Find the rightmost nonzero digit of \frac{2014!}{5^{20}}
Good day,
I try finding the eigen values of a 6 x 6 matrix with symbolic term but recieve the following error:
Error, (in expand/bigprod) Maple was unable to allocate enough memory to complete this computation.  Please see ?alloc
Please what do I do.
I am looking to do a custom non-linear axis in Maple, and no, not a logarithmic axis, but a custom one that i can define with a function. I know i can alter my data and the alter the display of the axis tickmarks, and in this way create the illusion of a custom axis. But there must be a better approach which does not require altering the data? I can see in the plot documentation that i can specify axis[mode = linear] or [mode = log] but why not a custom one?
I have a system of nonlinear differential equations with initial conditions:
diff(m(t), t) = m(t)+(18.676*(1+.3570*n(t)))/((1+0.714e-1*n(t))^2+(-3+m(t)-n(t))^2)
Let n be any positive Integer :\displaystyle \sum_{k=0}^{n-1}(\sqrt{ak^3+bk^2+ck+1}-\sqrt{ak^3+bk^2+ck})^{\frac{1}{3} }=\sqrt{n}. Find
Hi, I got a doubtI don’tknow how to make the Runge-Kutta’s and Euler’s method. The Runge-Kutta for thesecond and fourth order. I don’t know how to beginning the algoritms, I needsome help. Thanks.
Now I compute the integral
0<int((abs(c-x)/x)^n,x=a..b)=int((c-x)/x)^n,x=a..c),symbolic)+int((x-c)/x)^n,x=c..b)
assuming c>0,b>c,n>-1.
As it is not possible directly, I split this apparently real integral in two parts. Both parts are real for n>0. Look, what's happens!!!
> Za:=simplify(int(((c-x)/x)^n,x=a..c),symbolic) assuming a>0,c>a,n>-1;
I executed a Jacobian function as follows X:=Jacobian([a,b,c,d,e],[y[1],y[2],y[3],y[4],y[5]])
a,b,c,d,e are initialized expressions/equations and
y[i], i=1..5 are the variables and I got the result below
Hello all,
As in title I am really bothered with result in floating number obtained from laplace(expr, t, s).
I have a target to laplace and the laplace() gives me result with floating numbers.
(ex. laplace(diff(diff(f(t),t), t), t, s) = laplace(s^2. * laplace(f(t), t, s) : the period after 2 is annoying)
How can I avoid or do some conversions to kill the periods?
When I do integration and differentiation, even of the simplest functions, it gives me incorrect answers. What could I have done wrong? Just to mention I recently installed a licensed copy on my computer.
when i open a new worksheet its indicates it as untitled worksheet number 11. whcih means i have 10 previous untitled worksheets. where are these stored. i can not find them in the maple folder?
I have quite big problem with results processing from dsolv.
reseni := dsolve(numeric, number = nclas, procedure = PopBal, start = 0, initial = inicon, procvars = dvars, range = 0 .. tend)
If I want a results from "reseni" in "tend"
results(tend);
I got this one:
[t = 5., n[1](t) = 0.803965539772492772e-1, n[2](t) = 0.108666500575795332e-4,.........]
Now i dont know at all how I can work...
I'd like to create a table in Maple showing the values for multiple functions.
For example, I've three functions, y1,y2,y3, and I want to create a table for different values of my functions.
Is there a straightforward way to do that in Maple?
Many thanks in advance!
puckie
First 1549 1550 1551 1552 1553 1554 1555 Last Page 1551 of 2429
