I have some large systems of linear equations.  The solutions are probability generating functions.  I can get solutions in a few minutes for systems of up to n= 200 eqns or so, but Maple just cycles indefinitely if I try to solve much larger systems.  I really only need to perform Gaussian Elimination, as I only need to solve for one of the n solutions.  The matrices are sparse, there are only 3 non-zero entries per row.  I tried to get help from the manuals but I get the impression that sparse solutions are only available for numeric computations.   Doesn't Maple allow for sparse symbolic solutions?  If so, how to do it?
What is the correct way to plot objects which have been created by the geometry library.
e.g. circle, point, line, e.g.
restart; with(geometry)
point(B, 2, 0)
B
form(B)
point2d
coordinates(B)
[2, 0]
with(plots)
display(pointplot(B))
Error, (in plots:-pointplot) points are not in the correct format
Download plotpoint.mw
Hi everyone
how can i overcome this error to solve this ODE ? tnx in advanced.
U := 1:L := 10:k := 1:Dea := 0.00001:CA0 := 10:Pe := U*L/Dea:Da := k*CA0^2/Dea:
Eq1 := diff(CA(x), x, x) - Pe*diff(CA(x), x)/L = Da*L*CA(x)^2/CA0;
diff(diff(CA(x), x), x)-100000.0000*(diff(CA(x), x)) = 10000000.00*CA(x)^2
BCs := CA(0) = CA0, D(CA)(L) = 0
CA(0) = 10, (D(CA))(10) = 0
ans := dsolve([Eq1, BCs], numeric);
Download Hw.mw
Hallo every body
i have a question How can be written this system of eqautions without the variable "t"
eq10 := epsilon*F(-(V(t)*alpha^4*beta^2-V(t)*alpha^2*beta^4-S(t)*alpha^4*beta^2+S(t)*alpha^2*beta^4+X(t)*beta^4-Z(t)*alpha^4+S(t)*alpha^4-S(t)*beta^4-X(t)*beta^2+Z(t)*alpha^2-S(t)*alpha^2+S(t)*beta^2)/(alpha^2*(alpha^2-1)*(alpha^2-beta^2)*beta^2*(beta^2-1)), (W(t)*alpha^3*beta-W(t)*alpha*beta^3+Y(t)*beta^3-U(t)*alpha^3-Y(t)*beta+U(t)*alpha)/((alpha^2*beta^2-alpha^2-beta^2+1)*beta*alpha*(alpha^2-beta^2)), (X(t)*beta^2-Z(t)*alpha^2+V(t)*alpha^2-V(t)*beta^2-X(t)+Z(t))/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), -(Y(t)*alpha*beta^2-U(t)*alpha^2*beta+W(t)*alpha^2-W(t)*beta^2-Y(t)*alpha+beta*U(t))/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), -(X(t)*alpha^2*beta^2-Z(t)*alpha^2*beta^2-X(t)*alpha^2+beta^2*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), (Y(t)*alpha^3*beta^2-U(t)*alpha^2*beta^3-Y(t)*alpha^3+beta^3*U(t)+W(t)*alpha^2-W(t)*beta^2)/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), (X(t)*alpha^4*beta^2-Z(t)*alpha^2*beta^4-X(t)*alpha^4+beta^4*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)))-Y(t)*alpha
eq11 := alpha*X(t)
alpha*X(t)
