In my code, without knowing what the expression is, other than it has RootOf, the code called allvalues and got internal error
Error, (in SolveTools:-Basis) invalid input: igcd received 5/7, which is not valid for its 2nd argument
Is this to be expected depending on the input, or is this some internal problem I need to report?
expr:=RootOf(R^4*b+R^2*a*_Z+2*_Z^2-exp(RootOf(tanh(1/2*(a^2-8*b)^(1/2)*(4*S-_Z)/a)^2*R^4*a^2-8*tanh(1/2*(a^2-8*b)^(1/2)*(4*S-_Z)/a)^2*R^4*b-R^4*a^2+8*R^4*b-8*exp(_Z))))
allvalues(expr)
Maple 2023.2 on windows 10
ps.  Reported to Maplesoft
To label axes, names with Maple typesetting tags can be used. This is convenient because the typesetting package does not have to be loaded and code is shorter. However, when used together with plot white spaces (mo(“ “)) sometimes do render. Below is an example where a white space after the character N is not rendered.
with(Typesetting):
ta:=Typesetting:-Typeset(`#mrow(mo("N "),mo("* "),msup(mo("mm"),mo("-2")))`)
Typesetting:-mrow(Typesetting:-mo("N "), Typesetting:-mo("* "), Typesetting:-msup(Typesetting:-mo("mm"), Typesetting:-mo("-2")), Typesetting:-msemantics = "atomic")
tb:=`#mrow(mo("N ",color="red"),mo("* "),msup(mo("mm"),mo("-2")))`
tc:=Typesetting:-Typeset(mrow(mo("N "),mo("* "),msup(mo("mm"),mo("-2"))))
Typesetting:-mrow(Typesetting:-mo("N "), Typesetting:-mo("* "), Typesetting:-msup(Typesetting:-mo("mm"), Typesetting:-mo("-2")))
plot(x,x=1..10,labels=[ta,tb],title=tc)
A workarround is adding an addtional tag mspace() or an invisible html character. Are there any others?
Since typesetting of normal Maple output shows the whitespace I am wondering if this way of plotting axis labels is intended.
Download Typesetting_white_space.mw
Hello, I would like to integrate a Maple sheet into a LaTeX sheet. How to do ? Thanks in advance.
If one writes:
y := x+1
x+1
Then, one can display y = x+1 using this notation
'y' = y
y = x+1
However, regardless of the type of punctuation I use with the Explore procedure (or even the IntertForm package), the value for y is calculated. (See examples below.)  My question is:
How can I get Explore to write it out as in line (2) with x evaluated?
Examples:
(The first is a jpg of what is shown since MaplePrimes cannot show the Explore output.)
Explore('y' = y, x = 0 .. 5, echoexpression = false)
Explore(y = y, x = 0 .. 5, echoexpression = false)
Explore(InertForm:-Display(y) = y, x = 0 .. 5, echoexpression = false)
Download Explore_with_Inert_Form_of_display.mw
I am relatively new to Maple and I'm just getting used to working with units.  Please explain to me why the final calculation does not eliminate m^3 in both the numerator and denominator. Thanks for your help!
Problem
What would be the mass of a Dyson Shell set at Venus' orbit from the sun?
The shell is 150 ft thick and each 1m^2 section is 200 kg.
The entire Earth's mass is 5.97×10^24 kg
The entire mass of the solar system minus the sun is 2.6667×10^27 kg
``NULLNULL
Assumptions
Gravitational pull from the sun is uniform through the depth of the shell.
Venus' average orbital distance from the sun is 67,237,910 miles we will use that as.
