There is an animation of a falling rod in simulink here www.youtube.com/watch?v=lJEHzW-sp5c
How would that be presented in MapleSim?
Also for the double pendulum, model in say if the bottom swing were to hit a wall?  Also model if two double swinging pendulums were to hit each other?
How can I solve a pair of recurrence relations like this in maple 16?
{A(k)=1+((n-k-2)
Is there a way of importing data in NetCDF format into Maple 15? This format is very widely used in atmospheric sciences as a data standard for experimental data such as satellite-derived data.
I have the following expression  f(t)=0.342 Dirac(t)+6.352 exp(-4t)+.0981 exp(-3.056t)  I want to convert it to a piecewise function of the form given below
 f(t)=0.342  if t=0
 f(t)=6.352 exp(-4t)+.0981 exp(-3.056t)      if t>0
when I applied                     convert(f(t),piecewise,t)
I want to solve the equation f(f(-1))=sqrt(2)+g(f(2)), where
f:=x->a/x^2-3*x+2 and g:=x->a*sin(2*x), a is an unknow. I tried
f:=x->a/x^2-3*x+2:
g:=x->a*sin(2*x):
solve(f(f(-1))=sqrt(2)+g(f(2)),a):
evalf(%);
and receive 13.02210936+4.135282756*I.
I just updated to 16.02, and now the (writing) cursor has horrible problems, especially in text groups. Basically, it is erratic or unmoveable.
In a text group, if I move a cursor down by pressing <enter>, it will not move up with the arrow keys, or it disappears and then appears in previous groups. or a new cursor appears in the line above, but the old cursor remains, or ...
In an execution group, it does a lot of the same things, but not quite as erratic.
Prove that (k^{{2}^{n}}-1)\equiv 0 (mod2^{n+2}).If
This is my code - and I get the wrong output.... shouldnt it be around 900 K something?
restart:with(Units[Standard]):
T:=1200*Unit('degF');convert(T,'units','K');Units[UseSystem]('SI'):
evalf(%);
1200 Units:-Unit('degF')
2000
---- Units:-Unit('K')
666.6666667 Units:-Unit('K')
T:=1200*Unit('Fahrenheit');convert(T,'units','K');Units...
 Greetings,
I own Maple 15 Student License and I would like to change the HDD of my laptop. Is this going to pose any problems ? I am going to use the same laptop.
Hello everybody,
I just realised Maple is allowed for my upcoming exam after New Year.
My plan is to have templates of the most common math problems, I might encounter for quick solutions.
Anyway, I have run into a problem with Laplace shifted data, particularly initial value problems. I have been searching for HOURS, and feel like I have look up everything on google, maplesoft and other sites without succes.
I hope some of you are able to help me. The exercise is:
I'm trying to resolve a problem in physics (movement of a particle in a magnetic field) and plot it. I need initial conditions on both (x,y) and (x',y') but when I'm trying to put the four conditions in the initial list of DEplot, a mysterious mistake arises :
Error, (in dsolve/numeric/process_input) invalid specification of initial conditions, got {0 = 0, 0 = 1}
But here is my worksheet :
How to solve Function With Complex Numbers ?????
please help .....
z(1+I) + I  = 0
I'd like to solve  a system of 3 équations and 3 unknows. The system is composed with 3 trigonometric equations and the unknows are the angles gamma_e[1], psi_e[1],phi_e[1] which belongs between 0 and PI.
I have tried this with SOLVE function and i didn't have any results
Code:
when I use s:=evalf(...), maple give me reasonable results but when I use s1:=evalf(...) for the same problem the results are different from previous case!
Can you help me, please?
I thought this was a really fun visual representation of the standard normal curve, although technically the standard normal curve extends infinitely in both directions.  Of course.... you can't evaluate a graph whose x-range extends from -infinity to +infinity.  (Although Maple does a great job of evaluating such integrals, assuming of course that the integral is convergent.)
If you have any suggestions, email me!
And happy holidays to the entire Maple community.
First 1647 1648 1649 1650 1651 1652 1653 Last Page 1649 of 2430
