Warm greetings.
Is it possible to solve the numerical scheme present in the below paper.
Anita Chaturvedi, Kokila Ramesh, and Vatsala G A. (2017). “A MATHEMATICAL APPROACH TO STUDY THE EFFECT OF POLLUTANTS/TOXICANTS IN AQUATIC ENVIRONMENT.” International Journal of Research - Granthaalayah, 5(4) RAST, 33-38.
https://doi.org/10.5281/zenodo.803418
Could please help me solving the following problem?
Thank you a lot.
The question https://www.mapleprimes.com/questions/233780-Plot-Absolute-Advantage-Of-Option-A disappeared (I know since I answered today).
Why?
I simplified a vector column using side relations. Then I wanted to evaluate using
eval( equation,  [x1=3,  x2=5......})
But side relations uses the reverse order i.e. after evaluation
[3=x1, 5=x2......]
So then the internals of the list need to be swaped tto work with eval.That is easy. I am just wondering is there a neater way to achieve this?
P1 := Vector(3, {(1) = -(y[1]-y[3])*(y[2]-y[3])*((x[2]^2-x[2]*x[3]+x[3]^2)*x[1]^2-x[2]*x[3]*(x[2]+x[3])*x[1]+x[2]^2*x[3]^2)*(y[1]-y[2]), (2) = -(x[1]-x[3])*(x[2]-x[3])*(x[1]-x[2])*((y[2]^2-y[2]*y[3]+y[3]^2)*y[1]^2-y[2]*y[3]*(y[2]+y[3])*y[1]+y[2]^2*y[3]^2), (3) = ((-y[1]^2*y[2]+(3*y[2]*y[3]-y[3]^2)*y[1]-y[2]^2*y[3])*x[2]+x[3]*(y[1]^2*y[3]+y[2]*(y[2]-3*y[3])*y[1]+y[2]*y[3]^2))*x[1]^2+((y[1]^2*y[3]+y[2]*(y[2]-3*y[3])*y[1]+y[2]*y[3]^2)*x[2]^2+3*x[3]*(y[2]-y[3])*(y[1]-y[3])*(y[1]-y[2])*x[2]-x[3]^2*(y[1]^2*y[2]+(-3*y[2]*y[3]+y[3]^2)*y[1]+y[2]^2*y[3]))*x[1]-x[3]*((y[1]^2*y[2]+(-3*y[2]*y[3]+y[3]^2)*y[1]+y[2]^2*y[3])*x[2]-x[3]*(y[1]^2*y[3]+y[2]*(y[2]-3*y[3])*y[1]+y[2]*y[3]^2))*x[2]})
eqns := {(x[1]-x[2])*(x[2]-x[3])*(x[3]-x[1]) = R, (y[1]-y[2])*(y[2]-y[3])*(y[3]-y[1]) = S, x[1]^2*x[2]^2-x[1]^2*x[2]*x[3]+x[1]^2*x[3]^2-x[1]*x[2]^2*x[3]-x[1]*x[2]*x[3]^2+x[2]^2*x[3]^2 = Y, y[1]^2*y[2]^2-y[1]^2*y[2]*y[3]+y[1]^2*y[3]^2-y[1]*y[2]^2*y[3]-y[1]*y[2]*y[3]^2+y[2]^2*y[3]^2 = X, x[1]^2*x[2]+x[1]^2*x[3]+x[1]*x[2]^2-6*x[1]*x[2]*x[3]+x[1]*x[3]^2+x[2]^2*x[3]+x[2]*x[3]^2 = Z, y[1]^2*y[2]+y[1]^2*y[3]+y[1]*y[2]^2-6*y[1]*y[2]*y[3]+y[1]*y[3]^2+y[2]^2*y[3]+y[2]*y[3]^2 = W}
P1new := simplify(P1, eqns)
Vector[column](%id = 36893490132854572084)
values := {x[1] = 3, x[2] = 5, x[3] = 7, y[1] = 2, y[2] = -11, y[3] = 13}
vals1 := eval(eqns, values)
{-3432 = S, 16 = R, 120 = Z, 316 = Y, 2018 = W, 22753 = X}
eval(P1new, vals1)
vals1swap := [seq(rhs(vals1[i]) = lhs(vals1[i]), i = 1 .. nops(vals1))]
[S = -3432, R = 16, Z = 120, Y = 316, W = 2018, X = 22753]
eval(P1new, vals1swap)
Vector[column](%id = 36893490132849052116)
eval(P1, values)
Vector[column](%id = 36893490132871267020)
Download Q_6-03-2022_side_rels_and_eval.mw
Need help to plot a graph along x-axis  in attached worksheet.
