I want to display in 3d the following objects
  • Animated plottools objects (e.g. a spinning cube)
  • Static plot objects (e.g. surface plot)/li>
  • Time dependent spacecurves (to trace the path of objects)
Technically I could
  • create a sequence of time stamps
  • generate for each time stamp a plot structure using plots:-display for all the above objects
  • display the sequence of plot structures with plots:-display with the option insequence.
or
  • create separate plots with plots:-animate for each time dependent object
  • plot with plot3d all static objects
  • display all plots with plots:-display
or
  • defining a procedure containing all plotting commands as a function of time
  • create a background plot of all static objects using plots:-display
  • animate the procedure with a plots:-animate call with the background option
Without having any experience, my perference would be the last way. However I intend to generate some plot coordinates with dsolve,numeric. This would mean that at each point in time to be plotted, dsolve starts integration from the inital conditions (which I have not planned to update animation frame by animation frame)
Any recommensations or thoughts on this?
I want to compute the limit for a parameter (gamma) to infinity of an expression which includes summations over indexes. Below are two approaches. I believe that both should produce the same output, however:
  1. Approach A generates a signum, but I don't understand where this is coming from
  2. Approach B works smoothly once I fix the final value n of the index to some number but runs very slow if I leave n undefined (I had to interrupt the execution)
Maybe approach B is not wrong, and I just need to wait longer...
Any thoughts?
Approach A: Compute infinity limit while keeping X and lambda undefined (since they are independent of gamma, see below), then define X and lambda
problem: what generates signum?
local gamma;
gamma
assume(0 < gamma, 0 < n, 0 < w, 0 < Delta, 0 < vo[i], -1 < rho and rho < 1, 0 < sigma__v, 0 < sigma__d, 0 < sigma__dr, delta[i]::real, delta[j]::real, delta[k]::real, delta__r::real, X[i]::real, X[j]::real, X__r::real);
interface(showassumed=0);
W:=sum(X[i]*(-lambda*X[i]-lambda*delta[i]-vo[i]),i=1..n)+X__r*(-lambda__r*X__r-lambda__r*delta__r-w*sum(vo[i],i=1..n))+sum((X[i]+w*X__r)*(vo[i]+(1/(w*n))*(Delta)),i=1..n)-gamma/2*sigma__v^2*(1-(1+rho*(n-1))/(n))*sum((X[i]+w*X__r)^2,i=1..n)-gamma/2*sigma__v^2*(rho-(1+rho*(n-1))/(n))*sum(sum((X[i]+w*X__r)*(X[j]+w*X__r),j=1..i-1)+sum((X[i]+w*X__r)*(X[j]+w*X__r),j=i+1..n),i=1..n);
sum(X[i]*(-lambda*X[i]-lambda*delta[i]-vo[i]), i = 1 .. n)+X__r*(-lambda__r*X__r-lambda__r*delta__r-w*(sum(vo[i], i = 1 .. n)))+Delta*X__r+sum(Delta*X[i]/(w*n)+vo[i]*X__r*w+X[i]*vo[i], i = 1 .. n)-(1/2)*gamma*sigma__v^2*(1-(1+rho*(n-1))/n)*(n*X__r^2*w^2+sum(2*X__r*w*X[i]+X[i]^2, i = 1 .. n))-(1/2)*gamma*sigma__v^2*(rho-(1+rho*(n-1))/n)*(n^2*X__r^2*w^2-n*X__r^2*w^2+sum(sum(X__r*w*X[j]+X[i]*X[j], j = i+1 .. n)+sum(X__r*w*X[j]+X[i]*X[j], j = 1 .. i-1)+X__r*w*X[i]*n-X__r*w*X[i], i = 1 .. n))
limit(W,gamma=infinity);
-signum(-(sum(sum(X[j]*(X__r*w+X[i]), j = i+1 .. n)+sum(X[j]*(X__r*w+X[i]), j = 1 .. i-1)+X__r*w*(n-1)*X[i], i = 1 .. n))+(n-1)*(sum(X[i]*(2*X__r*w+X[i]), i = 1 .. n)))*infinity
#convert(%, piecewise);
Approach B: Define X and lambda first, then compute infinity limit
problem: why last execution so slow?
