;
5) alpha[11]=1/2*v*a* u* b* (-p*u*b+p*u*b*a+b*g-g);
6) alpha[22]=1/2*v*a*u*(1-b)* (p u b-p u b a-b g-p u+p u a);
7) alpha[33] =1/2*v*c*z*(1-a)* (c* (-z*p*a+q)-q);
8) alpha[44]=1/2*v*z*((1-a)*(1-c)* (c*z*p*a-z*p*a-q*c);
9) alpha[12]=v*a*u*b*(1- b)*(-p*u+p*u*a+g) ;
10) alpha[13]=v*a*u*b*z*c*p*(1-a) ;
11) alpha[14]=a*u*b*z*(1-a)*(1-c) ;
12) alpha[23]=a*u*z*c*(1-a)*(1-b);
13) alpha[24]=v*a*u*z*p*(1-a)*(1-b)*(1-c);
14) alpha[34]= v*c*z*(1-a)*(1-c)*(-z*p*a+q);
I have 14 equations/unknowns and 8 parameters (a, b, c, u, v, z, p, q).
I would like to write this system only in terms of alphas. In order to do so, I usually try to find the value for the parameters and the substitute them into the equations (and I have already found b,c,g,q using this technique) but I couldn't manage to find all of them.
Howveer, as you suggested me, with Maple there is the command "eliminate" that implement exactly what I'm looking for but I can't make it work.
This is my code:
> sys := {alpha[1] = v*a*u*(1-b), alpha[2] = v*a*u*b, alpha[3] = v*z*c*(1-a), alpha[4] = v*z*(1-a)*(1-c), alpha[11] = (1/2)*v*a*u*(1-b)*(p*u*b-p*u*b*a-b*g-p*u+p*u*a), alpha[12] = v*a*u*b*(1-b)*(-p*u+p*u*a+g), alpha[13] =      z*c*a*u*(1-a)*(1-b), alpha[14] = v*z*a*u*p*(1-a)*(1-b)*(1-c), alpha[22] = (1/2)*v*a*u*b*(-p*u*b+p*u*b*a+b*g-g), alpha[23] = v*z*c*a*u*b*p*(1-a), alpha[24] = z*a*u*b*(1-a)*(1-c), alpha[33] = (1/2)*v*c*z*(1-a)*(c*(-z*p*a+q)-q), alpha[34] = v*c*z*(1-a)*(1-c)*(-z*p*a+q), alpha[44] = (1/2)*v*z*(1-a)*(1-c)*(c*z*p*a-z*p*a-q*c)};
> eliminate(sys, {a,b,c, p, q, u, v, z});
> simplify(%, size);
I also tries to substitute in the system the four parameters I already found but still I can't find a solution.
What am I doing wrong? Or the problem is that it is too complicated?
Thank you for your attention,
Elena
I can't solve the problem to have the right solution of
solve({cos(x)!=0,x>=0,x<=2*Pi})
while solve works with
solve(cos(x)!=0)
Any ideas on why this happen?
Eq1:=r^2*diff(w(r),r$2)+r*diff(w(r),r$1)-r^2*G5*w(r)-P*r^3*G6-G7*r^3-G8*r^5+C1*r/G3=0;
res1:=dsolve(Eq1);
bcs:=D(w)(0)=0,w(h)=0;
res2:=(dsolve({Eq1,bcs},w(r)));
match(rhs(res2)=rhs(res1),r,s);
eval(_C2, s);
Any idea?
We know that sum can return an symbolic summation, for example,
But sometime the relation of parameters in series cannot be defined easily. And it seems that sum cannot correctly determine the symbolic summation of this kind of series:
Maybe it's due to the value of _C(infinite) is undefined. Does anyone have good idea to compute the symbolic summation of this series?
I'd appreciate any help on this topic. Thank a lot.
sum_cannot_return_symbolic_summation.mw
I tried to display an animation which can zoom as the time goes.
But it seems that if I display several animations in one plot window, it will display the animation with the maximum view size from these animations, not separately display these animations with their view size.
There are two examples:
Case1,
a1 := animate(plot, [x^2, x = -1 .. t, view = [-1 .. 1, 0 .. 1]], t = -1 .. 1);
a2 := animate(plot, [x, x = -1 .. t, view = [-1 .. 1, -1 .. 1]], t = -1 .. 1);
display(a1, a2);
Case2,
animate(plot, [x^2, x = -1 .. 1, view = [t .. 1, 0 .. 1]], t = 0 .. -1)
Is it possible to zoom the animation with time? What parameter should I set?
The related maple file is attached.
zoom_animation_with_time.mw
suppose W1 is weight matrix of graph G1 and W2 is weight matrix of graph G2 (G1 and G2 has same vertices and same edges but with different edge weights)
we want to create graph G3 that has a weight matrix W3. suppose w3[i][j] is an element of W3. we must have :
w3[i][j]=max(w1[i][j],w2[i][j])
w1[i][j] and w2[i][j] are elements of W1 and W2,respectively.
how can we create such graph G3 ?
When I enter the following code from the help file:
textplot3d([[1,2,3,"antelope", 'font'=["times","roman",20]], [3,2,1,"tiger"]], 'axes'='boxed', 'view'=[0..4, 0..4, 0..4]);
I receive the error message:
Plotting error, invalid FONT specification
I am trying to reduce the font size to fit many closely spaced strings in the plot.