help_graph.mw
with(plots):with(plottools):
Solve diagonal resistance of nodes (0,0,0)-(3,4,5), (Edge length = ohm).(156/47 ohm)
plots[display]([nodes, node2, plotlinesx], scaling = constrained, style = wireframe, axes = boxed, orientation = [-50, 70, 0])
Solve minimum diagonal surface distance of nodes (0,0,0)-(3,4,5).(sqrt(74))
Download Resistance-345.mw
Edge length = ohm, therefore, each edge has 3, 4 and 5 ohm, respectivery. (156/47 ohm)
Solve minimum diagonal surface distance of nodes (0,0,0)-(3,4,5). (sqrt(74))
Electric circuit study.
Tokoro.
A have som problems when i Will save a project. It Will take 2-5 Minutes where my other freinds never Experince this? Also i have some problems when i pauses writing, when i take notes in class, it Will give me the loading circle on mac( iam using a MacBook Air 2018)
i hope you Can help:)
thx
Hi, im trying to optimize a function with a constraint.
I've tried the Optimize package but I can't seem to make it work.
I've attached  an image to my question, witht the function and the constraint. I want to find the optimal "t_x"
Function: rho*ln((-beta*tau + rho)/(1 + t__x)) + sigma*ln(sigma/(1 + t__y)) + beta*tau + B - rho - sigma - beta*tau*ln((-beta*tau + rho)/(1 + t__x))
Constaint: -t__x*(-beta*tau + rho)/(1 + t__x) + t__y*sigma/(1 + t__y) = R
Hope you can help
Dear Colleagues,
I am trying to solve the following system of ode
odeSystem := {diff(y1(x), x) = -x*y2(x)-(1+x)*y3(x), diff(y2(x), x) = -x*y1(x)-(1+x)*y4(x), diff(y3(x), x) = -x*y1(x)-(1+x)*y4(x)-5*x*cos((1/2)*x^2), diff(y4(x), x) = -x*y2(x)-(1+x)*y3(x)+5*x*sin((1/2)*x^2), y1(0) = 5, y2(0) = 1, y3(0) = -1, y4(0) = 0};
systemSol := dsolve(odeSystem);
However, the result displayed is not explicit and contains integral sign. Please, I need help to obtain explicit result.
Please see the attached file; I'm attempting to do some calculations with the 'PDETools' package; notice the first term in equation (4), where sqrt(x2+y2) is not canceling in the fraction, despite using the 'simplify' command; why is this happening, and how can I achieve complete simplification?
Ques_Mapleprime.mw
with(PDEtools):
DepVars := [u(x, y, t), U(xi, eta)]; 1; alias(u = u(x, y, t))
u
xi[1] := 1/2*(x^2+y^2); 1; xi[2] := t; 1; u := (h(t)+(x^2+y^2)*(1/2))*arccos(x/sqrt(x^2+y^2))/t+U(xi[1], xi[2])
(1/2)*x^2+(1/2)*y^2
t
(h(t)+(1/2)*x^2+(1/2)*y^2)*arccos(x/(x^2+y^2)^(1/2))/t+U((1/2)*x^2+(1/2)*y^2, t)
(diff(u, x))*(diff(u, y))
(x*arccos(x/(x^2+y^2)^(1/2))/t-(h(t)+(1/2)*x^2+(1/2)*y^2)*(1/(x^2+y^2)^(1/2)-x^2/(x^2+y^2)^(3/2))/((1-x^2/(x^2+y^2))^(1/2)*t)+(D[1](U))((1/2)*x^2+(1/2)*y^2, t)*x)*(y*arccos(x/(x^2+y^2)^(1/2))/t+(h(t)+(1/2)*x^2+(1/2)*y^2)*x*y/((x^2+y^2)^(3/2)*(1-x^2/(x^2+y^2))^(1/2)*t)+(D[1](U))((1/2)*x^2+(1/2)*y^2, t)*y)
collect(simplify(subs(1/2*(x^2+y^2) = xi, t = eta, (x*arccos(x/(x^2+y^2)^(1/2))/t-(h(t)+(1/2)*x^2+(1/2)*y^2)*(1/(x^2+y^2)^(1/2)-x^2/(x^2+y^2)^(3/2))/((1-x^2/(x^2+y^2))^(1/2)*t)+(D[1](U))((1/2)*x^2+(1/2)*y^2, t)*x)*(y*arccos(x/(x^2+y^2)^(1/2))/t+(h(t)+(1/2)*x^2+(1/2)*y^2)*x*y/((x^2+y^2)^(3/2)*(1-x^2/(x^2+y^2))^(1/2)*t)+(D[1](U))((1/2)*x^2+(1/2)*y^2, t)*y))), D, 'distributed')