eq12 := epsilon*F(-(V(t)*alpha^4*beta^2-V(t)*alpha^2*beta^4-S(t)*alpha^4*beta^2+S(t)*alpha^2*beta^4+X(t)*beta^4-Z(t)*alpha^4+S(t)*alpha^4-S(t)*beta^4-X(t)*beta^2+Z(t)*alpha^2-S(t)*alpha^2+S(t)*beta^2)/(alpha^2*(alpha^2-1)*(alpha^2-beta^2)*beta^2*(beta^2-1)), (W(t)*alpha^3*beta-W(t)*alpha*beta^3+Y(t)*beta^3-U(t)*alpha^3-Y(t)*beta+U(t)*alpha)/((alpha^2*beta^2-alpha^2-beta^2+1)*beta*alpha*(alpha^2-beta^2)), (X(t)*beta^2-Z(t)*alpha^2+V(t)*alpha^2-V(t)*beta^2-X(t)+Z(t))/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), -(Y(t)*alpha*beta^2-U(t)*alpha^2*beta+W(t)*alpha^2-W(t)*beta^2-Y(t)*alpha+beta*U(t))/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), -(X(t)*alpha^2*beta^2-Z(t)*alpha^2*beta^2-X(t)*alpha^2+beta^2*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), (Y(t)*alpha^3*beta^2-U(t)*alpha^2*beta^3-Y(t)*alpha^3+beta^3*U(t)+W(t)*alpha^2-W(t)*beta^2)/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), (X(t)*alpha^4*beta^2-Z(t)*alpha^2*beta^4-X(t)*alpha^4+beta^4*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)))-beta*U(t)
eq13 := beta*Z(t)
beta*Z(t)
eq14 := epsilon*F(-(V(t)*alpha^4*beta^2-V(t)*alpha^2*beta^4-S(t)*alpha^4*beta^2+S(t)*alpha^2*beta^4+X(t)*beta^4-Z(t)*alpha^4+S(t)*alpha^4-S(t)*beta^4-X(t)*beta^2+Z(t)*alpha^2-S(t)*alpha^2+S(t)*beta^2)/(alpha^2*(alpha^2-1)*(alpha^2-beta^2)*beta^2*(beta^2-1)), (W(t)*alpha^3*beta-W(t)*alpha*beta^3+Y(t)*beta^3-U(t)*alpha^3-Y(t)*beta+U(t)*alpha)/((alpha^2*beta^2-alpha^2-beta^2+1)*beta*alpha*(alpha^2-beta^2)), (X(t)*beta^2-Z(t)*alpha^2+V(t)*alpha^2-V(t)*beta^2-X(t)+Z(t))/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), -(Y(t)*alpha*beta^2-U(t)*alpha^2*beta+W(t)*alpha^2-W(t)*beta^2-Y(t)*alpha+beta*U(t))/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), -(X(t)*alpha^2*beta^2-Z(t)*alpha^2*beta^2-X(t)*alpha^2+beta^2*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), (Y(t)*alpha^3*beta^2-U(t)*alpha^2*beta^3-Y(t)*alpha^3+beta^3*U(t)+W(t)*alpha^2-W(t)*beta^2)/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), (X(t)*alpha^4*beta^2-Z(t)*alpha^2*beta^4-X(t)*alpha^4+beta^4*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)))-W(t)
eq15 := V(t)
V(t)
eq16 := epsilon*F(-(V(t)*alpha^4*beta^2-V(t)*alpha^2*beta^4-S(t)*alpha^4*beta^2+S(t)*alpha^2*beta^4+X(t)*beta^4-Z(t)*alpha^4+S(t)*alpha^4-S(t)*beta^4-X(t)*beta^2+Z(t)*alpha^2-S(t)*alpha^2+S(t)*beta^2)/(alpha^2*(alpha^2-1)*(alpha^2-beta^2)*beta^2*(beta^2-1)), (W(t)*alpha^3*beta-W(t)*alpha*beta^3+Y(t)*beta^3-U(t)*alpha^3-Y(t)*beta+U(t)*alpha)/((alpha^2*beta^2-alpha^2-beta^2+1)*beta*alpha*(alpha^2-beta^2)), (X(t)*beta^2-Z(t)*alpha^2+V(t)*alpha^2-V(t)*beta^2-X(t)+Z(t))/