Please have a visit of this qestion `http://math.stackexchange.com/q/574843/8581`. I did a very elementary attempt there for example for a function:
 > with(plots):
      h := x->piecewise(x < -2, x+3, x <= 2, 5-x^2, 3-x):
      t:=x->h(-x):
      a:= plot(h(x), x = 0 .. 10, color = red, thickness = 3):
      b:= plot(t(x), x = -10 .. 0, color = green, thickness = 3):
      display(a,b);
But  I am eager to know  the formal codes if they exists. Thanks for your time.
First I know that the Newton-Raphson formula gives N(z)=z-(f(z))/(f'(z)). If f(z)=z^+1, then N(z)=(z^2-1)/2z
Then the Question asks me to first define two important functions which I did:
1)T(z)=z-i/z+i where is i is imaginery number, 2)N(z)=z^2-1/2z. Hence, I wrote the following in maple:
>T:=z->(z-i)/(z+i)
>N:=z->(z^2-1)/(2z)
Then I was asked to show that T(N(z))=(T(z))^2, so I wrote the following commands:
>z:=2
>T(N(z))-(T(z))^2 (I got zero for their difference, so they are equal)
next, the question said the same wave verify that T(N^2(z))=(T(z))^4, so i wrote:
>T(N^2(z))-(T(z))^4 (but I got 0.3239121662-1.392199407I which is a complex number, not zero but WHY?)
and the rest of the questions are as follow:
1) What will be the general result? <-I don't what does it mean by general result :S
2) T(N^k(z)) will be what power of T(z)? <-Is it power of 2k?I have no ideas.
3) Try T(N^3(z)).<-which I know that T(N^3(z))=T(N^2(N(z))), so does T(N^2(N(z)))=(T(z))^6 then?
It would be appreciated If anyone could help me with this/clear up my confusion with questions. thanks.
I have a statistics task that is very complicated to me, and I would really appretiate some help!
I believe that I have completed task a, but task b and c seems to be too hard for me to grasp.
Here is a presentation of the task text:
xi 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
yi 12.3 12.8 16.8 17.9 20.5 22.7 24.9 27.5 26.9 29.4 30.3 34.2 36.4 36.7 41.1
Assume that the data represents independent realizations of a "linearlnormal" model.
Yi = α + β xi + ei i = 1..15,
where ei˜N(0,σ), where sigma is unknown.
(a) create a scatterplot of the data {f(xi,yi)}15 ; i=1
Then calculate the empiric correlation coefficient.
(b) Find the minimum least square estimate for α & β.
(c) Create a 95% confidence interval for the parameter β. What does this confidence interval express?
Is there anyone out there who are able to help me with some maplecode?
thanks in advance,
Soeta
I was successful in getting the Maple add-in to load into Excel 2013 but the help file accessed in the Add-In Ribbon is not found.  Does anyone know where in Excel that file can be loaded?
I've been given a question:
Let pn denote the nth prime number. Then p1 = 2, p2 = 3, p3 = 5, p4 = 7, p5 = 11, . . . .
It is known that the infinite sum 1/p1 + 1/p2 + 1/p3 + · · · + 1/pn + · · · = infinity.
Find the smallest positive integer N so that 1/p1 + 1/p2 +1/p3 + · · · + 1/pN−1 + 1/pN > e. [Hint : ithprime(n) generates the nth prime number.]
How do I start off?
Many thanks!
Usually maple returns the behaviour about the expansion point, but now I get a series in terms of weird powers...
I think the behaviour is logarithmic, but thats not what maple reproduces.
What results in this behaviour of maple?
limitxkl.mw
restart; with(MultiSeries); assume(omega > 0, s > 0, s < 1); x := arctanh(sqrt((1-s)/(1+s))*tanh((1/2)*omega*t)); xinf := limit(x, t = infinity)
arctanh(((1-s)/(1+s))^(1/2))
y := solve(.9*xinf = x, t)
2.*arctanh(tanh(.9000000000*arctanh(((1.-1.*s)/(1.+s))^(1/2)))/((1.-1.*s)/(1.+s))^(1/2))/omega
y := 2*arctanh(sqrt((1+s)/(1-s))*tanh(.6*arctanh(sqrt((1-s)/(1+s)))))/omega
2*arctanh(((1+s)/(1-s))^(1/2)*tanh(.6*arctanh(((1-s)/(1+s))^(1/2))))/omega
series(y, s = 0)
23.71899812/omega-0.1319507911e11*s^.6000000000/omega+0.1000000000e11*s^1./omega+0.8705505636e20*s^1.200000000/omega-0.1319507911e21*s^1.600000000/omega-0.7657989038e30*s^1.800000000/omega+O(s^2.000000000)
Download limitxkl.mw
Hi there!
