Hi all, I am having two simultaneous equations , i dont know how to solve these two equations, any one help to solve these equations..
Im knowing the approximate/accurate answer for the equations,
These are the values for my equations
alpha=1.53222, beta= -0.555345, kappa= -0.399943,
need_help.mw
Find all the positive integers n ,such that
I'm trying to plot the function (5*x)/(x^2-4) highlighting all of its characteristics (maxima, minima, convexity, concavity...). I would like to plot this function in different colors in accordance with the different intervals of concavity and convexity. In order to do this, I have tried to use the piecewise function, as shown on another question (http://www.mapleprimes.com/posts/43593-Piecewise--Color). However, I feel I haven't understood quite well how it works, as I can't figure out how to write the intervals... I don't know if I should show you my attempt, but I think it's quite ridiculous (I just have tried to adapt it to the example shown on the question I have read).
Thank you very much for your attention!
Have a nice day!
Skyblue
a.
charc := 1/exp(-(1/4)*i^2*X^2);
Density := int(exp(-I*X*u)*charc, X = -infinity .. infinity);
b.
charc := 1/(i*X/(exp(i*X)-1))^n;
c.
Density := int(exp(-I*X*u)/(((-1+exp(i*X)+p)/(p*exp(i*X)))^y*(1/exp(i*X))^n), X = -infinity .. infinity);
d.
Density := int(exp(-I*X*u)/(ln(exp(i*X))/(exp(i*X)-1))^n, X = -infinity .. infinity);
e.
charc := 1+i*X/(i*X-1);
Density := int(exp(-I*X*u...
Would you please send me the numerical laplace inversion code of "de Hoog" 1982?
i use previous post link to derive again for weibull, the final integration seems can not be integrated,
any things need to notice?
Weibull
WeibullDist := (η/rho)*((x/rho)^(η-1))*exp(-((x/rho)^η));
WeibullDist := 1-summation((η/rho)*((x/rho)^(η-1))*exp(-((x/rho)^η)),x=0..k-1);
WeibullDist := int((η*z)*(((k-1)*z)^(η-1))*exp(-(((k-1)*z)^η)),z=0..1/rho);
svp. Je suis débutant en Maple et je souhaite que vous m'aidiez à réaliser une courbe avec maple étant donné un ensemble de points, et non pas une fonction. Comment faire? merci.
Dear friends,
I used Maple 13 previously, now am trying to install Maple 16 (Windows 7, 64bit, 2GB RAM), installation is ok.
But when I start using the Maple, then I am getting an error message 'Waiting for Kernel Connection' and then Kernel connection not found.
I disabled the windows firewall, and then reinstalled Maple  16, and again I got the same error.
what can I do now? how to cross that? its urgent for me.
can someone write code to replicate this in maple.
Begin with a square and draw an octagon inside it, as pictured. Now draw a regular 16-sided polygon inside the octagon, like so
i'm guessing it'll use the polygonplot comand
expand(convert(simplify(GammaDensity, size),exp)),size)
www.stat.rice.edu/~dobelman/textfiles/DistributionsHandbook.pdf
i use the derivation of gamma in above book to derive density again, but fail
GammaDist := int((lambda^k)*(z^(k-1))*(exp(-lambda*z))/(k-1)!, z=0..t);
GammaDensity := diff(GammaDist, t);
GammaDensity := (b^a)*(x^(a-1))*exp(-x*b)/GAMMA(a);
Hi every one
I was wondering whether is it possible to make a subzone plot with in a zone or not?
some thing like this
Dear Maple users
I know how to plot surfaces in 3D. However now I have a special task: I want to plot a piece of a solid region in 3D, more precisely a transverse or logitudinal wave. I wonder if there is an easy way to do this in Maple? Any hint will be appreciated!
Erik
helo
i want an exaact answer(numeral) of an equation but I can't maple answer a realation that include sin,cos,root,z how can i simplify that to a number
Hi all.. Just purchased the maple 16 today. When i tried to enter a few equations, i relised that equals sign does not work for the equations. I tried '' ctrl+= '' but the letters on the screen get minimized that time. I just can't do the thning. My OS is win7. It does the job when it comes to calculate 2+3 or something like that. You get the answer when you press enter. But when it comes to variable eq.s like x+3=2 or 2x+3y=4 when you press enter, nothing happens. ıt just...
First 1646 1647 1648 1649 1650 1651 1652 Last Page 1648 of 2430
