#### Code attached at the BOTTOM ####
If I run these seperately, they seem to be running fine as shown above. But when I run '8' after '7', it does not seem to be working as in first picture.
I am trying to solve a problem using fsolve. Where the fsolve is inside the integral. I keep getting the following message. Here is what I am trying to do
int(fsolve(int(k*r*PDF(R,r),r=-infinity..x)=0,x)*PDF(Q,z),z=-1..1);
where Q is a normal distribution and R is also normally distributed with its parameter conditional on Q. Following is the error message that I get.
"Error, (in fsolve) z is in the equation, and is not solved for"
Question (A)
The surface z=f(x,y)=5/(1+x^2+y^2) is a hill. A bug walks along the path with x(t)=2+3cos(t) and y(t)=-1+2sin(t)
and z(t) is on the surface (0≤t≤2pi).
Plot the surface z for -4≤x≤7, -4≤y≤4 and includethe path (in thick black) of the bug on the surface.
(this will require 2 graphing commands plus a display 3d. Think spacecurve for the bug's path.)
Animate a solid...
Please, explain me, why I got this? And how to get normal one?
with(ExcelTools):
with(ListTools):
with(DynamicSystems):
filename := "MSFT";
close3 := Import(cat(cat("C://US//",filename),".xls"), filename, "E2:E100");
this i usually use ln(close3[n]/close[n-1]) as the original series
as i do not know whether Sample in statistics package can use this directly,
or
need to use counting to classify them into some group and got a distribution graph
genDE := Diff(g(t),t)^2 - 1 - x*(g(t))^2 - (y-x^2)/12*(g(t))^4 = 0;gensol := dsolve(genDE,g(t));genfun := rhs(gensol[1]);
from above, i got generating function and then continue to derive got the following error
u = ln(-sqrt((-z^2+y)*(-3*z+sqrt(12*z^2-3*y)))*z^2/(sqrt(-z^3*(-3+2*sqrt(3)*csgn(z)))*(-z^2+y)))/x;
tau := subs(u=z,solve(q,z));
it said solution may have lost
if this can not be direct to...
restart;with(Statistics):
MartinPoisson := (p/((p+2*q*T)/(1+p*T+q*T^2)-(p*T+q*T^2)*(p+2*q*T)/(1+p*T+q*T^2)^2))^r*r^2*T^n/factorial(n);
Dist := subs(T=t,MartinPoisson) assuming t > 0;
MartinDist := Distribution(CDF = unapply(piecewise(t>1,Dist,0),t));
MartinDist := Distribution(CDF = unapply(Dist, t)) assuming t > 0; #Change 2
X:=RandomVariable(MartinDist);
MartinDensity := PDF(X,t);
MartinDensity := subs(t=x, MartinDensity);
SURF is the surface z=2x^2+y^2 for x=0 .. 2, y=0 ..4 and view= -1 ..16.
L is a straight line laser beam x=7-2t, y=t, z=4t-1 which hits SURF at the point P=(1, 3, 11).
Graph SURF, the laser path in red (t=0 to 3), the normal vector at P in black, and the reflected path in green.
Include the equations of the normal vector and the reflected path.
plot part of the surface f(x,y)=10-x^2-3y^2:
plot3d(10-x^2-3y^2, x=-1 .. 4, y=1 .. 2, view=0 .. 11, axes= normal); (press enter)
Determine the normal vector and the equation of the tangent plane at the point (2,1,3) on the surface.
Display the surface , a black vector and the tangent plane, and give the equation for each of them
label the normal vector and the tangent plane, and give the equation for each of them
LL_61)_Poker.mw
I am having some problem with this procedure located in the "experiment" sub section.
I am trying to calculate the win probability in a poker game pre flop ie each player
get two cards. I am trying to find out which two card combination will result in the
highest probability of winning in the end.
In the first example I simply assume that player 1 gets [DA, HA] ie dimond ace
how to find eigen value this 4x4 matrix:
i copy from notepad, it do not have line return, so i copy to MS WORD and copy here from MS WORD
but some characters missing, if there is some missing please tell me, it seems old web page is better
code and error here
https://skydrive.live.com/redir?resid=E0ED7271C68BE47C!351
restart;with(LinearAlgebra):
f:=[x3-x2^3,-x2,x1^2-x3]:
with(Physics):
u := subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),u)));u := -Physics[`*`](Physics[`*`](Physics[`*`](3, Physics[`^`](conjugate(x2(t)), 2)), x2(t))+Physics[`^`](x1(t), 2)-x3(t), Physics[`^`](1+Physics[`*`](3, Physics[`^`](conjugate(x2(t)), 2)), -1));
u = subs(conjugate(x3(t))=x3(t),subs(conjugate(x2(t))=x2(t),subs(conjugate(x1(t))=x1(t),u)));
would like to remove all conjugate back to normal variable
have a matrix An = [alpha(i,j)]
alpha(i,j) = (j-i+1)*(j-1)!/(i-1)!*a(j-i+1)*x    for j-i >= 0, j - i even
                   0, j-i >= 0, j-i odd,
                   -1, i-j = 1,
                    0, otherwise
First 1585 1586 1587 1588 1589 1590 1591 Last Page 1587 of 2430
