> eqns := {(x[1]+1)^2+y[1]^2 = (x[2]-1)^2+y[2]^2, (x[1]-c[1])^2+(y[1]-c[2])^2 = (x[3]-1)^2+y[3]^2, (x[2]-c[1])^2+(y[2]-c[2])^2 = (x[3]+1)^2+y[3]^2, y[1](x[3]+1) = y[3](x[1]+1), y[2](x[3]-1) = y[3](x[2]-1), (x[2]-c[1])(y[1]-c[2]) = (x[1]-c[1])(y[2]-c[2])};
 /          2       2            ...
The variable A is a matrix in Maple. I need to show A, A^2, A^3, ....., A^19, A^20, and that i do by making a for loop:
for n to 20 do A^n end do
And it works and shows correct results..
But i want to show more than just the result of each step in the for loop.
The result right now is without variable name etc. How can i show more than just the result ? ...
I have changed the Typesettinglevel to extended.
Hello guys,
I am unfamiliar with maple and have problems with dsolve complex system:
dz*_i/dt=sum(sum(z_i-z_j),j=1..2),i=1..2).
where i not equal to j and z* is conjugate(z).
here is my code:
for i from 1 to 2 do
summ(i)=0
od;
for j from 1 to 2 do
if i <> j then
summ(i)=summ(i)+(z_j(t)-z_i(t));
end if
od;
od
Dear Forum
I'm trying to evaluate the following expression:
Int(Int(Int(N*exp(-alpha*r^2)*N*exp(-alpha*r^2)*r^2,r=0..infinity) *sin(t), t=0..Pi),p=0..2*Pi)
The value of the integral should equal 1 and from that the value of the normalization constant N can be obtained. It should equal sqrt...
ggg:=(y,a,b)->
(2*(-a+6*y^2*a^2+2*b*y^2*a^2+9*b*y^3*a+3*b*y^2*a+b*y^6*a^2+4*b*y^5*a^2+5*b*y^4*a^2+2*b*y^5*a+8*b*y^4*a+3*b*y^3*a^2+4*b*y^2-y^3*a-3*y^2*a+y^6*a^3+5*y^5*a^3+8*y^4*a^3+4*y^3*a^3+y^5*a^2+5*y^4*a^2+9*y^3*a^2+b*y^4+4*b*y^3+y*a^2+2*a*b*y+y^3*a*(y+1)^(-2*b)+a*(y+1)^(-2*b)+3*y^2*a*(y+1)^(-2*b)+3*y*a*(y+1)^(-2*b)-2*y^2*a^2*(y+1)^(-2*b)-y*a^2*(y+1)^(-2*b)-3*y*a-y^3*a^2*(y+1)^(-2*b))/(y^2*(a+b)*(y+1)*(y+2)^2*(y*a+1)^2)+(-2-y^2+2*y^2*a^2-2*y+4*b*y^3*a+8*b*y^2*a+2*b*y^4*a^2+4*b*y^3*a^2...
I'm trying to use the geometry module. I tried the following code:
> with(geometry);
> point(A, xA, xB);
A
> point(B, xB, yB);
B
> line(AB, [A, B]);
line: One of the following conditions must be satisfied xA-xB <> 0 xB-yB <> 0
Error, (in geometry:-line) not enough information: the line is not defined
As you can see, maple is unable to create the line object since the two points can be the same....
calchas:~ sedoglavic$ maple
    |\^/|     Maple 14 (APPLE UNIVERSAL OSX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2010
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> 264 ;
I have downloaded the quaternion package in Maple but I can't figure out how to plot them. According to the help page I need a package 'with(Plots)' (with a capital P for plots). Has anyone had any success in plotting quaternions? I'd really appreciate some help.
What is the total number of the nonnegative integer solutions of the system
{x+2*y+5*z-10^2012<=0, x+3*y+4*z-10^2012<=0}?
Edit. Bad copy and paste and  the tags.
What is the total number of the natural solutions of the equation
2*x+3*y+5*z+8*t-10^2012 = 0? How to find it with Maple?
Is there some way to shade in the region between the red and blue curves?
implicitplot([y = (1/5)*x^2+5, y = (1/20)*(x-5)*(x+3)*(x-10)+30, x = 2, x = 10], x = 0 .. 12, y = 0 .. 40, color = [red, blue, black, black], thickness = 3)
I tried this, but it doesn't seem to like having the x's and y's in the z range.
 implicitplot3d(x = 6, x = 1 .. 7, y = 2 .. 5, z = 0 .. (1/4)*(x-4)^2+(1/5)*(y-3)^2+10
  , view = [0 .. 8, 0 .. 8, 0 .. 20], transparency = .5, style = hidden);
Error, (in plots/iplot3d/implicit3d) bad range arguments x = 1 .. 7, y = 2 .. 5, z = 0 .. (1/4)*(x-4)^2+(1/5)*(y-3)^2+10
I'm trying to plot a surface above the xy plane that looks like a solid,...
Which algorithm does maple follow for singular value decomposition by command 'SingularValues' in LinearAlgebra Package ?  Is it is QRSVD or divide and conquer or any other   .As far as  I know, MATLAB uses QRSVD.
Dear Maplers
I would like to define a component in MapleSim, which is difficult to write with a single equation, but rather it would be defined with a bunch of equations (a procedure). Can it be done programatically, i.e. can I write my own code (procedure) in Maple programming language to define the component? Or should I subdivide the problem to smaller steps (equations) and define a component for each of them? What would be the best way? Could you possibly give an example?
Hey
I have this spring setup:
spring setup
Now I wan't to analyse the motion of the springs, so i create this equations:
First 1799 1800 1801 1802 1803 1804 1805 Last Page 1801 of 2430
