I want to get a closed form of the nth order differentiation: diff(exp(-(x+sigma)^2/(2*sigma^2)), `$`(x, n)) where sigma is a positive constate. But maple gives an unevaluated answer. Howere, if calculating diff(exp(-x^2/sigma^2), `$`(x, n)),maple gives a closed form:x^(-n)*2^n*MeijerG([[0, 1/2], []], [[0], [1/2+(1/2)*n, (1/2)*n]], x^2/sigma^2).
As'salam u Alaikum / Hello!!
I want to add a revolute joint but i want the axis of revolution not to be aligned with base axis system (as maplesim only allows revoution about any of the bas axis-9 possibilities). The revolution should be about an axis which is at an angle from x-axis. How do I do it??
Moreover I will be very happy if you can share video tutorials of complicated cad models.
Thanks!!!
Hey,
I have some expression of the form
sqrt((a+b)*(a-b))/(sqrt(a^2-b^2))
which maple unfortuntely does not simplify...
I have tried assumptions as a>0 b
how can one make this work?
Hi! Today I tried Maple for the first time and unfortunately encountered a silly but really annoying problem. When I write a simple calculation expression like 2+2; it works as expected. However, when I use an expression like sin, ln, Pi, etc., the return (enter) key stops working, the program just doesn't accept them. I'm beginning to think this has something to do with my (quite old) Windows setup since I couldn't find a similar error anywhere in the internet.
I'm working on;
The command
f := -.1*(x+3)*(x-1)*(x-3.5):
Student[Calculus1][FunctionChart](f,x=-4..4,concavity=[],title="",caption="",gridlines);
produces different results in Maple 13 and Maple 16.02.
In particular, the concavity=[] option seems to be ignored in 16.
Also, it may be my imagination, but execution seems slower in 16, but I didn't try timing it.
My apologies, if this has already been noted.
Does anyone know how to us asympt on a function but with x going to -infinity rather than the standrad +infinity thx
Each announcement of a new version of Maple TA, including the latest Maple TA 9, see
http://www.maplesoft.com/products/mapleta/new/index.aspx
contains the sentence:
"... includes connectors to Blackboard® and Moodle™"
But I have never seen any bit of information about
- how to install
- how to use
- what it is capable of
- etc...
Our Institute has Maple and...
Could someone pls help write me code such that when text is entered, the first chemical element symbol in each word is identified and highlighed.
i/p: "the cat molly"
o/p: "tHe Cat Molly"
( like the opening title sequence on "Breaking Bad")
I got out the sledghammer and made a start
element.mw
I've tweaked it a bit to now look like this. Trialed it out with some examples:
Marks:=proc(m::positive)
if m < 40 then print (m, `Fail`)
elif m < 50 then print (m, `Third Class`)
elif m < 60 then print (m, `Lower Second Class`)
elif m < 70 then print (m, `Upper Second Class`)
elif m < 100 then print (m, `First Class`)
elif m > 100 then print (`error`)
else end if;
proc(m::positive) ... end;
Marks(30);
Hi there i have function as:
f(B,F)=
where: F,B>0 and
such that:
h=B^2;
I need to plot the surface (contour plot) f(B,F) at 0 and -ve points i.e f(B,F)<0.
I am trying to get a shaded area in my plot but I could not.
First we solve ODE without randomness:
ode := diff(U(t), t) = -(A+B*U(t))*U(t);
Then we add randomness to ODE and solve:
ode2 := diff(U(t), t) = -(A+r(t)+B*U(t))*U(t);
A with randomness for r in R=( - 0.0001/365, 0.0001/365) is:
A(t,r)= A+r
Where A is constant =  0.0001/365
We plot both solution. For the plot I...
relativistic_7.mwrelativistic_7.mwrelativistic_7.mw
I want to evaluate the function A(xi(t),eta(t),diff(xi(t),t),diff(eta(t),t)) atthe values of xi(t), eta(t), diff(xi(t),t),diff(eta(t),t)  given above.
Download posi1_-_Copy.mw
hey primes please i need help. i´m trying to create a procedure capable to find an arbitrary distance. at some point in loop clause, is important to 'unassigned'  the variables solved and here where i have problem. it work fine in...
So far, my math group has the entire roller coaster plotted using spacecurves on a 3D plot on Maple. The only issues is now we need to take the derivative between the different sections we created in order for there to be no corners or spaces; basically to make sure the "coaster" runs smoothly.
We get how to do it on paper but we're running into some difficulty doing it on Maple. My question is, how the heck do we do what I just said we wanted to do.
I am trying to plot the solution for eq1 and eq2 for different values of mu.  When I plot  this:
 f := proc (x) options operator, arrow; mu*abs(F[N]-g)*signum(x(t)) end proc;
it works.
When I do the same for the solution it won’t work.
Please any help or advise.
This is the code:
> restart;
> with(plots);
> with(DEtools);
> k := 100; L := .25; M := .5; g := 4; mu := 0.2e-1;
First 1627 1628 1629 1630 1631 1632 1633 Last Page 1629 of 2430