Pi
Pi
3.1415926535897932385
Dyson[Inside] := 355016117130*Unit('ft')``
NULLDyson[Outside] := 355016117280*Unit('ft')
355016117280*Units:-Unit(ft)
NULLNULL``
Vol[Dyson] := (4/3)*Pi*Dyson[Outside]^3-(4/3)*Pi*Dyson[Inside]^3 = 75621866085188578208340000*Pi*Units:-Unit(ft^3)"(->)"0.23757309894397957472e27*Units:-Unit(ft^3)
Total_Weight := 200*Unit('kg')*Vol[Dyson]/m^3
(6691789940422039289112993734304/15625)*Pi*Units:-Unit(kg*m^3)/m^3
0.13454641994365413638e28*Units:-Unit(kg*m^3)/m^3
Download Q_for_Dyson_Shell_Weight.mw
V := m^4*(1-(varphi/mu)^p);
V1 := diff(V, varphi);
-m^4*(varphi/mu)^p*p/varphi
V2 := diff(V1, varphi);
-m^4*(varphi/mu)^p*p^2/varphi^2+m^4*(varphi/mu)^p*p/varphi^2
f := Zeta * (varphi^2);
Zeta*varphi^2
f1 := diff(f, varphi);
2*Zeta*varphi
f2 := diff(f1, varphi);
2*Zeta
R:= simplify(((V/3-f1*V1/(3*V))/((1-kappa^2*f)/(12*kappa^2)+f1/V)));
4*kappa^2*m^4*(-3*(varphi/mu)^(2*p)*m^4+(varphi/mu)^(3*p)*m^4+3*(varphi/mu)^p*m^4-m^4-2*Zeta*(varphi/mu)^p*p+2*Zeta*(varphi/mu)^(2*p)*p)/((m^4*(Zeta*kappa^2*varphi^2-1)*(varphi/mu)^p+(-Zeta*kappa^2*varphi^2+1)*m^4+24*Zeta*varphi*kappa^2)*(-1+(varphi/mu)^p))
N:=evalf(int((3*V1*kappa^2*((2*V*V1)/3 - f1^2*V1*R/(3*V) - f1*V1^2/(3*V))/(V*(-f*kappa^2 + 1)*(-R*f1 - 2*V1))),varphi=varphi__hc..varphi__end)assuming varphi__hc > 0, varphi__hc > varphi__end);
-1.*(int(-3.*(varphi/mu)^p*p*kappa^2*(-.6666666667*m^8*(1.-1.*(varphi/mu)^p)*(varphi/mu)^p*p/varphi+5.333333333*Zeta^2*varphi*m^4*(varphi/mu)^p*p*kappa^2*(-3.*(varphi/mu)^(2.*p)*m^4+(varphi/mu)^(3.*p)*m^4+3.*(varphi/mu)^p*m^4-1.*m^4-2.*Zeta*(varphi/mu)^p*p+2.*Zeta*(varphi/mu)^(2.*p)*p)/((m^4*(Zeta*kappa^2*varphi^2-1.)*(varphi/mu)^p+(-1.*Zeta*kappa^2*varphi^2+1.)*m^4+24.*Zeta*varphi*kappa^2)*(-1.+(varphi/mu)^p)*(1.-1.*(varphi/mu)^p))-.6666666667*Zeta*m^4*((varphi/mu)^p)^2*p^2/(varphi*(1.-1.*(varphi/mu)^p)))/(varphi*(1.-1.*(varphi/mu)^p)*(-1.*Zeta*kappa^2*varphi^2+1.)*(-8.*kappa^2*m^4*(-3.*(varphi/mu)^(2.*p)*m^4+(varphi/mu)^(3.*p)*m^4+3.*(varphi/mu)^p*m^4-1.*m^4-2.*Zeta*(varphi/mu)^p*p+2.*Zeta*(varphi/mu)^(2.*p)*p)*Zeta*varphi/((m^4*(Zeta*kappa^2*varphi^2-1.)*(varphi/mu)^p+(-1.*Zeta*kappa^2*varphi^2+1.)*m^4+24.*Zeta*varphi*kappa^2)*(-1.+(varphi/mu)^p))+2.*m^4*(varphi/mu)^p*p/varphi)), varphi = varphi__end .. varphi__hc))
simplify(-1.*(int(-3.*(varphi/mu)^p*p*kappa^2*(-.6666666667*m^8*(1.-1.*(varphi/mu)^p)*(varphi/mu)^p*p/varphi+5.333333333*Zeta^2*varphi*m^4*(varphi/mu)^p*p*kappa^2*(-3.*(varphi/mu)^(2.*p)*m^4+(varphi/mu)^(3.*p)*m^4+3.*(varphi/mu)^p*m^4-1.*m^4-2.*Zeta*(varphi/mu)^p*p+2.*Zeta*(varphi/mu)^(2.*p)*p)/((m^4*(Zeta*kappa^2*varphi^2-1.)*(varphi/mu)^p+(-1.*Zeta*kappa^2*varphi^2+1.)*m^4+24.*Zeta*varphi*kappa^2)*(-1.+(varphi/mu)^p)*(1.-1.*(varphi/mu)^p))-.6666666667*Zeta*m^4*((varphi/mu)^p)^2*p^2/(varphi*(1.-1.*(varphi/mu)^p)))/(varphi*(1.-1.*(varphi/mu)^p)*(-1.*Zeta*kappa^2*varphi^2+1.)*(-8.*kappa^2*m^4*(-3.*(varphi/mu)^(2.*p)*m^4+(varphi/mu)^(3.*p)*m^4+3.*(varphi/mu)^p*m^4-1.*m^4-2.*Zeta*(varphi/mu)^p*p+2.*Zeta*(varphi/mu)^(2.*p)*p)*Zeta*varphi/((m^4*(Zeta*kappa^2*varphi^2-1.)*(varphi/mu)^p+(-1.*Zeta*kappa^2*varphi^2+1.)*m^4+24.*Zeta*varphi*kappa^2)*(-1.+(varphi/mu)^p))+2.*m^4*(varphi/mu)^p*p/varphi)), varphi = varphi__end .. varphi__hc)))
Error, (in content/content) invalid arguments
Download ex.mw
Can anyone help me factor this thing out, so I ll get an irreductible result?