local gamma;
gamma
X[i] := (1/(2*n*w))*sqrt((4*n-3)/(1+rho*(n-1)))*(sigma__d/sigma__v)*Delta-(1/(2*n))*delta[i]-(1/(2*n))*(sum(delta[j],j=1..i-1)+sum(delta[j],j=i+1..n));
X[j] := (1/(2*n*w))*sqrt((4*n-3)/(1+rho*(n-1)))*(sigma__d/sigma__v)*Delta-(1/(2*n))*delta[j]-(1/(2*n))*(sum(delta[k],k=1..j-1)+sum(delta[k],k=j+1..n));
X__r := (1/(2*w*sqrt(n*(1+rho*(n-1)))))*(sigma__dr/sigma__v)*Delta-(1/2)*delta__r;
lambda := sqrt((1+rho*(n-1))/(4*n-3))*(sigma__v/sigma__d);
lambda__r := w*sqrt(n*(1+rho*(n-1)))*(sigma__v/sigma__dr);
(1/2)*((4*n-3)/(1+rho*(n-1)))^(1/2)*sigma__d*Delta/(n*w*sigma__v)-(1/2)*delta[i]/n-(1/2)*(sum(delta[j], j = 1 .. i-1)+sum(delta[j], j = i+1 .. n))/n
(1/2)*((4*n-3)/(1+rho*(n-1)))^(1/2)*sigma__d*Delta/(n*w*sigma__v)-(1/2)*delta[j]/n-(1/2)*(sum(delta[k], k = 1 .. j-1)+sum(delta[k], k = j+1 .. n))/n
(1/2)*sigma__dr*Delta/(w*(n*(1+rho*(n-1)))^(1/2)*sigma__v)-(1/2)*delta__r
((1+rho*(n-1))/(4*n-3))^(1/2)*sigma__v/sigma__d
w*(n*(1+rho*(n-1)))^(1/2)*sigma__v/sigma__dr
W:=sum(X[i]*(-lambda*X[i]-lambda*delta[i]-vo[i]),i=1..n)+X__r*(-lambda__r*X__r-lambda__r*delta__r-w*sum(vo[i],i=1..n))+sum((X[i]+w*X__r)*(vo[i]+(1/(w*n))*(Delta)),i=1..n)-gamma/2*sigma__v^2*(1-(1+rho*(n-1))/(n))*sum((X[i]+w*X__r)^2,i=1..n)-gamma/2*sigma__v^2*(rho-(1+rho*(n-1))/(n))*sum(sum((X[i]+w*X__r)*(X[j]+w*X__r),j=1..i-1)+sum((X[i]+w*X__r)*(X[j]+w*X__r),j=i+1..n),i=1..n):
W limit for n=3
Winf := collect(expand(simplify(limit(eval(W,n=3),gamma=infinity))),[Delta,Delta^2]):
quad_term := collect(expand(simplify(coeff(Winf,Delta^2))),[sigma__d,sigma__dr]);
linear_term := expand(simplify(coeff(Winf,Delta)));
coeff_term := collect(expand(simplify(eval(Winf,Delta=0))),delta__r^2);
(-(1/4)/(sigma__v*(1+2*rho)^(1/2)*w^2)+(1/2)*(1/(1+2*rho))^(1/2)/(w^2*sigma__v))*sigma__d+(1/12)*3^(1/2)*sigma__dr/((1+2*rho)^(1/2)*sigma__v*w)
-(1/2)*delta__r-(1/6)*delta[1]/w-(1/6)*delta[2]/w-(1/6)*delta[3]/w
((1/4)*3^(1/2)*sigma__v*w/((1+2*rho)^(1/2)*sigma__dr)+(1/2)*3^(1/2)*sigma__v*w*rho/((1+2*rho)^(1/2)*sigma__dr))*delta__r^2+(1/36)*sigma__v*delta[1]^2/((1+2*rho)^(1/2)*sigma__d)+(1/36)*sigma__v*delta[2]^2/((1+2*rho)^(1/2)*sigma__d)+(1/36)*sigma__v*delta[3]^2/((1+2*rho)^(1/2)*sigma__d)+(1/18)*sigma__v*delta[1]^2*rho/((1+2*rho)^(1/2)*sigma__d)+(1/18)*sigma__v*delta[2]^2*rho/((1+2*rho)^(1/2)*sigma__d)+(1/18)*sigma__v*delta[3]^2*rho/((1+2*rho)^(1/2)*sigma__d)+(1/18)*sigma__v*delta[2]*delta[1]/((1+2*rho)^(1/2)*sigma__d)+(1/18)*sigma__v*delta[1]*delta[3]/((1+2*rho)^(1/2)*sigma__d)+(1/18)*sigma__v*delta[2]*delta[3]/((1+2*rho)^(1/2)*sigma__d)+(1/9)*sigma__v*delta[2]*delta[1]*rho/((1+2*rho)^(1/2)*sigma__d)+(1/9)*sigma__v*delta[1]*delta[3]*rho/((1+2*rho)^(1/2)*sigma__d)+(1/9)*sigma__v*delta[2]*delta[3]*rho/((1+2*rho)^(1/2)*sigma__d)
W limit for generic n
Winf := collect(expand(simplify(limit(W,gamma=infinity))),[Delta,Delta^2]):
Download Infinity_limit_and_summations.mw
Is it possible to configure Maple to rather use space-time indices {0,1,2,3} rather than it's default {1,2,3,4}.
