I have already solved my ODEs and used odeplot to analyse the change over time (0 to 10).
Below is my ODE,
d(a(t))/dt = x - y*(a(t))
d(b(t))/dt = m*a - n*(b(t))
My query here is,
I need to substitute a(t) and b(t) in a seperate equation,
h(t) = 60/0.98 * (a(t))*(b(t))
and i need to plot 'h' over time (0 to 10)
How do I go about doing this?
Please help.
i am trying to simulate a costum component, but i get this error when starting to compile initial values i get this error:
(in dsolve/numeric/RunSimulation) keyword event_blindeye not recognized
Simulation failed.
Why? This costum component was tested on another PC and worked.
Bear with, I'm a noob. This is my code so far:
    > ball := proc (x, y) plots[pointplot]([[x, y]], color = blue, symbol = solidcircle, symbolsize = 20) end proc;
    > animate(ball, [1+sin(t), 1-sin(t)], t = 0 .. 2*Pi, scaling = constrained, frames = 100);
I like the output I have but my aim is to have, say, 8 of these balls, all with their own trajectories, and animated on the same axis. All the trajectories would depend only on one parameter, t.
could you pls help me with this code, i dont understand why i get the error.
NewtonZweiVariablen := proc (funktion1, funktion2, startwertX, startwertY)
local Ableitung, StartwertNeuVektor, DurchgangsZaehler, Differenz, StartwertVektor, FunktionsVektor, Jacobi, g, h;
Jacobi := linalg:-inverse(Jacobian([funktion1, funktion2], [x, y]));
How to solve attached equation in Maple?
Is there a possiblity to solve using units?
wzel
PS
Solution was done in Mathcad
Hello Community,
Wondering if anyone has run into the problem outlined in my code below. I am looking to evalute a commutator involving Pauli spin matrices. One of the matrices is squared. Such a commutator should evaluate to zero. However, the way I implemented it below doesn't give such a simplified result. See Result 7 below. Any suggestions as to how to get Maple to evaluate the exponential before the Commutator? Or to otherwise get to a final, simplified result?
I am trying to solve the following system using the function "solve", but the message "warning solutions may have been lost" appears.
This is my script (a,b,c,d,e,f, Resp, Malcyt,Pyrcyt are parameters). The unknown variables are Citcyt, Citmt,Malmt,Pyrmt:
e1 := 0 = a.Pyrcyt-a.Pyrmt+(b-c).Malmt;
e2 := 0 = d.Malcyt+e.Citmt-(d+b+c).Malmt;
e3 := 0 = f.Citcyt+c.Malmt-(e+f).Citmt;
 e4 := 0 = 2.*e.Citmt+(b+c).Malmt-Resp;
Hello every one,
I have a question about summing data from an ode.
ode:=diff(T(x),x$2)-T(x)^2=0;
bc:=T(0)=1,T(n)=0;
n:=3:
I am new to Maple. I need to measure the time complexity of computing the GCD for a set of 1024-bit numbers. I have an equation as:
O(nm × log^2 m × log log m). Where n is the number of bits in the numbers in my set (say, 1024-bit) and m is the number of times I am going to do a computation. How can I perform this computation in Maple ?
does anyone see what i'm doing wrong, trying to solve for n
add(length(i), i = 1 .. n) = 2893;
o/p: Error, unable to execute add
fsolve(sum(length(i), i = 1 .. n) = 2893,n=500..2000);
o/p: n=2893
but if i do a procedure i get the right answer:
s := 0; for i to 5000 do t := length(i); s := s+t; if s <> 2893 then next else print(i) end if end do;
1000
Start with the numbers 1, 1/2, 1/3, ... , 1/100. Choose any two numbers M and N from this list and replace them by the single number M + N + M x N. Repeat the process until only one number is left.
eq, take pair (1,1/2)-->1+1/2+1*1/2=2
then (2,1/3)-->3 and so on .... and you obtain 100.
Can someone show me procedure to accomplish this, because when i try to do it i get into a tiz
Can you please let me about the folowing integral in Maple 13
 int(sech(1/2*k*Pi)/(k^2+1)*exp(I*k*x),k=-infinity..infinity);
 Is there any general precedure for finding these kind integrals
Let function f:\mathbb{R}\to\mathbb{R} so that
I'm trying to get a hold of using DLL with Maple at the moment.
Just to give you some background informations.
My Headerfile:
[code]
#include
using namespade std;
namespace WAVEFUNC
          class
          public:
Good day, dear Friends!
I'm trying to find real positive roots  of equation
sqrt(x+3-4*sqrt(x-1))+sqrt(x+8-6*sqrt(x-1)) = 1 with Maple 16.01.
One can easly verifies that this euqation has at least two positive  real (integer) solutions: at x=5 and x=10,
but Maple function
First 1644 1645 1646 1647 1648 1649 1650 Last Page 1646 of 2430
