in this example is so different solution How i can get directly answer of this kind of ode equation when contain complicate term
restart; ode := 6*x*y(x)^2+4*x^3*y(x)+(6*x^2*y(x)+x^4+exp(y(x)))*(diff(y(x), x)) = 0; with(DEtools, odeadvisor); Student:-ODEs:-Type(ode); W := dsolve(ode, y(x)); odetest(W, ode)
Download ode.mw
hello everyone,
I am a bit shortsighted even with my glasses.
So my question is easy :: is there a way that when I open a (new) worksheet the magnification is 150%.
I can do it easily by hand but I am looking for 'something' in my maple.ini file to do this?
As well with the help pages.
Because even if I have a 150% magnification and I call a help page the display is still 100 % not 150%.
A part that I would like to set for every session a Digits:16 .
In the .ini file where I must input this? A ";" or not?
Thank you veru much.
Jean-Michel
I've reported this problem to Maple many years ago but still not fixed in Maple 2025.
Maple not able to verify its own solution on some series solutions using odetest.
Any one can suggest a workaround one can use other than odetest to verify ode solution when using series? Or have an idea why this happens?
The solution is correct but for some reason odetest returns FAIL
Below is one example of many I have
`The "Physics Updates" version in the MapleCloud is 1861 and is the same as the version installed in this computer, created 2025, April 10, 15:58 hours Pacific Time.`
ode:=x*diff(y(x),x$2)+y(x)=0;
IC:=y(0)=1;
maple_sol:=dsolve([ode,IC],y(x),'series');
odetest(maple_sol,[ode,IC],'series','point'=0);
x*(diff(diff(y(x), x), x))+y(x) = 0
y(0) = 1
y(x) = c__1*x*(series(1-(1/2)*x+(1/12)*x^2-(1/144)*x^3+(1/2880)*x^4-(1/86400)*x^5+O(x^6),x,6))+ln(x)*(series(-x+(1/2)*x^2-(1/12)*x^3+(1/144)*x^4-(1/2880)*x^5+O(x^6),x,6))+(series(1-(3/4)*x^2+(7/36)*x^3-(35/1728)*x^4+(101/86400)*x^5+O(x^6),x,6))
Warning, unable to compute series necessary to test the given solution
FAIL
Download series_unable_to_odetest_april_12_2025.mw
I don't know what combination of keys I used, but I deleted all the answers and comments to this question in one go.
https://mapleprimes.com/posts/229696-I-Find-An-Error
Can some moderator recover all of them?
Thanks in advance and sorry for the inconvenience
I'm experimenting with building random series on different topics, inspired by several of your comments, using a table-style layout. For this example, I'm testing systems of linear equations with two unknowns, but I can't manage to generate the systems with curly braces. I hope the purpose of my question is clear. Any ideas? Thanks
Systmes_Idea.mw
This question is about a particularity of a widely used function, which looks like a bug at the first glance, but is not (after carefully studying the help page).
The function “add” (a built-in function with special evaluation rules) is intended to be used on sequences. If for any reason (in a procedure for example) a sequence degenerates to a single scalar expression and add is applied to it, the expression can change. This is most likely undesired. In the case below (simplified from a real case that happened to me) a product is transformed into a nonsense sum.
data := 1.*Unit(m);
accu_length := add(data);
data := data, 2.*Unit(m);
                       data := 1. Unit(m)
                  accu_length := 1. + Unit(m)
                 data := 1. Unit(m), 2. Unit(m)
                   accu_length := 3. Unit(m)
It is quite likely that the above unit error will be noticed. In the following case it is more likely that a change in value remains unnoticed.
data := 2/5;
add(data);
                           data := -
                                   5
                               7
I was wondering whether Maple could issue a warning to prevent this use error of add, when certain types of expressions are passed to add.
Alternatively Maple could return the expression unchanged. So far, I have not found a case where it makes sense to apply add to operands of a scalar expression (excluding set, list, array, ... ).
This leads to the question of whether this functionality (add working on a scalar expression) is needed at all. I tried a few and none of them is useful
[a = b, a^b, a@b, a/b, sin(a), int(f(x), x), a[b]];
map(add, %);
        [        b       a                            ]
        [a = b, a , a@b, -, sin(a), int(f(x), x), a[b]]
        [                b                            ]
          [                         1                ]
          [a + b, a + b, a + b, a + -, a, f(x) + x, b]
          [                         b                ]
Anything else which could make sense?
i dont know in this paper he do factoring or he solved by substitution i did both way but i can't do end step which is finding parameter can anyone help ? i did 2 way but i can't finished
find-parameter.mw
find-parameter_2.mw
In the File menu,  the Export As dialog is missing. Only the default (.pdf) can be used; no .mpl or .tex)
The Save As dialog is incomplete (e.g. save to .mws).
Or, is the installation corrupted?
In the transformation w = e^z, vertical lines in the complex z-plane of the form Re(z)=a are mapped to circles of radius e^a in the w-plane.
Can I create a Maple visualization that does the following:
  1. Displays the result side by side, showing each vertical line in the z-plane and its corresponding mapped circle in the w-plane.
