Hello everyone!
I am stuck after browsing my book and the help section for some time.
How can I find the value of a term like (with MAPLE syntax)
exp(x) for x=1,2,..,5 ?
I'm looking for something like matlab's k=1:5; operation.
Creating sequences or arrays/vectors didn't help.
Thank you for your time if you read this.
I have recently upgraded to Maple 14, and I can no longer cut and paste syntax between components when I am editing their properties.  Is this normal, or do I have to adjust a setting?
Phil
example.7.mwI have a question for a long time.
For some dynamic systems, I want to extract the matrices or the transfer functions which maple had yielded as a table. The table contains matrices or transfer function.
I want to extract them for other purposes, for example,using transfer function to plot its step response.
Now, is there any way to do this without retyping them manually? Becouse...
I'd like to modify the form of this expression
Code:
den := 1.*omega^4/omega[n]^4+1.-2.*omega^2/omega[n]^2+4.*epsilon^2*omega^2/omega[n]^2
To manage to have this form.
I have the function,
f:=5000/(1+99*exp((-0.8*t)));
and I would like to find it's inverse....how can I do this?
hi
I want to get points from plot for example I have a graph like y=x but I do not know its function I want to get just some points from that like [1,1] ,[2,2] and the others but I dont know how?
the second problem which I have is I cannot show points like [1,2,2] by plot,it shows just 2D not 3D points.
I mean x=1,y=2,z=2
plot shows just 2D like x=1,y=2
thanks for your attention.
I have an BW image, which i can read in with ImageTools. now i simply want a histogram of it. the plothistogram function works, but i am not sure that it does right, because the numbers in the plot seem far to big. so i am trying to use the histogram function but i am only able to plot a histogram for a single vector of my image. is there an easy way to use the histogram function for the entire array? as the next step, i would like to compute the variance of the histogram....
Is there a Maple procedure that generates all possible partitions of a given set? For example, for the set {1,2,3} it should give {1,2,3}, {1,{2,3}}, {2,{1,3}}, {3,{1,2}}, {{1,2,3}}.
If not, how could I write one?
Consider the following simple calculation with Ore algebras:
DA:=Ore_algebra[skew_algebra](euler=[theta,z]):
Ore_algebra[skew_power](sqrt(3)*theta,2,DA);
Error, (in Ore_algebra:-skew_power) skew polynomial must be member of the algebra
The error is due to the square root which is not recognized as a member of the algebra even though it is only a number. There seems to be no option to remedy this issue. Is there another solution ?
I made a model in MapleSim(Fig 1).
Here is the custom element named 'FcF' among the model. Its equation is defined as Fig 2.
I analyses
the model in Maple, the part related with the equation of FcF is shown
as Fig 3.
 I want to solve  matr.mw  for matrix A and B. Although it has 7 equations and 7 unknown parameters, but  doesnt have any result
Reza2961
I made a model in MapleSim 4, and an error occurred after I pushed the
button of 'simulate the model'.Maplesim froze at the step named
'CreateDataRecord: using dsolve method=rosenbrock_dae'. But it was Ok
when this file was simulated in Maplesim 3.
Is here anybody met the same problem?
question.mwWhen I sloving an exercise in my textbook using maple,I had a difficult.
First,I write the differential equation, deq:=[...];then using command,sys1:=DiffEquation(...);I want to get the system transfer function,so I use command tf:=TransferFunction(sys1),but it returns an error[Error, (in DynamicSystems:-TransferFunction) cannot handle input with frequency variable, s].
Then,since TransferFunction...
I always change text color, and I want the color in math mode to be the same as the text mode.  Is there a way to do this automatically?  The math mode always comes up in black, even if the previous text was red etc...
My problem that i just simlply can`t start Maple 12 under Windows 7 x64 in classic worksheet mode.
I like that much and i tried the suggested maplew.exe -cw but i got the same fancy window what i get starting just maplew.exe.
I need help and thank you.
First 1951 1952 1953 1954 1955 1956 1957 Last Page 1953 of 2431
