Let $F, f_1, \ldots f_5$ be polynomials in $\mathbb{Z}_p[r,s,t,u,v]$, the ring of polynomials in 5 variables over the integers modulo an odd prime $p$. By forming the ideal $J:=<>$ I can test whether $F$ is a member of $J$. Indeed $F$ is a member of $J$ and so I know there exists polynomials $a_1,\dots,a_r \in \mathbb{Z}_p[r,s,t,u,v]$ such that $$F = a_1f_1+\dots+ a_rf_r $$ My question is how to explicitly compute $a_1,\dots,a_r$ in Maple, or Sage if you prefer. Thank...
Hello all,
I was wondering if the following thing is possible and how to do it:
I have an assignment, to teach about circles and its equations. What I want to do, is to create some sort of application, that get as input the radius and and the other two parameters of the general equation of a circle, and plots it.
Now, to plot a circle using Maple 17, is fairly easy. But how do I create a graphical bar or other alternative...
How can I Solve this using maple?
Differential equation:
y(n+2) + 7/10 y(n+1) + 1/10 y(n) = x(n)
x(n) = 1
y(0) = 0
y (1) = 1
Use Z-transformer to define y(n).
Solve y(0), y(1), y(2), y(3) y(4) and y(5)
Any one?
Aslam-ul-Alikum I need some help urgently. I want to compare the coefficients of like powers of Y_1*Y_2, please help how i compare it in mapleHelp.mw
I compute a 12,3 matrix in Maple and when I try to generate matlab code with optimization on, the result is a 36 element vector. Also, it warns me as "Warning, cannot resolve types, reassigning t15's type" and "Warning, cannot translate list". When I tried it without optimize=false it yields correct result but the file size is big. I have obtained the correct optimized resutls using Maple 13 before and hence i guess theres somthing to do with maple 17. Any...
Find f:\mathbb{R} \to \mathbb{R}, continuous such that
Find the following integral
\int\frac{\sin x}{\cos x \sqrt{1+\sin^3 x}}dx
Find all integers a, b, c that satisfies the following condition. [condition] For all positive integer n, a4^n+b6^n+c9^n is a perfect square.
convert 1/(1+z) to
Summation(....
I have a function of n variables
y := (a,b .. n) → ....
For this function I need also n input values
y(x1,x2, ... ,xn)
The vector x has the input values ("x1,x2, ... ,xn") but how can I call them without typing them one by one?
Any ideas?
LegendreP(m-1/2, l+1/2, coth(x))/sqrt(sinh(x))
I want to calculate the series about x=0 but I get the error
Error, (in MultiSeries:-multiseries) need to determine the sign of, 2*m
What problem does maple encounter here?
I tried assume(m>0) and then I got the error
Error, (in MultiSeries:-multiseries) need to determine the sign of, 1-2*m
Within a for-loop I want to sum a column for a matrix, but using the column number j gives a error:
"Error, (in tools/add) bad index into Matrix"
script:
for j from 1 to J do
Y[1, j] := sum('X[i,j]', i = 1 .. n)
end do
Any solutions? Thanks!
How does one find a formula that  fits a given set of data  to the best advantage in Maple?
e.g
a := [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10];
b := [ 0.001, 0.001, 0.001, 0.001, 0.001, 0.001, 0.001, 0.001, 0.001, 0.001, 0.011, 0.011, 0.011, 0.011, 0.011, 0.011, 0.011, 0.011, 0.011, 0.011];
c := [ -0.88, -8.87, -0.86, -0.82, -0.77, -0.71, -0.66, -0.62, -0.57, -0.54, -0.89, -0.88, -0.85, -0.81,...
First 1547 1548 1549 1550 1551 1552 1553 Last Page 1549 of 2429