  2. Does it use a different color and style for each line and its image (e.g., dashed, dotted, solid, or different colors)?
restart; interface(imaginaryunit = 'i')
z := 2+2*I
2+2*I
with(plots); point1 := pointplot([[Re(z), Im(z)]], symbol = solidcircle, color = blue, axes = normal, labels = ["Re(z)", "Im(z)"], title = "Complex Number Plot")
mod_z := abs(z)
2*2^(1/2)
vector1 := arrow([0, 0], [Re(z), Im(z)], color = red, shape = double_arrow, width = 0.5e-1, border = false, head_width = .1, head_length = .1); vector2 := arrow([0, 0], [0, Im(z)], color = green, shape = double_arrow, width = 0.5e-1, border = false, head_width = .1, head_length = .1); vector3 := arrow([0, 0], [Re(z), 0], color = yellow, shape = double_arrow, width = 0.5e-1, border = false, head_width = .1, head_length = .1)
display([vector1, point1, vector2, vector3], axes = normal, labels = ["Re(z)", "Im(z)"], view = [0 .. 3, -1 .. 4], scaling = constrained, title = "Modulus of complex number")
w := 2+3*I
2+3*I
z+w
4+5*I
z-w
-I
z.w
-2+10*I
z/w
10/13-(2/13)*I
with(plots); a := 2; complexplot(a+I*t, t = -Pi .. Pi, title = "Vertical Line Re(z)=2")
A := [-3, -1, 0, 1, 2]; P := [seq(complexplot(x+I*y, y = -10 .. 10, color = red), `in`(x, A))]; display(P, title = "Multiple Vertical Lines in Complex Plane")
with(plots); B := [-3, -1, 0, 1, 2]; H := [seq(complexplot(x+I*y, x = -10 .. 10, color = blue), `in`(y, B))]; display(H, title = "Multiple Horizontal Lines in Complex Plane")
Download operations.mw
This is first type of solving parameter but  i solved some semilar but the shape of them are so different and solving them different too i did my trail but i can't reach out solution also the author solve by another way which i did too but i have to solve in this way too thanks  for any help !
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
_local(gamma)
declare(u(x, y, z, t))
declare(f(x, y, z, t))
pde := 9*(diff(u(x, y, z, t), t, x))+diff(u(x, y, z, t), `$`(x, 6))-5*(diff(u(x, y, z, t), `$`(x, 3), y)+diff(u(x, y, z, t), `$`(y, 2)))+15*((diff(u(x, y, z, t), `$`(x, 2)))*(diff(u(x, y, z, t), `$`(x, 3)))+(diff(u(x, y, z, t), x))*(diff(u(x, y, z, t), `$`(x, 4)))-(diff(u(x, y, z, t), x))*(diff(u(x, y, z, t), x, y))-(diff(u(x, y, z, t), `$`(x, 2)))*(diff(u(x, y, z, t), y)))+45*(diff(u(x, y, z, t), x))^2*(diff(u(x, y, z, t), `$`(x, 2)))+alpha*(diff(u(x, y, z, t), `$`(x, 2)))+beta*(diff(u(x, y, z, t), x, y))+delta*(diff(u(x, y, z, t), x, z))
9*(diff(diff(u(x, y, z, t), t), x))+diff(diff(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x), x), x)-5*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), y))-5*(diff(diff(u(x, y, z, t), y), y))+15*(diff(diff(u(x, y, z, t), x), x))*(diff(diff(diff(u(x, y, z, t), x), x), x))+15*(diff(u(x, y, z, t), x))*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x))-15*(diff(u(x, y, z, t), x))*(diff(diff(u(x, y, z, t), x), y))-15*(diff(diff(u(x, y, z, t), x), x))*(diff(u(x, y, z, t), y))+45*(diff(u(x, y, z, t), x))^2*(diff(diff(u(x, y, z, t), x), x))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+delta*(diff(diff(u(x, y, z, t), x), z))
oppde := [op(expand(pde))]; u_occurrences := map(proc (i) options operator, arrow; numelems(select(has, [op([op(i)])], u)) end proc, oppde); linear_op_indices := ListTools:-SearchAll(1, u_occurrences); pde_linear := add(oppde[[linear_op_indices]]); pde_nonlinear := expand(simplify(expand(pde)-pde_linear))
9*(diff(diff(u(x, y, z, t), t), x))+diff(diff(diff(diff(diff(diff(u(x, y, z, t), x), x), x), x), x), x)-5*(diff(diff(diff(diff(u(x, y, z, t), x), x), x), y))-5*(diff(diff(u(x, y, z, t), y), y))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+delta*(diff(diff(u(x, y, z, t), x), z))
H := u(x, y, z, t) = 2*(diff(ln(f(x, y, z, t)), x))
u(x, y, z, t) = 2*(diff(f(x, y, z, t), x))/f(x, y, z, t)
L := eval(pde_linear, H) = 0
2*(diff(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x), x))/f(x, y, z, t)-10*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), y))/f(x, y, z, t)-10*(diff(diff(diff(f(x, y, z, t), x), y), y))/f(x, y, z, t)+alpha*(2*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)-6*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^3)+beta*(2*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3)+delta*(2*(diff(diff(diff(f(x, y, z, t), x), x), z))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), z))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), z))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), z))/f(x, y, z, t)^3)+280*(diff(diff(diff(f(x, y, z, t), x), x), x))^2*(diff(f(x, y, z, t), x))/f(x, y, z, t)^3-5040*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^5/f(x, y, z, t)^6+5040*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^5-1260*(diff(diff(f(x, y, z, t), x), x))^3*(diff(f(x, y, z, t), x))/f(x, y, z, t)^4-80*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+360*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^4-240*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^3-20*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))^2/f(x, y, z, t)^3+84*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3-420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^4+420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^3+1680*