Here is an example where IntegrationTools:-Combine does not seem capable to combine two integrals whose lower bounds are -infinity (same situation holds where upper bounds equal to +infinity).
Is there a way to Combine(J1) without using the J3 workaround?
Is there any mathematical reason why Combine(J1) does not work or it is due to the way Maple handles infinity?
IntegrationTools_Combine.mw
IsFrobeniusGroup(SmallGroup(20, 3)) will get true, but IsFrobeniusPermGroup(SmallGroup(20, 3)) will get false. What happen? As the documentation, it will get same result:
The two definitions are equivalent in the following sense.  If G is a Frobenius permutation group, then G is Frobenius as an abstract group
I have the following double integral:
In the above integral, r and sigma are the random variables: r is distributed normally with a mean and standard deviation equal to sigma, which is a random variable by itself (k near sigma in integral is a known parameter). Sigma is distributed lognormally, with a known mean and standard deviation. The probability density function of the sigma is defined by fs(sigma) in the above integral. How is it possible to solve this integral in Maple?
I want a maple code to solve the caputo fabrizio differential equations using Runge Kutta method with implicit functions and impulsive conditions in maple. Is there any code structure for that.
with(Student[NumericalAnalysis]);
with(DEtools);
f := proc(u, r) local res; res := 1/25*r^2 + (sin(u(r)) + sin(diff(u(r), [r $ 1/5])))/(r^2 + 47); return res; end proc;
RK4 := proc(f, u0, r0, h, n) local u, r, i, k1, k2, k3, k4; u := Vector(n + 1); r := Vector(n + 1); u[1] := u0; r[1] := r0; for i to n do k1 := f(u[i], t[i]); k2 := f(u[i] + 1/2*h*k1, r[i] + 1/2*h); k3 := f(u[i] + 1/2*h*k2, r[i] + 1/2*h); k4 := f(u[i] + h*k3, r[i] + h); u[i + 1] := u[i] + 1/6*h*(k1 + 2*k2 + 2*k3 + k4); r[i + 1] := r[i] + h; end do; return [u, r]; end proc;
RK4 := proc (f, u0, r0, h, n) local u, r, i, k1, k2, k3, k4; u
   := Vector(n+1); r := Vector(n+1); u[1] := u0; r[1] := r0;
   for i to n do k1 := f(u[i], t[i]); k2 := f(u[i]+(1/2)*h*k1,
   r[i]+(1/2)*h); k3 := f(u[i]+(1/2)*h*k2, r[i]+(1/2)*h); k4 :=
   f(u[i]+h*k3, r[i]+h); u[i+1] := u[i]+(1/6)*h*(k1+2*k2+2*k3+k4\
  ); r[i+1] := r[i]+h end do; return [u, r] end proc
u0 := cos(abs(0.9))/15;
                      u0 := 0.04144066455
r0 := 0;
                            r0 := 0
h := 0.1;
                            h := 0.1
n := 100;
                            n := 100
solution := RK4(f, u0, r0, h, n)
u := solution[1];
r := solution[2];
plot(u, r, style = line, color = blue, labels = ["Time (r)", "Solution (u)"]);
 is this correct to solve the implicit fractional differential equations using 4th order Runge-Kutta Method. will fsolve command  solve the fractional differential equations ?
i am using maple 2023 and the physics package and have the following question:
I want to define a gauge-  plus coordinate covariant derivative i.e.
assuming i,j,k are SO(3) indices and greek indices describe 4-dim space-time (not necessary flat)
i need the following derivative:
D_sigma F_i _rho _lambda = nabla_sigma F_i _rho _lambda + epsilon_i ^j ^k  A_j_sigma  F_k~rho~lambda
with _ meaning lower indices and ^ upper indices and nabla the convenient coordinate covariant derivative of general relativity.
F is a tensor objekt with 2 space time indices and 1 so(3) indices (e.g. Yang Mills field strength) and A is the so(3)gauge potential
How can i define this Differentialoperator with the physics package.
I.e. i want to work with SO(3) Yang-Mills Fields in curved space time and need this generalized Differentialoperator
thanks for helping. I hope its clear from this ascii text in the screen
regards Michael
I want to find the formula for seq:
För example
{0,4,16,36,64,100,..}
{0,3,6,11,18,27.38,...}
How do i revers i backword fo get arithmetic sequence formula. I now the answare but want to learn how it's done in maple. I tried the app but i was not able to solve it. I have read the help and it looks like you have to use rsolve. Does anyboy has a sample to do not is trail and error.
Here we have a pretty well-behaved trig function:
y := t -> 144*cos(t)^6 - 216*cos(t)^4 + 32*cos(t)^3 + 81*cos(t)^2 - 24*cos(t) + 17;
proc (t) options operator, arrow; 144*cos(t)^6-216*cos(t)^4+32*cos(t)^3+81*cos(t)^2-24*cos(t)+17 end proc
plot(y(t), t=0..2*Pi, view=0..35);
Maple 2023 plots y^(3/2) with a strange artifact at t = Pi:
plot(y(t)^(3/2), t=0..2*Pi, view=0..200);
Any reason for that?  Maple 2021 and earlier used to produce the correct plot:
Download bug-in-plot.mw
Hi.
why in eq1 some parameters such as beta 1, Q110,... are not placed (They defined before eq1 !!!!)
