Hello every one,
I want to plot two parameters against each other from a system of ode.
The system is
with(plots):with(LinearAlgebra):
Eq1:=diff(f(eta),eta$3)+f(eta)*diff(f(eta),eta$2)-diff(f(eta),eta$1)^2-M^2*diff(f(eta),eta$1)+M^2*b+b^2=0;
Eq2:=diff(g(eta),eta$3)+f(eta)*diff(g(eta),eta$2)+(Lambda-2*diff(f(eta),eta$1)-M^2)*diff(g(eta),eta$1)+diff(f(eta),eta$2)*g(eta)=0;
N:=10: M:=0.1:
bc:=f(0)=0,D(f)(0...
Dear friends,
I ran into another problem while using Maple to do residue calculus. The following call
residue(1/x^(1/3)/(x^2+2*x*cos(phi)+1), x=-exp(I*phi));
returns zero -- it does not recognize the residue. On the other hand, if I do a subsitution like this
subs(x=-exp(I*phi), 1/x^(1/3)/(x^2+2*x*cos(phi)+1));
followed by
convert(%, trig); simplify(%);
then I get a divide by zero error, which shows that the...
hi everyone,
I need to plot a graph for system of nonlinear equations with multiple variables.
here is some example of system nonlinear
f1=3.65a^2-2ac-7ad+3.65b^2+7bc-2bd-1.65a+6.22b+0.5=0
f2=13.22a^2-7ac+2ad+13.22b^2-2bc-7bd-6.22a-1.65b+0.24=0
f3=2c^3-2ac-7bc+2d^2+7ad-2bd-0.2=0
f4=c^2+d^2-1=0
with initial condition (0.7, 0.2, 0.6, 0.3)t. I solved this using Newton's method and here the iteration
I have a procedure which accepts arguments of a (created by myself) type which are records, like so:
Subs:=proc(eqn::seq(equation),elemt::Element,$);
Here "Element" is  type I have defined; it is a record with certain fields present.
My question: will this work with option remember? I have the procedure sort-of working without the remember option, but I need to make it work recursively (the Element record can have fields which contain names of other records of type Element...
For the following procedure how do I dynamically grow the array? Is an Array the right datatype for this task?
How to find the maximum of sqrt((x-1)*(y-x))+sqrt((7-y)*(1-x))+sqrt((x-y)*(y-7)) for x=-2..3,
y=0..11 with Maple?
Here are  a few unsuccessful attempts.
> Optimization:-Maximize(sqrt((x-1)*(y-x))+sqrt((7-y)*(1-x))+sqrt((x-y)*(y-7)),
 x = -2 .. 3, y = 0 .. 11);
Error, (in Optimization:-NLPSolve) complex value encountered
> maximize(sqrt((x-1)*(y-x))+sqrt((7-y)*(1-x))+sqrt((x-y)*(y-7)), x = -2 .. 3, y = 0 .. 11);
How to solve the inequality 3^((x+3)/(5*x-2))-4 >= 5*3^((9*x-7)/(5*x-2)) with Maple?
An exact and explicit solution is required.
I'm trying to solve system of linear and nonlinear equations with inequalities and it looks like this:
    SX := solve(
                       seq(diff(EX,WX[k+1])=0, k = 0..m), # these are linear
use the formula provided in
http://en.wikipedia.org/wiki/Hermite_polynomials
and run in Maple
Restart;
with(SumTools):
Hn := n!*Summation(((-1)^(n/2-l))/((2*l)!*(n/2-l)!)*((2*x)^(2*l)),l=0..n/2);
genfun := Summation(Hn/n!*z^n,n=0..infinity);
but result is not exp(2*x*t - t^2)
1. I use your previous reply on V_G derive  on other characteristic function, but most are undefined
or complicated solution or can not evaluate, why?
for example
charc := 1+i*X/(i*X-1);
int(exp(-I*X*u)*charc, X = -infinity .. infinity);
it got this complicated thing
piecewise(Im(1/i) = 0, undefined, int(exp(-I*X*u)*(1+i*X/(i*X-1)), X = -infinity .. infinity, method = _UNEVAL))
Density := int(exp(-I*X*u)*charc, X = -infinity .. infinity);
How do i show that i am a student before my liscence expires.
Does the current implementation of Maple has any any command to characterize the solution of a linear PDE system with m unknows (functions) and n variables?
I need a command that receives as input the PDE system and tells the nature of the solutions: k0 constants, k1 functions of 1 variable, k2 functions of 2 variables, ... , kn functions of n variables. I think mathematicians call this the Cartan character of the system (I am an economist).
I was reading and...
I'm running a 2D parameter sweep from Maple 15 on a MapleSim 5 model. The output is stored in a 2D matrix.  I've encountered two problems:
1) when I graph it with matrixplot the z-axis values are fine but I can't figure out how to change the x-axis and y-axis values from the matrix indices to the actual values of the swept parameters.
2) When the parameter sweep begins I get a warning about storing the values in a matrix.  Maple...
I have a large equation where i need to substitute a part by omega but it doesn't work.
To illustrate the problem i uploaded a simplified program showing the same problem.
I know i can do it manually but since i have a lot of these substitutions I would like to do it automatically...
thanks in advance!
In the simple equation f I want to substitute the sqrt(g)*sqrt(m+M)/(M^(3/2)*sqrt(l) by omega so the function becomes cos(omega*t)
x = a*(3*cos(t) - cos(3*t))
y = a*(3*sin(t) - sin(3*t))
is there a library or function to convert above parametric equations into one equation in terms of x and y?
sys := x = a*(3*cos(t) - cos(3*t));
k := solve(sys, t);
simplify(subs(t=k[1], y = a*(3*sin(t) - sin(3*t))));
any simpler form?
First 1652 1653 1654 1655 1656 1657 1658 Last Page 1654 of 2430
