Hey guys,
I installed the 64 bit version of Maple 16, but it's still running as "maple.exe*32"? There is a similar quesion somewhere here...but this hasnt solved my issue...
There is no more Maple-software installed on the notebook. The other maple-tasks (mserver.exe) are running in 64bit-mode...
some specs: Thinkpad W520, i7-processor, 8GB RAM, Win7 (64bit)
Merry Christmas! :)
I'm very new user at Maple. i'm using Maple 13 and wrote a code taking help from another code. i'm writing my code here, i'm receiving error at highlighted line, also i'm unable to get any kind of out put.... plz d help
> newton:=proc(fx,m);
> local i,x0,s,n,x1,k,dfx,fx1,fx2,difference,difference1,x2,d2fx,x3;
> x0:=m;
> n:=128;
> k:=1;
> for i from 1 while i < 500 do
> dfx:=evalf[n](eval[n](diff(f(x),x),x=x0));
> x1:=evalf[n...
What about integrals along a curve and on the surface? How it may be presented by MAPLE tools?
I was trying to solve a VERY simple system of 2 equations,{ eq1,eq2}, for the variable d which appears only once to the first degree with coefficient 1. That is grade school algebra. Maple 15 refused; it needed help.
eq1:=s=a+b+c+d;
                    eq1 := s = a + b + c + d
eq2:=s=2*(a+b)*(a+c)*(b+c);
I have a list [1, 2, 3, 11, 29, 88, 252, 739, 2146, 6257, 18213, 53051, 154484, 449908, 1310217, 3815674, 11112091, 32360987, 94242573, 274456016]. How to select all even numbers of this list?
How to laplace transform for hypergeometric form in maple
if rsolve is solving difference equation for L(x) in summation(L*z^n, n=0..infinity)
can i use double encapsulation to solve for summation(L*z^n/n!, n=0..finity)
step 1 use rsolved result of a given classic difference equation times z^n/n! * t^n
step 2 then summation step 1 and use celine method to change into difference equation again
step 3 solve this new difference equation
then i imagine L should be L*z^n/n!
but i am not sure...
I have
f(x,y)=x y+x^2+1
g(t)=(2 t, 3 t).
I want to obtain the function (f o g)(t)  as a real-to-real one variable function.
What I tried:
f:=(x,y) -> x y+x^2+1,   it's ok;
g:=t -> <2 t, 3 t>,  it's ok.
But f@g  returns f@g.
How it would be possible to obtain f o g ?
I have an expression (with important physical meaning), I want to transform all the nasty numbers into scientific notations like transforming 203475439 to 2.0347e8.... anyone could help? thanks
2.03475439*10^8*(-1.*((203475439/5340588290000000000000000000)*n*Pi^2./V^1.+(1/2)*sqrt((41402254276242721/7130470820821281025000000000000000000000000000000000000)*n^2.*Pi^4./V^2.+(10681176580000000000000000000/610426317)*V+(1/2430046173368675201713890432319677067995801002565000000000000000000...
I would like to know if the maple student version can give the analytic solutions of a system of non linear and/or linear equations.
I have the following set of equations and boundary conditions. The problem is I cannot be able to make accurate guesses with the shooting method. I request your assistance.
> k1 := diff(X[1](t), t) = X[2](t);
> k2 := diff(X[2](t), t) = M*(X[1](t)-1)-(2*(eta+b))*X[2](t);
> k3 := diff(X[3](t), t) = X[4](t);
> k4 := diff(X[4](t), t) = (2*Sc*Du*(eta+b)*X[6](t)-Du*lambda*X[5](t)-2*Pr*(eta+b)*X[4](t)-Pr*Ec*X[2](t)^2-Pr*Ec*M*(X[1](t)-1)^2)/(1-Du*Sr);
I have data in Excel sheet. I want to make the data smooth using cubic spline.
My try can be found in the attached maple sheet. In my try, i was unable to see the
difference bewteen the exact data and the interpolated data. Please have a look and
help to smooth the given data in the attached Excel sheet.
Cubic_spline_smoothi.mw
i have a problem when i input this code in maple,..
how it can be error?
what the solve?
thanks for help me
the code:
> with(plots); with(DEtools); with(plottools); a := 0, 5; b := 0, 2; c := 0, 7; d := 0, 2; E := 0, 1;
                                    0, 5
The following commands can be plotted by maple 13&15,
but can't be done by 16.
x1 := sech(sqrt(a)*t); x2 := -sech(sqrt(a)*t)*tanh(sqrt(a)*t);
g1 := proc (t) options operator, arrow; int((int((eval(x2, t = tau))*sin(Omega*tau), tau = 0 .. u))/(eval(x2, t = u))^2, u = 0 .. t) end proc;
plot3d(subs(a = 1, g1(t)), Omega = 0 .. 3, t = 0 .. 1);
g2 := proc (t) options operator, arrow; int((int((eval(x2, t = tau))*cos(Omega*tau), tau = 0 .. u))/(eval(x2, t = u...
First 1648 1649 1650 1651 1652 1653 1654 Last Page 1650 of 2430