Published literature is full of the former, while it seems Maple cannot express indices as such and it creates havoc trying to convert between Maple results and published literature.
In particular, if I enter
Coordinates(X=(t,x,y,z));
Then Maple should be able to index the time "t" as zero.
Is this possible to configure Maple to do this ?
Let's say we enter an arbitrary metric with "Setup" in maple.
Also suppose the metric is a vacuum solution and therefore the Ricci tensor R[alpha,beta]=0
As soon as I enter the metric, maple will evaluate the Ricci tenso when I type R[alpha,beta] and equates it to zero.
What is the command to rather show the the equations that makes up the Ricci tensor for this metric and prevent Maple  from evaluating the equation.
This must be easy, but I just cannot find it in the manual. Must be simple to switch between displaying the constraint equation as calculated for say R[alpha,beta] from the metric and evaluating the equation.
I wanted to draw vertical line (as y axis) and add a solid disk at some y location (to indicate some point location). I used plottools:-disk  to make the small disk and used plottools:-line to make the y-axis then used plots:-display to combine them.
All is ok, except the disk is transparent. i.e. I can see the y-axis line below it. Is there a way to make it not transparent? i.e. solid color, so that the y-axis below it do not show?
#plot vertical line
L:=plottools:-line([0,0],[0,3],color="blue"):
c1:=plottools:-disk([0,1],.1,color="red"):
c2:=plottools:-disk([0,2],.1,color="green"):
plots:-display([L,c1,c2],scaling=constrained,axes=none)
i.e.
Download plotools_nov_9_2024.mw
 About 2 years ago I asked this question Application of how to test types in a module? - MaplePrimes on type checking and @CarlLove provided a great answer for inputs to a procedure in that package.
In the package I have a procdure to plot/draw lines. They require sorting out when there is a list of them The procedure recognises the different possible input formats. Could the types be defined in the procdure body. It would make sorting out a lot easier. I could possibly add them to Module load at the start of the package.