Maple has lot's of datatypes which are very related to each other, such as Matrices and Arrays, or sets, lists and vectors.
Most of the time I am not quite sure which type is the "right" one to use for me, and I guess for most of the stuff I have done so far it didn't really matter. However now I am going a bit into numerics, and there things can get big and computationally expensive. Also, recently I got an error message stating that I would assign a large list to a variable, and should rather use an Array instead. So I guess I should start to bother what to use. : )
Obviously the Matrix has some advantages to the Array in the sense that I can perform matrix calculations with it easier using the LinearAlgebra package. So it can be transposed and what not. But is it disadvantegeous to the Array in any way, especially when it comes to large matrices in numerical calculations?
The same would interest me for sets, lists and Vectors.
Cheers!
Gernot
Hi there!
I want to improve the way I code up my procedures. For instance I want to code them safe in the sense that they only accept the arguments when they have the correct type.
I know that in principle this is done with the double-colon operator in the following way:
proc(argument::argumenttype)::valuetype;
(Q1)Now, given that my argument is of a type such as set, list, Array, etc.:
(a) How would I specify the allowed types of the elements of that list (for all elements, and for specific ones)? And if the element of the list is a list again, how would I specify the type of that's elements? and so forth..
(b) How would I specify the allowed size of the listArray, etc. ?
(Q2) How do I specify the types of more than one output, if my proc returns more than one value?
(Q3) I know that there are special integer types, such as nonnegint, posint, negint. Is there also a way to specify that the ineger (or float) argument has to be greater than some given value, e.g. >2, or that it has to lie between two values, or out of a given set?
Thats all for now. Thanks for your help guys! : )
Gernot
Hi.
I have two problems:
1) Start code SetProperty(Button0, enabled, true); doesn't switch the property 'Enabled' of Button0 to 'true', as I'd like it to. How to correct the code to switch?
2) I'd like the property 'Enabled' of button 'Button1' switch to 'false' immediately after it is pressed. (I put SetProperty(Button1, enabled, false); at the beginning of Action When Clicked) However Maple waits untill all code within Action When Clicked is calculated. How to correct it?
probe2.mw
I have a set of 19 different items I need randomize, lets call them A-S. I tried the Random command, Random(19,A-S) listing all of the possiblities. I want each letter to be used once in that 19 times and using this way does not do that. Is there another command I can use to achieve this?
Hello guys, pls. how can I plot the graph of the rational function below.
The numerator against the denominator. this is very strange to me and does not make sense at all.
I want to show an animation in Plot component on Button press.
Action when clicked for the button :
use DocumentTools in
Do(%Plot0 = dis);
SetProperty(Plot0, play, true, refresh=true);
end use;
Variable dis was calculated earlier:
B := animate(plot, [u(t, x), x = xmin .. xmax], t = tmin .. tmax, frames = n):
dis:=display(B, insequence = true):
However, the first press on the button gives static first frame. Only second press starts the animation.
What's the problem with my code?
Hey
I'm trying to fit a spacecurve onto some points I have.
I know, I can use Spline to do this in 2D, but it doesn't work in 3D.
What command(s) can I use to fit a spacecurve onto my points?
I have to plot 4 vectors in one graph. I have the following structure:
plot(Vector([12, 12.5, 13, 13.5, 14, 14.5, 15]), Vector([1.622712644, 1.265443137, 1.028604736, .8605013333, .7352916667, .6386248233, .5618945274]), style = line, symbol = asterisk, color = blue)
plot(Vector([12, 12.5, 13, 13.5, 14, 14.5, 15]), Vector([5.483608580, 4.289400489, 3.496793877, 2.933480578, 2.513320599, 2.188469637, 1.930230220]), style = line, symbol = asterisk, color = blue)
Could you help me to plot these two curves in one graph.
please help me to find a solution for this issue...
I would like to thank you in advance
Best regards,
D.L.
Hi, I have encountered a difficult question.
My answer is A=151,B = 47.
Could anyone tell me whether this answer is correct?
The question is as follow:
Pi=∑((120n2+An+B)/(16n((512n4 + 1024n3 + 712n2 + 194n + 15))  (n starts from 0 to infinity)
First 1503 1504 1505 1506 1507 1508 1509 Last Page 1505 of 2429
