there’s few redundant values. I just want the positive values. How it can be done?
n := [80, 79, 83, 84, 83, 83, 81, 85, 86, 86, 83, 82, 83, 84, 81, 80, 83, 79, 82, 81, 85]
nops(n)
21
for i from 3 to 17 do f[i] := n[i-2]-3*n[i-1]+3*n[i]; i = i+1; f[i+1] := n[i-2]+4*n[i-1]-6*n[i]+n[i+1] end do
92
3 = 4
-18
82
4 = 5
-10
80
5 = 6
4
84
6 = 7
-1
77
7 = 8
14
95
8 = 9
-17
84
9 = 10
-9
85
10 = 11
-4
77
11 = 12
14
83
12 = 13
9
86
13 = 14
-3
85
14 = 15
-9
74
15 = 16
13
81
16 = 17
11
90
17 = 18
-18
Download fyp_2.mw
I am exploring the Grading package in Maple, and I want to create a random question about limits. (Question 9). Any ideas for the correct code? Thank you
QUIZZTestMaple.mw
I learned about Dodgson calculation of the determinant only recently (https://en.m.wikipedia.org/wiki/Dodgson_condensation).
I am only interested in symbolic expressions of the determinant.
Furthermore, I compared several methods. Not surprisingly, the build in method is the fastest. But why is the seq method slower than the proc method for the Dodgson method? Is there anything I could do to program it more efficiently?
restart; with(LinearAlgebra)
with(combinat); with(GroupTheory)
DetDef := proc (A) local i, n, sigma; description "Jeremy Johnson. Downloaded from https://www.cs.drexel.edu/~jjohnson/2016-17/winter/cs300/lectures/determinant.mw"; n := RowDimension(A); add(PermParity(Perm(sigma))*mul(A[i, sigma[i]], i = 1 .. n), `in`(sigma, permute([`$`(1 .. n)]))) end proc
InnerMatrix := proc (M::Matrix) SubMatrix(M, 2 .. RowDimension(M)-1, 2 .. ColumnDimension(M)-1) end proc
MatrixDet := proc (M::Matrix) local C, n, i, j; n := RowDimension(M)-1; C := Matrix(n, n); seq(seq(assign('C[i, j]', Determinant(M([i, i+1], [j, j+1]))), j = 1 .. n), i = 1 .. n); return C end proc
Dodgson := proc(M::Matrix)
 MatrixDet(M);
InnerMatrix(M) ^~ (-1) *~ MatrixDet(MatrixDet(M));
do if 1 < RowDimension(%) then InnerMatrix(`%%`) ^~ (-1) *~ MatrixDet(%);
until RowDimension(%) = 1;
Trace(%):
end proc:
Dodgsonseq := proc (E::Matrix) local w, dim, Z; dim := RowDimension(E); Z[dim] := E; Z[dim-1] := MatrixDet(E); Z[dim-2] := `~`[`*`](`~`[`^`](InnerMatrix(E), -1), MatrixDet(MatrixDet(E))); seq(assign('Z[w-1]', `~`[`*`](`~`[`^`](InnerMatrix(Z[w+1]), -1), MatrixDet(Z[w]))), w = dim-1 .. 1, -1); Trace(Z[1]) end proc
LaPlace := proc (M::Matrix) local c; add((-1)^(c+1)*M[1, c]*Minor(M, 1, c), c = 1 .. ColumnDimension(M)) end proc
dim := 7; A := Matrix(dim, dim, shape = symmetric, symbol = a)
7
start_time := time(); st := time[real](); Det1 := abs(A); CPUtime_used_Build_in_Determinant := time()-start_time; REALtime_used_Build_in_Determinant := time[real]()-st; start_time := time(); st := time[real](); Det2 := DetDef(A); CPUtime_used_Jeremy_Johnson_Determinant := time()-start_time; REALtime_used_Jeremy_Johnson_Determinant := time[real]()-st; start_time := time(); st := time[real](); Det3 := Dodgsonseq(A); CPUtime_usedDodgsonseq := time()-start_time; REALCPUtime_usedDodgsonseq := time[real]()-st; start_time := time(); st := time[real](); Det4 := Dodgson(A); CPUtime_usedDodgson := time()-start_time; REALtime_usedDodgson := time[real]()-st; start_time := time(); st := time[real](); Det5 := LaPlace(A); CPUtime_usedLaPlace := time()-start_time; REALtime_usedLaPlace := time[real]()-st; simplify(Det1-Det2); simplify(Det1-Det3); simplify(Det1-Det4); simplify(Det1-Det5)
0.32e-1
0.34e-1
0.93e-1
.108
47.094
41.295
40.766
38.158
0.31e-1
0.50e-1
Download test_Determinants_symbolic.mw
I had purchached reseach licience Maple 2022 towards the end of 2022 only and Quantum Chemistry Toolbox I purchased in Feb 2022 only.
Now i find significant update in toolbox in just 3 months. Now guide me how should i address this issuse.
I had to take loan in india to buy the toolbox.
It is only 3 months.
Can you suggest me how solve the problem to get the update without spending again.
What is the way guide someone.
I calculate the limit
Let me know if there are any errors in my calculations?
assume(a > 0)
limit(int(sin(x)/x, x = n .. n+a), n = infinity)
-Si(n)+Si(n+a)
plot3d(-Si(n)+Si(n+a), a = -5 .. 5, n = -5 .. 5)
limit(-Si(n)+Si(n+a), n = infinity)
limit(-Si(n), n = infinity)
-(1/2)*Pi
limit(Si(n+a), n = infinity)
(1/2)*Pi
Thank you in advance.
Download limit_int.mw
I have a polyhedron with A(1,1,0), B(-1,1,0), C(-1,-1,0), H(-1/2,0,1), K(1/2,-1/2,0). How can I calculate volume of polyhedron ABCHK?
How can a horizontal axis be curved in a plot? like this
plot(F*r*sin(theta) - m, theta = 0 .. Pi)
When I am setting up the coordinates in the physics package, I use the following command. And it sets it to (r,theta,phi,t).
Setup(dimension = 4, mathematicalnotation = true, coordinates = spherical)
Is there a way to change it to (t,r,theta,phi)?
It gets a bit more confusing when we are looking at rank 2 objects.
Hi, I am working on an activity about conic sections, but I have a small issue with the display of the ellipse and the circle. My outlines are not complete. Any ideas on how to identify my error? Thanks  SectionsConiquesTest.mw
Hi to every one. I have attached a maple for eigenvalues. Please see and tell be solution of problem.
Thanks for time.
Eigen_Values.mw
Hi, here is my question.
test:=v^3;
plot3d(test,u=0..1-v, v=0..1);
How can I  transform this plot in the right triangle into an equilateral triangle?
So that the three edges of the plot are the same length.
I wanna, squish it, or shear?
any tools i can use? Or can I do it using some tricks to change the function?
why the output wont appear eventhough I think the working is right?
y'' + 1/x * u' + u = 6 - 9x + x^2 - x^3
with baundary condition :
u(0) = 0 , and u(1) = 0
 I run the attached code, but after waiting for a few minutes, there is no response, does anyone know the reason?
 It only shows Evaluating!!!!
 sy01.mw
First 200 201 202 203 204 205 206 Last Page 202 of 2430