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^4/f(x, y, z, t)^5-2520*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^2*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^4+420*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), x))^2/f(x, y, z, t)^3+36*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), t))/f(x, y, z, t)^3-36*(diff(diff(f(x, y, z, t), t), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-18*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), t))/f(x, y, z, t)^2-14*(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-42*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^2-70*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)^2+1440*(diff(f(x, y, z, t), x))^7/f(x, y, z, t)^7+10*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+40*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), y))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+40*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2-120*(diff(diff(diff(f(x, y, z, t), x), x), y))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3+60*(diff(diff(f(x, y, z, t), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)^2-60*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+240*(diff(f(x, y, z, t), x))^3*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^4-240*(diff(f(x, y, z, t), x))^4*(diff(f(x, y, z, t), y))/f(x, y, z, t)^5+20*(diff(diff(f(x, y, z, t), x), y))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+10*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), y), y))/f(x, y, z, t)^2+18*(diff(diff(diff(f(x, y, z, t), t), x), x))/f(x, y, z, t) = 0
numer(lhs(-80*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+360*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^4-240*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^3+420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^3-2520*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^2*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^4+alpha*(2*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)-6*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^3)+beta*(2*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3)+delta*(2*(diff(diff(diff(f(x, y, z, t), x), x), z))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), z))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), z))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), z))/f(x, y, z, t)^3)+2*(diff(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x), x))/f(x, y, z, t)-10*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), y))/f(x, y, z, t)-10*(diff(diff(diff(f(x, y, z, t), x), y), y))/f(x, y, z, t)+1440*(diff(f(x, y, z, t), x))^7/f(x, y, z, t)^7+18*(diff(diff(diff(f(x, y, z, t), t), x), x))/f(x, y, z, t)+280*(diff(diff(diff(f(x, y, z, t), x), x), x))^2*(diff(f(x, y, z, t), x))/f(x, y, z, t)^3-5040*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^5/f(x, y, z, t)^6+5040*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^5-1260*(diff(diff(f(x, y, z, t), x), x))^3*(diff(f(x, y, z, t), x))/f(x, y, z, t)^4-20*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))^2/f(x, y, z, t)^3+84*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3-420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^4+1680*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^4/f(x, y, z, t)^5+420*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), x))^2/f(x, y, z, t)^3+36*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), t))/f(x, y, z, t)^3-36*(diff(diff(f(x, y, z, t), t), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-18*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), t))/f(x, y, z, t)^2-14*(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-42*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^2-70*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)^2+10*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+40*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), y))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+40*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2-120*(diff(diff(diff(f(x, y, z, t), x), x), y))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3+60*(diff(diff(f(x, y, z, t), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)^2-60*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+240*(diff(f(x, y, z, t), x))^3*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^4-240*(diff(f(x, y, z, t), x))^4*(diff(f(x, y, z, t), y))/f(x, y, z, t)^5+20*(diff(diff(f(x, y, z, t), x), y))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+10*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), y), y))/f(x, y, z, t)^2 = 