I encountered this issue while writing some code. Here is my code:
numArray := [17, 18, 19];
symArray := [x, y, z];
kronArray := map(i -> local j; symArray[i] = symArray[1]^mul(numArray[j], j = 1 .. i - 1), [$ (1 .. 3)]);
When I run it, I get the following warning:
Warning, (in anonymous procedure created in Typesetting:-FI) `j` is implicitly declared local;
After clicking the LINK  to Maple's help, I saw a similar issue in Example 3. However, Example 3 didn't resolve the problem. How can I declare a variable as local within an anonymous function?
I have a problem calculating integral analytically.
Can anyone help me in this regard?
problem_2_integral_&_moshtagh.mw
I wonder what is the general view on this.
Maple tries hard to find analytical solutions by trying different algorithms. Which is very good. But the question is, should it also hang doing this? Should not there be a circuit breaker to prevent the hang?
I mean there must be a limited number of algorithms it tries. So at one point one would expect it will finish and return either no solution or the solution it found.
For this Abel ode   y'=x+y^3, which is known not to be solvable, Maple hangs on
           > Step 2: calculating resultants to eliminate F and get candidates for
I waited for almost one hour. Clearly this indicates a problem internally. Right?
There should be some internal checks to prevent this hang I would think.  I do not know where it actually hangs, since trace only shows the last step above.
It will good to find out the cause of the hang and add code to prevent this in a future version of Maple dsolve to make it more robust.
btw, using that another software, it returns instantly on this ode with no solution. May be the other software did not try as hard, but at least it did not hang :)
`The "Physics Updates" version in the MapleCloud is 1861 and is the same as the version installed in this computer, created 2025, April 10, 15:58 hours Pacific Time.`
infolevel[dsolve]:=5;
ode:=diff(y(x),x)=x+y(x)^3;
sol:=dsolve(ode,y(x))
5
diff(y(x), x) = x+y(x)^3
Methods for first order ODEs:
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
Chini's absolute invariant is: (1/27)/x^5
differential order: 1; looking for linear symmetries
trying exact
trying Abel
The relative invariant s3 is: x
The first absolute invariant s5^3/s3^5 is: 1/x^5
The second absolute invariant s3*s7/s5^2 is: 0
...checking Abel class AIL (45)
...checking Abel class AIL (310)
...checking Abel class AIR (36)
...checking Abel class AIL (301)
...checking Abel class AIL (1000)
...checking Abel class AIL (42)
...checking Abel class AIL (185)
...checking Abel class AIA (by Halphen)
...checking Abel class AIL (205)
...checking Abel class AIA (147)
...checking Abel class AIL (581)
...checking Abel class AIL (200)
...checking Abel class AIL (257)
...checking Abel class AIL (400)
...checking Abel class AIA (515)
...checking Abel class AIR (1001)
...checking Abel class AIA (201)
...checking Abel class AIA (815)
Looking for potential symmetries
... changing x -> 1/x, trying again
The third absolute invariant s5*s7/s3^4 is: 0
 ->             ...checking Abel class D (by Appell)
 -> Step 1: checking for a disqualifying factor on F after evaluating x at a number
Trying x = 1
*** No disqualifying factor on F was found ***
 -> Step 2: calculating resultants to eliminate F and get candidates for C
Download why_hangs_dsolve_april_18_2025.mw
Occasionally I want to convert 2D-Math input to 1D-Math input. This is either not fully working with comments or changes the format. Example:
Try converting the input below to Maple 1D-Math (select -> right click -> 2D-Math -> convert to -> 1D-Math)
statement
statement
The*comment*dissapears:
statement;
statement
The Maple Input at the top can be converted by selecting the style C Maple Input from the edit tab but the font changes not to the default font for 1D Math-Input;
statement
statement
The above is in italic and not in bold. However the default for 1D-Math Input is the following
statement
statement
Also pasting code with comments in MaplePrimes (function insert code snippet) removes comments.
Any other ways? Ideally, I would also like to convert a whole document in one go, That is probably asked too much.
Download convert_comment_to_1D.mw
I would like to write a Maple program that gives me all possible sums >=  a given maximum maxsum and with and odd number q >= 3 of distinct summands from a given list. q can be 3, 5, 7, .. t, where t is odd and depends on L and max.
Example:
maxsum:=97, L := [9,15,21,25,27,33,35,39,45,49,51,55,57,63,65,69,75,77,81,85,87].
