Which algorithm does the LinearAlgebra->MinimalPolynomial function use to compute the minimal polynomial of a matrix?
I just lost the result of a 20h calculation due to the last-name evaluation using tables. Consider that
t := table([1=2]):
s := t:
save s, "table":
read "table":
s[1];
evaluates to t[1]. The save command only...
How can I expand (1+x)^n, where n is a posive integer number?
How to solve it with Maple? The explicit and nonnumerical solution is required.
I have this matrix with coefficients that I need to estimate;
I get there after some simple calculations and I know that my matrix it´s equal to the zero matrix; I have something like:
A:=Matrix(3, 3, [5*a-4,  5*sqrt(a) *sqrt(b)-5, 7*sqrt(a) *sqrt(c)-6,
        8*sqrt(a) *sqrt(b)-5, 8*b-2,  8*sqrt(b) *sqrt(c)-9,
        4*sqrt(a...
Hello, i'm having a problem whit my code for Finites Differences, but I don't really understand why.
The principal error said this "
Error, (in fsolve) eq[2] is in the equation, and is not solved for"
The other errors come from this one, but the strange thing is my code work whit differents "h"
For example whit h=1 it works, but with h=2.5;0.5;0.1 It doesn't works.
Please help I'm kind of amateur whit Maple
To begin with, there may be some confusion about units, because in Maple units are an organizational tool and a dimension specifier.
I am trying to prepare a document using 2D. I am not experienced, but am using Help, Maple on the web, &c., extensively to come up to speed. I wanted to get rid of units expressed in [[]] because I am not used to seeing them.
I am
1. I'd like to subscript ESCS below, but cannot unless I use (z)
2. It would be nice to use "natural units" for ESCS(z)
3. It would be nice to remove nT outside the vector in BavgSCS
4. It would be nice to combine the units in EBPP
5. In B:=norm(), the |nT| causes future problems
For each result, I'd like to set the tolerance for zero to some value so that I don't get -0.0. For example, I might choose 10^-5 to be zero for one result and 10^-12 for another.
These notes are also in the attached file.Maple_primes_questio.mw
Dear Markiyan Hirnyk
From  Phase-space trajectories i mean below photo which the asterisk arecritical points. but how can i compute the critical points and their nature ( stable , unstable , saddle) with maple ?
Thank for your time
Jacobe
Thanks a lot Markiyan, and I am sorry I may have overlooked this already answered question. But, now I have just one more thing to know. On using AllSolutions = true in solve I get the answer as x = _z1~ ∏ / k, I then try to subs my fav symbol N instead of _Z1~, but Maple doesn't take it! It keeps it as it is. What kind of constant is this _Z1~, I had thought it to be the same as _C1, which is used by Maple while solving any ODE.
Reason why I want to...
I am using the function solve() to find roots of a trig. equation. Such as for sin(k*x) = 0, Maple retuns x = 0, whereas I expecting to get  x = n ∏/k, for n = 0,1,2,.... I am sorry I am new to Maple, can anyone help me get what I am looking for?
nonlinear_system.pdf
Has anyone seen this form of a nonlinear equation with respect to X, but linear with respect to Y & Z?  I provided a contour plot within the region for all 3 variables between -2 & 2.  The plot is actually Z*conjugate(Z) so that the magnitude is above ZERO.  If I am correct I may have seen this before in orbital mechanics, but my undergrad years are a bit...
 What justifies the t-1; to achieve this result?
interface(warnlevel = 0, imaginaryunit = I, rtablesize = 12);
with(plots); with(plottools);
alias(FFT = DiscreteTransforms[FourierTransform], IFFT = DiscreteTransforms[InverseFourierTransform]);
Temp := [24.2, 28.4, 32.7, 39.7, 47.0, 53.0, 56.0, 55.0, 49.4, 42.2, 32.0, 27.1];
POI := seq([n, Temp[n]], n = 1 .. 12);
 p1 := pointplot([POI], labels = ["x~month", "y = Temperature~ºF"...
I have enjoyed Maple computer algebra system as a platform for some work on prime constellations.  A summary of my work is here -
https://sites.google.com/site/primeconstellations/
At the bottom of the page are 3 relevant files and the filenames start with "A constellation"  Two of those files are .mw files.  The code searches the integers for solutions, and it works fine, but after about half a day, it consistantly crashes.  I...
How to plot a dynamical system as x' = f(x,y,z) , y'=g(x,y,z) . z'=h(x,y,z) ?
e.g.    x'=(x z )/y - x - 1
         y'=x y - 5 x z + y
         z'=( x z^3 )/y+( z^2)/y+6z
First 1656 1657 1658 1659 1660 1661 1662 Last Page 1658 of 2430