0))*denom(rhs(-80*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+360*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^4-240*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^3+420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^3-2520*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^2*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^4+alpha*(2*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)-6*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^3)+beta*(2*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3)+delta*(2*(diff(diff(diff(f(x, y, z, t), x), x), z))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), z))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), z))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), z))/f(x, y, z, t)^3)+2*(diff(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x), x))/f(x, y, z, t)-10*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), y))/f(x, y, z, t)-10*(diff(diff(diff(f(x, y, z, t), x), y), y))/f(x, y, z, t)+1440*(diff(f(x, y, z, t), x))^7/f(x, y, z, t)^7+18*(diff(diff(diff(f(x, y, z, t), t), x), x))/f(x, y, z, t)+280*(diff(diff(diff(f(x, y, z, t), x), x), x))^2*(diff(f(x, y, z, t), x))/f(x, y, z, t)^3-5040*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^5/f(x, y, z, t)^6+5040*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^5-1260*(diff(diff(f(x, y, z, t), x), x))^3*(diff(f(x, y, z, t), x))/f(x, y, z, t)^4-20*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))^2/f(x, y, z, t)^3+84*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3-420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^4+1680*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^4/f(x, y, z, t)^5+420*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), x))^2/f(x, y, z, t)^3+36*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), t))/f(x, y, z, t)^3-36*(diff(diff(f(x, y, z, t), t), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-18*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), t))/f(x, y, z, t)^2-14*(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-42*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^2-70*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)^2+10*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+40*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), y))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+40*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2-120*(diff(diff(diff(f(x, y, z, t), x), x), y))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3+60*(diff(diff(f(x, y, z, t), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)^2-60*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+240*(diff(f(x, y, z, t), x))^3*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^4-240*(diff(f(x, y, z, t), x))^4*(diff(f(x, y, z, t), y))/f(x, y, z, t)^5+20*(diff(diff(f(x, y, z, t), x), y))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+10*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), y), y))/f(x, y, z, t)^2 = 0)) = numer(rhs(-80*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+360*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^4-240*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^3+420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^3-2520*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^2*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^4+alpha*(2*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)-6*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^3)+beta*(2*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3)+delta*(2*(diff(diff(diff(f(x, y, z, t), x), x), z))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), z))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), z))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), z))/f(x, y, z, t)^3)+2*(diff(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x), x))/f(x, y, z, t)-10*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), y))/f(x, y, z, t)-10*(diff(diff(diff(f(x, y, z, t), x), y), y))/f(x, y, z, t)+1440*(diff(f(x, y, z, t), x))^7/f(x, y, z, t)^7+18*(diff(diff(diff(f(x, y, z, t), t), x), x))/f(x, y, z, t)+280*(diff(diff(diff(f(x, y, z, t), x), x), x))^2*(diff(f(x, y, z, t), x))/f(x, y, z, t)^3-5040*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^5/f(x, y, z, t)^6+5040*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^5-1260*(diff(diff(f(x, y, z, t), x), x))^3*(diff(f(x, y, z, t), x))/f(x, y, z, t)^4-20*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))^2/f(x, y, z, t)^3+84*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3-420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^4+1680*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^4/f(x, y, z, t)^5+420*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), x))^2/f(x, y, z, t)^3+36*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), t))/f(x, y, z, t)^3-36*(diff(diff(f(x, y, z, t), t), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-18*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), t))/f(x, y, z, t)^2-14*(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-42*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^2-70*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)^2+10*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+40*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), y))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+40*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2-120*(diff(diff(diff(f(x, y, z, t), x), x), y))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3+60*(diff(diff(f(x, y, z, t), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)^2-60*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+240*(diff(f(x, y, z, t), x))^3*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^4-240*(diff(f(x, y, z, t), x))^4*(diff(f(x, y, z, t), y))/f(x, y, z, t)^5+20*(diff(diff(f(x, y, z, t), x), y))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+10*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), y), y))/f(x, y, z, t)^2 = 0))*denom(lhs(-80*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+360*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^4-240*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^3+420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^3-2520*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^2*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^4+alpha*(2*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)-6*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^3)+beta*(2*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3)+delta*(2*(diff(diff(diff(f(x, y, z, t), x), x), z))/f(x, y, z, t)-2*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), z))/f(x, y, z, t)^2-4*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), z))/f(x, y, z, t)^2+4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), z))/f(x, y, z, t)^3)+2*(diff(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x), x))/f(x, y, z, t)-10*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), y))/f(x, y, z, t)-10*(diff(diff(diff(f(x, y, z, t), x), y), y))/f(x, y, z, t)+1440*(diff(f(x, y, z, t), x))^7/f(x, y, z, t)^7+18*(diff(diff(diff(f(x, y, z, t), t), x), x))/f(x, y, z, t)+280*(diff(diff(diff(f(x, y, z, t), x), x), x))^2*(diff(f(x, y, z, t), x))/f(x, y, z, t)^3-5040*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^5/f(x, y, z, t)^6+5040*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^5-1260*(diff(diff(f(x, y, z, t), x), x))^3*(diff(f(x, y, z, t), x))/f(x, y, z, t)^4-20*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))^2/f(x, y, z, t)^3+84*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3-420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))^3/f(x, y, z, t)^4+1680*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^4/f(x, y, z, t)^5+420*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), x))^2/f(x, y, z, t)^3+36*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), t))/f(x, y, z, t)^3-36*(diff(diff(f(x, y, z, t), t), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-18*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), t))/f(x, y, z, t)^2-14*(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2-42*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(diff(f(x, y, z, t), x), x))/f(x, y, z, t)^2-70*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), x))/f(x, y, z, t)^2+10*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+40*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), y))*(diff(f(x, y, z, t), x))/f(x, y, z, t)^2+40*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^2-120*(diff(diff(diff(f(x, y, z, t), x), x), y))*(diff(f(x, y, z, t), x))^2/f(x, y, z, t)^3+60*(diff(diff(f(x, y, z, t), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), y))/f(x, y, z, t)^2-60*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), y))/f(x, y, z, t)^3+240*(diff(f(x, y, z, t), x))^3*(diff(diff(f(x, y, z, t), x), y))/f(x, y, z, t)^4-240*(diff(f(x, y, z, t), x))^4*(diff(f(x, y, z, t), y))/f(x, y, z, t)^5+20*(diff(diff(f(x, y, z, t), x), y))*(diff(f(x, y, z, t), y))/f(x, y, z, t)^2+10*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), y), y))/f(x, y, z, t)^2 = 0))
420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), x))*f(x, y, z, t)^4-2520*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^2*(diff(diff(f(x, y, z, t), x), x))*f(x, y, z, t)^3-6*f(x, y, z, t)^5*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*alpha-2*f(x, y, z, t)^5*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), y))*beta-4*f(x, y, z, t)^5*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))*beta+4*f(x, y, z, t)^4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))*beta-2*f(x, y, z, t)^5*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), z))*delta-4*f(x, y, z, t)^5*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), z))*delta+4*f(x, y, z, t)^4*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), z))*delta-80*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))*f(x, y, z, t)^4+360*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), y))*f(x, y, z, t)^3-240*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), x), y))*f(x, y, z, t)^4+2*(diff(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x), x))*f(x, y, z, t)^6-10*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), y))*f(x, y, z, t)^6-10*(diff(diff(diff(f(x, y, z, t), x), y), y))*f(x, y, z, t)^6+18*(diff(diff(diff(f(x, y, z, t), t), x), x))*f(x, y, z, t)^6-14*(diff(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x), x))*(diff(f(x, y, z, t), x))*f(x, y, z, t)^5-42*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(diff(f(x, y, z, t), x), x))*f(x, y, z, t)^5-70*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), x))*f(x, y, z, t)^5+10*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), y))*f(x, y, z, t)^5+40*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), y))*(diff(f(x, y, z, t), x))*f(x, y, z, t)^5+40*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), y))*f(x, y, z, t)^5-120*(diff(diff(diff(f(x, y, z, t), x), x), y))*(diff(f(x, y, z, t), x))^