I need Maple to evaluate something quite complicated with Groebner:-UnivariatePolynomial
When do I know that maple is at a point where it should be terminated instead of being left to run?
Is the output's length proportional to the amount of time used to calculate it?
RC_1D.msim
Dear Community
I'm a newbie in MapleSim trying to run a simple RC circuit simulation. Unfortunately I get the error message "system inconistent, simulation failed", but I have no clue why. I've uploded the model. I'm trying to withdraw a constant current of 0.1A from capacitance C6. I do certainly something wrong. I would be grateful if you could have a look, and help.
Tx. in advance, best regards
One thing I have always found interesting is that exponential growth/decay
is not symmetrical hence:
100*(1+0.01)^2+100*(1-0.01)^2-200 = 0.0200
For example:
If you start with 100 and bet 1% and you win and then again bet 1% of your portfolio value
and you win again your portfolio value will be PW=100*(1+0.01)^2.
If you start with 100 and bet 1% and you lose and then again bet 1% of your portfolio value
and you lose again your portfolio value will be PL=100*(1-0.01)^2. ...
           Which Platonic solids can be obtained as the intersection of the 4d cube   -1<=x1<=1, -1<=x2<=1,-1<=x3<=1, -1<=x4<=1 and a 3d hyperspace A*x1+B*x2+C*x3+D*x4+E=0 (A^2+B^2+C^2+D^2<>0) in R^4? How to find it with Maple?
I'd like to increase the vertical space for the x-axis and horizontal space for the y-axis, between the tick marks on the axes and the labels (e.g. 1, 2, 3, etc.) of the tickmarks.
Is there a way to do this?
Thanks for any help!
I would like to set an axis to logarithmic scale, after having loaded the Units[Standard] package.
The command is:
plot3d( function(input), x=-1..1, y=1..1, axis[3]=[mode = log] )
Confoundingly, the error is:
Error, (in plot3d) expecting option mode to be of type identical(linear, log)
 but received Units:-Standard:-log
So the problem is that with(Units[Standard]) hijacks all occurences of log and replaces them with...
Hey there
I got a little problem.
I would like to have the positive numbers on the y-axis to point downworth, and of couse the negative going upworth. Is that even possible?
Hope you can help.
Consider the following two functions, one of which is defined using a differential operator:
DO:=(f,x1,x2)->(sqrt(2)*x1+x2)*D[2](f)(x1,x2)-x2:
a:=(x1,x2,o)->1:
b:=(x1,x2,o)->simplify(DO((x1,x2)->a(x1,x2,o),x1,x2)):
b(x1,x2,o);
The Maple output is (D[2](f))(x1, x2)*sqrt(2)*x1+(D[2](f))(x1, x2)*x2-x2*D[2].
Why does this output contain the variable f, which should be substituted by a?
hi all,
To create an observability grammian I have to integrate a matrix with some equations that are difficult to integrate due to multiple time dependent variables. The simplest expression in the matrix is:
z1^2 * sin( z5 * t)^2          (1)
where z1 and z5 are from a state space model with 5 states and are given by:
z1dot = z2     ...
This is somewhat related to the interactive stock quote importer.
The TSX, DOW jones industrial average, FTSE 100, Heing Seng indexes are all a collection of stocks and their index reflects the movement of those stocks.
The Dow Jones Industrial average is designated ^DJI in finance.yahoo.com but that symbol is not available in the download.finance.yahoo.com from the interactive stock quoted importer.  Is there perhaps a way I missed...
I am having trouble extracting one part of a return of a solve.
> relatie := CD^2 = (AB+BC*cos(beta)+AD*sin(alpha))^2+(BC*sin(beta)-AD*cos(alpha))^2;
> vergelijking := solve(relatie, beta);
the solve seems to return 4 expresions and the data type is exprseq. I only need the first expresion (till the first comma) I tried using temp:=vergelijking[1] but that still contains 2 parts separated by a comma.
Has anyone gotten Wigner Rotation to work in Maple. My implementation based on a formula derived in Edmonds, which is equivalent to whatever is on wikipedia, just isn't working. And I don't know where the problem lies. I know for sure that my z axis rotaition works. But I guess my Y-axis rotation is failing for some reason. I'm sure that it matches the formula. I do a Z-Y-Z rotation, so the resulting rotation matrix is real.
Ideas? Thanks fo any help you can provide!
Why does it give a error? I don't get it and I'm frustrated! Thanks a lot!
> restart; Digits := 4;
Verplaatsing (s) achteras naar hoek alpha
> AG := 382.5; AB := 45; BC := 369; CE := 117; EF := 108; GE := 135; CD := 238; FG := 36; BG := 346.5; DF := 222.8;
> rc := Vector(2, {(1) = 0, (2) = 0});
Vector[column](%id = 213058548)
> rcb := Vector(2, {(1) = BC*cos(alpha(t...
Hello guys I'm writing to you becouse I have some problem with miktex and maple.
I exported Maple workshed to tex file, but when I compiled  pdf by Winshell or TexnicCenter I have big problem.
The pdf file looks that:
I dont know why. I did some things ( copy ETC files from Maple to my document folder) but it's dosent help. I red some website and they are writing that:
"The MikTeX installer will create 2 directories that you should know the locations of: texmf and localtexmf. By default, these directories are created as
c:\texmf
c:\localtexmf
You are given the option of creating the second one (localtexmf), and I highly recommend that you do, especially if you plan on creating PDF files from Maple. "
But I can't find texfm or localtexfm on my PC
What should I do?? Please help me !  I need this to my graduate project
Best regards ( Sorry for my english)
Hi Colleagues
I made a worksheet program in Maple 12 then i want to print it as a PDF file but i want to add header and page numbers. How can i do that??????
First 1821 1822 1823 1824 1825 1826 1827 Last Page 1823 of 2430
