I would uninstall maple but i get the following error:
java.lang.IllegalArgumentException: No product for ID=16000347-aaa2-0000-99a9-b0cb0eddf46e
                at ZeroGgv.<init>(DashoA10*..)
                at ZeroGf3.c(DashoA10*..)
   Let GL(2,Z) be the  group of all the matrices of dimension 2 over the integers with the determinant equal to +/-1.
   A matrix M in GL(2,Z) is called primitive if M is not equal to K^n for any K in GL(2,Z) and any positive integer n >= 2.
   Is the matrix M:= Matrix([[27,5],[11,2]]) primitive? How to determine it in Maple?
Edit. GL(2,Z) instead of UL(2,Z).
I am solving an equation that has two piecewise functions on it. It seems that Maple ignore the second piecewise. If I include it or remove it  I will get the same solution. I tried to fix the problem but still cannot figure out why Maple ignores it.
This is Maple code:
with(DEtools);
eq := diff(x(t), t) = -piecewise(abs(x(t))-.5 > 0, abs(x(t))-.5, 0)-piecewise(0 > x(t) and x(t) > 1, 0, x(t) > 1, 1);
Salut,
Il est clair que la multiplicité d'intersection des courbes C1:=x^2-y*(x+y^2) et C2:=x*(x+y^2) au point (0:0:1) est égale à 7 ; I(C1,C2,(0:0:1))=7.
Mais l'extension student[intercept] fournie que 4 solution :
> with(student):
> C1:=x^2-y*(x+y^2):
> C2:=x*(x+y^2):
> intercept(C1=0,C2=0,[x,y]);
   [[x = 0, y = 0...
Hello.
I have following peace of code:
>restart;
>assume(a::complex);
>z1:=t=conjugate(a)*b;
>z2:=a^2;
>a:=solve(z1,a);
>z2;
I need to get (conjugate(t))^2/b as a result of last operation but get a~^2. What do I have to change in code? Of course, I can skip
>assume(a::complex);
and it will get me exactly what I need. But I have to use this command for other reasons.
First of all I just want to say that your forum is great and it helped me to find a lot of new stuff for Maple. I am yet still a beginner but …we all need to learn. So let’s get to my question. I have an equation with 2 variables - x and y. This is the equation
x = y*(25+2*x)^(2/3)/(25*(.566*(25*x)^(2/3)))
So… I know I can solve the equation for x and y and I can give it specific values for y and it solve it every time. When,...
I’m a beginner in Maple and I have problem in understanding the RootOf
my equations are shown below:
M1alone := (1/2)*hs*fm*sigma*mu/(Ps*sqrt(sqrt(M1/h0)/Ps+ts))-As*h0*mu^2/M1 = (1/2)*hs*mu^2/Ps-(1/2)*hs*mu:
> M1sol := isolate(M1alone, M1);
M1 = Ps^2*(-ts+RootOf((-hs*mu*Ps+hs*Ps^2)*_Z^5+hs*fm*sigma*_Z^4*Ps+(-2*hs*Ps^2*ts+2*hs*mu*ts*Ps)*_Z^3-2*hs*fm*sigma*ts*Ps*_Z^2+(hs*Ps^2*ts^2-2*As*mu-hs*mu*ts^2*Ps...
I need to solve elementary equation, where "t" is real and all other variables are complex values:
Bonjour,
Où se trouve l'extention ?algcurves,intersectcurves dans maple 12?
Merci d'avence,
Gérard.
r1:=2*(1-s^2)^(1/2)*arctanh((1+s)*tanh(x)/((1-s)*(1+s))^(1/2))/((1-s)*(1+s))^(1/2)+ln((1/2)*arccosh(1/s)-x)
with x=1/2*arccosh(1/s)-beta*u
is to be calculated to the first order in u.
in fact im only interested in the first order not in the zero order.
so when applying the series I get for the first order
-beta*u/sqrt(1-s^2)
whereas by hand I get:
-beta*u*s/sqrt(1-s^2)
 I'd really appreciate some idea since...
I want to draw a graph of this non-linear equation
d^2*y/dt^2+y^3-sin*t = 0
when:
y(0) =0
y'(0)=1
someone can help me ??
Bonjour,
Comment se calcule (bien sûr avec Maple) la multiplicité d'intersection de deux courbes algébriques d'équations f(x,y)=0,g(x,y)=0 ?
Merci d'avence
Gérard.
Maple can do:
assume(H>0)
this function:
2*arctanh((1+s)*tanh(x)/sqrt((1-s)*(1+s)))+ln((1/2)*arccosh(1/s)-x)
shall be calculated @ x=1/2*arccosh(1/s)
when taking the limit maple tells me its 0
whereas when calculating it by hand i get ln(sqrt(1-s^2)/s)
whats the problem?
PS: 0<s<1
Notice that the order of the output from the EulerLagrange command when three functions are input does not correspond to the order of the functions listed, and when they are requested separately, the last function is not included:
with(VariationalCalculus):
T3:=(1/2)*m*(diff(r(t),t)^2+r(t)^2*diff(theta(t),t)^2+diff(z(t),t)^2):
U3:=m*g*z(t):
L3:=T3-U3;
EL6:=EulerLagrange(L3,t,[r(t),theta(t),z(t)]);
EL6ra:=EulerLagrange(L3,t,r(t));
EL6thetaa:=EulerLagrange(L3,t,theta(t));
EL6za:=EulerLagrange(L3,t,z(t));
First 1608 1609 1610 1611 1612 1613 1614 Last Page 1610 of 2430
