I am using Maple 15 and every time I try to plot this equation it doesnt seem to want to plot. This is the code I keep trying to input:
plot(3*e^(-x)*x-e^(-x)-1.5*e^(-x)*(x^2)+e^(-x)*(x^2)*log(x),x=0..9,y=-1..0.6);
Every time I get "Plotting Error, empty plot"
The equation came from the original differential equation .5(d^2y/dx^2)+(dy/dx)+.5y(x)=ln(x)e^(-x)
 Also When i try to plot this equation:
-.5*e^(-10*x)*sin(10*x)-.5*e^(-10*x)*cos(10*x)+(3/2)=300
Solve for x in the following expression.
log x=-4
I just got a simple expression after a longer equation where the last number in the expression is very small, and should be se seen as zero.
E[A]+40,0*10^-9, and it should only say E[A]
Is there a simple command to "round away" 40*10^-9?
It has to be simple because it is written in a report.
Best Regards
 Nicolai
hi friends i have already asked help related to this code which am gona post but this time I am facing some different problem. In the worksheet which i attached below is having algorthim for cubic spline on heat equation. IN this sheet FD equation is my main equation and i want this equation to use boundary conditions mention in code. After using that i want this equation to generate system of linear equations when i=0..M, j=1..N. But i dont want to solve it completely. After...
I use the following commands to export a graph to a file:
plotsetup(gif, plotoutput=cat(filefolder,examplenr,".gif")):
print(display([pol],color=grey,scaling=constrained,axes=none,view=[0..100,0..100])):
filefolder is defined as a complete path: filefolder:="D:/TopUp/models/vergelijking/":
And pol is a pol:=plottools[polygon](polygonlist,color=grey):
This works fine when I use it directly in a Maple worksheet.
However, if I save...
We want to fit
f(x) = a_0 + a_1 *x + a_2 * x^2 + ... + a_n * x^n
to the data (x_i,f(x_i)) for i = 0 ... n.
It will give rise to the following system
[ a_i ] = [A]^{-1} * [ f(x_i)].
Here [a_i] = [ a_1 a_2 a_3 ... a_n],
[A] = [ 1 x_0 x_0^2 ... x_0^n ; 1 x_1 x_1^2 ... x_1^n ; 1 x_2 x_2^2 ... x_2^n ; ... ; 1 x_n x_n^2 ... x_n^n]
[f(x_i)] = [f(x_0) f(x_1) f(x_2) ... f(x_n)].
I want to know how to take the fourier transform of a solution to an IVP obtained using dsolve/numeric and consequently plot the transform. any ideas?
i'd be glad to get some help with that problem:
i want to do a plot3d of serveral functions depending on x1, x2.
My problem is the that I need it to be plotted on a triangular domain. i.e. the triangle limited by the edges (0,0), (0,1), (1,1).
I tried the following:
p[i]:= plot(phiX1[i](x1,x2),x1=x2..1-x2,x2=0.. 1);
and received:
Error, (in plot) expecting a real constant as range endpoint but received x2
I have an animated spacecurve with arrow:
restart:with(plots):
p4:=animate(arrow,[<cos(tend),sin(tend),0.9 tend>,<-cos(tend),-sin(tend),0>,color=red],tend=0..50,axes=boxed,frames=150);
I succeed in putting text at basis of arrow:
l3:=animate(textplot3d,[[cos(tend),sin(tend), 0.9 tend, 'basis'],color=black,align={BELOW},font=[TIMES,ROMAN,14]],tend=0..50,frames=150);
I like tot put text at the end of the arrow. This is my 'progress':
Hello evrybody,
my first question here.
i'm a engineer studend in electronic and i'm working on the inverted pendulum problem at my university.
so i need to use the lagrange way to get my equations in the good form.
i have this equations :
I have a plot of a cylinder with points singled out.
Firstly, the points are currently given by (x,y,z) but I would like them in terms of (r,θ,z), how can I do this?
Secondly, I was wondering how to assign to each point an [i,j] value? So you could have r[i,j], θ[i,j] and z[i,j] as matrices of the points?
Points_on_the_initia.mw
Maple is saying 'Error, Vector index out of range'. Can you see how maple executes all steps, so I can see where exactly the problem is?
I want to solve the system A - B = C to A, with A, B, C matrices and the variables in the matrix C are a combination of the variables in A. How do I do this?
http://www.maplesoft.com/applications/view.aspx?SID=33040&view=html
it can calculate from numeric data, is it the end?
where do multiset coming from?
if given a multiset, and calculate its power sums, then i express this power sums in terms of symmetirc polynomials, what is the purpose of this?
I often have to create density plots with many (thousands of) points. Hence the first thing I do when I install a new version of maple on linux, is edit dir_of_maple/bin/maple so that
JAVAHEAP=512
is instead
JAVAHEAP=4096
I have done this for years and never have any memory problems. But recently I have sent my code to someone who runs Windows and they seem to have "out of memory" issues when trying to do density plots of large datasets.
First 1605 1606 1607 1608 1609 1610 1611 Last Page 1607 of 2430