2*f(x, y, z, t)^4+60*(diff(diff(f(x, y, z, t), x), x))*(diff(diff(diff(f(x, y, z, t), x), x), y))*f(x, y, z, t)^5-60*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), y))*f(x, y, z, t)^4+240*(diff(f(x, y, z, t), x))^3*(diff(diff(f(x, y, z, t), x), y))*f(x, y, z, t)^3-240*(diff(f(x, y, z, t), x))^4*(diff(f(x, y, z, t), y))*f(x, y, z, t)^2+20*(diff(diff(f(x, y, z, t), x), y))*(diff(f(x, y, z, t), y))*f(x, y, z, t)^5+10*(diff(f(x, y, z, t), x))*(diff(diff(f(x, y, z, t), y), y))*f(x, y, z, t)^5+280*(diff(diff(diff(f(x, y, z, t), x), x), x))^2*(diff(f(x, y, z, t), x))*f(x, y, z, t)^4-5040*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), x))^5*f(x, y, z, t)+5040*(diff(diff(f(x, y, z, t), x), x))^2*(diff(f(x, y, z, t), x))^3*f(x, y, z, t)^2-1260*(diff(diff(f(x, y, z, t), x), x))^3*(diff(f(x, y, z, t), x))*f(x, y, z, t)^3-20*(diff(f(x, y, z, t), x))*(diff(f(x, y, z, t), y))^2*f(x, y, z, t)^4+84*(diff(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x), x))*(diff(f(x, y, z, t), x))^2*f(x, y, z, t)^4-420*(diff(diff(diff(diff(f(x, y, z, t), x), x), x), x))*(diff(f(x, y, z, t), x))^3*f(x, y, z, t)^3+1680*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(f(x, y, z, t), x))^4*f(x, y, z, t)^2+420*(diff(diff(diff(f(x, y, z, t), x), x), x))*(diff(diff(f(x, y, z, t), x), x))^2*f(x, y, z, t)^4+36*(diff(f(x, y, z, t), x))^2*(diff(f(x, y, z, t), t))*f(x, y, z, t)^4-36*(diff(diff(f(x, y, z, t), t), x))*(diff(f(x, y, z, t), x))*f(x, y, z, t)^5-18*(diff(diff(f(x, y, z, t), x), x))*(diff(f(x, y, z, t), t))*f(x, y, z, t)^5+2*f(x, y, z, t)^6*(diff(diff(diff(f(x, y, z, t), x), x), x))*alpha+4*f(x, y, z, t)^4*(diff(f(x, y, z, t), x))^3*alpha+2*f(x, y, z, t)^6*(diff(diff(diff(f(x, y, z, t), x), x), y))*beta+2*f(x, y, z, t)^6*(diff(diff(diff(f(x, y, z, t), x), x), z))*delta+1440*(diff(f(x, y, z, t), x))^7 = 0
F1 := %
S := f(x, y, z, t) = a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])
A := eval(F1, S)
600*a[1]^4*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3+1204*a[1]^3*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4-4200*a[1]^4*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3-500*a[1]^3*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4+30*a[1]^2*k[1]*p[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5-54*a[1]^2*w[1]*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5-6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*a[1]^2*k[1]^3*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*alpha-6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*a[1]^2*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*p[1]*beta+4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*a[1]^3*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*p[1]*beta-6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*a[1]^2*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*r[1]*delta+4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*a[1]^3*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*r[1]*delta+18*a[1]*w[1]*k[1]^2*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6-10*a[1]*k[1]*p[1]^2*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6+2*a[1]*k[1]^7*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6-10*a[1]*k[1]^4*p[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6+2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*a[1]*k[1]^2*p[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*beta+2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*a[1]*k[1]^2*r[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*delta+1440*a[1]^7*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^7-5040*a[1]^6*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))+6720*a[1]^5*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2-20*a[1]^3*k[1]*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*p[1]^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4+36*a[1]^3*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*w[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4+2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*a[1]*k[1]^3*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*alpha+4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*a[1]^3*k[1]^3*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*alpha-126*a[1]^2*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5+150*a[1]^2*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5-240*a[1]^5*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2 = 0
simplify(1440*a[1]^7*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^7+6720*a[1]^5*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2-126*a[1]^2*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5+1204*a[1]^3*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4-4200*a[1]^4*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3+2*a[1]*k[1]^7*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6-5040*a[1]^6*k[1]^7*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))+600*a[1]^4*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3-500*a[1]^3*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4+30*a[1]^2*k[1]*p[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5-54*a[1]^2*w[1]*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5-6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