(1/4)*(2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*x^3+2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*x*y^2)*(2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*x^2+2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*y^2)*(D[1](U))(xi, eta)^2/(y*(x^2+y^2)^2*eta^2)+(1/4)*((2*arccos(x/(x^2+y^2)^(1/2))*x^3*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)+2*arccos(x/(x^2+y^2)^(1/2))*x*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)*y^2-x^2*y^2-y^4-2*h(eta)*y^2)*(2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*x^2+2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*y^2)+(2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*x^3+2*(y^2/(x^2+y^2))^(1/2)*(x^2+y^2)^(1/2)*eta*x*y^2)*(2*arccos(x/(x^2+y^2)^(1/2))*x^2*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)+2*arccos(x/(x^2+y^2)^(1/2))*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)*y^2+x^3+x*y^2+2*h(eta)*x))*(D[1](U))(xi, eta)/(y*(x^2+y^2)^2*eta^2)+(1/4)*(2*arccos(x/(x^2+y^2)^(1/2))*x^3*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)+2*arccos(x/(x^2+y^2)^(1/2))*x*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)*y^2-x^2*y^2-y^4-2*h(eta)*y^2)*(2*arccos(x/(x^2+y^2)^(1/2))*x^2*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)+2*arccos(x/(x^2+y^2)^(1/2))*(x^2+y^2)^(1/2)*(y^2/(x^2+y^2))^(1/2)*y^2+x^3+x*y^2+2*h(eta)*x)/(y*(x^2+y^2)^2*eta^2)
Download Ques_Mapleprime.mw
Hi, is it possible to convert mathematica files into maple. i was trying to upload mathematica file here but got failed, so uploading mathematica file into pdf. could anyone can help me to convert these file into maple.
Conversion.pdf
Could you help me to convert the following maple solution expressed by the hypergeom function to the LegendreP and Q function?
diff(T[3](t), t, t)+3*(diff(a(t), t))*(diff(T[3](t), t))/a(t)+(2*(diff(a(t), t, t))/a(t)+6*(diff(a(t), t))^2/a(t)^2+(-Omega^2+6)/a(t)^2)*T[3](t)
diff(diff(T[3](t), t), t)+3*(diff(a(t), t))*(diff(T[3](t), t))/a(t)+(2*(diff(diff(a(t), t), t))/a(t)+6*(diff(a(t), t))^2/a(t)^2+(-Omega^2+6)/a(t)^2)*T[3](t)
"a(t) :=Zeta*(1-(1-t/(Zeta^()))^(2))^(1/(2)) "
proc (t) options operator, arrow, function_assign; Zeta*(1-(1-t/Zeta)^2)^(1/2) end proc
ODE2 := diff(T[3](t), t, t)+3*(diff(a(t), t))*(diff(T[3](t), t))/a(t)+(2*(diff(a(t), t, t))/a(t)+6*(diff(a(t), t))^2/a(t)^2+(-Omega^2+6)/a(t)^2)*T[3](t)
diff(diff(T[3](t), t), t)+3*(1-t/Zeta)*(diff(T[3](t), t))/((1-(1-t/Zeta)^2)*Zeta)+(2*(-(1-t/Zeta)^2/((1-(1-t/Zeta)^2)^(3/2)*Zeta)-1/((1-(1-t/Zeta)^2)^(1/2)*Zeta))/(Zeta*(1-(1-t/Zeta)^2)^(1/2))+6*(1-t/Zeta)^2/((1-(1-t/Zeta)^2)^2*Zeta^2)+(-Omega^2+6)/(Zeta^2*(1-(1-t/Zeta)^2)))*T[3](t)
generalsol := dsolve(ODE2, T[3](t))
T[3](t) = _C1*hypergeom([1/2+(-Omega^2+1)^(1/2), 1/2-(-Omega^2+1)^(1/2)], [1-((1/2)*I)*15^(1/2)], (1/2)*t/Zeta)*t^(-((1/4)*I)*15^(1/2)-1/4)*(2*Zeta-t)^(((1/4)*I)*15^(1/2)-1/4)+_C2*(-(-2*Zeta+t)*t)^(((1/4)*I)*15^(1/2)-1/4)*hypergeom([((1/2)*I)*15^(1/2)+1/2+(-Omega^2+1)^(1/2), ((1/2)*I)*15^(1/2)+1/2-(-Omega^2+1)^(1/2)], [1+((1/2)*I)*15^(1/2)], (1/2)*t/Zeta)
convert(_C1*hypergeom([1/2+sqrt(-Omega^2+1), 1/2-sqrt(-Omega^2+1)], [1-I*sqrt(15)*(1/2)], t/(2*Zeta))*t^(-I*sqrt(15)*(1/4)-1/4)*(2*Zeta-t)^(I*sqrt(15)*(1/4)-1/4), LegendreP)