Here t= 3 and only q=3 is possible. In the final version of the program the list L and the maxsum will be much larger, so that the sums for every odd q =3, 5, 7, ..., t.
I tried to write a code for this basic case:
q := 3:
p := 91:
L := [9,15,21,25,27,33,35,39,45,49,51,55,57,63,65,69,75,77,81,85,87]:
M := []:
NestedLoops := proc(startIndex, remainingDepth, currentSum)
    local i;
    if remainingDepth = 0 then
        if currentSum <= p then
            M := [op(M), currentSum]:
        return:
    for i from startIndex to nops(L) - remainingDepth + 1 do
        NestedLoops(i + 1, remainingDepth - 1, currentSum + L[i]):
    od;
NestedLoops(1, q, 0);
M;
The result ist "[]". What is wrong? How would be a correct and efficient version?
Thanks for helping me.
Do you think could be a bug in dsolve?
Physics:-Version()
ode:=x^2+3*x*diff(y(x),x)=y(x)^3+2*y(x);
DEtools:-odeadvisor(ode);
dsolve([ode,y(1)=1],[Abel])
x^2+3*x*(diff(y(x), x)) = y(x)^3+2*y(x)
[_rational, _Abel]
Error, (in dsolve) numeric exception: division by zero
Download dsolve_division_by_zero_abel_april_16_2025.mw
If I do not tell it to use Abel, then dsolve does not give divison by zero.
Maple 2025 on Linux
As shown in the paper, and in many similar ones, the authors use a particular method that I believe is related to the long wave limit. I’m familiar with other approaches, but the traditional methods haven’t been successful in this case. This author, along with a few others, has tried applying this long wave limit approach, though many papers don’t explicitly mention the substitutions they use to arrive at the lump solution.
I’ve been able to separately find the lump series, but for some of the other solutions, we first need to figure out how to derive this key result. Once that part is clear, the rest should be easier to handle. I've been working through everything step by step and have managed to reproduce many of the solutions from the paper.
Also i don't know how finding (eq17) in paper, which they found by apply long wave limit to (eq7) in paper
additionaly How finding line which i think they found by finding velocity?
Please, if you have any information or insight into how we can obtain this more difficult result, I would really appreciate your help.
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
_local(gamma)
declare(u(x, y, z, t))
declare(f(x, y, z, t))
alpha := 1; beta := 1; delta := 1; lambda := 1
pde := diff(diff(u(x, y, z, t), t)+6*u(x, y, z, t)*(diff(u(x, y, z, t), x))+diff(u(x, y, z, t), `$`(x, 3)), x)-lambda*(diff(u(x, y, z, t), `$`(y, 2)))+diff(alpha*(diff(u(x, y, z, t), x))+beta*(diff(u(x, y, z, t), y))+delta*(diff(u(x, y, z, t), z)), x)
diff(diff(u(x, y, z, t), t), x)+6*(diff(u(x, y, z, t), x))^2+6*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))+diff(diff(diff(diff(u(x, y, z, t), x), x), x), x)-(diff(diff(u(x, y, z, t), y), y))+diff(diff(u(x, y, z, t), x), x)+diff(diff(u(x, y, z, t), x), y)+diff(diff(u(x, y, z, t), x), z)
thetai := t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i]
eq15 := w[i] = -(k[i]^4+k[i]^2+k[i]*l[i]+k[i]*r[i]-l[i]^2)/k[i]
eq17 := u(x, y, z, t) = 2*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)-2*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^2