TRASH.mw
When I use IdentifySmallGroup(DihedralGroup(4)), I will get result 8,3. Then I know DihedralGroup(4) is SmallGroup(8, 3) actually. But I will get different result when I use it in IsTransitive:
IsTransitive(DihedralGroup(4), [1, 2, 3, 4])
IsTransitive(SmallGroup(8, 3), [1, 2, 3, 4])
How to rectify this error.
NF-1.mw
How should optional input parameters be handled for procedures. The example has three optional inputs
vars:=[x,y]   ,  clr:="b"   and prnt:="y"  . if one wants to change prnt to"n", vars and clr values must be entered.
{vars:=[x,y]  } , { clr:="b" }  and{ prnt:="y"}  this is a good method because one just enteres prnt="n".  But have to remember the input parameter name prnt.
I have a 3rd option, but it is to complicated and probably unreliable to use in practice.  and with more than 3 optional inputs too difficult to code.
I am wondering  are the other approaches and what is the prefered methodology. I have about 30+ procedures to apply this to in a package.
Edit:-  I can change the prnt to boolean true, false instead of "y" , "n".  That would make the all the optional inputs different types.
In Test1 its should be vars::list:=[x,y] not vars::{list , `string`}:=[x,y]
Geomclr := "b"
"b"
Test1 := proc (A, B, vars::{list, string} := [x, y], clr::string := Geomclr, prnt::string := "y") if vars::string then clr := vars; vars := [x, y] end if; if clr = "y" or clr = "n" then prnt := clr; clr := Geomclr end if; print(clr); if prnt = "y" then print("good") end if; A*vars[1]+B*vars[2] end proc
Test1(A, B)
A*x+B*y
Test1(A, B, [r, s], "n")
Error, (in Test1) invalid left hand side in assignment
Test1(A, B, "g")
Test1(A, B, "n")
Test1(A, B, [x, y], "b", "n")
A*x+B*y
Test2 := proc (A, B, { vars::{list} := [x, y], clr::string := Geomclr, prnt::string := "y" }) print(clr); if prnt = "y" then print("good") end if; A*vars[1]+A*vars[2] end proc
Test2(A, B)
A*x+A*y
Test2(A, B, clr = "r")
A*x+A*y
Test2(A, B, prnt = "n")
A*x+A*y
A*x+A*y
Test2(A, B, prnt = "n", clr = "green", l = [r, s])
A*x+A*y
# 3 This is possible but is a very complicated method of handling the optional inputs and difficult the handle altered sequence on inputs.
Test3 := proc (A, B, vars::{list, string} := [x, y], clr::string := Geomclr, prnt::string := "y") local varsl, clrl, prntl; global Geomclr; varsl := vars; clrl := clr; prntl := prnt; if vars::string then varsl := [x, y]; if vars = "y" or vars = "n" then prntl := vars; clrl := Geomclr elif vars = "r" or vars = "g" or vars = "b" then clrl := vars end if elif vars::list and clr = "y" or clr = "n" then prntl := clr; clrl := Geomclr end if; if clr = "y" or clr = "n" and vars::string then prntl := clr; clrl := vars end if; print("Colour print out ", clrl); if prntl = "y" then print("This is a test Message") end if; A*varsl[1]+B*varsl[2] end proc
Test3(A, B)
A*x+B*y
Test3(A, B, [r, s])
A*r+B*s
Test3(A, B, [r, s], "n")
A*r+B*s
Test3(A, B, "n")
A*x+B*y
Test3(A, B, [r, s], "r", "n")
A*r+B*s
Test3(A, B, "r", "n")
A*x+B*y
(14)
Test3(A, B, "n", "r")
A*x+B*y
(15)
Download Q_2024-02-25_Test_proc_Args.mw
Cong:=proc(n)
 local  a,b,An,Bn,Cn,Dn:
if n mod 2 = 1
An:=0:     Bn:=0:
for a  from (round(-sqrt(n/(2)))) to round(sqrt(n/(2)) )
do:
for b  from (round(-sqrt(n)) )to round(sqrt(n) )do :
if (sqrt(n-2*a^(2)-b^(2)) )/(32)isInteger
then An:=An+1
elif (sqrt(n-2*a^(2)-b^(2)) )/(8) isInteger
then Bn:=Bn+1  fi:
od:  od:
 if 2*An=Bn
 return(True)  else  return(False)
fi: else if n mod 2 = 0 :
Cn:=0:  Dn:=0:
for a  from (round(-sqrt(n/(8)))) to round(sqrt(n/(8)) )
do :
 for b  from (round(-sqrt(n/(2)))) to round(sqrt(n/(2))) do:
f (sqrt(n/(2)-4*a^(2)-b^(2)) )/(32)isInteger
then Cn:=Cn+1
elif (sqrt(n/(2)-4*a^(2)-b^(2)) )/(8) isInteger
then Dn:=Dn+1 fi: od:  od:
if 2*Cn=Dn:
return(True)  else  return(False)fi:
end:
Why do I get this messge : Error, unterminated procedure. Thank you.
ow to get plot for the exact solution of a piecewise function and i need the correct plot which has curve started at y-axis (0.5) and goes till 2?
I am a beginner on Maple and I am working on approximate solutions of partial differential equations.
After finding the approximate solution I wanted to compare both the plots (The exact solution and the approximate one), is here any tool or command that allows me to do so ?
Thanks in Advance !
First 132 133 134 135 136 137 138 Last Page 134 of 2430