x2 := 2*u - 2/3*(a - 1)*(a + 1)*u^3 + (26/45*a^4 - 4/9*a^2 + 26/45)*u^5 + O(u^6)
In an old question, @mbras asked for a "partial" `convert/elsymfun`. However, SymPy's sympy.polys.rings.PolyElement.symmetrize seems to provide more examples that cannot be handled by the program that appeared in that question.
For instance,
>>> from sympy import var
>>> var('x:z,p:r')
(x, y, z, p, q, r)
>>> from sympy.polys.polyfuncs import symmetrize
>>> symmetrize(x**2-(y**2+2**z),[y,x],formal=True,symbols=[p+p,q*q])[0]
-2**z - 4*p**2 + 2*q**2
>>> symmetrize(x*x*y+y*y*z+z*z*x,[y,x,z],formal=True,symbols=[p,q,r])
(0, x**2*y + x*z**2 + y**2*z, [(p, x + y + z), (q, x*y + x*z + y*z), (r, x*y*z)])
Though I can , can't the built-in  be generalized to such expressions (in other words, write the polynomial part of input as a symmetric part and a remainder with (named, if need be) elementary symmetric polynomials)?
Besides, since any symmetric polynomial can also be expressed in terms of the complete symmetric polynomials, is there a similar  command in Maple?
I have a small issue when trying to calculate the I have assigned 'g' to the derivative function, but I have to use 'subs' to obtain the images. Thank you for your insights
QFonction.mw
I find that if if declare a variable in a procedure inside a if  statement it Maple things something is wrong with the if statement:
tSound=proc(xMic,yMic,zMic,xGun,yGun,zGun,mode)
global vSound;
local locMic:=Vector([xMic,yMix,zMix]);
local locGun:=Vector([xGun,yGun,zGun]);   l
ocal delGunToMix;   if mode=1 then #`direct  `
local x=0.0;    <==remove this sand fine
delGunToMix:=locMic-locGun;
return vSound*Norm(delGunToMix);
elif  mode=2 then #`reflect off wall at z=0`
end if;   return 0.0;  end proc:
Error, invalid 'if' statement
==>I can delclare the variable 'local' outside the if. Why? It doesn't make much sense, though not that hard to avoid.
So, every year our family picks names for Christmas, but this year seemed odd.  My wife pointed out that one family always just happens to randomly pick another families name.  That is the majority of the time most of one family is always trading with another, the only rule is that each family member can not trade with a member of their own family.
I was wondering if someone could come up with a way to calculate just how random the choice actually was from the previous year or years using whatever means necessary .. graph theory came to mind.  The draw was done behind closed doors, so my wife questioned how failrly that was done, and so brought me here with the question ...
Was the name choosing really random or was it actually a fixed draw?
In our group there are total of 9 adults and 9 children, but actually the 2 youngest children swap gifts so it's really 9 adults and 7 children who can swap presents.  But I will breakdown the families less the two trading children.
Family A - 2 adults 1 child
Family B - 2 adults 2 children
Family C - 2 adults 2 children
Family D - 2 adults 2 children
Family E - 1 adult
Oh, a child can trade with another child or a parent and similarily a parent can trade with another parent or a child.
My code
reqn:=f(n+1) = f(n)  + sqrt(2*f(n+1)-f(n)):
rsolve({reqn, f(1) = 15},f(n));
I can not get the answer. How can I get the answer?
The uploaded worksheet begins to uniformly tile the Poincare disk with pentagons using hyperbolic reflection .
Although relatively easy to create the central pentagon and the first adjacent pentagon, it becomes increasingly difficult to determine which lines to reflect to create the remaining pentagons in the first tier adjacent to the central pentagon and more so to create the pentagons of the second tier adjacent to those in the first tier and so on.
Is there a better technique for accomplishing this?
In particular can Mobius tranformations be employed to do this? If so, please replay with or point to a working example of this for me to follow.
 Tile_Poincare_disk.mw
Sorry, I forgot that respondents to this question must establich their own link to the DirectSearch package.
I wonder if this a bug or Am I overlooking something?
I set infolevel[dsolve]:=5; and first time calling dsolve(ode), it works as expected. It prints on the screen the trace and steps it did.  But when I repeat the command dsolve, now it only prints one line and the rest of info that were printed before no longer show.
