I have a very difficult time finding things in the documentation.
I would like to see documentation for `<,>` and `<|>`, as in `<,>`(1,2,3,4).
If I write ?<|> in Maple I get
If I do ?<,> I get
However, there is no mention of the usage of the backticks.
Finally, if I do ?`<,>` I get
No mention of the use of `<,>`. I only know about this from a previous reply to one of my questions and now I have forgotten the details so I am trying to look it up but it's hard to find.
Dear Power Users, I tried to make a model in Maple but after several hours of struggling I need some help. Can someone tell me what I did wrong or explain to me what is the meaning of the maplemint comment on procedure (optimalisatie)? Thank you in advance.
DiLeoCasper.mw
Suppose I have a set of vectors, say S = {x+4, 3x-7}, a specific vector f = -5x + 10 and I would like to determine if f is an element of Span(S). By hand it's a rather simple process, check the consistency of the corresponding linear system. Is there a way to automate this in Maple? That is, define a vector space (using any finite vectors: polynomials, matrices, etc.) with some basis and check to see if a given element belongs to that space? Moreover, if it does belong, could we get the linear combination of the elements of the basis that produces the desired vector?
For the t output I need to show 1, 1.2, 1.4....2, my attempt is highlighted in green below
Can anyone assist please?
#Clear memory and load packages.
with(Statistics):
#Define vectors and variables.
actual:=<2,3.5136,5.8016,9.1136,13.7376,20>:
t:=<1,1.2,1.4,1.6,1.8,2>:
n:=6:
RMSE:=0:
#Perform a simple linear regression on the data.
P:=LinearFit([1,x],t,actual,x);
#Display the model errors.
printf("t    Actual P  Model P  Error\n");
for i from 1 to n do
   model:=subs(x=t[i],P):
   err:=actual[i]-model:
   RMSE:=RMSE+err^2:
   printf("%2d %7.4f% 10.4f% 9.4f\n",(i+(1/5)),actual[i],model,err);
#Display the root mean square error.
RMSE:=sqrt(RMSE/n);
#Plot the points and the model.
p1:=plot(t,actual,style=point,view=[0..7,8..26]):
p2:=plot(P,view=[0..7,8..26]):
display(p1,p2);
-HFloat(17.540266666666668)+HFloat(17.712)*x
Error, (in fprintf) integer expected for integer format
HFloat(0.7463867411787324)
Download Asst_4_Question_1f.mw
I have a lists within lists.  I needed to search for a specific element in the sub-list and need to extract each such sublist that has an element.
I am only familiar with the search tool. Could someone suggest a simple way to do this.
For example, I have the following.
s := [{f0(t, r) = 0, n(t) = n(t)}, {f0(t, r) = 0, n(t) = 0}, {f0(t, r) = 0, n(t) = 0}]
I need to extract the sublist that has n(t)=n(t) so only the first element of the list s.
I recently discovered the "Physics" package wich provides tools for manipulating abstract vectors (non-component).
In the "Physics:-Vectors", an orthonormal basis (i,j,k) is available and my main concern is how to generate arbitrary other 3D orthonormal bases to be able to calculate results in "vectorial form" without manipulating vectors' components.
To better explain my needs I have setup a kind of minimal example in the attached file where some questions are asked.
Thanks in advance for any feedback.
orthonormal-triads.mw
with(Physics)
with(Physics[Vectors])
Creation of 2 rotation matrices
dir1 := `<,>`(0, 0, 1)
dir2 := `<,>`(0, 1, 0)
seq(assign(cat(R, i), Student:-LinearAlgebra:-RotationMatrix(theta[i], eval(cat(dir, i)))), i = 1 .. 2)
print(R1, R2)
Matrix(%id = 36893490614987576012), Matrix(%id = 36893490614987577572)
whattype(R1)
Creation of  orthogonal unit "Physics:-Vectors" from previous matrices
x1_ := _i*R1[1, 1]+_j*R1[2, 1]+_k*R1[3, 1]``
y1_ := _i*R1[1, 2]+_j*R1[2, 2]+_k*R1[3, 2]
z1_ := _i*R1[1, 3]+_j*R1[2, 3]+_k*R1[3, 3]NULL
x2_ := _i*R2[1, 1]+_j*R2[2, 1]+_k*R2[3, 1]NULL
y2_ := _i*R2[1, 2]+_j*R2[2, 2]+_k*R2[3, 2]
z2_ := _i*R2[1, 3]+_j*R2[2, 3]+_k*R2[3, 3]
Q1: Is there a more elegant way of creating "Physics:-Vectors" from matrices ?