A[sj] := (3*k[i]^4*k[j]^2-6*k[i]^3*k[j]^3+(3*k[j]^4+l[j]^2)*k[i]^2-2*k[i]*k[j]*l[i]*l[j]+k[j]^2*l[i]^2)/(3*k[i]^4*k[j]^2+6*k[i]^3*k[j]^3+(3*k[j]^4+l[j]^2)*k[i]^2-2*k[i]*k[j]*l[i]*l[j]+k[j]^2*l[i]^2)
F2 := 1+exp(eta[1])+b[1, 2]*exp(eta[1]+eta[2])+exp(eta[2])
F22 := 1+exp(eta[1])+(3*k[1]^4*k[2]^2-6*k[1]^3*k[2]^3+(3*k[2]^4+l[2]^2)*k[1]^2-2*k[1]*k[2]*l[1]*l[2]+k[2]^2*l[1]^2)*exp(eta[1]+eta[2])/(3*k[1]^4*k[2]^2+6*k[1]^3*k[2]^3+(3*k[2]^4+l[2]^2)*k[1]^2-2*k[1]*k[2]*l[1]*l[2]+k[2]^2*l[1]^2)+exp(eta[2])
F222 := exp(-(t*k[1]^4+t*k[1]^2+t*k[1]*l[1]+t*k[1]*r[1]-t*l[1]^2-x*k[1]^2-y*k[1]*l[1]-eta[1]*k[1])/k[1])+(3*k[1]^4*k[2]^2-6*k[1]^3*k[2]^3+(3*k[2]^4+l[2]^2)*k[1]^2-2*k[1]*k[2]*l[1]*l[2]+k[2]^2*l[1]^2)*exp(-(t*k[1]^4+t*k[1]^2+t*k[1]*l[1]+t*k[1]*r[1]-t*l[1]^2-x*k[1]^2-y*k[1]*l[1]-eta[1]*k[1])/k[1]-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]-eta[2]*k[2])/k[2])/(3*k[1]^4*k[2]^2+6*k[1]^3*k[2]^3+(3*k[2]^4+l[2]^2)*k[1]^2-2*k[1]*k[2]*l[1]*l[2]+k[2]^2*l[1]^2)+exp(-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]-eta[2]*k[2])/k[2])
indets(F222)
{t, x, y, eta[1], eta[2], k[1], k[2], l[1], l[2], r[1], r[2], exp(-(t*k[1]^4+t*k[1]^2+t*k[1]*l[1]+t*k[1]*r[1]-t*l[1]^2-x*k[1]^2-y*k[1]*l[1]-eta[1]*k[1])/k[1]), exp(-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]-eta[2]*k[2])/k[2]), exp(-(t*k[1]^4+t*k[1]^2+t*k[1]*l[1]+t*k[1]*r[1]-t*l[1]^2-x*k[1]^2-y*k[1]*l[1]-eta[1]*k[1])/k[1]-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]-eta[2]*k[2])/k[2])}
eq1 := eval(F222, {eta[1] = -1, eta[2] = -1, k[1] = K[1]*epsilon, l[1] = L[1]*epsilon, r[1] = R[1]*epsilon})
exp(-(epsilon^4*t*K[1]^4+epsilon^2*t*K[1]^2+epsilon^2*t*K[1]*L[1]+epsilon^2*t*K[1]*R[1]-epsilon^2*t*L[1]^2-epsilon^2*x*K[1]^2-epsilon^2*y*K[1]*L[1]+epsilon*K[1])/(K[1]*epsilon))+(3*K[1]^4*epsilon^4*k[2]^2-6*K[1]^3*epsilon^3*k[2]^3+(3*k[2]^4+l[2]^2)*K[1]^2*epsilon^2-2*K[1]*epsilon^2*k[2]*L[1]*l[2]+k[2]^2*L[1]^2*epsilon^2)*exp(-(epsilon^4*t*K[1]^4+epsilon^2*t*K[1]^2+epsilon^2*t*K[1]*L[1]+epsilon^2*t*K[1]*R[1]-epsilon^2*t*L[1]^2-epsilon^2*x*K[1]^2-epsilon^2*y*K[1]*L[1]+epsilon*K[1])/(K[1]*epsilon)-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]+k[2])/k[2])/(3*K[1]^4*epsilon^4*k[2]^2+6*K[1]^3*epsilon^3*k[2]^3+(3*k[2]^4+l[2]^2)*K[1]^2*epsilon^2-2*K[1]*epsilon^2*k[2]*L[1]*l[2]+k[2]^2*L[1]^2*epsilon^2)+exp(-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]+k[2])/k[2])
G := limit(eq1, epsilon = 0)
exp(-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]+2*k[2])/k[2])+exp(-1)+exp(-(t*k[2]^4+t*k[2]^2+t*k[2]*l[2]+t*k[2]*r[2]-t*l[2]^2-x*k[2]^2-y*k[2]*l[2]+k[2])/k[2])
Download LWL.mw
Where is my question ?
No reason to delete this...nothing copy righted code
Hello! How can I plot a tiling of regular 6-gons in Maple, and paint it using three colors?
Maybe someone would be so kind as to share the code for such a tiling.
in try to figure out why in some function i can find this critical point for ploting i need that point , untill now i just find in one function and other i can't and my program not runing for other and really this is make problem for my invistigation i want to fixed that and i upload that file i did and that file i can't find it for , thanks for any help?
line-undone.mw
Line-1-Done.mw
I can't find the help page for Abel second kind, class B.
