hello with the new online maple enviroment called "maple learn" can i use this to run maple on my ipad.
my main goal is to just open the files on the ipad when i am standing at a blackboard so i can tjeck and so i know what to write on the board.
are there other methods - if so i would like to hear them
i havent look at mapleNet could this be used.
PS: MAKING PDF IS NOT AN OPTIONS in general, and AS LONG AS THEY LOOK " so bad "
so just to not confuse i dont need to write formulas i just need to be able to look at my work in maple from an ipad.
and really important - i am noot looking to generate maplelearn files for everything. i want to find a normal maple file via the ipad via cloud/onedrive and open it. (no more) or login to maplelearn and open onedrive via file->open (and look through my files on the pc.
Every time I convert Mathematica expressions to Maple in order to use them there, I have to spend hrs by hand adding () around places in the input Mathematica expression because Maple complains about a^b^c.
The problem is that Mathematica has no problem with this, as it always takes a^b^c as a^(b^c). Here is an example to illustrate
But in Maple
MmaTranslator:-FromMma("E^x^2")
So I have to edit the input by hand
MmaTranslator:-FromMma("E^(x^2)")
The problem is that this is how Mathematica produces the expressions, and I have no way to tell Mathematica to put an extra () around to clear this ambiguity,
So I am hoping there is a way in Maple to do it. May be using some option? I know even using Maple own expressions, it complains about this:
x^y^z
But in Mathemtica it accepts this
If there is no way to change this behavior maple, else it means I have to spend hrs again editing all the Mathematica input by hand before using MmaTranslator:-FromMma each time. There are 100's of these in each file.
I think Maple here is not behaving the same as other CAS system. In Fricas it also works as is
(1) -> x^y^z
          z
         y
   (1)  x
Same in Maxima
(%i2) x^y^z;
                                        z
                                       y
(%o2)                                x
Same in Giac
0>> x^y^z
x^(y^z)
And in every other CAS system I tried. It is only Maple who complain about this.
Any suggestions for workaround?
What is the procedure to add global optima package in maple?
I have the function: f(x)= sqrt(x) for x>=0; f(x)=1/x for x<0 and I would like to plot the function.
How exactly to implement this?
Can we write v matrix in terms of matrix u? i.e., v=const*u.
uv_mat.mw
Is it possible to do machine learning using maplesoft I have 2020 for now
Say I have an excel sheet with one dependent variable and n number of independent variables. I can ask for the number of hidden layers we need.
Then i want to traing the data with 70% of the data for training ,  15% of the data for validation and 15% of the data for testing.
I want some charts may be on the performance of the neural networks.
and get the regression equation formed by this training would be looking to repeat the training until MSE has certain approximation.
If this is not possible in maplesoft kindly help me with some other code way to do this. Please help. I will surely acknowledge please advice me.
Is there a way to take a long integer representing the ticks in JS and convert them to a date in maple?
Example: Assume expressions assigned to names
xa, xb, xc := y = x, y = x^2, x = x^3
where you want to apply a command (rhs in this example) to all names fitting to a certain scheme (here a and c)
seq(cat(x, i), i = [a, c])
xa, xc
`~`[rhs]([xa, xc])[]
x, x^3
Combining (2) and (3) in one line
seq(rhs(cat(x, i)), i = [a, c])
Error, invalid input: rhs received xa, which is not valid for its 1st argument, expr
throws an error. Although xa evaluates to an equation
rhs(xa)
x
whattype(cat(x, a))
seems to do the same.
I have not worked out what the xa is that rhs is receiving in the one line statement (see error).
Since rhs returns xa it does not look like a delayed evaluation.
Besides an explanation of what is going on, I'm interested if there is a way to debug what is passed to rhs?
Download cat_in_nested_statement.mw
I am looking to adapt the MathApp to draw random rectangle triangles. Ideas for correcting my sheet?
