Hi:
I have a problem in calling a procedure. The problem that the code is working perfectly when I use it without precedure, but when I wrap it with a procedure and call the procedure I get like this problem
Error, (in Chisqr1) invalid input: `convert/Matrix` expects its 1st argument, M, to be of type {Array, Matrix, Vector, array, list}, but received Concatenate(2, Determinant(Transpose(Jacobian([(16759.00586-A-C)^2+(19630.75977-A-4*B-C*cos(32...
hi
I have two unkhnown matrices. I intruduce one of them with fill:
The built-in Histogram command in the Statistics package only creates a Histogram from raw data, unfortunately. There is however a big number of situations, where you only have grouped data with intervals and their associated frequencies (probabilities) and want to plot the Histogram. Suppose that the intervals are of equal width and (indirectly) are specified from a starting point x0, a column-width named 'width' and the number of intervals given by n. Suppose the frequencies...
From 1 to 2013, how many   times do we use
Hi everybody,
Like the title said, I have a DC circuit (*.msim attach here).  In two differents ways, I find the current in R3 to be equal to -1A (*.mw attach here).  The M17 file is in french but the equations speak for themselfs.  Can someone help me to sort this problem out.
problème_5-4.msim
Solution_5-4.mw
I use maple 16, whenever I try to plot two polar curves on the same axis, it gives me a wrong graph. However with maple 15, I get the right graph. How can I plot two polar curves on the same axis with maple 16?
I have a matrix A4
I am trying to use the procedure described in the answers to this question:
http://www.mapleprimes.com/questions/100137-Solving-Trigonometric-Equations-For
to find the solutions to sin(2*x) = 1/2 where -2*Pi <= x <= 2*Pi. After the isolve() command is issued, I get the warning that solutions may have been lost. i think the issue is the form in which Maple represents the general solution to the equation. Any ideas on how to rectify this would be greatly appreciated!
Dear Maple users
I have a question, which is probably very basic, but I can't find how to handle it in the Programming Manual or elsewhere. I need to declare a parameter, which is a vector of lists. Example of element:
< [3,7,2,4], [-3,6,8,0], [-5,8,4,2]>
Vector has n components and each list has k components. I tried declaring it like:
boxVector:=Vector(n,datatype=list());
and other ways, but it didn't work. How can it be done?...
I'm rediscovering maple, and i want to find the zeroes of an expression by numerical calculation. But it seems that the function fsolve can not handle the monster i created...
(The monster in question here is a determinant of a 12x12 matrix with one variable an trigonometric functions that i don't want to copy pas (NDA))
The problem might comes from the extrem values it gives for a numerical calculation (slope around 1e6)...
My problem is How to use events command in dsolve/numeric for different points of independent variable?                                     A simple example:
de:=diff(x(t),t)=-x(t);
ds:=dsolve({de,x(0)=1}, numeric, method = rkf45,abserr=1E-12,relerr=1E-11,events =[[x(t)-1E-8,halt]]);
works perfectly, but I need to compare x(t) and x(t-h) in two consecutive...
How to compute the integral: int((c-x)/x)^n,x=a..c) ?
This integral is an incomplete beta function and could be expressed in terms of hypergeometric function, but my Maple refuse to deal is. Pleas help
pl explain me how to find a and b in this eqation
a^x + b^y = 1,
were a= 5 and b= 8
I want to invlaplace the following complex expression that I call PQ.
>PQ:=(cosh((1/2)*eta*sqrt(C3^2+4*C1*s))*sqrt(C3^2+4*C1*s)+sinh((1/2)*eta*sqrt(C3^2+4*C1*s))*C3)*(cosh((1/2)*eta*C3)-sinh((1/2)*eta*C3))*(-cosh(C4)-sinh(C4)+s)/(s^2*(-sinh((1/2)*C3)+cosh((1/2)*C3))*(sinh((1/2)*sqrt(C3^2+4*C1*s))*C3+sqrt(C3^2+4*C1*s)*cosh((1/2)*sqrt(C3^2+4*C1*s))))
where C1 C3 C4 eta are constant .
Then I do like this
>invlaplace(PQ)
But I got
First 1550 1551 1552 1553 1554 1555 1556 Last Page 1552 of 2429
