I need help finding the 10th order power series and graphing it. The initial problem is x2y''+xy'+x2y=0 with initial conditions y(0)=0 and y'(0)=0. Whenever I try using dsolve({eqn, y(0) = 0, (D(y))(0) = 0}, y(x), type=series) where eqn= the initial problem, it doesn't give an output, not even an error message. And help or ideas at all would be greatly appreciated.
So i have to plot 3 ODEs. How would I go about plotting dx/dt=10(y-x) AND dy/dt=x(28-x)-y AND dz/dt= xy-8z/3. Any help at all would be appreciated.
this question has been asked several times here already accoruding to the search function, but I didn't find an actual answer to it.
My Maple 15 gives outlarge numbers without scientific notation, so even 10^20 would be displayed as 1000....000  (20 zeroes). It seems like this is not the standard, so at one point I might have changed the way Maple displays the output, and cannot remember anymore how.
How can I tell Maple to display the output in scientiffic notation, and how can I set up the threshold of powers of ten, when this is done. (so that e.g. 100 still gets disaplyed as 100, and not as 1*10^2, but anything above gets displayed in scientific notation).
I know that I can right click on the output to change it's display form. But I want to change this generally, so I dont have to do this for any single numerical output I get.
I use Maple 15, running in Mac OS.
Thanks for help!
I have a column vector that looks like this:
"GOOG.NASDAQ_GOOG"
"GOOG.NASDAQ_AAPL"
"GOOG.NASDAQ_ZN"
"GOOG.NASDAQ_ZOOM"
However, I need it to be in this format:
GOOG.NASDAQ_GOOG.4,GOOG.NASDAQ_AAPL.4,GOOG.NASDAQ_ZN.4,GOOG.NASDAQ_ZOOM.4 etc
It appears to be very simple but I cant figure out how to do it in Maple.
LL_101)_Quandl_Get_D.mw
Hello everyone, I need your help again. I've been trying recently to select different colors and other line options to different curves in the 2D plot generated by the algorithm attached to this message, but I've had no success whatsoever. I tried using the setcolors([]) option, but it didn't work.
Any help with that would be much appreciated.
Link:
Equações_H,_S_e_G_(r.mw
Let a convex polygon, for example Q:=polygon([[0,2],[1,4],[4,4],[5,1],[3,0]]), be given.
How to find the rectangle of the biggest area which is contained in Q?
A procedure is required. This problem seems to be more complex than the previous one.
I have two procedures X() and P() which both are working. (See attached worksheet )
LL_100)_Quandl_Get_D.mwLL_100)_Quandl_Get_D.mw
When I put:
z := X(P());
Do(%DataTable0 = z);
I get an error:
Attempted to set unknown property 'value' on component 'DataTable0'
why??
Is there any way to program a button component to stop current calculations and restart maple server?
with(plots)
u := proc (x) options operator, arrow; int(exp(-(x-xi)^2)*f(xi), xi = -infinity .. infinity, numeric) end proc; f := proc (x) options operator, arrow; 1/(1+x^2) end proc; u(4.0); plot(u(x), x = -10 .. 10)
.1139815572
Is there a way to speed up the calculations?
Download slow.mw
Let the polygon P:=polygon([[0,2],[1,4],[2,3.5],[4,4],[5,1],[4,0.75],[3,0]])
be given.
How to find the rectangle of the minimal area which contains P? Of course, with Maple. Is it a rectangle having a side parallel to the longest diagonal of P?
The same problem in the general case: a procedure is required.
If I type the following:
a := 1
a2 := 1.5
a*a2
When I press enter
I want it to display the expression without evaluating and then the result:
(1)*(1.5)
By default the program displays  1.5.  Is it possible to display it this way?
hello please help me for maple worksheet 17
how can i do parametric diff?
i know implicitdiff and diff but i don't know how can i do parametric diff thanks very much
i got loop dat gives me Vx and Vy functions in evry step,i need to solve this ode
proc (X) options operator, arrow;
X(t) end proc;
proc (Y) options operator, arrow;
Y(t) end proc;
ode := diff(X(t), t) = evalf(subs(x = X(t), y = Y(t), subs(vvx = Vx, vvx))), diff(Y(t), t) = evalf(subs(x = X(t), y = Y(t), subs(vvy = Vy, vvy)));
ics := X(0) = xxx, Y(0) = yyy;
ds := dsolve([ode, ics], type = numeric, method = rkf45, maxfun = 0, output = listprocedure);
XX := rhs(ds[2]); YY := rhs(ds[3])
i got XX(t) and YY(t) this is one parametric function,she looks like this
[URL=http://hostingkartinok.com][IMG]http://s5.hostingkartinok.com/uploads/images/2013/11/6b7bc8537f9f8d3d37c7b30bc3c2b316.jpg[/IMG][/URL]
i need to get her 1st and last value of t when she exist.
i make XX(-9999999)  and XX(9999999) to catch erorr and get values.
but for some Vx and Vy i get
"cannot evaluate the solution further left of %1, too many step failures, tolerances may be too loose for problem",−0.15345979
erorr.
When he try to get XX(999999) he spends like 10-15 minuts, so its realy big waste of time , i just need to get this critical valuse,so maybe there is another way?
eq1:=
(1/4)*D^2*Pi-(1/4)*D^2*arccos((-D+2*h)/D)-(1/2)*sqrt(h)*sqrt(D-h)*D+h^(3/2)*sqrt
(D-h);
eq2 :=
-(1/2)*sqrt(h)*sqrt(D-h)*D+h^(3/2)*sqrt(D-h)+(1/4)*D^2*arcsin((-D+2*h)/D)+(1/8)*
D^2*Pi;
These equations are the same. yet simplify(eq1-eq2,trig);
<>0
The Mathematica COMMAND FullSimplify[..] gets zero.
Use the command taylor to find the Taylor’s series about  pi of e-(x-pi)^2
specifically compute the 11th coefficient a11.
taylor(exp(-(x-Pi)^2),x=Pi,11);
is this correct?
First 1501 1502 1503 1504 1505 1506 1507 Last Page 1503 of 2429