Pythagorian.mw
MathAppsPytago.mw
I want to  return {x = 0., y = 1.158748796 + 0. I}  as  {x = 0., y = 1.158748796 }.  The solution is coming from:
soln3:= fsolve({b1, b2}, {x = 0 .. infinity, y = 0 .. infinity});
and the second solution is coming from:
 soln4:= fsolve({b1, b2}, {x = -infinity ..0, y = -infinity .. 0});
See my code below
Procedure
doCalc:= proc( xi )
                 # Import Packages
                 uses ArrayTools, Student:-Calculus1, LinearAlgebra,
                      ListTools, RootFinding, plots, ListTools:
                 local gamma__1:= .1093,
                       alpha__3:= -0.1104e-2,
                       k__1:= 6*10^(-12),
                       d:= 0.2e-3,
                       theta0:= 0.0001,
                       eta__1:= 0.240e-1,
                       alpha:= 1-alpha__3^2/(gamma__1*eta__1),
                       c:= alpha__3*xi*alpha/(eta__1*(4*k__1*q^2/d^2-alpha__3*xi/eta__1)),
                       theta_init:= theta0*sin(Pi*z/d),
                       n:= 30,
                       g, f, b1, b2, qstar, OddAsymptotes, ModifiedOddAsym,
                       qstarTemporary, indexOfqstar2, qstar2, AreThereComplexRoots,
                       soln1, soln2, qcomplex1, qcomplex2, gg, qq, m, pp, j, i,
                       AllAsymptotes, p, Efun, b, aa, F, A, B, Ainv, r, theta_sol, v, Vfun, v_sol,minp,nstar,
                       soln3, soln4, Imagroot1, Imagroot2;
# Assign g for q and plot g, Set q as a complex and Compute the Special Asymptotes
  g:= q-(1-alpha)*tan(q)+ c*tan(q):
  f:= subs(q = x+I*y, g):
  b1:= evalc(Re(f)) = 0:
  b2:= y-(1-alpha)*tanh(y) -(alpha__3*xi*alpha/(eta__1*(4*k__1*y^2/d^2+alpha__3*xi/eta__1)))*tanh(y) = 0:
  qstar:= (fsolve(1/c = 0, q = 0 .. infinity)):
  OddAsymptotes:= Vector[row]([seq(evalf(1/2*(2*j + 1)*Pi), j = 0 .. n)]);
# Compute Odd asymptote
  ModifiedOddAsym:= abs(`-`~(OddAsymptotes, qstar));
  qstarTemporary:= min(ModifiedOddAsym);
  indexOfqstar2:= SearchAll(qstarTemporary, ModifiedOddAsym);
  qstar2:= OddAsymptotes(indexOfqstar2);
# Compute complex roots
  AreThereComplexRoots:= type(true, 'truefalse');
  try
   soln1:= fsolve({b1, b2}, {x = min(qstar2, qstar) .. max(qstar2, qstar), y = 0 .. infinity});
   soln2:= fsolve({b1, b2}, {x = min(qstar2, qstar) .. max(qstar2, qstar), y = -infinity .. 0});
   qcomplex1:= subs(soln1, x+I*y);
   qcomplex2:= subs(soln2, x+I*y);
   catch:
   AreThereComplexRoots:= type(FAIL, 'truefalse');
  end try;
# Compute the rest of the Roots
  soln3:= fsolve({b1, b2}, {x = 0 .. infinity, y = 0 .. 10});
  Imagroot1:=subs(soln3, I*y);
  Imagroot2:= subs(soln4, I*y);
  OddAsymptotes:= Vector[row]([seq(evalf((1/2)*(2*j+1)*Pi), j = 0 .. n)]);
  AllAsymptotes:= sort(Vector[row]([OddAsymptotes, qstar]));
  if AreThereComplexRoots
  then gg:= [qcomplex1, qcomplex2,op(Roots(g, q = 0.1e-3 .. AllAsymptotes[1])),
              seq(op(Roots(g, q = AllAsymptotes[i] .. AllAsymptotes[i+1])), i = 1 .. n)];
  elif not AreThereComplexRoots
  then gg:= [op(Roots(g, q = 0.1e-3 .. AllAsymptotes[1])), seq(op(Roots(g, q = AllAsymptotes[i] .. AllAsymptotes[i+1])), i = 1 .. n)];
  end if:
# Remove the repeated roots if any & Redefine n
  qq:= MakeUnique(gg):
  m:= numelems(qq):
## Return all the plots
            return qq, Imagroot1,Imagroot2, p, soln3, soln4;
ans:=[doCalc(0.06)]:
ans[5];
ans[6];
                   {x = 0., y = -1.158748796}
How to write a_{01} in Maple
a[1]
a[1]
a[01] makes a_1. It mates a[01] - a[1] =0. However, a[0] becomes a_0. What to do? I want to write in maple in such that LaTeX conversion works good.