# Line type
#type _TNL1  expression type {`+`,`*`,`=`, `symbol`,procedure}                         2D line or any expression function equation
#type _TNL2  listlist [[a,b],[c,d]] or [[a,b,c],[d,e,f]]                               2D  line just draws a line between the 2 points
#type _TNL4  listlist [[a,b,c],[d,e,f]]                                                3D line just draws a line between the 2 points
#type _TNL4  list of list & vector 2D [[a,b],<c,d>]  or possibly  [<c,d>,[a,b]]        2D generates line A*x+B*y+C
#type _TNL5  list of list & vector 3D [[a,b,c],<d,e,f>] or possibly [<d,e,f>,[a,b,c]]  3D line <a+alpha*d, b+alpha*e, c+alpha*f>
#type _TNL6  vector 3D <a+alpha*d, b+alpha*e, c+alpha*f>                               3D line <a+alpha*d, b+alpha*e, c+alpha*f> checks indets to know
#type _TNL7  list of vector[row] and vector[row]  [<a|b|c>, <d|e|f>]                   projective points are converted to [a/c,b/c] and [d/f,e/f] and line drawn between the points
sorts:=proc(l1::{list,set,Vector[column],`+`,`*`,`=`, `symbol`,procedure},
{range::list:=[-5,5,-4,4]},
{vars::list:=[':-x',':-y']},
{rangep::list:=[-3,3]},
{plopts::list:=[':-colour'=':-blue,magenta']})
description " sort the list of line formats and converts to plotable format  ";
local i,n,Listsystem,subplt, subL, tmp, vv,ll,subpltemp;
      #single line;
if l1::{'Vector[column]',`+`,`*`,`=`, `symbol`,procedure} then
   n:=1;
   subplt:=[{}];
   if l1::'Vector[column]'(3) and indets(l1)={} then
      subL:=[l1[1]*vars[1]+l1[2]*vars[2]+l1[3]];
      subL:=[l1];
 elif l1::list and nops(l1)= 2 and not(hastype(l1,set))then
    #for j to 2 do
    #   if  l1[j][1]::listlist or l1[j][2]::listlist  then
                                                        # this section not finished supposed
                                                        # to detect is the list is two line without extra plopts, range, rangexy
   #   end if;
   # end do;
   n:=1;
   subplt:=[{}];
    #print("here now");
   if hastype(l1,'Vector[column]'(3)) and hastype(l1,list) then
      #print("in  here");
      vv:=(select(type,l1,('Vector[column]'(3)))[]);
      ll:=select(type,l1,list)[];
      #print("vv " ,vv, "ll",ll);
      subL:=[ll+~alpha*vv];
    elif hastype(l1,'Vector[column]'(2)) and hastype(l1,list)  then
      vv:=(select(type,l1,('Vector[column]'(2)))[]);
      subL:=[ (ll[2] - vars[2])*vv[1] - vv[2]*(ll[1] - vars[1])];
      subL:=[l1];
      #single line with own sub-options plopts range rangep bundled as a set
elif l1::set then
   n:=1;
   subpltemp,tmp:=selectremove(has,l1,{':-rangep',':-range',':-plopts',':-rangep'});
   #print("00",subpltemp,tmp);
   subplt:=`if`(has(subpltemp,{':-plopts',':-range',':-rangep'}),[subpltemp],[{}]);
   tmp:=op(tmp);
   #print("TMP ",tmp ,nops(tmp));
   if tmp::{'Vector[column]',`+`,`*`,`=`, `symbol`,procedure} then
     if tmp::'Vector[column]'(3) and indets(tmp)={} then
        subL:=[tmp[1]*vars[1]+tmp[2]*vars[2]+tmp[3]];
      elif hastype(tmp,'Vector[column]'(2)) and hastype(tmp,list)  then
        vv:=select(type,tmp,'Vector[column]'(2))[];
        ll:=select(type,tmp,list)[];
        subL:= [(ll[2] - vars[2])*vv[1] - vv[2]*(ll[1] - vars[1])];
       subL:=[tmp];
 elif nops(tmp)= 2  then
   #print("0th nops(tmp)",nops(tmp),tmp);
   # print("here here now");
   if hastype(tmp,'Vector[column]'(3)) and hastype(tmp,list) then
      #print("in  here here");
      vv:=(select(type,tmp,('Vector[column]'(3)))[]);
