I cannot copy and paste into this site using the Google Chromium brower (v 32). Has anyone had this problem and know of a work-around? What I'd really like to do is use Edit-with-Emacs (a chromium extension). It works for other sites.  I can open it from this site, but nothing I enter gets transferred. I'm guessing this is related to the inability to cut/paste.
I'm having some trouble overlaying a set of complex plots. I follow the usual procedure 'display(p0,p1)' I only get p1...
If i try with plots the display command works fine, here's the piece of code I'm trying to get working (r is defined elswhere as function of x and phi):
i := 0;
p := Array(0 .. 10);
for x from 0 by .2 to 2
do p[i] := complexplot(r, phi = -(1/2)*Pi .. (1/2)*Pi);
i := i+1
display(p[1], p[10]);
Any hints?
Cheers,
Felipe
I am a new user of Maple. Could anyone help me to know how to call a Maple function/procedure from a Matlab program with a simple example? And conversely, how to call a Matlab function from Maple.
I have 20 datapoints in two groups. I may name them as f[1],...,f[10];g[1],...,g[10]. f[1]:=[1.2,3.5] etc
I would like to plot these 20 points
(1) in one plot
(2) f[1]~f[10] in one color; g[1]~g[10] in another color.
I checked http://www.maplesoft.com/support/help/Maple/view.aspx?path=plots%2fpointplot
and did not get the point :(
Do you any suggestion what can I do to realize the aims (1) and (2)?
Thank you very much in advance!
  I tried to use generated random as following
for j from 1 to 5 do
    c:=rand(0..1):
    d:=c();
    print(`random number`,c(),d);
    if c()=1 then
       print(`Y`)
     print(`N`);
  The output is
                      random number, 1, 0
                               Y
                      random number, 1, 1
                               Y
                      random number, 1, 1
                               N
                      random number, 1, 1
                               N
                      random number, 0, 0
                               N
  Why the output numbers in one line are different? And Using "if" sentence seems do not correspond to the printed "c()" value..
Say we solve numerically and ODE using Maple. Say ode1:= { diff(Q(x),x)= Q(x)/3x , Q(1)=1 }
The solution is a procedure so now suppose we have another ODE where the solution appears.Say  ode2:= { diff(f(x),x)= Q(x)*x , f(1)=4}.
To extract the solution of the first ODE I set sol1:=dsolve(ode1,numeric) and Q:=proc(x) local s: return rhs(sol(x)[2]): end proc:
But now I got an error message when I trying sol2:=dsolve(ode2,numeric).
Is it possible to use a procedure in the definition of the ODE one wants to solve?
Rewrite the code that counts the number of primes less than using an if-then statement.  Implement    your code where j goes from 2 to 15.
j:=1;
for i from 2 to 10
while ithprime(j)<2^i do
j:=j+1
end:
print(2^i,primes=j-1):
                        2048, primes = 9
I need to edit this code to satisfy a IF then Statement. can any one help me out?
regards "Geordi"
I have a rational function
R(s)=(s+21.2618806754099918582959684287)*(s+11.5825785765671047665686926962)*(s+2.32652929385663964079968631791)*(s+1.59184930187007023058678840475)*(s+.810126597053864402120805704729)*(s+.767936478999246633196341750975)*(s+.389728032793176474756405528288)*(s+.389709386740696868210134112440)*(s+.384534001672741409749016411776)*(s+.211738661184088496193941380283)*(s+.211735400886327624028116769728)*(s+0.123260440562617421046327062708e-1)*(s+0.749282759458414677904525855939e-2)*(s+0.129947118285955895103018704133e-2)*(s+0.128454333534479589397814117349e-2)*(s+0.342482256507583139104896521750e-3)*(s+0.342471571076865824849860353286e-3)/(s+21.2618806754099918582960530179)*(s+21.1471825573992794470615428324)*(s+2.32652929385663964079964525218)*(s+2.28350165975702233286000082419)*(s+.810126597053864402120855775248)*(s+.804997206582678244211665005890)*(s+.389728032793176474755312749208)*(s+.389718248252695846631246554139)*(s+.384534001672741409750430258543)*(s+.243633167007009257956784127718)*(s+.211735400886327624028133231990)*(s+.211726934369736929202050835884)*(s+0.749282759458414677904914554540e-2)*(s+0.555247691543530827690454070563e-2)*(s+0.128454333534479589395816020810e-2)*(s+0.126961222591792792857168643430e-2)*(s+0.342471571076865824866184397991e-3)*(s+0.342461825593204099734633561207e-3)
I want to cancell the roots which are equal up to 7 digits?