Now, suppose that we want to compute `&x`(`#mover(mi("x1"),mo("&rarr;"))`, `#mover(mi("y2"),mo("&rarr;"))`) : since `#mover(mi("y2"),mo("&rarr;"))` = `#mover(mi("j"),mo("&and;"))` we have `&x`(`#mover(mi("x1"),mo("&rarr;"))`, `#mover(mi("y2"),mo("&rarr;"))`) = sin(`#mover(mi("x1"),mo("&rarr;"))`, `#mover(mi("j"),mo("&and;"))`)*`#mover(mi("z1"),mo("&rarr;"))` and sin(`#mover(mi("x1"),mo("&rarr;"))`, `#mover(mi("j"),mo("&and;"))`)*`#mover(mi("z1"),mo("&rarr;"))` = sin((1/2)*Pi-`&theta;__1`)*`#mover(mi("z1"),mo("&rarr;"))` and sin((1/2)*Pi-`&theta;__1`)*`#mover(mi("z1"),mo("&rarr;"))` = cos(theta[1])*`#mover(mi("z1"),mo("&rarr;"))`
The cross product operator  `&x`(x1_, y2_) yields
cos(theta[1])*_k
(which is a correct answer) instead of cos(theta[1])*`#mover(mi("z1"),mo("&rarr;"))` because vector `#mover(mi("z1"),mo("&rarr;"))` has is not known as a unit basis vector.
Similarly, `&x`(z1_, x1_) yields -sin(theta[1])*`#mover(mi("i"),mo("&and;"))`+cos(theta[1])*`#mover(mi("j"),mo("&and;"))` instead of  `#mover(mi("y1"),mo("&rarr;"))` as it would be the case when computing `&x`(_k, _i) ?
Q2: Is there a way to declare new triads of "Physics:-Vectors" with properties similar to the provided triad _i, _j, _k ?
Q3: Is the code defining the canonical basis i, _j, _kavailable for inspection and inspiration to setup orthonormal triads ?
Q4: Is it possible to get a (column) matrix of the vector components ? The function Physics:-Vectors:-Component(y1_, n) can only get 1 component at a time and only in the canonical basis i, _j, _k.
with(Physics)
with(Physics[Vectors])NULL
After a proper definition of 2 new vector bases `#mover(mi("x1"),mo("&rarr;"))`, `#mover(mi("y1"),mo("&rarr;"))`, `#mover(mi("z1"),mo("&rarr;"))` and `#mover(mi("x2"),mo("&rarr;"))`, `#mover(mi("y2"),mo("&rarr;"))`, `#mover(mi("z2"),mo("&rarr;"))`, the position vector OM_ := l__1*x1_+l__2*x2_NULLNULL
l__1*x1_+l__2*x2_
projected on `#mover(mi("x2"),mo("&rarr;"))` would yield directly Typesetting[delayDotProduct](l__1, `#mover(mi("x2"),mo("&rarr;"))`.`#mover(mi("x1"),mo("&rarr;"))`, true)+l__2 instead of expand(OM_.x2_)
l__1*Physics:-Vectors:-`.`(x1_, x2_)+l__2*Physics:-Vectors:-Norm(x2_)^2
because of the unit vectors.
Download orthonormal-triads.mw
This used to work in Maple 2022.  Something is broken in 2023.
kernelopts(version);
`Maple 2023.1, X86 64 LINUX, Jul 07 2023, Build ID 1723669`
`The "Physics Updates" version in the MapleCloud is 1561 and is the same as the version installed in this computer, created 2023, October 20, 22:58 hours Pacific Time.`
U := Int(exp(-1/4*t - 1/4*x)*piecewise(x < -2, 1, x < -1, -x - 1, 0), x = -t .. 0);
Int(exp(-(1/4)*t-(1/4)*x)*piecewise(x < -2, 1, x < -1, -x-1, 0), x = -t .. 0)
Uval := simplify(value(U));
Uval := `simplify/piecewise/unfactor`(4*piecewise(t < 1, 0, t < 2, t-5+4*exp(`&ndash;`((1/4)*t)+1/4), 2 <= t, 1+4*exp(`&ndash;`((1/4)*t)+1/4)-4*exp(`&ndash;`((1/4)*t)+1/2)))
eval(Uval, {x=5, t=6});
`simplify/piecewise/unfactor`(4+16*exp(-5/4)-16*exp(-1))
Download simplify-piecewise-bug.mw
I just spent 5h trying to figure out why when I return a table from a procedure defined in an .mpl file, and then execute that procedure in a worksheet, I can't access the table entries by using regular ol' bracket notation.