      vv:=(select(type,tmp,('Vector[column]'(2)))[]);
      subL:=[tmp];
    #a list of lines with possible sub-options if
   n:=nops(l1);
   subplt:=[];
   subL:=[];
   for i to n do
     subpltemp:=select(has,l1[i],{':-plopts',':-range',':-rangep'});
     #print("subpltemp",subpltemp);
     #print("subpltemp",has(subpltemp,{':-plopts',':-range',':-rangep'}));
     if has(subpltemp,{':-plopts',':-range',':-rangep'})then subplt:=  [subplt[],subpltemp]else subplt:=[subplt[],{}] end if;
     tmp:=select(not(has),l1[i],{':-plopts',':-range',':-rangep'});
     if type(tmp,set)then tmp:=op(tmp)end if;
     #print("1st nops(tmp)",nops(tmp),tmp);
        subL:=[subL[],tmp[1]*vars[1]+tmp[2]*vars[2]+tmp[3]];
        subL:=[subL[],tmp];
   #print("nops(tmp)",nops(tmp),tmp);
   #print("2nd here here now");
      #print(tmp,"vv " ,vv, "ll",ll);
      subL:=[subL[],ll+~alpha*vv];
      subL:= [subL[],(ll[2] - vars[2])*vv[1] - vv[2]*(ll[1] - vars[1])];
      subL:=[subL[],tmp];
end if:
return subplt, subL, n
L1:=2*x+3*y-4;
L1ext:={L1, range=[-5,2,-4,4],plopts=[colour=red ,linestyle=dot] };
L2:=<5,-1,3>:
L2ext:={L2,plopts=[linestyle=dash, thickness=4]}:
L3:=[[2,1],[4,-5]]:
L3ext:={L3,plopts=[color=red,thickness=1]}:
L4:=[[2,1,-3],[4,-5,-2]]:
L4ext:={L4,plopts=[color=green]}:
L5:=[[2,3],<-1,4>]:
L5ext:={L5,plopts=[color=green,thickness=2],range=[-6,6,-6,6]}:
L6:=[[1,2,-3],<-3,1,4>]:
L6ext:={L6,rangep=[-4,1],plopts[linestyle=dash]}:
L7:=<1+3*alpha,4-1*alpha,-1+2*alpha>:
L7ext:={L7,rangep=[-4,1],plopts=[colour=purlpe,thickness=3]}:
L8:=[<2|3|1>,<4|7|2>]:
L8ext:={L8,plopts=[colour=red]}:
2*x+3*y-4
{2*x+3*y-4, plopts = [colour = red, linestyle = dot], range = [-5, 2, -4, 4]}
Lst:=[L1,L1ext,L2,L2ext,L3,L3ext,x^2+2*y^2+3-4*x*y,L4,L4ext,L5,L5ext,L6,L6ext,L7,L7ext,L8,L8ext]:
A,B,c:=sorts(Lst):
for i to c do
print(i,"  A= ",A[i],"    B= ",B[i]);
end do
1, "  A= ", {}, "    B= ", 2*x+3*y-4
2, "  A= ", {plopts = [colour = red, linestyle = dot], range = [-5, 2, -4, 4]}, "    B= ", 2*x+3*y-4
3, "  A= ", {}, "    B= ", 5*x-y+3
4, "  A= ", {plopts = [linestyle = dash, thickness = 4]}, "    B= ", 5*x-y+3
5, "  A= ", {}, "    B= ", [[2, 1], [4, -5]]
6, "  A= ", {plopts = [color = red, thickness = 1]}, "    B= ", [[2, 1], [4, -5]]
7, "  A= ", {}, "    B= ", x^2-4*x*y+2*y^2+3
8, "  A= ", {}, "    B= ", [[2, 1, -3], [4, -5, -2]]
9, "  A= ", {plopts = [color = green]}, "    B= ", [[2, 1, -3], [4, -5, -2]]
10, "  A= ", {}, "    B= ", -11+y+4*x
11, "  A= ", {plopts = [color = green, thickness = 2], range = [-6, 6, -6, 6]}, "    B= ", -11+y+4*x
12, "  A= ", {}, "    B= ", Vector[column](%id = 36893490129638901388)
13, "  A= ", {plopts[linestyle = dash], rangep = [-4, 1]}, "    B= ", Vector[column](%id = 36893490129638901628)
14, "  A= ", {}, "    B= ", Vector[column](%id = 36893490129638901988)
15, "  A= ", {plopts = [colour = purlpe, thickness = 3], rangep = [-4, 1]}, "    B= ", Vector[column](%id = 36893490129661594308)
16, "  A= ", {}, "    B= ", [Vector[row](%id = 36893490129661594428), Vector[row](%id = 36893490129661594548)]
17, "  A= ", {plopts = [colour = red]}, "    B= ", [Vector[row](%id = 36893490129661594428), Vector[row](%id = 36893490129661594548)]
Download 2024-11-09_A_Line_Type.mw
I'm trying some number theory functions and got a problem with prime factorization.
When I try the function ifactor in Maple, it works perfectly, but when I try it in MapleFlow, I get:
ifactor(50) = 50
Is there something I'm missing?
