How do I plot 3D cylinder with following constraints: radius from 0..1, and theta 0..2*pi with a volume of pi/2. I keep getting error messages for all attempts. Please advise. Thanks Charles
I want to make tridaigonal matrix like this for n x m order
[3  2  0  0  0  0]
[1  3  1  0  0  0]
[0  1  3  1  0  0]
[0  0  1  3  1  0]
[0  0  0  1  3  1]
[0  0  0  0  2  3]
please help me how to write it in maple
Hello!!
I have modeled a 3DOF manipulator with crank-arm type actuators in maplesim!!!
It simulates the model... but when I "Create Attachement>Equations" and when I click on "load selected subsystem"... it starts evaluating but never gives me equation... I have waited for almost 2 hours but no luck!!!!
Any idea what should I do to get equations for this model???
P.s. I have attached the moel!!!
I have a PWM signal in MapleSim and want to have a spectrum analysis of it. The time domain signal should be transfomed into a frequency domain signal, to get the harmonics of this signal.
My first intention was to bring the MapleSim signal to Maple (Attachment->Worksheet->LinkModel->Simulate). Then I had a 2x1000 Matrix which i want to transform with a FFT. My problem is that it doesn´t work. How can I get a spectrum plot of this Matrix or function?
I am wondering if there is a way to create a pdf from a Maple worksheet that has an animation, or in the case of Maple 17, a video, that allows the viewer of the pdf to play the animation/video.
I have 3 numerical methods s1, s2 and s3 for solving the linear system Ax=b ,
and I have the maple script (program) for each one of the methods. BUT I want to collect all of them in one program only such that the user(person) can select (choose) one of them,
How can I do this?
So I am doing a project for my stat class and I'm using maple to generate the simulation of russian roulette. What I want to do is have X1 through Xn trials, and within each trial I would like to simulat a round of russian roulette where the round ends upon the gun firing. Then I want to take how many times the trigger was pulled in each trial and make a n by 1 matrix where the column is the amount of times the trigger was pulled in each round, and the rows being the specified...
How do I define an algebra in Maple?
Say for example Quaternions:
i^2=j^2=k^2=i*j*k=-1
Thx
I'm using Maple 16 on Mac mountain lion.
Trying to export a densityplot animation with 150 frames, but when I export as a gif the file it creates is empty.
Any idea why this is happening or how to fix it?
I want to simplify (x+1)/sqrt(2*x+2) into sqrt((x+1)/2). Is there a way to do this?
I like to use Maple as an informal  text editor for math correspondence. (I do not use Tex and am firmly committed to not learning Tex. Principled laziness.) I usually insert a Document block in a new worksheet, type my letter utilizing all the wonderful automatic formatting-powers, symbols, integrals, etc. easily available in Maple and then print the resulting document as a pdf and email it. It is much more readable for me and for the person receiving the document.
In a worksheet how can one see all of the page breaks.  I want to be able to size plots to minimize white space.
Is Maple able to get the lightning data from here www.lightningfinder.com
The map is refreshed every 30 seconds and displays where the lightning strikes are occuring.  I can't determine where the page is getting the data from.  Where is the page getting the data and how can we use Maple to pull the data?
I understand completely how the Playfair cipher works but I'm not sure how to begin to implement it into Maple. Does anyone know how to begin encrypting and decryptin a code using this cipher?
Hi, I'm starting my program using Maple, then will bring some data to calculate in matlab, later on bring the data back to be calculated in Maple.
My equations have lots of trigonometry multiplication of matrix. When I run it in matlab, it runs fine. But when I try to use Matlab[FromMFile]("test.m",'evaluate') it gives me this statement:
"Error, (in Matlab:-FromMFile) unable to strore '(3.500000000*I)*2^(1/2)' when datatype=float(8)"
Could someone please...
First 1603 1604 1605 1606 1607 1608 1609 Last Page 1605 of 2430