I can see the keys and values by using indices and entries and passing in the return value of the procedure, but that's it.
I have tried using eval, and I have even tried reproducing my use case in a simpler worksheet to try to isolate the issue but the issue doesn't appear. I am working in an .mpl file within a larger Maple project. I have read about last name evaluation, and have tried using eval with a numeric second parameter. Nothing works.
The file is very small and contains one single procedure, and it doesn't import any other file.
When I get the return value from my procedure and print it out all I see is the name of the original table defined in the procedure and the subscript I am trying to access, but not the data.
Maddening.
 Could Maple confirm below Mathematica result (desirably without using the trick of adding 10^-20 to the values of "n") ?
 W[n_] := 1/(3 n Sqrt[Pi] Gamma[2 - n] Gamma[2 + n])*2^(-7 - 4 n) (3 256^
  n Gamma[2 - n] Gamma[-(1/2) +
    n] (8 n (-3 + 5 n + 2 n^2) Hypergeometric2F1[1 - n,
      2 - n, -2 n, 3/
      4] - (-1 +
       n) (4 (-4 + 7 n + 2 n^2) Hypergeometric2F1[2 - n, 2 - n,
         1 - 2 n, 3/4] - (-10 + 3 n + n^2) Hypergeometric2F1[
         2 - n, 3 - n, 2 - 2 n, 3/4])) -
 9^n Gamma[-(1/2) - n] Gamma[
   2 + n] (8 n (5 + 11 n + 2 n^2) Hypergeometric2F1[1 + n, 2 + n,
      2 n, 3/4] -
    3 (1 + n) (4 (4 + 9 n + 2 n^2) Hypergeometric2F1[2 + n, 2 + n,
          1 + 2 n, 3/4] -
       3 (6 + 5 n + n^2) Hypergeometric2F1[2 + n, 3 + n,
         2 (1 + n), 3/4])));
 Table[N[W[n + 10^-20], 20], {n, 1, 15}] // Rationalize
 (*{2, 14, 106, 838, 6802, 56190, 470010, 3968310, 33747490, 288654574, \
 2480593546, 21400729382, 185239360178, 1607913963614, 13991107041306}*)
Maple thinks the inverse Laplace transform of 1/(s+a) is exp(a*t).  It should be exp(−a*t).
This used to work correctly in Maple 2022.  Something got messed up in 2023.
with(inttrans):
exp(-a*t);
exp(-a*t)
laplace(%, t, s);
1/(s+a)
invlaplace(%, s, t);
exp(a*t)
Download laplace-transform-bug.mw
The following test program (Test.cpp) fails with.L + Test.cpp+, but not with plain .L, nor with gcc. It also does not tell me anything about why where it fails!
#include <string>
int Test(std::string x) {
cout << x << "\n";
 return 1;
Error in <ACLiC>: Executing 'C:\root_v6.28.06\bin\rootcling -v0 "--lib-list-prefix=C:\Users\snyde\BFROOT\ROOT\Test_cpp_ACLiC_map" -f "C:\Users\snyde\BFROOT\ROOT\Test_cpp_ACLiC_dict.cxx"  -rml Test_cpp -rmf "C:\Users\snyde\BFROOT\ROOT\Test_cpp.rootmap" -DR__ACLIC_ROOTMAP -I%ROOTSYS%\include -D__ACLIC__  "C:/Users/snyde/BFROOT/ROOT/Test.cpp" "C:\Users\snyde\BFROOT\ROOT\Test_cpp_ACLiC_linkdef.h"' failed!
Huh? Why?
I can't learn what's wrong using 'g++  -c Test.cpp' (outside ROOT)  as it compiles w/o complaint in that case.
Is there a way to get ROOT to tell us what it objects to?