How to write a maple code for this problem?
In doing multiple linear regression with Statistics:-LinearFit, how do I get or compute the values commonly called R^2 and R^2[adjusted], also known as the coefficient of determination? I know that residualsumofsquares is part of it. I also need the "total sum of squares" to compute R^2. And how do I modify that to get R^2[adjusted]? These things do not seem to be among the numerous output options to LinearFit. These values (R^2 and R^2[adjusted]) are typically part of the output of other statistics software when doing multiple regression.
I'd also like the p - values for the significance of the individual parameters and the p - value for the global utility---also things that are standardly reported by statistics software.
Hi Mapleprimes community,
I am a maple novice and was trying to write a procedure but cannot tell what my syntax error is.  I would greatly appreciate if anyone can point out what I did wrong or any improvement in the code that I can make.  Thanks
SLRrepeatedsample_pr.mw
Henry
I am trying to create a procedure that can solve integrals using the Composite Simpson's 3/8 rule. However when I test my procedure against maple's ApproximateInt I am getting the wrong results.
Here is my attempt:
f:= x -> exp(x)*sin(4*x); # function I am using
simp := proc(a, b, n)
  local h, sum, i, single:
  h := (b-a)/n:
  sum := 0:
  single := (3*h/8) * (f(a) + f(b)): # this is the end points
    for i from a+h by h to b-h do
       sum := sum + (3*h/8) * (3*f(i)):
print(evalf(sum + single));
simp(0,1,12);
        0.6224486445
evalf(Student:-Calculus1:-ApproximateInt(f(x), 0..1, method = simpson[3/8], partition=12));
        0.5323516717
As you can see my answer is not very close to the answer given by Maple. I am not sure why my procedure simp is wrong.
I tried to solve the equation f(s) and got the unknow error:
 The related file is attached.
Error.mw
I'd appreciate any help on this topic. Thank a lot.
If i use expression with function add() it runs normaly, but if I use expression with Threads:-Add (parallel implementation) it causes error "Error, continuation task already created for the current task" or "Kernel connection has been lost"
Expression:
Array(1 .. N,1 .. 1/2*N-NR-1,(i, m) -> evalf(Add(cosArr2[modp(k*i,N)]/kl[k],k = 1 .. NR+m-1)+Add(cosArr2[modp(k*i,N)]*alpha[k],k = NR+m .. 1/2*N)))
What am I doing wrong? Can I use two Add in one evalf?
Birthday_LP.mw
I am attempting to solve the following using C.Loves Logicproblem package. But i do not know how to tell it either/or constaints. being a circular arrangement might also throw a spanner in the works.
Alans Birthday Logic Problem
It is Alan’s birthday and he is having a party. Seven other people will attend: Amy, Brad, Beth, Charles, Debbie, Emily and Frances.
Everyone will sit around the circular dining table. The seating arrangement must meet the following conditions:
• Amy and Alan sit together
• Brad and Beth sit together
• Charles sits next to either Debbie or Emily
• Frances sits next to Debbie
• Amy and Alan do not sit next to either Brad or Beth
• Brad does not sit next to Charles or Frances
• Debbie and Emily do not sit next to each other
• Alan does not sit next to either Debbie or Emily
• Amy does not sit next to Charles
Arrange the guests around the table to meet all of the conditions listed above.
Vars:= [Name,PN]:
Name:= [Alan,Amy, Brad, Beth, Charles, Debbie, Emily,Frances]:
PN:=[$1..8]:
Cons:= [NextTo(Amy,Alan,PN),NextTo(Brad,Beth,PN),NextTo(Charles,Debbie,PN),NextTo(Charl es,Emily,PN),NextTo(Frances,Debbie,PN),Rel(NotNextTo,Amy,Brad,PN),Rel(NotNextTo, Amy,Beth,PN),Rel(NotNextTo,Alan,Brad,PN),Rel(NotNextTo,Alan,Beth,PN),Rel(NotNext To,Brad,Charles,PN),Rel(NotNextTo,Brad,Frances,PN),
Rel(NotNextTo,Debbie,Emily,PN),Rel(NotNextTo,Alan,Debbie,PN),Rel(NotNextTo,Alan,Emily,PN),
Rel(NotNextTo,Amy,Charles,PN)]:
read "LogicProblem.mpl";
Birthday:= LogicProblem(Vars):
with(Birthday):
First 1463 1464 1465 1466 1467 1468 1469 Last Page 1465 of 2429