Maple has help page for Abel second kind, class A and Abel second kind, class C. But not for class B.
Here is an example of Abel second kind class B
ode:=(3*t*y(t)+y(t)^2)+(t^2+t*y(t))*diff(y(t),t)=0;
I wanted to know the difference and the transformation used for class B to make it Abel first kind.
I googled and can't find it. Also local help skips over class B.
Is this documented somewhere else?
btw, find error on the help page for class A. Transformation used is wrong. Will leave this for another question.
I'm not currently working on the topic of fluids and I'm not very familiar with it. However, my partner is working on it and is using other software. They have a question about whether Maple can handle this kind of work. Are there any examples available? I’d appreciate any help
thanks!
Dear Maple experts,
is there a possibility/command to get a vizualization of the output of the command FeedbackConnect?
I was thinking of something like this:
as it is given on the maple-help page for that command (but not generated via a maple command as far as I understood)
Thanks in advance !
I have repeatedly seen this on two Windows PCs:
The assignement operator := is rendered as a roman d
This happens after using Maple for some time.
 Exiting Maple and restart of Maple is required. Has someone noticed the same?
All on Windows 10 and for sure in screen reader mode (my default, cannot report on the new GUI).
Please, I am encountering error trying to run these codes for sensitivity analysis using the formula for sensitivity analysis
# Set up numerical values for all problem parameters
  params:=[ Lambda__p=100,         gamma__B=0.05,      gamma__B=0.05,
                 gamma__C=0.01, omega__C=0.001,  omega__B=0.001,
            sigma__B=0.0001,     sigma__C=0.01, sigma__BC=0.01,
                theta__B=0.8,     theta__C=0.5,      mu__C=1.0,
              Lambda__A=1.0,       Lambda__w=1.0,   varphi__8.33,
            mu__A=1.0, mu__w=1.0, alpha__B=0.005, alpha__C=0.005, alpha__BC=0.15, Zeta__B=0.5, Zeta__C=0.5, delta__A=0.66, delta__w=1.33
# Define main function
  R:= (varphi^2*theta__B*Lambda__p*alpha__B*Lambda__A)/((mu__c*mu__A*N__p^2)*(mu__A*mu__c+mu__A*omega__B+mu__A*sigma__B+mu__c*delta__A+delta__A*omega__B+delta__A*sigma__B));
varphi^2*theta__B*Lambda__p*alpha__B*Lambda__A/(mu__c*mu__A*N__p^2*(mu__A*mu__c+mu__A*omega__B+mu__A*sigma__B+mu__c*delta__A+delta__A*omega__B+delta__A*sigma__B))
# Compute "all" derivatives and evaluate numerically.
# For the purposes of this calculation "all"
# derivatives, means the derivatives with respect to
# every variable returned by indets(R, name)
# Output a list of two element lists where each of
# the latter is
# [ varName,
#   eval( diff( R, varName), params )
 [ seq( [j, eval( diff( R, j), params )],j in indets(R, name))];
Error, invalid input: eval expects its 2nd argument, eqns, to be of type {integer, equation, set(equation)}, but received [Lambda__p = 100, gamma__B = 0.5e-1, gamma__B = 0.5e-1, gamma__C = 0.1e-1, omega__C = 0.1e-2, omega__B = 0.1e-2, sigma__B = 0.1e-3, sigma__C = 0.1e-1, sigma__BC = 0.1e-1, theta__B = .8, theta__C = .5, mu__C = 1.0, Lambda__A = 1.0, Lambda__w = 1.0, 33*varphi__8, mu__A = 1.0, mu__w = 1.0, alpha__B = 0.5e-2, alpha__C = 0.5e-2, alpha__BC = .15, Zeta__B = .5, Zeta__C = .5, delta__A = .66, delta__w = 1.33]
# Compute all "sensitivities" (where the sensitivity
# is as defined in Rouben Rostamian response to the
# OP's earlier post) and evaluate numerically.
# For the purposes of this calculation "all" sensitivities
# means the sensitivity with respect to every variable
# returned by indets(R, name)
# the latter is
# [ varName,
#   eval( varName*diff( R, varName)/R, params )
  seq( [j, eval( j*diff( R, j)/R, params )],j in indets(R, name));
Download Computed_Sensitivity_Analys_for_CBD.mw
First 21 22 23 24 25 26 27 Last Page 23 of 2429
