I need fsolve to round down its solutions but the 'Rounding" operator doesnt work . Here's a simple example
Digits:=5:
Rounding=-infinity:
fsolve(sin(x)=0, x=2..4);
The answer is 3.1416 but I need it to return 3.1415. There also doesnt seem to be a command to obtain the nth digit of a number, aka. digit(3, 3.14) = 4 in case I wanted to write a quick procedure to round down the answer.
Any suggestions?
i'm using DirectSearch package to solve the following system of equations (in order to find x1a,x1c,x2a,x2c):
How can i limit the solutions just for positive values of x1a,x2a,x1c,x2c? (Currently, I'm just using
Gil
     So I'm trying to animate a ball moving around in a moving circle. I can do a sequence of points, and a sequence of static circles which works okay but I'd like a continuous animation. Here is the points where the ball hits the circle (x,y) position and the times (t).  and the animation of the circle
x1 := [.9, -0.6953537244e-1, .5084436548, .5084436548, -.5253004431, -.4186356935,
     -.8180728424, -.8180728424,...
How can I get the correct multiset power set of a hashmset in Maple? For example for the following hasmset s I have two different answers in Maple and MuPad. I need to compute MuPad like answer in Maple:
>s := hashmset:-new( [ a, 4 ], [ c,3 ] );
                  s := table(sparse, [a = 4, c = 3])
> combinat:-powerset(entries(s));
Hi, I use Maple 13 and have this issue to solve.
In an archive.txt there is the following Vector:
-1/64*cosdincl^2*cos(2*ele-2*g-2*anom-2*w)
+1/16*sinfJ*cosfK*sindincl*cos(2*ele+g-h+om-2*anom-2*w)
-1/16*sinfJ*sinfK*cosdincl*cos(2*ele-g-2*h+2*om-2*anom-2*w)
+1/16*sinfJ*cosfK*sindincl*cos(2*ele-g-h+om-2*anom-2*w)
-1/16*sinfJ*sinfK*cosdincl*cos(2*ele-g+2*h-2*om-2*anom-2*w)
+1/16*sinfJ*cosfK*sindincl*cos(2*ele-g+h-om-2*anom-2*w)
+1/128*cos(2*ele+2*g-2*h+2*om-2*anom-2*w)
I work at a University and we use Maple 9.5, 13, and 16.  We have had problems with 13 and 16.  In this instance the program gets stuck at
for k from -N to N do
e[k]:=g[k]/L2norm(g[k])
We left it run for 24 hours but it will not calculate e7. The program doesn't freeze but just seems to be in an endless loop. I have tried on multiple computers with different RAM/CPU configurations.
In Maple 9.5 this program...
http://wenku.baidu.com/view/7d013c8c680203d8ce2f24ee.html
 goal is to evalute to (5.10)
with(inttrans):
with(SumTools):
r := sqrt(2*p)*exp(p*t)/(i-1)!*Diff((t^(i-1))*exp(-2*p*t),t$(i-1));
L := laplace(r,t,s);
L := int(r*exp(-s*t), t=0..infinity);
no matter laplace it or integrate it, also failed
when doing ztransform
with(inttrans):
with(SumTools):
network := sqrt(2*p)*((s-p)^(i-1))/((s+p)^i)
ztrans(network, s, z);
error, recursive
http://en.wikipedia.org/wiki/Laguerre_polynomials
how to evaluate to equation (5.9) in page 195 from rodrigues formula?
rodrigues := exp(x)*(x^alpha)/n!*Diff(exp(-x)*(x^(n+alpha)), x$n);
rodrigues := subs(x=2*p, rodrigues);
rodrigues := subs(alpha=1/2, rodrigues);
i want to plot a streamlines for the functions
psi=2y-exp(-x):
for different values of psi=0,1,2,3 and x=0 to 1 i want plot stream lines
Dear Friends.   I solve a group of linear equations and the memory is not enough and i can't
adding a new hardware to the computer.
i increase the virtual memory of the computer from some chose for the operating system
but it seem to me the Maple use the memory from the hardware only.
I want to know is there any method to make the Maple using the virtual memory for
the computer
Amr
When i use the pronumeral thetac (using greek characters) I initially get numeric data reported, but later in the script i get the pronemeral literally repeated (as though there is no value defined for this pronumeral).
This does not happen for thetahs (using greek characters), where I always get numeric results (through the entire script).
See the following script: sample_1.mw
I re-wrote the...
I just encountered a very strange behavior when using DEplot. I want to generate a slopefield and solution curves. However, when I enter the command, only the arrows in the slopefield are showing. If I click on the plot where the solution curve should be, I see the outline of the curve. It's as if the curve isn't begin colored. I hope someone is able to replicate this behavior and suggest a fix. Thanks! (See attached file)
I have three functions f,g,h and I want to create an n by 3 matrix with columns:
[f(1), f(2), f(3), ..., f(n)] , [g(1), g(2), ..., g(n)] , [h(1), h(2), ..., h(n)]
I can do this for a particular positive integer n, but I would like be able to just input n and get the n by 3 matrix.  I am new to Maple and could not find an answer easily.  Thanks.
I have a set of 9 equations and 9 unkowns. These equations are massive 9th order polynomials. The equations themselves are contained in a vector called "C" in the .m file that follows:
Cvector_with_a.txt    (please rename the .txt file to .m since this forum doesn't seem to allow the upload of .m files)
In order to solve the eqautions, you must first set the values of two extra...
First 1634 1635 1636 1637 1638 1639 1640 Last Page 1636 of 2430
