Still being a newbie to Maple, I am stuck on this one. I am trying to create a general system of changing my equations in an [x,y] coordinate system to a [u,v] system. As a specific example: I have two substitution equations, u=2x-3y and v=-x+y. I have four equations: x=0, x=-3, y=x, y=x+1. I have tried MapToBasis with both static and procedure statements and I am not having any luck. The equations do not completely change to [u,v]. Here is one example: > proc (u, v) u = 2*x-3*y end proc; > proc (u, v) v = -x+y end proc; > with*VectorCalculus; > SetCoordinates('cartesian', [u, v]);
I am trying to plot the equations shown in Figures 5 and 6, which are solutions to Equations (14), (15), and (16). These equations are developed in the Lo paper (attached). I am working through the symbolic solution by hand and would greatly appreciate any suggestions on how to set these equations and the graphs of the same in a worksheet. Thank you for the assistance anyone may offer. Wayne Bell Download 4865_Lo_p691.pdf
View file details Download 4865_Lo_p692.pdf
View file details
I'm having a problem to run this Maple. Thank you for your help. > solve({e1⊢e1=e1,e2⊢e2=e2, e1⊣e1=alpha1*e1+alpha2*e2,e1⊣e2=alpha3*e1+alpha4*e2,e2⊣e1=alpha5*e1+alpha6*e2,e2⊣e2=alpha7*e1+alpha8*e2, (e1⊣e1)⊣e1=e1⊣(e1⊣e1),(e1⊣e1)⊣e1=e1⊣(e1⊢e1),(e1⊢e1)⊣e1=e1⊢(e1⊣e1),(e1⊣e1)⊢e1=e1⊢(e1⊢e1),(e1⊢e1)⊢e1=e1⊢(e1⊢e1), (e1⊣e1)⊣e2=e1⊣(e1⊣e2),(e1⊣e1)⊣e2=e1⊣(e1⊢e2),(e1⊢e1)⊣e2=e1⊢(e1⊣e2),(e1⊣e1)⊢e2=e1⊢(e1⊢e2),(e1⊢e1)⊢e2=e1⊢(e1⊢e2), (e1⊣e2)⊣e1=e1⊣(e2⊣e1),(e1⊣e2)⊣e1=e1⊣(e2⊢e1),(e1⊢e2)⊣e1=e1⊢(e2⊣e1),(e1⊣e2)⊢e1=e1⊢(e2⊢e1),(e1⊢e2)⊢e1=e1⊢(e2⊢e1), (e1⊣e2)⊣e2=e1⊣(e2⊣e2),(e1⊣e2)⊣e2=e1⊣(e2⊢e2),(e1⊢e2)⊣e2=e1⊢(e2⊣e2),(e1⊣e2)⊢e2=e1⊢(e2⊢e2),(e1⊢e2)⊢e2=e1⊢(e2⊢e2), (e2⊣e1)⊣e1=e2⊣(e1⊣e1),(e2⊣e1)⊣e1=e2⊣(e1⊢e1),(e2⊢e1)⊣e1=e2⊢(e1⊣e1),(e2⊣e1)⊢e1=e2⊢(e1⊢e1),(e2⊢e1)⊢e1=e2⊢(e1⊢e1), (e2⊣e1)⊣e2=e2⊣(e1⊣e2),(e2⊣e1)⊣e2=e2⊣(e1⊢e2),(e2⊢e1)⊣e2=e2⊢(e1⊣e2),(e2⊣e1)⊢e2=e2⊢(e1⊢e2),(e2⊢e1)⊢e2=e2⊢(e1⊢e2), (e2⊣e2)⊣e1=e2⊣(e2⊣e1),(e2⊣e2)⊣e1=e2⊣(e2⊢e1),(e2⊢e2)⊣e1=e2⊢(e2⊣e1),(e2⊣e2)⊢e1=e2⊢(e2⊢e1),(e2⊢e2)⊢e1=e2⊢(e2⊢e1), (e2⊣e2)⊣e2=e2⊣(e2⊣e2),(e2⊣e2)⊣e2=e2⊣(e2⊢e2),(e2⊢e2)⊣e2=e2⊢(e2⊣e2),(e2⊣e2)⊢e2=e2⊢(e2⊢e2),(e2⊢e2)⊢e2=e2⊢(e2⊢e2)},{alpha1,alpha2,alpha3,alpha4,alpha5,alpha6,alpha7,alpha8});
I wonder if this is the right way to plot following function. > restart: > huur:=t->400*(1.01)^ceil(t); floor(t) huur := t -> 400 1.01 > plot(huur(t),t=0..50,discont=true); As you can see I have a the function huur(t) with t a positive integer. I can't find another way to plot this function except by making use of the floor function. Isn't there a better way? Asumming that t is a positive integer didn't worked.