Can anyone help.  I am running maple 16 on  Windows 7 machine.
I'm trying to extract the coefficients from the equation below, the fat expressions in the equation. I don't have any trouble seperating the sine or cosine functions. But the constants are a problem. Since t is the only variable in the function i tried, coeff(R, t, 0). This does not work apparantly. Any suggestions?
R:=(1/12)*C2^3*cos(2*t) - (1/48)*C2^3*cos(4*t) - C2^3*sin(t) + C2^3*sin(3*t)-C2^2*C4*cos(t) + C2^2*C4*cos(3*t) - (1/8)*C2^2*C4*sin(2*t) + (1/16)*C2^2*C4*sin(4*t) + (1/16)*C2*C4^2*cos(4*t) - C2*C4^2*sin(t) - C2*C4^2*sin(3*t) - C4^3*cos(t) - C4^3*cos(3*t) - (1/24)*C4^3*sin(2*t) - (1/48)*C4^3*sin(4*t) - (1/16)*C2^3 - (1/16)*C2*C4^2 - (1/2)*C2*cos(2*t) + C2*sin(t) + C4*cos(t) + (1/2)*C4*sin(2*t) + (1/2)*C2
It says at
http://www.maplesoft.com/products/maple/new_features/maple18/Language_Programming.aspx#random
"When generating matrices and vectors of floats and integers, these flavors are very fast. "
But when I compare the new
time[real](Generate(('Matrix')(float, 300, 300)))
time[real](RandomMatrix(300, 300))
I find RandomMatrix over 300 times faster. Am I doing something wrong, or is RandomMatrix still the fastest way to generate random numbers?
i'm trying to simulate a diffusion problem. It contains two connected regions in which a species is diffusing at different speeds. In one region (zeta) one boundary is set to be constant whereas in the other region (c) there is some oscillation at the boundary.The code i try to use is as follows:
sys1 := [diff(c(x, t), t) = gDiffusion*10^5*diff(c(x, t), x$2), diff(zeta(x, t), t) = KDiffusion*10^6*diff(zeta(x, t), x$2)]
pds := pdsolve(sys1, IBC, numeric, time = t, range = 0 .. 3000, spacestep = 3)
However the main problem are my boundary conditions:
IBC := {c(0, t) = 0, c(x > 0, 0) = 0, zeta(0, t) = .4, zeta(x > 0, 0) = .4, (D[1](c))(3000, t) = sin((1/100)*t), (D[1](zeta))(0, t) = 0}
Like this it principally works (however it is apparently ill-posed).
Now what i do like is that the two equations are coupled at x=2000 with the condition that c(2000,t)=zeta(2000,t). This however i dont seem to be able to implement.
I appreciate your comments
Goon
Hello.
Two related questions: I'd like to measure the CPU time used by a computation. Should I use with(CodeTools)? or use  time[real]? What would be the most accurate way to measure the CPU time used by one call, say dsolve()?
Also, How would one return both the result of the computation and the time used in one call so that one does not have to make two separate calls: to obtain the result and to obtain the CPU time?
Example:
with(CodeTools):
ode:=2*a*x^3*y(x)^3+2*x*y(x)+diff(y(x), x);
result:=Usage(dsolve(ode=0,y(x)),output='cputime');
Gives result:=0.141 while
result:=time[real](dsolve(ode=0,y(x)));
Gives result:= 0.145
But in both cases, I have to make another call to get the result of the DSolve in this example. result:=dsolve(ode=0,y(x)); which I'd like to avoid if possible.
I am using Maple 18
I'm not being notified anymore about responses to answers or comments to MaplePrimes. I'm assuming that I'm not the only one (?). This has happened before.
Hello, everyone.
There are two variables: n1 and n2, how to define n1+n2=1 (not n1:=1-n2).
Thanks!!
I have a Maple program that fits a nonlinear function with 9 parameters to a dataset that contains multiple records; each record gets fitted separately. The records are ordered by a certain experimental variable (an angle of a target). The initial parameters for each fit are the solutions of the previous fit; in this case I get relatively good initial estimates and not too much trouble fitting. I use Statistics:-NonLinearFit to do the actual fitting.
Since this is a bit time consuming and I need to do this a fair amount of times, I'd like to see if I can't speed his up by employing parallel programming.
One way to speed up a fit is to compute the sum of residuals in parallel; is there a way to do this in Maple?
Another way would be to run several fits at the same time. The problem I have with that in this case is that I use the results of the previous fit as starting values for the next fit. I might be able to increase the stride of this scheme; i.e. for 4 processes, use the result of fit 1 as starting point for fit 5; fit 2 for fit 6 etc. But before I embark on this non-trivial change; can Statistics:-NonLinearFit even be used in this way (i.e. is it thread safe)?? My fitting function is an actual function (as opposed to a procedure with local variables) so I don't think the function itself would cause trouble.
I could also contemplate the Grid package; except that I am concerned about the overhead moving the data over to each node (although it would all sit on one machine with 4 processors).
I realize that I may have to do some experimentation by myself, but if there is any experience out there I'd like to know about it...
Mac Dude
First 1402 1403 1404 1405 1406 1407 1408 Last Page 1404 of 2429
