I want to plot:
plot(int(x^2*e^(PI*x/10^12 M), x = 0 .. infinity))
where M is 10^8 but i want the units of the x axis to be x/M, is this possible if so please can i have some help.
There is a state space system as follows:
X_dot = A.X + B.U
Y = C. X
The transfer function of this system is
H(s) = C. (sI-A)-1.B                 (1)
H(s), that is calculated in Maple by using the formula (1), is very complex (please see the attached file).
Would you please show me how to find the transfer function of the system?
In addition, how to plot its bode plot?
I'm trying to plot this equation with initial conditions. I'm following the exact same code that my professor used, but it isn't working.
restart; with(plots): with(DEtools):
DE := y(t)^2*(4-y(t)^2);
p1 := DEplot( DE, y(t), t=0..1/2, {[y(0)=1],[y(0)=3]}, arrows=none, thickness=2, linecolor=[blue,green]):
Under the last line of code I get the error "Error, (in DEtools/DEplot/CheckInitial) the 'number' option...
Possibly a quick one,
I have two sets of precedures, both return the right values however one returns the values alone e.g.
x := 123123.2312323
The other wrongly returns
x :=  Return(123123.2312323)
I have literally pages of code, any suggestions why this would be the case?
Thank you!!!
Can we find exact solution of PDE with help of maple?
If it is yes the please let me how to write commands for parabolic pde
ut=k uxx with boundary conditions u(0,t)=u(l,t)=0 and initial condition u(x,0)=e-x
I have a question about the "applyrule" function. I have an expression that looks like:
exprsn1:=sin(z)(Acos(z) + Bcos(x)cos(2z) + Ccos(x));
I would like to express cos(2z)sin(z) in the form 1/2(sin(3z)-sin(z)). However, when I use the "applyrule" as:
exprsn2 := applyrule(sin(z)cos(2z)=1/2(sin(3z)-sin(z), exprsn1);
it returns the same expression. Is there something else I should be doing before I use applyrule?
I have a model with 3 parameter blocks containing a lot of constants. I would like to know how can i print those lists to papper, .pdf, word or something like that.
Hi Guys, I hope you can help!
I am stuck trying to plot a function that has a conditional based on 'x' the plotted variable.
e.g.
> pltx := proc (num1::integer, num2::integer, x)
if 1 < x then
return 0
elif x < 0 then
return 0
return num1*x^num2
end if
> d := plot(pltx(2, 5, x), x = 0.1 .. 0.4);
Error, (in pltx) cannot determine if this expression is true or false: 1 < x
I am trying to solve a problem in theoretical applied mechanics in which I need to find the solution for 5 unknown but I have 6 equations. None of the equations is redundant and I need the solution of the variable to satisfy each of the equations.
These are the equations
24-52*L^4*m[0]*Omega^2*(R+1/2)/EI[0]-168*beta[1]-52*F*L^2/EI[0]+104*beta[2]+(120+72*beta[1]+104*L^4*m[0]*Omega^2*R/EI[0]-504*beta[2]+312*beta[3]+84*L^4*m[0]*Omega^2*(R+1/2)/EI[0...
I have created a test document to check an equation and I would like to feed a range of k values (ranging from 0 to say 512) in increments of 1) to the main function, and then plot the result as a graph of Zuncomp (y-axis) vs k(x-axis).
I can verify the values of the function by typing say Zuncomp(0) or Zuncomp(10) etc but how do you run this so that you do Zuncomp(k) to read all values of k and generate the output to plot?
Using Maple 13 (Windows 7...
I am new to maplesim. I want to model the human hand and constrain the fingers to a certain range of angle. Then apply a controller to analyse its controllability and also see the dynamic equation formulation
assume(alph>0);
assume(alph,real);
f_exp:=exp(-alph*r^2);
ff_deriv:=simplify(r^2*f_exp^2);
ff:=simplify(int(ff_deriv,r=0..infinity));
It seems to understand what i'm trying to integrate but when I try and find ff it comes up with an awful expression full of erf functions and with a lim r--> infinity at the front. However on wolfram alpha I get the answer that I want: sqrt(pi/2)/(8*alpha^(3/2)).
I am trying to solve two differential equations numericaly:
I recently get a new macbook pro with retina display. Unfortunately Maple 16 seems to be not retina ready. Searching the net I found a tool called retinizer. Using it Maple 16 seems to be displaying a little better, but still the outputs of calculations looks blured. however, whenever certain texts are selected, the whole Maple window display becomes very sharp, so I guess Maple is somehow retina ready but this functionality is disabled by default. Checking the "Get Info" window...
hey all..
i want to plot graph for two tables.
Table1 shows value for crank nicolson method at different x and t
t╲x  0.05	0.15	0.25	0.35	0.45	0.55	0.65	0.75	0.85
0.05	0.0855	0.2446	0.3708	0.4512	0.4815	0.4646	0.4609	0.3160	0.2001
0.15	0.0283	0.8214	0.1277	0.1607	0.1779	0.1776	0.1599	0.1267	0.0813
0.25 0.0112 0.0310 0.0474 0.0597 0.0662 0.0662 0.0597 0.0474 0.0306
0.35 0.0073 0.0128 0.0174 0.0222 0.0246 0.0246 0.0222 0.0175 0.0119
First 1639 1640 1641 1642 1643 1644 1645 Last Page 1641 of 2430