*a[1]^2*k[1]^3*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*alpha+18*a[1]*w[1]*k[1]^2*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6-10*a[1]*k[1]*p[1]^2*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6-10*a[1]*k[1]^4*p[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6-20*a[1]^3*k[1]*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*p[1]^2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4+36*a[1]^3*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*w[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4+2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*a[1]*k[1]^3*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*alpha+4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*a[1]^3*k[1]^3*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*alpha+150*a[1]^2*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5-240*a[1]^5*k[1]^4*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*p[1]*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2-6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*a[1]^2*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*p[1]*beta+4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*a[1]^3*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*p[1]*beta-6*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^5*a[1]^2*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^2*r[1]*delta+4*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^4*a[1]^3*k[1]^2*(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^3*r[1]*delta+2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*a[1]*k[1]^2*p[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*beta+2*(a[0]+a[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]))^6*a[1]*k[1]^2*r[1]*exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*delta = 0)
2*a[0]*k[1]*(-57*a[0]^4*(k[1]^6-(15/19)*k[1]^3*p[1]-(1/19)*k[1]^2*alpha+(1/19)*(-beta*p[1]-delta*r[1]-9*w[1])*k[1]+(5/19)*p[1]^2)*a[1]*exp(2*t*w[1]+2*x*k[1]+2*y*p[1]+2*z*r[1])+302*a[0]^3*(k[1]^6+(25/151)*k[1]^3*p[1]+(1/151)*k[1]^2*alpha+(1/151)*(beta*p[1]+delta*r[1]+9*w[1])*k[1]-(5/151)*p[1]^2)*a[1]^2*exp(3*t*w[1]+3*x*k[1]+3*y*p[1]+3*z*r[1])-302*a[0]^2*(k[1]^6+(25/151)*k[1]^3*p[1]+(1/151)*k[1]^2*alpha+(1/151)*(beta*p[1]+delta*r[1]+9*w[1])*k[1]-(5/151)*p[1]^2)*a[1]^3*exp(4*t*w[1]+4*x*k[1]+4*y*p[1]+4*z*r[1])+57*a[0]*(k[1]^6-(15/19)*k[1]^3*p[1]-(1/19)*k[1]^2*alpha+(1/19)*(-beta*p[1]-delta*r[1]-9*w[1])*k[1]+(5/19)*p[1]^2)*a[1]^4*exp(5*t*w[1]+5*x*k[1]+5*y*p[1]+5*z*r[1])+(exp(t*w[1]+x*k[1]+y*p[1]+z*r[1])*a[0]^5-exp(6*t*w[1]+6*x*k[1]+6*y*p[1]+6*z*r[1])*a[1]^5)*(k[1]^6-5*k[1]^3*p[1]+k[1]^2*alpha+(beta*p[1]+delta*r[1]+9*w[1])*k[1]-5*p[1]^2))*a[1] = 0
E := %
indets(E)
{alpha, beta, delta, t, x, y, z, a[0], a[1], k[1], p[1], r[1], w[1], exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]), exp(2*t*w[1]+2*x*k[1]+2*y*p[1]+2*z*r[1]), exp(3*t*w[1]+3*x*k[1]+3*y*p[1]+3*z*r[1]), exp(4*t*w[1]+4*x*k[1]+4*y*p[1]+4*z*r[1]), exp(5*t*w[1]+5*x*k[1]+5*y*p[1]+5*z*r[1]), exp(6*t*w[1]+6*x*k[1]+6*y*p[1]+6*z*r[1])}
(14)
E1 := subs({exp(t*w[1]+x*k[1]+y*p[1]+z*r[1]) = eX, exp(2*t*w[1]+2*x*k[1]+2*y*p[1]+2*z*r[1]) = eY, exp(3*t*w[1]+3*x*k[1]+3*y*p[1]+3*z*r[1]) = eZ, exp(4*t*w[1]+4*x*k[1]+4*y*p[1]+4*z*r[1]) = eW, exp(5*t*w[1]+5*x*k[1]+5*y*p[1]+5*z*r[1]) = eV, exp(6*t*w[1]+6*x*k[1]+6*y*p[1]+6*z*r[1]) = eB}, E)
2*a[0]*k[1]*(-57*a[0]^4*(k[1]^6-(15/19)*k[1]^3*p[1]-(1/19)*k[1]^2*alpha+(1/19)*(-beta*p[1]-delta*r[1]-9*w[1])*k[1]+(5/19)*p[1]^2)*a[1]*eY+302*a[0]^3*(k[1]^6+(25/151)*k[1]^3*p[1]+(1/151)*k[1]^2*alpha+(1/151)*(beta*p[1]+delta*r[1]+9*w[1])*k[1]-(5/151)*p[1]^2)*a[1]^2*eZ-302*a[0]^2*(k[1]^6+(25/151)*k[1]^3*p[1]+(1/151)*k[1]^2*alpha+(1/151)*(beta*p[1]+delta*r[1]+9*w[1])*k[1]-(5/151)*p[1]^2)*a[1]^3*eW+57*a[0]*(k[1]^6-(15/19)*k[1]^3*p[1]-(1/19)*k[1]^2*alpha+(1/19)*(-beta*p[1]-delta*r[1]-9*w[1])*k[1]+(5/19)*p[1]^2)*a[1]^4*eV+(-eB*a[1]^5+eX*a[0]^5)*(k[1]^6-5*k[1]^3*p[1]+k[1]^2*alpha+(beta*p[1]+delta*r[1]+9*w[1])*k[1]-5*p[1]^2))*a[1] = 0
(15)
indets(E1)
{alpha, beta, delta, eB, eV, eW, eX, eY, eZ, a[0], a[1], k[1], p[1], r[1], w[1]}
(16)
p2c := normal(E1)
-2*a[0]*k[1]*(eB*a[1]^5*k[1]^6-57*eV*a[0]*a[1]^4*k[1]^6+302*eW*a[0]^2*a[1]^3*k[1]^6-eX*a[0]^5*k[1]^6+57*eY*a[0]^4*a[1]*k[1]^6-302*eZ*a[0]^3*a[1]^2*k[1]^6-5*eB*a[1]^5*k[1]^3*p[1]+45*eV*a[0]*a[1]^4*k[1]^3*p[1]+50*eW*a[0]^2*a[1]^3*k[1]^3*p[1]+5*eX*a[0]^5*k[1]^3*p[1]-45*eY*a[0]^4*a[1]*k[1]^3*p[1]-50*eZ*a[0]^3*a[1]^2*k[1]^3*p[1]+alpha*eB*a[1]^5*k[1]^2+3*alpha*eV*a[0]*a[1]^4*k[1]^2+2*alpha*eW*a[0]^2*a[1]^3*k[1]^2-alpha*eX*a[0]^5*k[1]^2-3*alpha*eY*a[0]^4*a[1]*k[1]^2-2*alpha*eZ*a[0]^3*a[1]^2*k[1]^2+beta*eB*a[1]^5*k[1]*p[1]+3*beta*eV*a[0]*a[1]^4*k[1]*p[1]+2*beta*eW*a[0]^2*a[1]^3*k[1]*p[1]-beta*eX*a[0]^5*k[1]*p[1]-3*beta*eY*a[0]^4*a[1]*k[1]*p[1]-2*beta*eZ*a[0]^3*a[1]^2*k[1]*p[1]+delta*eB*a[1]^5*k[1]*r[1]+3*delta*eV*a[0]*a[1]^4*k[1]*r[1]+2*delta*eW*a[0]^2*a[1]^3*k[1]*r[1]-delta*eX*a[0]^5*k[1]*r[1]-3*delta*eY*a[0]^4*a[1]*k[1]*r[1]-2*delta*eZ*a[0]^3*a[1]^2*k[1]*r[1]+9*eB*a[1]^5*k[1]*w[1]-5*eB*a[1]^5*p[1]^2+27*eV*a[0]*a[1]^4*k[1]*w[1]-15*eV*a[0]*a[1]^4*p[1]^2+18*eW*a[0]^2*a[1]^3*k[1]*w[1]-10*eW*a[0]^2*a[1]^3*p[1]^2-9*eX*a[0]^5*k[1]*w[1]+5*eX*a[0]^5*p[1]^2-27*eY*a[0]^4*a[1]*k[1]*w[1]+15*eY*a[0]^4*a[1]*p[1]^2-18*eZ*a[0]^3*a[1]^2*k[1]*w[1]+10*eZ*a[0]^3*a[1]^2*p[1]^2)*a[1] = 0