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), -(Y(t)*alpha*beta^2-U(t)*alpha^2*beta+W(t)*alpha^2-W(t)*beta^2-Y(t)*alpha+beta*U(t))/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), -(X(t)*alpha^2*beta^2-Z(t)*alpha^2*beta^2-X(t)*alpha^2+beta^2*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)), (Y(t)*alpha^3*beta^2-U(t)*alpha^2*beta^3-Y(t)*alpha^3+beta^3*U(t)+W(t)*alpha^2-W(t)*beta^2)/((alpha^2-beta^2)*(alpha^2*beta^2-alpha^2-beta^2+1)), (X(t)*alpha^4*beta^2-Z(t)*alpha^2*beta^4-X(t)*alpha^4+beta^4*Z(t)+V(t)*alpha^2-V(t)*beta^2)/((alpha^2-beta^2)*(beta^2-1)*(alpha^2-1)))
Download problem.mw
how can be solved this system in maple 18
fa[1] := -(1/4608)*V[0]^2+(1/4608)*W[0]^2+(1/2304)*U[0]*W[0]+(1/2304)*V[0]*Z[0]``
fa[2] := (1/153600)*(45*U[0]^2*V[0]-50*U[0]*V[0]*W[0]-50*U[0]*W[0]*Z[0]-5*V[0]*Z[0]^2-16*Z[0]*r[0]^2)/r[0]
fa[3] := -(1/153600)*(5*U[0]^2*W[0]+50*U[0]*V[0]*Z[0]-16*U[0]*r[0]^2-50*V[0]*W[0]*Z[0]-45*W[0]*Z[0]^2)/r[0]
fa[4] := (1/115200)*(25*U[0]*V[0]*W[0]-25*V[0]*W[0]^2-160*V[0]*r[0]^2-25*W[0]^2*Z[0]-64*Z[0]*r[0]^2)/r[0]
fa[5] := -(1/115200)*(25*U[0]*V[0]^2+64*U[0]*r[0]^2-25*V[0]^2*W[0]-25*V[0]*W[0]*Z[0]-160*W[0]*r[0]^2)/r[0]
fa[6] := (11/57600)*U[0]^2+(1/768)*V[0]^2+(1/768)*W[0]^2+(11/57600)*Z[0]^2+(1/600)*r[0]^2
Download system.mw
I want to implement to attached fortran program in Maple 2015 (the procudure starts at the end of the first page).
localmin.pdf
The code does not seem dificult, but I don't know how to interpret the instructions "go to" of fortran. Reading Maple's doc about the "goto" instruction, I don't understand how to implement it.
Can somebody help with this code, please?
In the following I show two functions f and g where ShowSolution(Limit(..)) works for f but not for g. Any idea why?
with(Student[Calculus1]);
f := x^2 + x:
limit(f, x = -infinity);
infinity
ShowSolution(Limit(f, x = -infinity), maxsteps = 100);
// step-by-step solution is produced
g := x^2 + 3*x:
limit(g, x = -infinity);
infinity
ShowSolution(Limit(g, x = -infinity), maxsteps = 100);
Error, (in Student:-Calculus1:-ShowSolution) unable to compute solution steps
Maple is able to change f into an equivalent expression by factoring out x^2, but does not seem to be able to do it with g.
I attach two screenshots that show this curious behaviour.
An interval graph is an undirected graph formed from a set of intervals on the real line, with a vertex for each interval and an edge between vertices whose intervals intersect. Recognizing interval graphs  is in linear time.
Seven intervals on the real line and the corresponding seven-vertex interval graph.