In the publication
https://www.scirp.org/pdf/apm_2021062513594181.pdf
I read that Maple18 contains the "Adomian Decomposition". In "Help" of "Maple2024" I found no direct reference to this method. I would like to ask you to provide references in the help text to this method for solving differential equations.
The other night, first time using Maple in more than 20 years, I asked for the solution to this, looking for u1 in terms of u2:
equ := u2 - u1/(-u1^2 + 1)
solve(equ, [u1])
==> u1 = (-1 + sqrt(4*u2^2 + 1))/(2*u2)
But this is sheer nonsense. The correct solution should be:
u1 = (-1 + sqrt(u2^2 + 1))/u2   ;; note the lack of 4x scaling inside the Sqrt, nor the 2x in the denominator.
What the heck??
I want collect 1/G(xi) & G'(xi)/G(xi) also 1/G(xi)*G(xi)/G(xi)  when they have power ,and give me what i looking for, i can do by hand but it take time any one can do this by maple code? like this picture below, and if possible find some arbitrary parameter
collect.mw
how this integro-differential equation can be solved?
any assumption or suggestion is appreciated. tnx in advance
eq:=diff(y(x),x)=y(x)+exp(x)*exp(-3*x)/2+int(exp(x+t)*y(t),t=0..x);
IC:=y(0)=1;
diff(y(x), x) = y(x)+(1/2)*exp(x)*exp(-3*x)+int(exp(x+t)*y(t), t = 0 .. x)
y(0) = 1
eq2:=g(x)=int(exp(x+t)*y(t),t=0..x);
g(x) = int(exp(x+t)*y(t), t = 0 .. x)
IC_2:=eval(eq2,[x=0,y=1])
g(0) = 0
sys:={diff(eq2,x),subs(rhs(eq2)=lhs(eq2),eq)}
{diff(g(x), x) = int(exp(x+t)*y(t), t = 0 .. x)+exp(2*x)*y(x), diff(y(x), x) = y(x)+(1/2)*exp(x)*exp(-3*x)+g(x)}
dsolve(sys union {IC,IC_2},numeric)
Error, (in dsolve/numeric/process_input) input system must be an ODE system, got independent variables {t, x}
Download integro-diffrential_problem.mw
Hey all Maple experts.I could really use some help with  diff,D,Diff
interface(version)
with(Physics[Vectors])
CompactDisplay(A_(x, y, z, t), `&varphi;`(x, y, z, t), v_(x, y, z, t), F_(x, y, z, t), v__x(x, y, z, t), v__y(x, y, z, t), v__z(x, y, z, t), A__x(x, y, z, t), A__y(x, y, z, t), A__z(x, y, z, t), quiet)
macro(Av = A_(x, y, z, t), `&vartheta;` = `&varphi;`(x, y, z, t), Vv = v_(x, y, z, t), Fv = F_(x, y, z, t))
show, ON, OFF, kd_, ep_, Av, vartheta, Vv, Fv
Fv = q*('-VectorCalculus[Nabla](`&vartheta;`)'-(diff(Av, t))+`&x`(Vv, `&x`(VectorCalculus[Nabla], Av)))
F_(x, y, z, t) = q*(-Physics:-Vectors:-Nabla(varphi(x, y, z, t))-(diff(A_(x, y, z, t), t))+Physics:-Vectors:-`&x`(v_(x, y, z, t), Physics:-Vectors:-Curl(A_(x, y, z, t))))
Av = A__x(x, y, z, t)*_i+A__y(x, y, z, t)*_j+A__z(x, y, z, t)*_k, Vv = v__x(x, y, z, t)*_i+v__y(x, y, z, t)*_j+v__z(x, y, z, t)*_k, F_(x, y, z, t) = F__x*_i+F__y*_j+F__z*_k
A_(x, y, z, t) = A__x(x, y, z, t)*_i+A__y(x, y, z, t)*_j+A__z(x, y, z, t)*_k, v_(x, y, z, t) = v__x(x, y, z, t)*_i+v__y(x, y, z, t)*_j+v__z(x, y, z, t)*_k, F_(x, y, z, t) = F__x*_i+F__y*_j+F__z*_k
