Hello, I need some help on how to solve this eq: A(z)*diff(P(z),z,z)-alpha(z)*P(z)-beta(z)*P(z)^3-gamma(z)*P(z)^6=0; A(z), alpha(z), beta(z), and gamma(z) is known. P(z) is the unknown. When I tried to do this by solve command, I get "warning, solutions may have been lost". I really need help on this from the experts out there... Thanks, G.
In diagaonalizing a Hermitian matrix, the eigenvectors come out un-normalized, and as a result, when performing a similarity transformation on the original (Hamiltonian) matrix, the diagonal elements come out proportional to the true values, not the values themselves. I can't find out how to simply normalize the eigenvectors so that they can be made into the appropriate matrix (and its transpose complex-conjugate). There's got to be a simple way, but I can't seem to find it. Can someone point the way? Thanks Carl David
Hey I am trying to do on maple to make a 3d ball which bounces up and down. Any help would be greatfully apprecaited.
Hello, Is there a mathmatical formula for horn 3D plot simulation. I tried the following but no luck so far. http://en.wikipedia.org/wiki/Cylindrical_coordinates http://mathworld.wolfram.com/Cone.html How do I convet a cone formula to a Horn formula. Where I can control the shape and size of the horn using parameters. I any help would be appreciated. Regards Raj
I am trying to integrate this equation numerically, but Maple just returns it every time. Any suggestions on how to tackle this kind of problem? I want to treat mu and T as const. I made the worksheet a public file on my account called Numerical Integration. PLease give it a try if you have the time and let me know what you come up with. You can also make your own worksheet, the integral is as follows. int(sqrt(x)/(exp((x-mu)/T)+1), x = 0 .. infinity) Thanks, Good Luck
Hello, i'm newbie here and spanish... Someone can help my, i want an procedure/function that you put an array and it will give you the rang/rank but not using the function implemented un maple... I'm using MAPLE 10 THX
How can the number of digits found in computed values of exponents be controlled? Here is my problem: I am appling a power fit to statistical data using the following command power:=PowerFit(X,Y,x); and I get the following output: 4.686027976 x^(0.413637849985206863) I would like to have these coefficients truncated to say 3 digits so that the expression is manageable when I insert the expression into a plot title. I have tried: power:=evalf[3](PowerFit(X,Y,x)); which produces 4.69 x^(0.413637849985206863)
How is a legend displayed using scatterplot? For example the command plot:=scatterplot(X,Y,legend="DATA"); will not work. It produces: Error, unexpected object: >LEGEND("DATA")
A little while ago on another thread I asked about putting hats on variables and Georgious pointed me in the direction of a most helpful thread. I found that there was more that 1 way to do it. One of the ways involved this syntax `#mover(mi(θ),mo("∧"))` It works, but I haven't been able to find any documentation mi, mo or mover. I sure would appreciate it if someone could help me understand this syntax. Also, what if I want to out a dot above a hat on a variable ? Thanks
When I input 3*(x+y) the outpupt is 3x + 3y. Is there any way to go the other direction - that is, perform some operation on 3x + 3y that will yield the output 3*(x+y) ?
implement a program for a matrix a a vector x and numbers eps>0, omega e(0,2) approximates the solution of the system Ax=b by relaxation with parameter omega and accuracy eps the program should stop when last iterations x[i-1],x[i] and x[i+1] satisfy norm(x[i+1]-x[i]> norm(x[]-x[i-1]
I used to do this, but it seems I have forgotten how...
> P1 := plot(sin(x),x=-Pi..Pi);
> with(plots):display([P1]);
> plotsetup(ps,plotoutput=`aa.ps`,plotoptions=`portrait,noborder`);
I am trying to use Optimization[LSSolve] to fit the solution to a differential equations to data. I can solve my problem using Matlab, but I'd like to be able to use Maple as well. This is Maple 10. The proc is not getting the values of the parameters. > data := [[0,95], [11,425], [22, 928], [33,1358], [44,1589], [56,1683], [67,1724]]: > try2 := proc(K,alpha,r,IC) local DE1,R; print(K,alpha,r,IC): # for debugging DE1:=diff(y(t),t)=r/alpha*y(t)*(1-(y(t)/K)^alpha); R:=dsolve({DE1,y(0)=IC},numeric); map((d) -> rhs(R(d[1])[2])-d[2],data): end: > sol2 := Optimization[LSSolve](try2(K,alpha,r,IC), initialpoint = {r=.09, K=1750, IC=95, alpha=.3});
Hi, Sorry but i ve repeated the same question a few days ago but because it was quite down the line i thought to give it another shot I would like to make a 3D plot of some density functions(F(X)) where each lets say cdf, corresponds to a time value.So far Ive tried using the transform((x, y) command.The example below where I show how I have worked out for 4 cdfs corresponding to 10,20,30 and 40 ms, hopefully it will make it clearer of what i mean.(I have a thousand of different distributions up to 10 secs). with(stats): > C001:=plot(statevalf[cdf,lognormal[0.3792,0.9556]], 0..4, colour=green):
I am using the latex2edu conversion service at qa.brownstone.net/latex2edu to convert latex files into MapleTA questions. However, for the last 4 days this service has not been available. Mail to support@brownstone.net and my local MapleSoft representative has not been answered. Has anyone else experienced this problem? Does anyone know whether the service is available elsewhere? Arne Jensen Aalborg University Denmark
First 2343 2344 2345 2346 2347 2348 2349 Last Page 2345 of 2429