IsIntervalGraph(G) (was introduced in Maple 2022) tests whether the graph G could be expressed as an interval graph for some collection of intervals. If a graph is an interval graph, then the intervals corresponding to its vertices should be given. However,  IsIntervalGraphdoes not provide such an option, which makes it impossible for me to verify the correctness of the results or see more information.
with(GraphTheory):
G:=Graph({{1,2},{1,3},{1,4}, {4,2},{4,3}});
IsIntervalGraph(G)
Therefore, an option like the "certificate" option in SageMath needs to be provided.
g = Graph({1: [2, 3, 4], 4: [2, 3]})
g.show()
g.is_interval()
g.is_interval(certificate=True)
(True, {1: (0, 5), 2: (4, 6), 3: (1, 3), 4: (2, 7)})
I have looked at the source code of IsIntervalGraphand it seems to be checking whether the complement graph is comparability. I am not sure if this transformation can still find the corresponding intervals.
print(IsIntervalGraph)
proc(G::GRAPHLN)::truefalse;
    local G2;
    G2 := GraphTheory:-GraphComplement(G);
    return GraphTheory:-IsComparabilityGraph(G2);
end proc
print(IsComparabilityGraph)
proc (G::GRAPHLN, { transitiveorientation::truefalse := false,
   usecached::truefalseFAIL := FAIL }, ` $`)::truefalse; local
   iscomparability, L, A, result, V; A := op(4, G); result :=
   FindTransitiveOrientation(A, transitiveorientation); if
   result = NULL then false elif transitiveorientation then V
   := op(3, G); true, GraphTheory:-Graph(V, result) else true
   end if end proc
By the way, can the  "FindTransitiveOrientation "  in the function IsComparabilityGraph be used by the user?
I have an simple exmple of expresion :
v1 := sin(c)*sin(a)(a - b);
                  v1 := sin(a)(-b + a) sin(c)
v2 := sin(c1)*sin(a1)(-a + b);
                 v2 := sin(a1)(-a + b) sin(c1)
sort(v1);
                      sin(c) sin(a)(a - b)
sort(v2);
                    sin(c1) sin(a1)(-a + b)
what i want  is :  sort(v2); --->     sin(c1) sin(a1)(b-a)
That mean i want the "+" sign comme alwase first
Merci
https://www.maplesoft.com/support/help/Maple/view.aspx?path=copyright lists some external packages used by Maple, but it appears that certain libraries are of outdated (albeit not obsolete) versions. For example, Maple 2023 uses FLINT 2.6.3 (released in 2020), but the newest stable version of FLINT is 2.9.0. Also, Maple 2023 uses Z3 4.5.0 (released in 2016), but the newest stable version of Z3 is 4.12.1. In addition, Maple 2023 uses GCC 10.2.0 (released in 2020), but the newest stable version of GCC is 13.1. Since they are distributed under free licenses, I can download the most recent (or even nightly) release's source code, but how can I replace the old components that Maple uses by the latest ones by myself?
Please, how do I fix this? I have
n := Vector[row]([cos(theta(x, y, t)), sin(theta(x, y, t))]);
and Tried :
sum(Multiply(n[i], n[i]), i = 1 .. 2)
But received: "Error, bad index into Vector".
I cannot. If I right click on the warning I get only a copy option
Double_Pendulum_warning.msim
Can we impliment Artificial Neural Network for nonlinear coupled ODE equation with boundary conditions.? In maple
I wont seen any post regarding ANN in mapleprime.
I am trying to evaluate this expression numerically or symbolically without success.
> sum(1/(4.0*n^2-4*n+4*100000000^2+1)/10^n,n=1..infinity);
Maple is having hard time to convert it to LerchPhi and even more to evalf(%);
PS : mathematica is doing it at any precision very fast or can translate this into hypegoemetric.
PS2 : I use maple 2020 on windows 10 64 bits.
I use PDsolve to solve sets of PDEs analytically.
I have had tremendous success with this but recently realized that for PDEs if you manually factor out common expressions , it makes it much easier for maple to solve it.
I was wondering if there were other "tricks" like these that I might be unaware of.
Also I found this link comparing how maple compares to mathematica in solving known PDES just in case the maple developers are interested.
Results (12000.org)
First 208 209 210 211 212 213 214 Last Page 210 of 2431
