Hello.
I took the battery out of my laptop by a mistake while it was in sleep mode. Now maple can't open the document even though i did save it before. It opens a file where 80% of my work is gone.
Download BET.mw
Maple says Incomplete worksheet when I open the file.
Can someone please help me?
I am trying to get the following matrix:
int00:=Matrix(3,3);
int00[2,2]:=a;
int00[2,3]:=b;
int00[3,2]:=c;
int00[3,3]:=d;
int00;
cols:=MTM:-sum(int00,1);
rows:=MTM:-sum(int00,2);
int00[1,1..3]:=-cols:
int00[1..3,1]:=-rows:
int00;
int00[1,1]:=a+b+c+d:
int00;
MTM:-sum(int00,1);
MTM:-sum(int00,2);
How do I get the sum of all elemnets in the 'original' matrix? Bascially, the int00[1,1] term in the toy example.
Z := proc (theta) options operator, arrow; sin(theta+2.3)+sin(2*theta+2*(-1.5))+sin(3*theta+3*(-0.94e-1)) end proc
Zbar := proc (theta, phi) options operator, arrow; Z(theta+phi)-Z(theta)end proc
plot3d(int(signum(Zbar(theta, phi)+l)*abs(Zbar(theta, phi)+l)^(1/4), theta = 0 .. 2*Pi, phi = 0 .. 1, l = 0 .. 1)
Hello, I am having some trouble plotting 3D of these function. There is no error message or anything, but when I enter plot3d command it takes too...
I want to find all the max or min values in a range, from a numerical function [t,x(t)], numerical solution of a differential equation.
For example if the solution was periodic in time, I want to find the max values of x in a certain intervalot t
Hi Guys. I´ve got a problem with the mod (mods,modp) function of maple.
I want to calculate the following congruences:
mod(4,-5) = -1 BUT maple returns 4
mod(-3,-4)=-3 but maple returns 1
and so on....
Does anybody of you know how to fix this? thanks!
I have a problem. I want to make plot 3d for pressure drop in diffuser by posuille formula,
plot3d(∫_0^l▒〖(128∙1.2∙〖10〗^(-3)∙〖10〗^(-14))/(π∙〖(d+2∙x∙tan⁡〖θ)〗〗^4 )  dx,d=0.1∙〖10〗^(-6)..1.5∙〖10〗^(-6),l=5∙〖10〗^(-6)..50∙〖10〗^(-6),axes=box,font=[TIMES,ROMAN,13])〗
but with increasing of "l"(length of channel) graph shows wrong pressure drop. Normally with i increasing of "L" we should have...
> restart; R := 8.314;print(??); # input placeholder> G1[1] := piecewise(`and`(T > 298, T < 700), -7976.15+137.093038*T-24.3671976*T*log(T)-0.1884662e-2*T^2-0.877664e-6*T^3+74092/T, `and`(T >= 700, T < 933), -11276.24+223.048446*T-38.5844296*T*log(T)+0.18531982e-1*T^2-0.5764227e-5*T^3+74092/T, `and`(T >= 933, T < 2900), -11278.361+188.684136*T-31.748192*T*log(T)-0.1230622e29/T^9, 0);print(??); # input placeholder
> G1[2] := piecewise(`and`(T > 298, T < 700...
The system consists of 3 equationsHow can you single out one of the solutions in obtaining module and plot for it?
a := 1; m := 1/64
l1 := 2*(diff(ur(e, t), t))+(1+tanh((1/20)*e))*(diff(ui(e, t), `$`(e, 2)))+2*a*(ui(e, t)*ur(e, t)*ur(e, t)+(ui(e, t)*ui(e, t))*ui(e, t))+m*ui(e, t)*(diff(ur(e, t)^2, e))+m*ui(e, t)*(diff(ui(e, t)*ui(e, t), e)) = 0
l2 := -2*(diff(ui(e, t), t))+(1+tanh((1/20)*e))*(diff(ur(e, t), `$`(e, 2)))+2*a*(ur(e, t...