subs[eval](A_(x, y, z, t) = A__x(x, y, z, t)*_i+A__y(x, y, z, t)*_j+A__z(x, y, z, t)*_k, v_(x, y, z, t) = v__x(x, y, z, t)*_i+v__y(x, y, z, t)*_j+v__z(x, y, z, t)*_k, F_(x, y, z, t) = F__x*_i+F__y*_j+F__z*_k, F_(x, y, z, t) = q*(-Physics[Vectors][Nabla](varphi(x, y, z, t))-(diff(A_(x, y, z, t), t))+Physics[Vectors][`&x`](v_(x, y, z, t), Physics[Vectors][Curl](A_(x, y, z, t)))))
F__x*_i+F__y*_j+F__z*_k = q*(-(diff(varphi(x, y, z, t), x))*_i-(diff(varphi(x, y, z, t), y))*_j-(diff(varphi(x, y, z, t), z))*_k-(diff(A__x(x, y, z, t), t))*_i-(diff(A__y(x, y, z, t), t))*_j-(diff(A__z(x, y, z, t), t))*_k+(-v__y(x, y, z, t)*(diff(A__x(x, y, z, t), y))+v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x))+v__z(x, y, z, t)*(diff(A__z(x, y, z, t), x))-v__z(x, y, z, t)*(diff(A__x(x, y, z, t), z)))*_i+(-v__z(x, y, z, t)*(diff(A__y(x, y, z, t), z))+v__z(x, y, z, t)*(diff(A__z(x, y, z, t), y))+v__x(x, y, z, t)*(diff(A__x(x, y, z, t), y))-v__x(x, y, z, t)*(diff(A__y(x, y, z, t), x)))*_j+(v__y(x, y, z, t)*(diff(A__y(x, y, z, t), z))-v__y(x, y, z, t)*(diff(A__z(x, y, z, t), y))-v__x(x, y, z, t)*(diff(A__z(x, y, z, t), x))+v__x(x, y, z, t)*(diff(A__x(x, y, z, t), z)))*_k)
map(Component, F__x*_i+F__y*_j+F__z*_k = q*(-(diff(varphi(x, y, z, t), x))*_i-(diff(varphi(x, y, z, t), y))*_j-(diff(varphi(x, y, z, t), z))*_k-(diff(A__x(x, y, z, t), t))*_i-(diff(A__y(x, y, z, t), t))*_j-(diff(A__z(x, y, z, t), t))*_k+(-v__y(x, y, z, t)*(diff(A__x(x, y, z, t), y))+v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x))+v__z(x, y, z, t)*(diff(A__z(x, y, z, t), x))-v__z(x, y, z, t)*(diff(A__x(x, y, z, t), z)))*_i+(-v__z(x, y, z, t)*(diff(A__y(x, y, z, t), z))+v__z(x, y, z, t)*(diff(A__z(x, y, z, t), y))+v__x(x, y, z, t)*(diff(A__x(x, y, z, t), y))-v__x(x, y, z, t)*(diff(A__y(x, y, z, t), x)))*_j+(v__y(x, y, z, t)*(diff(A__y(x, y, z, t), z))-v__y(x, y, z, t)*(diff(A__z(x, y, z, t), y))-v__x(x, y, z, t)*(diff(A__z(x, y, z, t), x))+v__x(x, y, z, t)*(diff(A__x(x, y, z, t), z)))*_k), 1)
F__x = -v__y(x, y, z, t)*(diff(A__x(x, y, z, t), y))*q+v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x))*q+v__z(x, y, z, t)*(diff(A__z(x, y, z, t), x))*q-v__z(x, y, z, t)*(diff(A__x(x, y, z, t), z))*q-(diff(varphi(x, y, z, t), x))*q-(diff(A__x(x, y, z, t), t))*q
collect(F__x = -v__y(x, y, z, t)*(diff(A__x(x, y, z, t), y))*q+v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x))*q+v__z(x, y, z, t)*(diff(A__z(x, y, z, t), x))*q-v__z(x, y, z, t)*(diff(A__x(x, y, z, t), z))*q-(diff(varphi(x, y, z, t), x))*q-(diff(A__x(x, y, z, t), t))*q, [q, v__x(x, y, z, t), v__y(x, y, z, t), v__z(x, y, z, t)])
F__x = (v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x)-(diff(A__x(x, y, z, t), y)))+(diff(A__z(x, y, z, t), x)-(diff(A__x(x, y, z, t), z)))*v__z(x, y, z, t)-(diff(varphi(x, y, z, t), x))-(diff(A__x(x, y, z, t), t)))*q