_C1*GAMMA(1-((1/2)*I)*15^(1/2))*(-t/Zeta)^(((1/4)*I)*15^(1/2))*LegendreP(-1/2+(-Omega^2+1)^(1/2), ((1/2)*I)*15^(1/2), 1-t/Zeta)*t^(-((1/4)*I)*15^(1/2)-1/4)*(2*Zeta-t)^(((1/4)*I)*15^(1/2)-1/4)/((2*Zeta-t)/Zeta)^(((1/4)*I)*15^(1/2))
convert(_C2*(-t*(t-2*Zeta))^(I*sqrt(15)*(1/4)-1/4)*hypergeom([I*sqrt(15)*(1/2)+1/2+sqrt(-Omega^2+1), I*sqrt(15)*(1/2)+1/2-sqrt(-Omega^2+1)], [1+I*sqrt(15)*(1/2)], t/(2*Zeta)), LegendreQ)
_C2*(-t*(-2*Zeta+t))^(((1/4)*I)*15^(1/2)-1/4)*hypergeom([((1/2)*I)*15^(1/2)+1/2+(-Omega^2+1)^(1/2), ((1/2)*I)*15^(1/2)+1/2-(-Omega^2+1)^(1/2)], [1+((1/2)*I)*15^(1/2)], (1/2)*t/Zeta)
Download solve3.mw
Like this
I was wondering if it is possible to write Maple code in 2D notation inside .mpl and have it converted automatically to standard Maple 1D math.
For example, suppose I have A.mpl file with the content
#--- this is inside A.mpl file
ode:=y''(x)+y'(x)=sin(x);
ic:=y(0)=1,y'(0)=0;
dsolve([ode,ic],y(x));
Right now, reading this file in worksheet or even in document mode gives error:
        read "A.mpl"
Error, on line 1, syntax error, unexpected single forward quote:
But in document mode, one can type this in, and Maple will accept it.
Since I do not use document mode and most of my code is in mpl files, I was wondering if one can write y'(x) instead of diff(y(x),x) and have maple automatically convert the code as it reads it somehow?
I find it much easier and more natural to write   y''(0)=1  than (D@@2)(y)(0)=1  for example.
I do understand the technical problems parsing this as ' has special meaning in Maple. But Maple does handle this input OK if typed in by hand in document 2D mode. It just needs to extend this to reading it from mpl files.
May be a future release of Maple will support this (using some switches or option when reading the file?)
Hi all!
I was wondering if it was possible to execute different subsections in my sheet based on if statements? I'm calculating two different processes and by being able to switch between the two with if statemens it would save me a lot of variables. Lets say i have three subsections in my sheet:
  • Variables
  • Process 1 calculation
  • Process 2 calculation
So by using an if statement i can choose which calculation that should be used, and therefore i can use the same variables. Or at least that's what i hope :)
The two points on the sphere has radius r=1/2. So, the distance is 1.
The three points on the sphere has radius r=1/sqrt(3). So, all distances are 1.
The four points on the sphere has radius r=sqrt(6)/4. So, all distances are 1.
What is the smallest sphere radius for 5 points and above numbers?
Find the smallest sphere radius and 3D position of each point.
Answer of smaller radius is better.
Tokoro.
All distances of point to point on the sphere to be integer.
What is the smallest sphere radius for 5 points and above numbers?  Find the smallest sphere radius and 3D position of each point.
with(plots)with(GraphTheory); with(LinearAlgebra); with(SpecialGraphs)
with(plottools)
The answer of 4 points. r=sqrt(6)/4
plots[display]([c, nodes, plotlinesx], scaling = constrained, style = wireframe, axes = boxed)
Download 3D-4points.mw
First 374 375 376 377 378 379 380 Last Page 376 of 2469
