i am wondering if anyone can give me some examples of functions that would help show the relationship between smooth functions and convergence of the fourier series so that i can graph these functions using maple over the period [-Pi,Pi]
Caitlin
I have 2 equations... f[1] := x[2]+x[3]+x[5]+x[6]=16; and f[2] := x[1]+x[2]-x[3]+x[4]+3*x[6]+x[7]=28;
Is there a method that will allow me to count the number of equations?
Is there a method to display the indeterminants or variables which are in the equations i.e x[1],x[2],x[3],x[4],x[5],x[6],x[7]?
Is there a method to find the maximum indeterminant or variable from both the equations i.e x[7]?
Dear Maple helpers. Here a toy-version of my huge problems.
I want to do following:
1). Assuming (0 <a=1/2,  b=1/2, c=1/2)
I want  to plot (the surface of)
f(x,y,z) = x^a * y^b * z^c   in the space (x,y,z) for
f(x,y,z)=50, 100 and 150, and with  x=0..40 ,  y=0..40, z=0..40
I tried with plot3d but it is not possible.  How could I do with Maple 14?...
I have a problem changing a maple matrix to a matlab code without getting the error
Error, (in PrintTarget) assigning to a long list, please use Arrays ( I don't know how to use arrays ) thanks Big in advance
Here is my code:
> J[p1] := Matrix(3, 4, {(1, 1) = -sin(theta[1](t))*`&Delta;x`[1]-cos(theta[1](t))*`&Delta;z`[1], (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (2, 1) = cos(theta[1](t))*`&Delta;x`[1]-sin(theta[1](t))*`&Delta;z`[1], (2, 2...
I tried solving the following equation but when i do i get
> solve((500*.87)*(1-(1/x)^.2385)-(288*(x^.3174-1))/(.85), x);
Is it not possible to solve for highly nonlinear equations ?
Hola;
one short question:
 How to apply random permutations of data within an matrix.
<a,b,c;d,e,f> --Shuffle-->
It was mentioned in the post that Maple can not solve some oscillatory integrals, mainly this one
int(cos(log(x)/x), x = 0 .. 1)
int(cos(log(x)/x), x = .001 .. 1) is okay
but we find that when we go from 0.0001 .. 1 Maple endlessly evaluates.  It seems as soon as we hit that 4th decimal there appears a problem.
int(cos(log(x)/x), x = .00001 .. 0.0001) won't work either.  Oh, this is...
i want to use numerical technique to solve non linear ode.
are there some built in numerical techniques in maple13.?
kindly name few and there syntax.
i have seen that we can solve linear ode numerically. how can i check that what technique does maple use?
I have functions f(x,y) and g(x,y).
How can I plot the dependencies of f on g for different x and y?
If I had only f(x) and g(x), than I could use plot[parameric] like it's shown in Help page
plot([sin(t), cos(t), t=0..Pi]);
I would prefer 2D plot, if possible.
I want to use the values of the solutions of
sol := solve({x+y=a, x-y=b}, {x,y});
I would like to be able to continue some symbolic computationg, for example
dernier:= sol[1]/sol[2];
but I get an error message.
How can I take only the values of x (and not the expression x= something) to compute, for example "dernier"?
Thanks in advance,
I have alot of figures but i have problem to convert the figure to latex. when i use export as eps, i get problem that the border of figure become inside the figure and the label of x, y for figure become outside.
when i remove the border of the figure. there is other problem when i convert to latex, the distence between the  figure and my writing very large.
 could you please give...
Thanks for the reply; It was very close to what it is needed, but I have another question.
In that post, first a recursion is found using "listtorec" and then that recursion is solved using "rsolve"
Isn't there any way to generate the sequence from the recursive formula without solving? because solving is not necessary, as long as you have recursive formula and the base cases, sequence can be generated ....
//Mehrdad
Now I've joined the club too...
Attached file gives me this error when I try to open it: "There were problems during the loading process.
Your worksheet may be incomplete". Mads_Anthon.mw
I've looked through the source code but I can't find the issues. Can any of you guys help me?
Thanks you so much
Best
Mads
I am a student from Sweden; Concerning a project about integer sequences, I have a question about Maple and Integer Sequence recognition.
I am trying to find a command in Maple capable of identfying and recognizing integer sequences as appear in IQ tests or any general form of integer sequences. For example, Wolfram Mathematica has a command named "FindSequenceFunction" as descibed here: http://reference.wolfram.com/mathematica/ref/FindSequenceFunction.html
First 1923 1924 1925 1926 1927 1928 1929 Last Page 1925 of 2431