Hi, I have a cable driven robot arm consist of three joint and four links driven by cables from three pulleys. Each joint conneted to each pulley by cables independently. When I use inverse kinematic steps in maple I get these messages :
MB := zModel:-GetMultibody('simplify' = true):
                     "Analyzing system..."
              "Performing constraint analysis..."
"The system has 6 degree(s) of freedom.  It is modeled using 6
   generalized coordinate(s) coupled by 0 algebraic constraint(s\
the problem is that I have six Generalized coordinates (3 joints + 3 pulleys) , I can find the inverse kinamatic of joint angles according to end effector position , the question is:
how can I apply it to pulley's angle?
I currently do extensive modeling that involves Monte Carlo simulations. This kind of analysis seems idially suited to parallel computing. To begin the process I have been following the teachings of chapter 15 of the Programming Guide 2023. As a first excersize I copyied the code on pages 583-584 and attempted to run it on my system. My Maple program is a 2019  Student Version running on anHP laptop using Windows11. The code yields an error code "Error, invalid input: add_range uses a 1st argument, lo, which is missing"
This is an exact copy of the ccode in the guide. Is there posibly a probem with my installation? I am willing to update and upgrade as may be needed. Any suuggestions how to procced?
Ray
Dear Maple experts
I face an issue in using ‘implicit plot’ or ‘inequal’ commands in the attached file.
I use three Maple procedures to make some simple calculations and draw an output. It is Firm Profit versus ‘alpha’. This graph is correct and makes perfect sense.
Then, I use ‘inequal’ command to compare the same outputs when ‘alpha’ and ‘delta’ change. There is a conflict between these plots and the above diagram. For example, P2 plot says
restartNULL
with(plots); with(RealDomain)
c := 1; cr := 0.3e-1*c; u := 1; sExp := 0.6e-1*c; s := .65*c; v := 3*cNULL
FirmModelPP := proc (alpha, beta, delta) local p0, xi0, q0, Firmpf0, G01, Recpf0, Unsold0, Environ0; xi0 := 1; p0 := min(s+sqrt((v-s)*(c-s)), delta*v+sExp); q0 := u*(v-p0)/(v-s); f(N) := 1/u; F(N) := N/u; G01 := int(F(N), N = 0 .. q0); Firmpf0 := (p0-c)*q0-(p0-s)*G01; Recpf0 := (sExp-cr)*xi0*q0; Unsold0 := G01; Environ0 := q0+Unsold0; return p0, q0, Firmpf0, Recpf0, Environ0, Unsold0 end proc
NULLNULLNULL
FirmModelFC := proc (alpha, beta, delta) local p00, xi00, q00, Firmpf00, G001, G002, Recpf00, Unsold00, Environ00, pr00; option remember; xi00 := 1; p00 := s+sqrt((v-s)*(c-s)); q00 := alpha*u*(v-p00)/(v-s); f(N) := 1/u; F(N) := N/u; G001 := int(F(N), N = 0 .. q00/alpha); G002 := int(F(N), N = 0 .. beta*xi00*q00/(1-alpha)); pr00 := p00-delta*v; Firmpf00 := (p00-c)*q00-alpha*(p00-s)*G001; Recpf00 := xi00*q00*(sExp-cr)+(pr00-sExp)*(beta*xi00*q00-(1-alpha)*G002); Unsold00 := alpha*G001; Environ00 := q00+Unsold00; return p00, q00, Firmpf00, Recpf00, Environ00, Unsold00 end proc
NULLNULL``
NULLNULL
