qRacah := qhyperterm([q^(-x), alpha*q^(-x)/(gamma*delta)], [alpha*q], q, gamma*delta*q^(x+1)*t, k)*qhyperterm([beta*delta*q^(x+1), gamma*q^(x+1)], [beta*q], q, q^(-x)*t, k);
i use inverse laplace to transform ordinary generating function into exponential generating function
can not further evaluated
2.
i do not know whether x is main variable or q is main variable or both are.
ff := eval(subs(x=0, exponential_genfun));
I would be grateful if other users of Maple TA could post their experiences of the Equation Editor here.  I have used it in Maple TA 5 (on premise) and 8 (hosted) and in both cases it is incredibly slow to load, has errors with out of date certificates (I've been told these will be fixed in version 9), and sometimes just won't display an equation from the question at all.  I don't think I'm doing anything wrong (I position my cursor on the equation...
How to give the different colors in implicit plot  and add legends my codes are
g:=y*(1-1/(x^2+y^2)):
aa:=[g=0.1,g=0,g=0.5]:
implicitplot({seq(aa[i],i=1..3)},x=-5..5,y=0..2,legend="g=0.1,g=0,g=0.5",color=[red,blue,green],scaling=constrained);
i want to draw  a countour plot and i want the graph in the given below patter  and my codes are
for Q=1, and Q=2 ,Q=3.2
F:= x^2+2*y^3+Q:
p1:=contourplot( F, x=0..1, Q=1,color=red):
p2:=contourplot( F, x=0..10, Q=2,color=blue):
display(p1,p2):
thanks in advance
Is there a function that will return the current orientation values in a 3dplot, or can anyone help me with this. I would like to display the orientation as I rotate a plot.
TIA
Does anyone know why the scale isn't matching what i asked for here?
Case_I.mw
a)can someone pls help write code to generate this circle within square, then square within circle....(with the colours)
figure.doc
Its a bit like this problem:
http://www.mapleprimes.com/questions/141883...
I have a trigonometric series which contains 1D and 2D modes. It looks something like the following:
S:= Acos(mx)sin(nz) + Bcos(kz)sin(qx) + Csin(sz) for m,n,k,q,s=1,.....10.
I am iterested in obtaining the amplitudes of the 1D modes (i.e. C in the above expression). Is there a way to do this using the coeffs function? I would like to use this in such a way as to isolate the 1D modes from th series. Any suggestions?
Thanks for your help.
   I'm solving two equations and two unknowns with fsolve where there are multiple solutions (at most 3). I iterate this and my next set of solutions depends on the previous one. The problem is the the first solution (the only one I need) may be arbitrarity close to to the previoius solutions and fsolve skips it and finds the second solution. Any recommendations or ways of makign fsolve resolve arbitrarily close solutions?
Hi guys,
I have the following complex equation,
Az:=unapply((rhs(sol[2])*BesselJ(q,t2*r)+rhs(sol[3])*BesselY(q,t2*r))),r)
It gives a value which is constant for frequency upto 3000 Hz, i.e. if I run the solution again keeping all the values constant the result is the same  BUT   When I change the frequency to 15000 Hz, the equation still give me the result but every time its different when I run the program with constant values.
I am aplying a simple energie balance with some simplification, and i am implementing it on maplesim.
The component has the following equations:
Am i missing something? Do i need any aditional equation to maplesim know to where should the fluid be moving when Qjacto is positive or negative? Why do i have...
If I have  the following..or different numbers, but 2 different arrays I need to calculate sample mean & variance
Array A:=([1,1,1,0,0,3,2,4])
Array B:=([2,1,0,1,3,3,4,1])
what formula do I use to force Maple 16 to calculate the sample mean and the sample variance?
I am trying to perform a simple model of the entrainment of air in a jet by aplying energy emand momentum balances to the injector and flute. But i am having doubts on how to prescribe pressure on a point. This is the equations of the component Injector:
In the component porti...
I want to plot a graph of Sin[x*Pi]*Exp[A*x], this works perfectly well for low A values but I want to try say A=10^2. Is there any way to plot this sort of function?
I need to use subscripts to define a system of equation and its respective variables. I do not encounter any problem when I use solve or Basis (with Groebner package) but when I tried to use RealRootCounting (with RegularChains and SemiAlgebraicSetTools packages), I got the following error message:
Error, (in RegularChains:-SemiAlgebraicSetTools:-RealRootCounting) invalid input: TRDnearsolve expects its 5th argument, vlist, to be of type list(symbol), but received [p[1], x[1], q[1], u[1]]...
First 1632 1633 1634 1635 1636 1637 1638 Last Page 1634 of 2430
