hi all..
i m solving a system of four coupled differential equations using bvp[midrich] technique on maple..
i have two questions..
1). is it possible to calculate the numerical data using bvp[midrich] instead of graphs?
2). there is a physical constant "A" in my second equation..can i compute its numerical values while fixing all other physical parameters of my equations...
If a, b and c are the roots of the equation x^3-x^2-x-1=0.
Find S=(a^2014-b^2014)/(a-b)+(b^2014-c^2014)/(b-c)+(c^2014-a^2014)/(c-a)
Today, I was working on a problem in the class which said:
if f(x)=ax^2+b, x<=1 and 1/x, x>1; then find the values of "a" and "b" such that f'(1) be defined. I checked it to be continuous at x=1 first and so I got a+b=1. Secondly, I wanted to get another equation, so I checked the differentiability of the function by the definition of derivation at x=1, so:
[> f := x-> piecewise(x <= 1, a*x^2+b, 1 < x, 1/x);
> limit((f(x)-f(1))/(x-1), x = 1, right);
I have a set E of linear equations in variables x[1],...,x[8] (which I created with X := Matrix(8,1,symbol=x)). I now call
> solve(E);
I get back something like
x[1] = x[2]-x[3], x[2] = x[2], x[3] = 5, ...
I would rather like to get
x[1] = t[1] - 5, x[2] = t[1], x[3] = 5, ...
back.
How to do this? I do want to use the solve function (not LinearSolve et.c.).
I'm supposed to do the following. I tried to ask my teacher how I could go about doing it and she told me to just figure it out. I am supposed to find the linear and quadratic approximations to the function f at x=a. Then, I'm supposed to sketch the graph of the function and its lienar and quadratic approximations.
The linear approximation is:
P1(x)= f(a) + fprime(a)*(x-a)
The quadratic approximation is:
P2(x)= f(a) + fprime(a...
I have that problem that I am trying to solve the following equation explicit:
TY = RootOf(6.750969101*10^26*_Z*1000^(9/59)*800^(41/59)-1.015701668*10^27*1000^(50/59)-1.189275761*10^27*800^(50/59)+1.103397224*10^26*_Z*1000^(32/59)*800^(18/59)-7.457053114*10^23*3^(1/5)*1000^(41/59)*800^(50/59)*_Z^(4/5)*sqrt(12500)*4^(19/20)*(800^(9/59)+1000^(9/59))^(1/50)*(702.222720*1000^(9/59)+976.508160*800^(9/59))^(4/5)-7.457053114*10^23*3^(1/5)*1000^(50/59)*800^(41/59)*_Z^(4/5)*sqrt(12500...
Can maple in any way simplify this any further?
-(1/4)*m*omega*sin((1/2)*omega*T)*(2*cos((1/2)*omega*T)^2*xa^2+2*cos((1/2)*omega*T)^2*xb^2-xa^2-2*xa*xb-xb^2)/((cos((1/2)*omega*T)^2-1)*cos((1/2)*omega*T))
I've tried simplify, radnormal, combine but am wondering why maple does not convert for example the denominator in sin(omega*T)
How do enter and use the notation of a step function (u(t-3)-u(t-4) in maple to use in calculations? thanks
I wondered if you would be able to help.
I've set up a for-loop and while-loop that substitutes values of j and k into a given function
I want to get the answer for every right for example right[1], right[2]..but this code give the answer for right[1]nd right[6] only..
 P := array([[1, 4], [2, 3], [3, 2], [4, 1], [6, 5], [6, 1], [6, 2], [5, 3]]);
j := 1; k := j+2; Fold := 0; Fnew := 1; counter := 0;
 for...
hello,i have a problem i have to program analytic solution of heat equation of a rod with two heat sources if you can help me by anything please d'ont hesitate, thank you.
Hi, how I can find the variable Z in this equation? thanks.
equation
I know how to export to .png or .jpg but I'm not quite pleased with the quality of the images.
Is there a way to export high quality images? i.e. no sharp edges of the function in the plot
I have define the following ODE system
with(LinearAlgebra);
dC1 := diff(C1(t), t) = -2*a1*C1(t)+b1*C2(t);
dC2 := diff(C2(t), t) = 2*a1*C1(t)-(b1+a1)*C2(t)+2*b1*C3(t);
dC3 := diff(C3(t), t) = a1*C2(t)-(2*b1+a2)*C2(t)+b2*O1(t);
dO1 := diff(O1(t), t) = a2*C3(t)-b2*O1(t);
syst := dC1, dC2, dC3, dO1;ics := C1(0) = 1, C2(0) = 0, C3(0) = 0, O1(0) = 0;
func := {C1(t), C2(t), C3(t), O1(t)};
sol := dsolve([syst, ics], func);
After evaluating...
Solve Differential Equation :(3x-y)*dy/dx=2x
I cannot access HELP ?orbital in the Orbital Package; it does not appear in "Science and Engineering/Orbitals" . I have followed Initialization instructions in orbitals.mw, creating "c:\MapleLibs" in Windows8 . Is libname:=libname,"c:/MapleLibs" correct? Any help on this help would be a help.With thanks,Michael Caola
First 1535 1536 1537 1538 1539 1540 1541 Last Page 1537 of 2429