convert(F__x = (v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x)-(diff(A__x(x, y, z, t), y)))+(diff(A__z(x, y, z, t), x)-(diff(A__x(x, y, z, t), z)))*v__z(x, y, z, t)-(diff(varphi(x, y, z, t), x))-(diff(A__x(x, y, z, t), t)))*q, Diff)
F__x = (v__y(x, y, z, t)*(Diff(A__y(x, y, z, t), x)-(Diff(A__x(x, y, z, t), y)))+(Diff(A__z(x, y, z, t), x)-(Diff(A__x(x, y, z, t), z)))*v__z(x, y, z, t)-(Diff(varphi(x, y, z, t), x))-(Diff(A__x(x, y, z, t), t)))*q
convert(F__x = (v__y(x, y, z, t)*(diff(A__y(x, y, z, t), x)-(diff(A__x(x, y, z, t), y)))+(diff(A__z(x, y, z, t), x)-(diff(A__x(x, y, z, t), z)))*v__z(x, y, z, t)-(diff(varphi(x, y, z, t), x))-(diff(A__x(x, y, z, t), t)))*q, D)
F__x = (v__y(x, y, z, t)*((D[1](A__y))(x, y, z, t)-(D[2](A__x))(x, y, z, t))+((D[1](A__z))(x, y, z, t)-(D[3](A__x))(x, y, z, t))*v__z(x, y, z, t)-(D[1](varphi))(x, y, z, t)-(D[4](A__x))(x, y, z, t))*q
Hello everyone, in the result of this command execution process, it appears that the symbols for partial derivatives and derivatives in equation (8) are displayed incorrectly. What should I do?
Download error_display.mw
I am trying to compute partial derivatives of some complicated expression which include summations. First, I noticed that sum behaves differently if I use 1D vs. 2D math. Why?
Questions:
  1. Partial derivative of a summation: why is it not just 2*X[i]?
  2. Partial derivative of a double summation: how to define the nested structure of a double summation with j<>i?
  3. System of n+1 equations: how to define and solve for it?
For 3., each i equation is the partial derivative of my complicated expression with summations with respect to X[i], where i ranges from 1 to n. The last equation is the partial derivative with respect to X_r (a fixed variable).
A := sum(X[i]^2, i = 1 .. n); eq[1] := diff(A, X[i]) = 0
sum(2*X[i], i = 1 .. n) = 0
B__wrong := sum(sum((X__r*w+X[i])*(X__r*w+X[j]), j = 1 .. n), i = 1 .. n); B__correct := 'sum(sum((X__r*w+X[i])*(X__r*w+X[j]), j = 1 .. n), i = 1 .. n)'
n^2*X__r^2*w^2+sum(sum(X__r*w*X[j]+X[i]*X[j], j = 1 .. n)+n*X__r*w*X[i], i = 1 .. n)
eqs := seq(eq[i], i = 1 .. n); vars := seq(X[i], i = 1 .. n)
Error, range bounds in seq must be numeric or character
Download equations_with_summations.mw
On some occasions I have seen output like this
where the user name is replaced by a placeholder.
How to achieve this?
Let P(u,v) = -u⁴+88u³v-146u²v²+88uv³-v⁴+2u²+40uv+2v²-1, with P(u,v)=0,
and u0 = sqrt(2)/6 i,  v0 = -sqrt(2)/6 i. We see that P(u0,v0)=0.
Direct substitution of implicitdiff(P(u,v),v,u) at u0, v0 leads to 0/0.
For obtaining the true value of dv/du at (u0,v0) we have written in Maple:
solve(limit(subs(v=v0+k*(u-u0), implicitdiff(P(u,v),v,u)), u=u0)-k, k);
There are two solutions: 49/113 - 72*sqrt(2)/113*I, and 49/113 + 72*sqrt(2)/113*I.
However we were unable to determine the true value of d²v/du² at (u0,v0).
QUESTION:  How to determine it?
First 60 61 62 63 64 65 66 Last Page 62 of 2429
