i have a problem in using command "collect".
if i uninstall maple and keep some dll,  Is it possible to use openmaple without install maple?
What does convert(max(a,b), piecewise) algorithm use?
convert(min(a,b), piecewise)
Hi All,
I am working on a soil mechanics problem that defines a Cam-Clay model via a system of ODE's and initial values. For this problem there are two parts, the elastic behaviour followed by plastic behaviour.
I have 7 ODE's all wrt to an independant variable called eq. I wish to run the elastic dsolve expresion in such a way that, at the value of eq where a dependant variable f(eq) = 0, I can extract all 7 of the parameters for use as initial...
Maple people:
Does anyone know why, if you plot a discontinuous function of one variable, Maple's default behavior is to try to make the function continuous by adding a vertical line segment?  I don't know why anyone would anyone would ever want to graph a function this way.  As far as I know, you have to use the option "discont=true" to remove the vertical segment, which is a hassle.  I consider this to be practically a bug.  I couldn't...
a) How can i use laplacetransform to solve with maple?
i1 = i2 + i
2i1 + i2 + 2i1 = 30 + 20cos5 + 114sin5
1/50 i3 + 4i3 - 2 i2 = 0
i1(0) = 0
i2(0)=0
i3(0)=0
Plot
what should i do ? i face this message when i want to solve my equations? can anyone help me ?view the worksheet
Hello. I have three diff. equations that I believe I have solved correct. But how do I put this in maple? They must also plotted. Grateful for your help.
1)
y´´ + 2y´ + 2y = 5
Answer: y(x) = C1 e-x sinx + C2 e-x cosx + 5/2
Plot.
2)
y´´ + 2y´ + 2y = sin5x
answer: y(x) = sin5/2 + C1 e-x
If I change a sample calendar the base calendar is also changed.
with(Finance):
c:=Calendar(Toronto):
IsHoliday("November 11, 2013",c)
Dear Maple's expertise
Here is the code in simple way with the output.
The peoblem that I am calling the procedure with the same input but from time to time it gives different output shown in bold below. Although I make  restart for Mape?Is it bug in maple??Any Suggestions please.Should make clearing for some varibale and how?
The code is
> restart;
> Chisqr1 := proc (w...
I have always been experiencing problems using a university server. It runs Red Hat 6.4 (Santiago) and Maple 17 X64.
The problem never occurs on Windows 7 SP1 X64 with Maple 17 X64.
Only reason I want to use the university machines is that it's "faster".
I had raised...
Plotting the follwing function between x=0..2*Pi
I'm trying to plot a function that is defined as an integral of another function. I know that the function is quite smooth with no singularities over the region that i'm plotting. However, the resultant surface plot is bumpy/has holes in it. I tried changing the integration method and lowering epsilon to increase the precision but it still is not working. Can anyone help? Thanks for your time.
Maple file:
I'm looking for any procedure to calculate orthogonal latin squares. I found this:
rOrt := proc (A, B, n)
local freq, i, j;
freq := Array(0 .. n^2-1);
for i to n do
for j to n do
freq[A[i][j]+n*B[i][j]] := 1
freq := convert(freq, list);
return numboccur(freq, 1)
But I don't know what I now have to write to see result, for example for n=3?
First 1546 1547 1548 1549 1550 1551 1552 Last Page 1548 of 2429