Should not the same information be printed each time? This is what happens on another example I tried. It seems infolevel does not work the same depending on the ode being solved?  Here is a worksheet attached to show the above.
Is there a workaround to make it display same information each time?
Maple 2023.2 on windows 10.
`Standard Worksheet Interface, Maple 2023.2, Windows 10, October 25 2023 Build ID 1753458`
ode:=[2*diff(x(t),t)+diff(y(t),t)=x(t)+y(t)+t,diff(x(t),t)+diff(y(t),t)=2*x(t)+3*y(t)+exp(t)];
dsolve(ode);
[2*(diff(x(t), t))+diff(y(t), t) = x(t)+y(t)+t, diff(x(t), t)+diff(y(t), t) = 2*x(t)+3*y(t)+exp(t)]
5
-> Solving each unknown as a function of the next ones using the order: [y(t), x(t)]
-> Calling odsolve with the ODE diff(diff(y(x) x) x) = 4*(diff(y(x) x))-y(x)-3*x+1 y(x) singsol = none
Methods for second order ODEs:
trying a quadrature
trying high order exact linear fully integrable
trying differential order: 2; linear nonhomogeneous with symmetry [0,1]
trying a double symmetry of the form [xi=0, eta=F(x)]
-> Try solving first the homogeneous part of the ODE
   checking if the LODE has constant coefficients
   <- constant coefficients successful
   -> Determining now a particular solution to the non-homogeneous ODE
      trying a rational particular solution
      <- rational particular solution successful
<- solving first the homogeneous part of the ODE successful
{x(t) = exp((2+3^(1/2))*t)*c__2+exp(-(-2+3^(1/2))*t)*c__1-3*t-11, y(t) = -(1/2)*exp((2+3^(1/2))*t)*c__2*3^(1/2)+(1/2)*exp(-(-2+3^(1/2))*t)*c__1*3^(1/2)-(3/2)*exp((2+3^(1/2))*t)*c__2-(3/2)*exp(-(-2+3^(1/2))*t)*c__1-(1/2)*exp(t)+2*t+7}
dsolve(ode);
5
dsolve(ode);
dsolve(ode);
ode:=diff(y(x),x$2)+y(x)=sin(x);
dsolve(ode);
diff(diff(y(x), x), x)+y(x) = sin(x)
trying a quadrature
      building a particular solution using variation of parameters
y(x) = sin(x)*c__2+cos(x)*c__1+(1/2)*sin(x)-(1/2)*cos(x)*x
dsolve(ode);
trying a quadrature
On a side note. the first line of the display is hard to read. Any one know what it is supposed to mean by the space between the 1 and y(x) at the end there?
Download infolevel_stops_working.mw
Another example where infolevel changes on second call to dsolve: The first call gives more information which is lost in the second call. There does not seem to be a way to fix this at user level.
ode:=diff(y(x),x)+(a*x+y(x))*y(x)^2=0:
infolevel[dsolve]:=5:
dsolve(ode)
Methods for first order ODEs:
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
differential order: 1; looking for linear symmetries
trying exact
trying Abel
The relative invariant s3 is: -1/27*a*(2*a^2*x^3-9)
The first absolute invariant s5^3/s3^5 is: 729*a^4*x^6*(2*a^2*x^3-15)^3/(2*a^2*x^3-9)^5
The second absolute invariant s3*s7/s5^2 is: 5/3/a^2*(2*a^2*x^3-9)/x^3*(2*a^4*x^6-21*a^2*x^3+18)/(2*a^2*x^3-15)^2
...checking Abel class AIL (45)
...checking Abel class AIL (310)
...checking Abel class AIR (36)
inverse of the transformation solving the problem is: {t = 1/2*(-2*a^2)^(1/3)*x, u(t) = -(-2*a^2)^(1/3)/a*y(x)}
<- Abel successful
y(x) = 2*a/(a^2*x^2+2*RootOf((-2*a^2)^(1/3)*AiryBi(_Z)*c__1*x+(-2*a^2)^(1/3)*x*AiryAi(_Z)+2*AiryBi(1, _Z)*c__1+2*AiryAi(1, _Z))*(-2*a^2)^(1/3))
dsolve(ode)
trying a quadrature
trying Bernoulli
trying separable
trying Chini
trying exact
trying Abel
<- Abel successful
Download another_example_info_level_changes.mw
I'd like to plot vectors with one beginning at the head of the other. The application is a reflection at a surface. VectorPositionPlot doesn't seem to do it.
The same kind of plot would be used to illustrate vector addition.
First 154 155 156 157 158 159 160 Last Page 156 of 2430