Hello, in a differential equation (in Maple 10) a variable should be replaced by a constant K so that all differentiations of this variable should evaluate to zero. This is my code: constants:= constants, K: myDG1:= u(t) + diff(u(t),t)^2 + v(t)=0: subs(u(t)=K,myDG1); K+(diff(K, t))^2+v(t) = 0 Although I have already assigned K to be constant, Maple doesn't replace d/dt K by 0. Any help would be appreciated.
Consider a sum: Sum((-1)^(i+1)*Sum(1/j,j=1..i)*x^i,i=1..infinity); value(%); The result given by Maple 11 is: sum((-1)^(i+1)*(Psi(i+1)+gamma)*x^i, i = 1 .. infinity) However, from an calculus book I know the answer is: log(1+x)/(1+x). How can I get this result from Maple? Whether should I give some assumptions? Best wishes.
Here I difine a subfunction:
mandelbrot := proc(x, y)
local c, z, m;
c := evalf(x+y*I);
z := c;
for m to 30 while abs(z) < 2 do
z := z^2+c
od;
abs(z);
end:
Then I want to plot this function using densityplot command:
plots[densityplot](mandelbrot, -2 .. 0.7, -1.2 .. 1.2, grid=[50, 50], style=patchnogrid, scaling=constrained);#This command is right.
But...
plots[densityplot](mandelbrot(x,y), x=-2 .. 0.7, y=-1.2 .. 1.2, grid=[50, 50], style=patchnogrid, scaling=constrained);#Error, the proc I defined could not determine whether abs(x+1.*I*y) < 2.
To Maplet enthusiast: I uploaded a functional shortened code from a 35-page code. See ShortVersion.mw under Recent Files. Although the file is compiled/interpreted successfully by Maple 11, the maplet plotter did not plot. I will appreciate it very much if someone can offer an explanation why the element failed and a possible suggestion on how to correct the problem. Many thanks Pat Velez
Here is a derivative that I'm trying to take that I get a different answer from Mathcad. This would normally be ok I guess except when trying to figure arclength in Maple I don't get an answer and in Mathcad it works fine. diff((3+4*y^4)/12*y,y); The original equation is: 12xy - 4y^4 = 3 Thanks, glenn
I am trying to convert equations from cartesian to polar and spherical expecting Maple to change the variables from x,y and z to r, theta, etc. I presume I am using the wrong commands. convert(exp(sqrt(x^2+y^2)),polar) returns the same expression in x and y. What is the correct command? thanks
I seem to keep running into things in Maple that I just can't get to plot. I have been using Mathcad and am trying to learn to do everything in Maple, but keep finding myself having to go to Mathcad to do even the simplest things. Could someone please help and explain to me what I'm doing wrong? I have with(plots) and restart() at the top of my page. I then do this: g1 := implicitplot(3x^2,x=0..10,y=0..10); display( g1 ); This results in it just printing the display line again, no graph is shown. I can get this to work using the plot command but since its not very easy in Maple to print multiple equations on a single graph I have started trying to do them this way. If there is a better way to do graphs then please tell me this as well as I'm trying to learn Maple as best as I can.
I have a fairly simple integral that I'm trying to complete in Maple and keep having to go to Mathcad to get an answer that I can use. This is just one example of many times this has happened and I'm wondering if maybe I'm entering something wrong or if there is a better way to do it. int( (x^2 + 1)^3/2, x=0..1); The answer coming back from Maple is really long, where the answer coming from Mathcad is really short. Can anyone tell me what I might be doing wrong? Thanks, glenn
Hi, I'm new at Maple, trying to migrate from Mathcad but I'm getting stuck on a basic problem. I want Maple to find numeric solutions to a maximization problem and express the solution as a function of the problem's parameters. To take a very simple example of the more general thing I want to do, suppose I have a profit function which is a function of inputs T and L and factor prices w and r. F:=(T,L)->T^(1/2)*L^(4/5); Profit := (T, L, w, r) -> F(T, L)-w*L-r*T; I seem to be able to almost isolate the parameterized functions I want as follows:
Can someone help me with the Dagger command in the Physics package ? I can't seem to get it to work for matrices. thanks,
I'm just learning to write Maplets for the purpose of using them as a teaching tool. Two questions: 1. I'd like to have a slider that updates a plot argument AND plays the plot's animation but I can't seem to figure out how to write two controls into the slider's options. (I've tried "Action(Evaluate...,SetOption...) to no avail. 2. Is it possible to have the location of the slider read in 'real-time' i.e. as the user moves the slider back and forth a feature in a plot changes? It seems as if the 'onchange' option is required but I can't seem to get this going either. Cheers, Co
First 2319 2320 2321 2322 2323 2324 2325 Last Page 2321 of 2430