FirmModelHmax := proc (alpha, beta, delta) local q, p, pr, FirmpfSiS, F1, G1, G2, G3, RecpfSiS, sol, UnsoldSiS, EnvironSiS, p0, OldSoldPrim, xi, h, ps, qs, prs, prof1m, prof2m; option remember; xi := 1; prs := ps-delta*v; prof1m := (ps-c)*qs+((1/2)*beta^2*xi^2*qs^2/(u*(1-alpha))-(1/2)*(1+beta*xi)^2*qs^2/u)*(ps-s)+(prs-sExp)*(beta*xi*qs-(1/2)*beta^2*xi^2*qs^2/(u*(1-alpha))); prof2m := (ps-c)*qs-(1/2)*(ps-s)*qs^2/(alpha*u)+(prs-sExp)*(beta*xi*qs-(1/2)*beta^2*xi^2*qs^2/(u*(1-alpha))); if alpha <= 1/(1+beta*xi) then p, q := (eval([ps, qs], solve({diff(prof1m, qs) = 0, qs = alpha*u*(v-ps)/(v-s), c < ps, sExp+delta*v < ps, qs < 2*u*(1-alpha)/(beta*xi)}, [ps, qs])[1]))[]; `h&Assign;`*(p-delta*v-sExp)/(p-delta*v); FirmpfSiS := eval(prof1m, [ps = p, qs = q, prs = p-delta*v]); RecpfSiS := (sExp-cr)*xi*q; UnsoldSiS := (1/2)*(1+beta*xi)^2*q^2/u-(1/2)*beta^2*xi^2*q^2/(u*(1-alpha)); EnvironSiS := q+UnsoldSiS else p, q := (eval([ps, qs], solve({diff(prof2m, qs) = 0, qs = alpha*u*(v-ps)/(v-s), c < ps, sExp+delta*v < ps, qs < 2*u*(1-alpha)/(beta*xi)}, [ps, qs])[1]))[]; h := (p-delta*v-sExp)/(p-delta*v); FirmpfSiS := eval(prof2m, [ps = p, qs = q, prs = p-delta*v]); RecpfSiS := (sExp-cr)*xi*q; UnsoldSiS := (1/2)*q^2/(alpha*u); EnvironSiS := q+UnsoldSiS end if; return p, q, FirmpfSiS, RecpfSiS, EnvironSiS, UnsoldSiS, h, OldSoldPrim, xi end proc
NULLNULL
NULLNULL
pltPP3A := plot('FirmModelPP(alpha, .35, .40)[3]', alpha = 0. .. 1.0, color = red, legend = "", style = pointline, labels = [alpha, "Firm Profit"], labeldirections = ["horizontal", "vertical"], symbolsize = 10, axes = boxed, symbol = box, numpoints = 10, adaptive = false, thickness = 1.0, view = [0 .. 1, 0 .. .18])
pltPP3B := plot([[0., eval('FirmModelPP(0., .35, .40)[3]', alpha = 0.)]], color = red, legend = ["PP"], style = point, symbol = box, symbolsize = 10, axes = boxed, view = [0 .. 1, 0 .. .18])
pltFC3A := plot('FirmModelFC(alpha, .35, .40)[3]', alpha = 0. .. 1, linestyle = [solid], color = black, legend = "FC", labels = [alpha, "Firm Profit"], labeldirections = ["horizontal", "vertical"], axes = boxed, adaptive = false, thickness = .7, view = [0 .. 1.0, 0 .. .18])
NULLNULLNULLNULLNULL
pltHmax3A := plot('FirmModelHmax(alpha, .35, .40)[3]', alpha = 0. .. 1.0, linestyle = [dashdot], color = brown, legend = [SiS(h__max)], labels = [alpha, "Firm Profit"], labeldirections = ["horizontal", "vertical"], symbolsize = 10, numpoints = 50, adaptive = false, thickness = 1.0, axes = boxed, view = [0 .. 1, 0 .. .19])
NULLNULLNULL
display([pltPP3A, pltPP3B, pltFC3A, pltHmax3A])
diffr2 := proc (alpha, delta) if not [alpha, delta]::(list(numeric)) then return ('procname')(args) end if; FirmModelFC(alpha, .35, delta)[3]-FirmModelHmax(alpha, .35, delta)[3] end proc
P2 := plots:-inequal(diffr2(alpha, delta) <= 0, alpha = 0 .. 1, delta = 0 .. 1, optionsfeasible = [[color = "Spring 1"]])
diffr3 := proc (alpha, delta) if not [alpha, delta]::(list(numeric)) then return ('procname')(args) end if; FirmModelHmax(alpha, .35, delta)[3]-FirmModelPP(alpha, .35, delta)[3] end proc
P3 := plots:-inequal(diffr3(alpha, delta) <= 0, alpha = 0 .. 1, delta = 0 .. 1, colour = "Orange")
Download ConflcitInequal.mw
SiS is superior to FC in small ‘alpha’s. But in the initial diagram, it is obvious that it should be the opposite!
Perhaps I am making a mistake in using commands. Would you please help me?
First 163 164 165 166 167 168 169 Last Page 165 of 2429
