[A]+[B] N+[C] N^(2)+[D] N^(3)+...N^(8)
[A],[B],[C],[D],... is known 8*8 matrix ;
how to find Eigenvalues and Eigenvectors and N?
eig([A],[B],[C],[D],...) ?!?!?
Hi there
I'm a new user of Maple 15 and would really appreciate some tips on how to get started, this time more specifically on how to change the axis orientation. I'm a geotechnical engineer and in practice we always plot all the soil properties (strength, density, water content, etc) with depth, and so it should be positive downwards.
I've seen a few posts where the issue was raised by some people years ago but was just curious to know if the new version...
I've got the following Maple math code (its called the 'Strickler function', giving a relation between water hight 'y' in a channel and other paramaters), that works like a charm and correctly outputs my function Q =
> restart;
> A := (b+m*y)*y;
> R := A/(b+2*y*sqrt(1+m^2));
> Q := k*A*R^(2/3)*s^(1/2);
However, all contants in the functions are know, except for 'y' (Q is known as well). How do I solve the last equation for...
My problem: Write the equation of the line (Delta) passing the point A(-2;3;4), perpendicular to the line
(l): x = -t + 1, y = 2t, z = 3t + 1
and have a distance from the point B(1;2;-4) obtain
a) maximum;
b) minimum.
Can you write for me a code? Thank you.
I would like to know how can I go out from two nested loops. I tried with the command 'break', but it go out only from the one loop. For example,
for i from 0 to 10 do
for j from 0 to 10 do
for z from 0 to 10 do
p:=i*j*z;
if p<=40 then print(p)
else break fi;
od; od;
I execue flow command,but it doesnot generate;
how i fix it?
> with(CodeGeneration);
> m:=diff(theta1(t),t);
> Matlab(m);
Warning, the function names {diff, theta1} are not recognized in the target language
cg0 = diff(theta1(t), t);
Hey guys !
I wondered if it's possible in maple to hundle functions, for exemple to know if a function is a sum or a product of two functions.
Is there a function like this : sum (\x -> x+3)  -------->  [(\x -> x), \x -> 3] ?
If I ask this, is because I want to know if it's possible de rewrite the function `deriv` or `integrate` or `simplify` by hands, without using the native functions.
Problem. Let A(-1,3,-2), B(-3,7,-18), C(2,-1,-3) be three points and (P):
2*x - y +z  + 1 = 0 be a plane. Find the coordinates of the point M lies on the plane (P) so that MA^2 + 2MB^2 + 3MC^2 obtain the minimum value.
This is my code.
restart: with(geom3d):
A:=: B:=: C:=:
M:=: o:=:
eq:=solve([seq(o[i] = (A-M + 2*(B-M) + 3*(C-M))[i], i=1..3)]);
point(T, -1/6, 7/3, -43/6); # put T by my hand
plane(P,2*x - y +z + 1 = 0,[x,y,z]):
how I import maple code in matalb for matlab simulink?
Hi,  I have and integral its results contains Beta function and hypergeometric function.
I found a difficulty to program the hypergeometric function with Maple 13. is any one can solve this problem
where
∫₀^{(π/2)}((sin^{α}xcos^{β}x)/(√(1-k²sin²x)))dx=(1/2)B(((α+1)/2),((β+1)/2))F(((α+1)/2),(1/2);((α+β+2)/2);k²),α>-1,β>-1,∣k∣<1
The problem in written...
simplify(sqrt(a+sqrt(b))*sqrt(a-sqrt(b))-sqrt((a+sqrt(b))*(a-sqrt(b)))) assuming a>0,b>0,a>sqrt(b);
It's mathematically zero but it does not return zero.
How can I simplify it?
4200000*(diff(T(x, t), t))-0.1e-2*(diff(T(x, t), x))^2-0.1e-2*(diff(T(x, t), x, x))*T(x, t)-.445*(diff(T(x, t), x, x))-158780+4200*T(x, t)-50000/(exp(x))^200 = 0
with boundry conditions:
u[0](0.3e-1, t) = 37
Problem. Let (P): 2x -y +2z + 9 = 0 be a plane and two points A(3,-1,2), B(1,-5,0). Find coordinates of the point M lies on (P) such that scalar product of two vectors MA and MB obtain  the minimum value.
I have a rather burly system of PDE that I need solved in maple.  It's a little complicated to explain the set-up, but I am solving for some coefficients of a function expansion where each coefficient is solved in terms of some other known functions.
Basically the problem is the technique and code works perfectly for another application, but it fails me here.  For one, when I try rifsimp(%,[a[0](x,y,t),b[0](x,y,t),c[0](x,y,t)]), it runs for...
How do you make a straight line defined over an x interval?
First 1774 1775 1776 1777 1778 1779 1780 Last Page 1776 of 2430
