I'm trying to modify the size of the window where an animation is shown. Tipically, this window has axis going from xmin to xmax and ymin to ymax but this causes some scaling problems when xmax-xmin>>ymax-ymin. I would like to focus in a certain region of my animation and change this viewpoint depending on the position of the elements of the animation. Can anybody help me?
This is my code:
> tf := 5;
> nfr := 201;
I'm solving a system of ordinary differential equations numerically, I used the dsolve(system,numeric) to do it. I have also plotted the solutions. Now I want to know where does this solution cross zero and use this value for later computations, is there a way to do it?
This question is, as I think, equivalent to how to find the roots for a curve expressed in numerical arrays.
How to determine the volume of a sphere from its cross-sectional area, if we rotate it with center the diameter?
Gracias
I'm having trouble with the function G:=(n)-> 3 +2n-sum(sum(f(h), a=1..floor(m/2)), m=1..n) with base case G(0):=3, where h:=2a and f(h):=sum('f(2m)*3m, m=1..(h/2 -1).
For G(1), G(2) etc I get "Error, (in type/satisfies) too many levels of recursion" , note f(h) works properly. So I think the error is from the double summation. Any ideas what may be the problem?
Any help would be greatly appreciated.
I was trying to place the legend of a plot inside of it, and skimming through this site I found a solution based on a textplot, something like this:
plot(loglogplot1, loglogplot2, loglogplot3, loglogplot4): #just the functions to plot
textplot({[placement, 'typeset'(beta=10-9 ),color=black],[...],[...],[...]}): #just the value of beta changes
plot([placement],x=4..6,color=[black,blue,red,green],linestyle=[solid,dash,dot,dashdot]):
Hi comrades. I am trying to do something like this
plot3d( fsolve( x^2 + a*x + b =0, x), a=0.1..5, b=0.5..3);
(this is not what I'm actually doing, I want to make a 3D plot of a more complicated function that uses fsolve, so don't just suggest the quadratic formula!).
I.e. plot the root of an equation as a function of some parameters in the equation.
It's not plotting because it says
"Error, (in fsolve) {a, b} are in the equation, and are not solved for"
I have the following problem:
My function is defined by the determinant of 2 Heun functions
If I plot the phase I get something which looks quite what I'm looking for.
To get a better result I thought I would manually carry out the Wronskian as far as possible...
Doing some manipulations I get another form of the Wronskian which in fact should give the same result...
the problem is it doesnt :-(
I've added the spreadsheet....
In the solution set linked to above, I would like to replace each instance of the constant sqrt(k*(m[2]+m[1])/(m[2]*m[1])) with ω. I feel that this should be possible with algsubs, but cannot figure out the proper...
I am facing the error message "Error, (in factors) Bad inputs to diophant." raised by a call to
factors(p, {I, sqrt(3)})
for a polynomial p in 7 variables (with integer coefficients). Unfortunately, the error is not reproducible: After some thousand calls to factors (with different polynomials) this error suddenly occurs.
  1. Interestingly, it does not depend on the actual polynomial,...
I know how to solve system of differential equations numerically, but now I want to know how to set a bound on the solutions.
For example, if my system of DE is like this:   dx/dt = x+y   dy/dt = x-y    , solve x and y in t.
I can solve this without any restriction on x and y, now I need to know how to bound x and y, e.g. x can only fall in the interval [0,1]
Thank you very much!
Hi, I am trying to do the calculation with a matrix, and I have hard time to find a way to calculate the Moore-Penrose generalized inverse of a matrix in Maple. Could anybody help me?
I have a solution with RootOF(_Z^6+....). I do not need to find the roots explicitly(I know that I should use 'allvalues' to find the roots). My question is "Is it okay if I use RootOF(...) expression in another equation without finding the roots explicitly? I mean does RootOF(_Z^6+...) stand for all its roots and can it be used for each roots?"
Thank you in advance.
Anybody has a hint on how to solve a non-linear system with trigonometrics. I want to solve x, y and z.
How can I use factor in equations?
For example:
x^6+y*x^4+z*x^2-g*x^4-3*x^6====>-2*x^6+(y-g)*x^4+z*x^2
or
a*cn+w*dn+e*cn+f*dn=====>(a+e)*cn+(w+f)*dn
These examples are very simple.
How do you graph y''+8y'-9y=0?
How do you graph 4y"-y=0?
And for these i need to sketh the graph of the solution solution and describe its behavior as t increases.
First 1630 1631 1632 1633 1634 1635 1636 Last Page 1632 of 2430
