Hi, I have been given a question that involves plotting the sloutions to an equation over the range 0<><>
question is : with(combinat): sum(numbcomb(80, x)*numbcomb(100, 27-x), x = 1 .. 27)
this cannot get the answer rather than add
of course the following is ok
tot := 0; for x to 27 do tot := tot+numbcomb(80, x)*numbcomb(100, 27-x) end do: tot
Dear Maple users
Often I use Maple for solving problems in Physics. Maple does indeed a nice job when calculating expressions containing units. However when I want to plot functions containing units it sometimes work and sometimes not. Look at the following example:
I'm using the commands:
RungeKutta(d/dt(y(t))=-y(t),y(0)=1,t=1,submethod=rk4,output=plot,numsteps=10);
Euler(d/dt(y(t))=-y(t),y(0)=1,t=1,output=plot,numsteps=10);
Each of these commands yields its own serperate graph.  How can I plot both on graph to see how the approximations vary?
I am presented with a list of known roots to a polynomial. How can I reconstruct the original polynomial with a variable "x"  from the given roots?
The list of roots is: [-1/2,2/3,7/3,4+3I,4-3I]
I have the following function:
y(t) = _C1*exp(-2*t)*sin(6*t)+_C2*exp(-2*t)*cos(6*t)
My start parameters are y(0)=1, and y'(0)=2
How do I isolate _C1 when y(0)=1?
My code works fine when not part of a procedure it is only until I turn it into a procedure when I have problems. After running the proc once I get:
"Error, (in opt) cannot determine if this expression is true or false: min(`.`(Transpose(Vector(1, {(1) = 7})), ..."
Strangely if I execute the proc() code a second time and try again I get an answer out. Any suggestions as to how I can solve this problem?
I have (which I believe is where the problem lies),
Hi have made my first package in maple, and need some help. I've got a funktion, and need maple to put something into this function..
Dams := proc (a, b, c)
local A, f;
 f(x) := a;
printf("\nDin funktion er %a", f(x));
 A := diff(a, b);
printf("\nDen differentierede funktion er %a", A);
use x = c in f(x);
 printf("\n%a i ligningen ", f(x));  ...
I found in the help a reference that animation in uniparametric:
"plots[animate] - create a 2-D or 3-D animation on one parameter".
I need multiparametric animate. If it does not exist..it would be difficult to find somewhere the procedure written to get ANIMATE( for one parameter)?. If available, maybe it would be hard but possible to get something that performs a multiparametric animate.
Otherwise, if somebody knows that in MAPLE is impossible to implemente...
In the name of God
Dear my friends
Can Maple work with differential operators without introducing a known function?
For example, assume that we have
diff(diff(f(x),x)+f(x),x);
How can we apply differential operators such as diff or D without applying any known function as:
diff(diff(...,x)+...,x);
if...
I have two issues.
if I say
int(exp(I*k*x),x=-Pi..Pi) assuming k::integer
Maple answers me with
which is wrong, as one would expect the result to be a kronecker delta (k=0 is a type-integer for mapel). Is there a way to make Maple understand it is doing a mistake?
Related to this there is another point.
If I write
int(exp(I*(k-q)*x),x=-infinity..infinity)
Maple does not write (or convert) the result...
In the name of God
Dear my friends
 I have a function as the following:
 temp:=phi(Lambda(tau, 0), tau, 0)+((D[1](phi))(Lambda(tau, 0), tau, 0)*(D[2](Lambda))(tau, 0)+(D[3](phi))(Lambda(tau, 0), tau, 0))*q;
 I have equivalent functions for Lambda(tau,0) and phi(Lambda(tau,0),tau,0) as the following:
 c[0](tau) instead of Lambda(tau,0)
y[0](c[0](tau),tau) instead of phi(Lambda(tau,0),tau,0)
Is there a simple way to allow for the input of a list of equations into a procedure?
I have these three equations:
f[1] := x[2]+3*x[4]+x[5]-x[6]=2;
f[2] := x[1]+2*x[2]-x[3]+x[4]+3*x[6]+x[7]=13;
f[3] := x[1]+x[2]-3*x[3]-x[4]+x[5]-x[8]=26;
Ideally I would want something like proc([f[1],f[2],f[3]]). Is something like this possible?
P.S. I have tried proc(f::algebraic) but got the error message:
Error, invalid input:...
I try to get the answer of int by newton cotes method,
but after runnig,it gives a complex number for the answer.
I think its because of singular point.
Is there any method which find singulaitis and make integarl to some parts without that singular point automatically?
First 1922 1923 1924 1925 1926 1927 1928 Last Page 1924 of 2431
