Hi, I'm working on fitting model. For some reason is taking way too long to evaluate it actually hasn't finished it at all. Im running on i7. Thanks for any help. this is my code:
> X := Vector([0, 170, 0]);
> Y := Vector([0, 11, 56]);
Q(t) := -(36788*76)*(.28*K*p/(-p-exp(-r*t...
Hey all :)
W:=(x,t)->(8*R/Pi^2*sum((1/(2*n-1))^2)*sin((2*n-1)*pi/2)*sin((2*n-1)*pi*x/2*L)*(cos(c*(2*n-1)*pi*t/2*L)),n=1..infinity);
L:=0.25;
T:=2500;
rho:=0.01;
R:=0.005;
c:=sqrt(T/rho);
evalf(W); (this just comes up with W)
I have tried...
I'm having a little trouble displaying the desired solution when using what might otherwise be refered to as the 'symbolic toolbox' - I'm a matlab user..
The output from maple is great! so much cleaner than matlab in this instance. The problem I'm having however is displaying the solution of simple algebra pproblems
ex: I would like to verify my handcalculation of cramers rule.
Given
I am currently trying to integrate a long string of fractional sine and cos terms with a cos term on the denominator and other exponential multipliers, but all variables and coefficients are real (and I have put this assumption in Maple).
When I integrate them on Maple it is automatically simplifying the result using Euler's rule to give me a complex fraction with a complex numerator and denominator. This is not very helpful as I need to use the result in further calculation,...
Loading a customised package on my computer I can use all of its functions easily. But I am looking to find the maple code of the procedure that make this function works, I am sure there is a trick but I am struggling to find it. I researched online quite a bit without any success as the threads I found about making your own packages are too technical for me.
Would anyone know how to do that?
P.K
I can't solve probably very easy problem. How to plot a filled semicircle which is rotated across one axis by an angle alpha? I came to the solution which I don't consider as the best one (since e.g. it will not work for alpha=Pi/2*(odd integer)) and I believe someone of you will show me a better approach. Thank you in advance.
My solution:
alpha := (1/6)*Pi:
plot3d([x, y, y*tan(alpha)], x = -1 .. 1, y = 0 .. sqrt(1-x^2)*cos(alpha), axes = normal, labels = ["x", "y", "z"...
I made a prodecure:
with(numtheory);
divs:=proc(k)
local n,q:
for n from 1 to infinity do
q:=tau(n);
if k=q then break;
return [q,n];
[seq(divs(i),i=1..20)];
I have make it for i from 1 to 100 too, but it should work in five minutes. I think it should be made somehow with the integer factorization, but i can't realize it. Can someone help me?
Eryndis
hi,
is there a procedure to convert a number (or list of numbers) into its english equivalent?
eg
 1 = "one", 2= "two", ......, 100 = "one hundred"
Preben Alsholm now i take another dynamical system , i found 2 critical points , which one is saddle and other one has too involved eigenvalues , but didn't know how to plot the digrams you did in the worksheet ! i dont know how to define seq() .
 dy.mw
Fine a_{n} of sequence
Hello again Maple forums, it's been a while but I'm confident I came to the right place :)
I'm trying to fit our data (attached: maphelp.mw) to this function of Z:
-(1/2)*Zc^2-a*(Z-Zc)-b*(Z-Zc)^(3/2)-c*(Z-Zc)^2-d*(Z-Zc)^(5/2)+e*(Z-Zc)^3+f*(Z-Zc)^(7/2)
It has the linear parameters a-f...
First of all I'm French so excuse my English.
I have some questions about Maple 14 on MacOSX,
1- I want to use the "proc()" fuction with an "if" fuction in the "proc()" but it's not workink, I tested many display with the "print" command to evaluate where is the problem and now I can say that the problem is in the "if" fuction. Here his my worksheet :
> suite := proc (n) local u, k, i; u := n; k := 0; for i from 0 to 10 do print(irem(u, 2...
Can somebody, please, try this command in Maple 16 (or at best Maple 16.02)?
Student[Calculus1][FunctionChart](x*exp(1/x));
In Maple 15 I get the graph in about 1s, however in Maple 16.02 it loads about 20s and it is even not as perfect as is in Maple 15. Furthermore, when I try to evaluate
st:=time():
time();
it says that it lasted only 1-2s. There is some problem...
Assumption:f(x)=x^2+2x
how to solve f(x+1) according the assumption.
this question is going to be asked has been done several times by me but no answere is sent,but i do it again:
f(x)=sqrt(x+1)→domain(f):[1,+∞),range(f);[0,+∞)
how to solve them at the maple15
Hi, i'm trying to solve the following PDE in Maple:
First 1654 1655 1656 1657 1658 1659 1660 Last Page 1656 of 2430
