Howdy
would like to know how to generate alternating series.
eg, we have an infinite (large number) number of coins all Heads up.
seq(H,i=100)=HHHHHHHHH.......
Now we flip every 2nd coin (to tails), eg HTHTHT.......
then flip every 3rd coin, eg HTTTHH........
what does it coverge to or does it....?
How to simulate this in maple?
I guess we could also use binary code.
I have equations of the form x=max( f(x,u,E) ), where x is the unknown "variable" to solve for, where u is the "control" variable that can be selected to maximize f, and where E is a parameter. These are all real, positive scalars on [0,1].
One of my objectives is to plot x against E, for those values of u that solve the maximization. In my problem, the optimal values of u are expected to be unique for a given value of E.
My approach was to define...
hi,
how we get exact solution of the given system of equations correspond to boundary conditions.
and how we can plot its solution?
>restart;
with(DEtools);
ode:=[(diff(f(eta), eta$3))+beta*((diff(f(eta), eta$2))^2-f(eta)*(diff(f(eta), eta$4)))+(1+lambda)*(f(eta)*(diff(f(eta), eta$2))-(diff(f(eta), eta))^2)= 0,diff(theta(eta),eta$2)+pr*(f(eta)*diff(theta(eta),eta)+Nb*diff(theta(eta),eta$1)*diff(phi(eta),eta$1)+Nt*diff(theta(eta),eta)^2)=0,diff(phi(eta...
assuming the skier is projected at an angle theta with respect to the horizontal over a landing incline sloped with an arbitrary angle phi :
xf = (vi*cos(theta)*t=d*cos(phi)
yf=(vi*sin(theta)*t-1/2*g*t^2=-d*sin(phi)
By eliminating the time t between these two equations and using differentiation to maximize d in terms of theta,
we should arrive at the following equation for the angle theta that gives the maximum value of d :
theta = 45° -phi/2  (Answer from a text book)
How can I handle that problem about ski jump with MAPLE  ?
In the Signal Processing Webinar there existed a few worksheets I would like to request,
Ultrasound Transmission through a Band Gap Medium + xls data
Coded Excitation Signal analysis
Acoustic Scattering
If anyone would be so kind to provide these worksheets?
Dear Sirs,
I am a post-doc working on the university and I am dealing with elliptic integrals together with Maple, nowadays. I am using for my computations en EllipticK(.) function and I need to know how this function computes its exact values for a given parametr of an elliptic modulus. Does it use some kind of a series(how does it pertinently look like?) or is it tabelated and consequently interpolated? Please, will you be so kind and could you give...
Dear Readers,
Given an expression for e.g. x^n+ y^3.5, how to extract the symbolic/floating point exponent, I tried with degree method but it fails whenvever there is symbolic or floating point exponent. Is there any alternative ?
Regards, Satya
I've plotted this graph, but it's supposed to be smooth, any idea what's happened?
I'm looking for several challenging projects for a Calculus II course using Maple which I'll be teaching in Spring 2013.  By challenging I mean that the project will have several steps including both conceptual and computational aspects.  I'd also like them to be suitable for group work if possible.  I'd be willing to devote from 3-5 class periods for each of three or four different projects.  Our Calc I and Calc II are five hour...
I'm trying to solve the effects (deflictions, tensions, etc) of a load on a timoshenko beam. It uses two partial diffential equations, wherein q is the load:
> PDE1 := kappa*G*A*(diff(y(x, t), x, x)-(diff(theta(x, t), x)))-rho*A*(diff(y(x, t), t, t))-q;
> PDE2 := E*J*(diff(theta(x, t), x, x))+kappa*G*A*(diff(y(x, t), x)-theta(x, t))-rho*J*(diff(theta(y, x), t, t));
The boundary conditions are that in the corners the moments (derative of theta...
Hi everyone i've tried to solve two coupled nonlinear ode but maple gives me these two errors can you help me with this?
ode1 := diff(f(x), x, x, x)+3*f(x)*(diff(f(x), x, x))-2*(diff(f(x), x))^2+g(x) = 0;
 ode2 := diff(g(x), x, x)+(3*10)*f(x)*(diff(g(x), x)) = 0;
 bcs1 := (D(f))(0) = 0, f(0) = 0, (D(f))(6) = 0;
 bcs2 := g(0) = 1, g(6) = 0;
 sys := {bcs1, bcs2, ode1, ode2};
 dsn := dsolve(sys, numeric);
 print(plots:-odeplot(dsn, [x, g(x)...
Dear Friends, I asked my question here http://stackoverflow.com/questions/13677399/why-this-program-cant-work and got one answer. I don't want to prove that if Maple is unable solve my problem or not, but want to know if you agree with the answer there. What can I do with this problem noted there which happened during teaching in the class and made me ashamed badly.
Best and Thanks.
Hey everyone. The last few days I work on a non-linear PDE.
U*`∂`(F(s))/`∂`(x) = -k*sigma*cos(theta)*`∂`(F(s)*kro(s)*`∂`(J(s))/`∂`(x))/(`μo`*sqrt(k/phi)*`∂`(x));
with boundary conditions: when x=-∞: s=swi       and
x=L : U*dF(s)+k*sigma*F(s)*kro(s)*`∂`(J(s))/(`μo`*sqrt(k/phi)*`∂`(x))
I need to plot...
with(LinearAlgebra);
CAb := <1, 1, 2;1, 2, 3;1, 3, 1>;
# Get the QR decomposition of CAb:
Q, R := QRDecomposition(CAb); R;
Error in R
Maple Matrix(3, 3, {(1, 1) = 1.7321, (1, 2) = 3.4642, (1, 3) = 3.4642, (2, 1) = 0., (2, 2) = 1.4142, (2, 3) = -.70710, (3, 1) = 0., (3, 2) = 0., (3, 3) = 1.2248})
MathCad Matrix(3, 3, {(1, 1) = 1.7321, (1, 2) = 3.4642, (1, 3) = 3.4642, (2, 1) = 0., (2, 2) = 1.4142, (2, 3) =...
I am trying to add an if statement to maple code for example if U(tk) less or equal to 4 then
the initial condition=0 else the initial condition=value .
I am getting this error:
Error, cannot determine if this expression is true or false: U(365)
 k := 0; B[1] := 0.001/365; B[2] :=0.002/365:
First 1653 1654 1655 1656 1657 1658 1659 Last Page 1655 of 2430