Let say that you have two datasets:
with(MyFinance):
z1 := GetCSV("http://www.quandl.com/api/v1/datasets/USER_18Q/18R.csv?&auth_token=BXckVSG3twWkV272c9Q4&trim_start=1968-04-01&trim_end=2013-04-12&collapse=daily&transformation=rdiff&sort_order=desc");
z2 := GetCSV("http://www.quandl.com/api/v1/datasets/USER_18Q/1EV.csv?&auth_token=BXckVSG3twWkV272c9Q4&trim_start=1994-01-03&trim_end=2013-04-12&collapse=daily&...
** comparison link has been updated for Maple 2015 **  All three M's have identical speed performances
Someone has created a comparison of Mathermatica 9, Maple 17 and Matlab 2013a here http://12000.org/my_notes/rankTest/test.htm
The timings and codes used were as follows:
2.2.1 Mathematica
Remove["Global‘*"];
Share[];
n = 7000;
m = Table[Random[], {i, 1, n}, {j, 1, n}];
AbsoluteTiming[MatrixRank[m];]
2.2.2 Maple
kernelopts(gcfreq= 2^22):
UseHardwareFloats:= true:
gc():
n:=7000:
M:= LinearAlgebra:-RandomMatrix(
     n
    ,n
    ,generator=0.0 .. 1
    ,outputoptions=[datatype=float[8]]
time[real](LinearAlgebra:-LA_Main:-Rank(M));
2.2.3 Matlab
clear all;
n=2500;
A=rand(n,n);
tic();
rank(A);
toc()
Certainly that must be the slowest possible route for Maple ever.  Anyone care to post their code and timings?
Maple gives the fourier transformation:
fourier(int(y^k*exp(-k*x*y/phi+I*y*omega), y = 0 .. infinity), omega, t) as:
2*Pi*t^k*exp(-t*k*x/phi)*piecewise(t < 0, 0, 1)+piecewise(0 < t, -2*Pi*t^k*exp(-t*k*x/phi), 0)
but it is identically 0.
if change the order of integration and integate exp(I*y*omega) first, the transform is equal to
int(Dirac(y-t)*y^k*exp(-k*x*y/phi), y = 0 .. infinity)
which is Heaviside(t)*t^k*exp(-t*k*x/phi)
When I solve a systems of equations, fsolve gives the solution
{ x = 5, y= 6, z = 1}.
I now want want to define the variables x, y and z as respectively 5, 6 and 1 - but without copying the solution. Because this is a solution that I get in a loop, so it changes in every step. Maybe there is a easy way to put it in a vector?
I often have large matrices and have to grab only every nth column or row (for plotting
for example). So far I've been doing it this way:
nthColumns:=proc(v_m, v_n)
v_m[..,[seq(i, i=1..rtable_size(v_m)[2], v_n)]]
end;
nthRows:=proc(v_m, v_n)
 v_m[[seq(i, i=1..rtable_size(v_m)[1], v_n)],..]
end;
A := LinearAlgebra:-RandomMatrix(20, 20, outputoptions = [datatype = float[8]]);
I only want to display 'position' in animation while tend <= 12:
This is the trial:
restart:with(plots):
for tend from 0 to 50
while (tend <= 12) do
pos:=animate(textplot3d,[[-1.8,0,alpha*tend, 'position']], tend=0..50,frames=150);
od;
display(pos);
I receive error messages:
error, (in plots/animate) 0=0..50 is an invalid animation range
Then I try:
Helo every one,
I'm trying to find the positive real root from:
and substitute it in:
my prog is:
eq5:=u->-3*b*k*u^2-3*b*k^2*u^4-k^3*u^6*b+k*u+5*k^2*u^3-b:
                   (solve(eq5(u),u)): S:=array([...
First 1604 1605 1606 1607 1608 1609 1610 Last Page 1606 of 2430
