i'd like to know how type the infinity symbol and other symbols in the integration methods tutor, when i type the word infinity , it says "invalid value, must be a number"
I'm trying to plot the 3d graph of a solid in Maple 16. The solid is generated by equilateral triangles. One vertex is  A(x,0,0), and the other one, B, moves on the circunference described by: y^2+x^2=121, z=0. The AB segment is always parallel to the Y axis and the triangles are in the yz plane. In other words, one side (of each triangle) is sqrt(121-x^2).
I tried using the spacecurve command to start plotting lines but then I didn't know how...
hi
how can I write two "for do" loops which one of them is inside the other
I want to integrate the following
int(vf(v), v = 0 .. infinity)
where f(v) is f(v) = 4*Pi*(m/(2*`πkT`))^(3/2)*v^2*exp(-mv^2/(2*kT))
I have tried to do the following:
with(algcurves):
f := y^2 - x^3  - x^2 =0;
c := simplify(subs(x=x1/x0, subs(y=x2/x0, f)));
c := -x2^3+x1^3+x0*x1^2;
parametrization(c, x0, x1, x2, u, v);
how to make
x0 = a0*u + b0*v
x1 = a1*u + b1*v
x2 = a2*u + b2*v
 > with(algcurves); f := y = x^3; v := parametrization(f, x, y, t);
[AbelMap, Siegel, Weierstrassform, algfun_series_sol, differentials, genus,
  homogeneous, homology, implicitize, integral_basis, is_hyperelliptic,
  j_invariant, monodromy, parametrization, periodmatrix, plot_knot,
  plot_real_curve, puiseux, singularities]
hi In tensors, I want to calculate covariant derivative of a tensor of rank (1,1) but if found some erors in maple outputs whit (cov_diff) so I m trying to write a progeam with "for circle" for calculating covariant derivative. Please, help me to figure it out.
I am on iMac (OS X 10.6.8) and I am trying to upgrade my Maple 16 software using Maple1602MacUpgradeInstaller, but it does not work :-/
When I launch Maple1602MacUpgrade program the Authentification window open, I unlock entering my admistrator password, OK, then the installer display "Please wait while the installer is being configured"... the progression bar is displayed, and at the end an empty window (window content is uniformly grey) is displayed...
I know how to solve them in person but I just don't know how to do it with Maple. Please help.
Analyze the solution to the ode dy/dx = f(x,y), where f(x,y) is a 3rd degree polynomial that you will randomly generate where the coefficients are integers between -2 to 2.
a) Solve the general solution using dsolve (may be an integral).
b) Sketch the directional field.
c) Using the directional field, you will be able to identify where a constant solution...
1.
   Suppose thT the population y(t) of a certain kind of fish is given by (D(y))(t) = Ay(t)-By(t)^2, and fish are caught at a rate Hy proportional to y.Solve this so-called schaefer model. Find the euilibrium solutions y1,y2(>0) when H
2.< Intermittent harvesting>
 In 1. assume that you fish for 3 years, then fishing is banned for the next 3 years. Thereafter you start again. And so on. This is called intermittent harvesting....
How do you plot in Maple 17 a function like f(t)= e-t for -1<=t<=1, with a Period of 2? I know that in "The fourier Series" package back in Maple 10 this was possible.
1. x^2*diff(y(x),x,x)+x*diff(y(x),x)+(x^2-1/9)*y(x)=0
I want solve this equation with Bessel'function in maple.
2. x*(diff(y(x),x&2))+2*(diff(y(x), x))+16*x*y(x) = 0
3. x*(diff(y(x),x&2))+(2*x+1)*(diff(y(x), x))+(x+1)*y(x) = 0
I want solve these equation with frobenius method in maple.
Thank you ♥
It seems that empty symbol is redefined (overloaded) in Physics package:
Code:
with(Physics):
a := ``;
Result:
A sequence of real numbers a_1,a_2,a_3....... satisfies a_0=1 and
regarding optimization, we know about inputs like "assume=integer". I want to instruct Maple that the variables in my problem are required to be unique.
eg I have three variables a,b,c that could take values 1,3 or 4 (but not 1,1,2 or 2,3,3 ....etc).
With DirectSearch I could always add the constraint {a<>b, b<>c, a<>c}, but it gets complicated if you have more than 3 variables. Additionally Maples Optimization package...
First 1537 1538 1539 1540 1541 1542 1543 Last Page 1539 of 2429
