I am trying to solve a tricky system of diff eq....can somebody point me in the right direction, the error message is involved with the initial conditions..
how do i add more buttons into my maplets
I have 2 column vectors I am trying to plot against each other. The vertical axis needs to be logarithmic.
If I say
plot(mass,map(log,pressure),style=point);
it works and I get all 19 points.
If I say
logplot(mass,pressure);
I get the correct scales in both directions (so nothing would be cut-off) but it plots only 4 points.The same happens if I use plot(...,axis[2]=[mode=log]);
The pressure values range from 1E-7 to 1E-12....
how do i write this procedure in maplet.
I am trying to solve a simple equation
x(0.0178){tan([2.10^-5](x)^0.5)}^2=+2.32.10^12-x, which I want to be solved over the range 1.10^10......2.10^12.
I have tried the following program (which I have got help on):
eq := x(0.0178)*tan²(Sqrt(x)*2E-5) = 2.32e12-x;
I have a function which Maple is happy to integrate from -100 μm to +100 μm,  but won't do between -60 μm and 100 μm.  Screenshot here:
 http://oi39.tinypic.com/34jdif9.jpg
The graph of the function reveals no obvious reason why it shouldn't be able to integrate from +infinity to -infinity (which I'd like to be able to do) and everything in between:
Hi everyone.
I have a system of differential equations with some parameters, and I need to numerically solve for several values of these. How can I do it in a simpler way than solving the system everytime declaring different values for the parameters?
And I need plots and quantities depending on the solution of the system.
Hope I made myself clear.
PS: It's maple 14 by the way.
Using the same post for a different question, also related:
How to solve the  partial derivative at a specified point
The latex code is
f(x,y)=x+(y-1)\arcsin\sqrt{\frac{\,x}{y}}
f''_{xx}(x,1)
Is it possible in maple to estimate a density using my own kernel function (Gamma; Beta, Exponential...) instead of the  default kernels ( 'gaussian', biweight, epanechnikov, triangular, rectangular)?
Hallo,
I have to estimate a logistic growth function, with the functional form
f(t)=A/(B+exp(-k*t))
The dataset is given by
X:=[1950,1960,1970,1980,1990,2000,2010];
which describes the values of t
and by
Y:=[2.53,2.76,3.12,3.75,4.2,4.3,4.35];
which describes the values of f(t).
I now have to estimate the values of A,B and k.
I tried NonlinearFit by
with(Statistics):
NonlinearFit(A/(B+exp(-k*t)),X,Y,t);
What do these parameters of Clutch mean,phi_nominal,w_small,k_locked?
And, how can I use them?
Anyone can tell me the detail?
I have something like E1:=y=x*b+z*a+c*i. and i want to solve for y/i. I try doing solve(E1,y/i) but it says i cant solve for an expression. is there a way to get around that?
Hi all.
I want to make a graphical application for a webpage, showing curves with a certain number of points on X axis (about 10 or 15), and some sort of “handles” on curve values (for every curve,...
I have a set of test equations. I am substituting the coefficients of the variables A1 ..A4 and the constants in the equations. Most of this I have made work fine. There are 2 coefficients I cand make be substituted. In eq1 k*d the coefficient of A3 and eq5 3.1d2 also the coeff of A3 .Have tried subs and algsubs but can't make it work. The reason I want to do this is in reality I have 15 equations...
1.msim
I want to compare two signals with relational block in Maplesim, i.e. greater or equal
The output signal should be a pulsed signal which represents the intervals where one signal is greater or equal to the second signal
How to do this
First 1736 1737 1738 1739 1740 1741 1742 Last Page 1738 of 2430