(17)
indets(p2c)
(18)
eqns := {coeffs(collect(p2c, {eB, eV, eW, eX, eY, eZ}, distributed), {eB, eV, eW, eX, eY, eZ})}; nops(%)
Error, invalid arguments to coeffs
Co := solve(E1, {a[0], a[1], k[1], n[1], p[1], r[1], w[1]}, explicit)
{a[0] = a[0], a[1] = a[1], k[1] = 0, n[1] = n[1], p[1] = p[1], r[1] = r[1], w[1] = w[1]}, {a[0] = a[0], a[1] = 0, k[1] = k[1], n[1] = n[1], p[1] = p[1], r[1] = r[1], w[1] = w[1]}, {a[0] = 0, a[1] = a[1], k[1] = k[1], n[1] = n[1], p[1] = p[1], r[1] = r[1], w[1] = w[1]}, {a[0] = a[0], a[1] = a[1], k[1] = k[1], n[1] = n[1], p[1] = p[1], r[1] = -(eB*a[1]^5*k[1]^6-57*eV*a[0]*a[1]^4*k[1]^6+302*eW*a[0]^2*a[1]^3*k[1]^6-eX*a[0]^5*k[1]^6+57*eY*a[0]^4*a[1]*k[1]^6-302*eZ*a[0]^3*a[1]^2*k[1]^6-5*eB*a[1]^5*k[1]^3*p[1]+45*eV*a[0]*a[1]^4*k[1]^3*p[1]+50*eW*a[0]^2*a[1]^3*k[1]^3*p[1]+5*eX*a[0]^5*k[1]^3*p[1]-45*eY*a[0]^4*a[1]*k[1]^3*p[1]-50*eZ*a[0]^3*a[1]^2*k[1]^3*p[1]+alpha*eB*a[1]^5*k[1]^2+3*alpha*eV*a[0]*a[1]^4*k[1]^2+2*alpha*eW*a[0]^2*a[1]^3*k[1]^2-alpha*eX*a[0]^5*k[1]^2-3*alpha*eY*a[0]^4*a[1]*k[1]^2-2*alpha*eZ*a[0]^3*a[1]^2*k[1]^2+beta*eB*a[1]^5*k[1]*p[1]+3*beta*eV*a[0]*a[1]^4*k[1]*p[1]+2*beta*eW*a[0]^2*a[1]^3*k[1]*p[1]-beta*eX*a[0]^5*k[1]*p[1]-3*beta*eY*a[0]^4*a[1]*k[1]*p[1]-2*beta*eZ*a[0]^3*a[1]^2*k[1]*p[1]+9*eB*a[1]^5*k[1]*w[1]-5*eB*a[1]^5*p[1]^2+27*eV*a[0]*a[1]^4*k[1]*w[1]-15*eV*a[0]*a[1]^4*p[1]^2+18*eW*a[0]^2*a[1]^3*k[1]*w[1]-10*eW*a[0]^2*a[1]^3*p[1]^2-9*eX*a[0]^5*k[1]*w[1]+5*eX*a[0]^5*p[1]^2-27*eY*a[0]^4*a[1]*k[1]*w[1]+15*eY*a[0]^4*a[1]*p[1]^2-18*eZ*a[0]^3*a[1]^2*k[1]*w[1]+10*eZ*a[0]^3*a[1]^2*p[1]^2)/(delta*k[1]*(eB*a[1]^5+3*eV*a[0]*a[1]^4+2*eW*a[0]^2*a[1]^3-eX*a[0]^5-3*eY*a[0]^4*a[1]-2*eZ*a[0]^3*a[1]^2)), w[1] = w[1]}
(20)
case1 := Co[1]
(21)
F := subs(case1, S)
f(x, y, z, t) = a[0]+a[1]*exp(t*w[1]+y*p[1]+z*r[1])
(22)
F1 := eval(H, F)
u(x, y, z, t) = 0
(23)
pdetest(F1, pde)
Download F-P-O-W.mw
Dear community,
i want to create my own RGB Matrix for a plot. In this picture from maple soft homepage you can see a matrix A. I created a Matrix with 49 rows and 49 columns. From Datatyp Float. The plots is just red. Has anybody an idea how I can create a Matrix, which works?
I have two conditions, A and B, which must both be greater than or equal to zero. However, when I try to solve the problem, I encounter an error.
Could you please help me resolve this?
Note: All the parameters, whether specified or not, are positive and greater than zero.
File : Q3.mw
sometime this code i use make a problem for me and sometime they work very good how i can get something general for use in all equation
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
_local(gamma)
declare(u(x, y, z, w, t))
u(x, y, z, w, t)*`will now be displayed as`*u
declare(f(x, y, z, w, t))
f(x, y, z, w, t)*`will now be displayed as`*f
pde := 4*(diff(u(x, y, z, w, t), x, t))-(diff(u(x, y, z, w, t), `$`(x, 3), y))+diff(u(x, y, z, w, t), x, `$`(y, 3))+12*(diff(u(x, y, z, w, t), x))*(diff(u(x, y, z, w, t), y))+12*u(x, y, z, w, t)*(diff(u(x, y, z, w, t), x, y))-6*(diff(u(x, y, z, w, t), z, w)) = 0
4*(diff(diff(u(x, y, z, w, t), t), x))-(diff(diff(diff(diff(u(x, y, z, w, t), x), x), x), y))+diff(diff(diff(diff(u(x, y, z, w, t), x), y), y), y)+12*(diff(u(x, y, z, w, t), x))*(diff(u(x, y, z, w, t), y))+12*u(x, y, z, w, t)*(diff(diff(u(x, y, z, w, t), x), y))-6*(diff(diff(u(x, y, z, w, t), w), z)) = 0
pde_linear, pde_nonlinear := selectremove(proc (term) options operator, arrow; not has((eval(term, u(x, y, z, w, t) = a*u(x, y, z, w, t)))/a, a) end proc, expand(pde))
() = 0, 4*(diff(diff(u(x, y, z, w, t), t), x))-(diff(diff(diff(diff(u(x, y, z, w, t), x), x), x), y))+diff(diff(diff(diff(u(x, y, z, w, t), x), y), y), y)+12*(diff(u(x, y, z, w, t), x))*(diff(u(x, y, z, w, t), y))+12*u(x, y, z, w, t)*(diff(diff(u(x, y, z, w, t), x), y))-6*(diff(diff(u(x, y, z, w, t), w), z)) = ()
Download seperate_L-NL.mw
I need to take up an issue which is quite old, but still unsolved.
https://www.mapleprimes.com/questions/234249-Text-Quality-On-Screen
The problem is that in specific display configurations with one (rotated) vertical screen and multiple horizontal screens, the quality of fonts especially is significantly lower in Maple as with a configuration with just horizontal screens.
The affect is visible in Maple when it is on the horizontal (unrotated) screens.
Here are screenshots for comparision, and the layout of my desktop.
Screen layout:
Screenshot rotated
Screenshot unrotated
It seems that the problem is present when starting Maple. Changing the rotation of the screen when Maple is running does not affect the font quality in Maple.
Other (Windows) programs are not affected at all of this changes, so this seems to be a Java issue.
For constants I prefer subscripts over indeces.
I noticed that numbers in subscripts are printed in italic. This is against a common prettyprint convention, where variables are in italic and numbers are in roman. In the example below "1" can easily be misread as "l" (which is probably one of the reasons for this convention)
Is there a way to get numbers printed in roman in subscripts? To force roman print I tried
t__`#mo("1");`
In 2d-Math the convention is respected in the input but not in the outut
First 23 24 25 26 27 28 29 Last Page 25 of 2430