I'm using a procedure but the out is not returned. Please why?
Procedure
doCalc:= proc( xi )
                 # Import Packages
                       k__1:= 6*10^(-12),
                       d:= 0.2e-3,
                       theta0:= 0.0001,
                       eta__1:= 0.240e-1,
                       n:= 30,
                       AllAsymptotes, w, Efun, b, aa, F, A, B, Ainv, r, theta_sol, v, Vfun, v_sol,minp,nstar,
                       qq := [2.106333379+.6286420119*I, 2.106333379-.6286420119*I, 4.654463885, 7.843624703, 10.99193295,14.13546782, 17.27782732, 20.41978346, 23.56157073, 26.70327712, 29.84494078, 32.98658013,         36.12820481, 39.26982019, 42.41142944, 45.55303453, 48.69463669, 51.83623675, 54.97783528,                     58.11943264, 61.26102914, 64.40262495, 67.54422024, 70.68581510, 73.82740963,                                 76.96900389, 80.11059792, 83.25219177, 86.39378546, 89.53537903, 92.67697249];
                        m:= numelems(qq):
                        for i from 1 to m do
                        w[i] := gamma__1*alpha/(4*k__1*qq[i]^2/d^2-alpha__3*xi/eta__1);
  return w;
ans[1];
Kind help with Function given two graphs G1 and G2 then co-normal product be the graph G3 given by the function
conormal(G1,G2)
Defination is explained in youtube link  https://www.youtube.com/watch?v=qz1StIvzrAI
If any other explanation will surely give kind help please will surely acknowlege
This is a much simplified version of a problem I am seeing. I think I have to remove all the coerce code I added as it seems to have problems.
Made an object with constructor that take an optional argument. These optional arguments use coerce to convert different types on one type of list.
I have another proc foo() that is called with these arguments, also same optional ones, and it then creates the object passing these arguments to it.
The problem is that if foo() is called with an optional argument itself, which will default to empty list [], I am not able to create the object now, when doing  ':-ic'=ic  since debugger gives
Error, invalid input: too many and/or wrong type of arguments passed to ModuleCopy; first unused argument is [] = []
Even though I made sure to pass the optional argument using  ':-name'=value.
The strange thing is that this only shows in the debugger. i.e. when typing the command in the debugger window. But in my application, it does not work inside the debugger and outside since it is much more complicated setup.  This is the simplest example I could make to show the same error in the debugger.
A small example will show the problem.
A:=module()
   option object;
   export ode;
   export ic;
   export ModuleCopy::static:=proc(_self, proto::A, ode::`=`,
                    { ic::coerce( (ic::list(`=`))->ic,
                                  (ic::set(`=`))->[ic[]],
                                  `:-NoUserValue`):=[]
        print("ode=",ode);
        print("ic=",ic);
end module;
foo:=proc(ode::`=`,{ ic::coerce( (ic::list(`=`))->ic,
                     (ic::set(`=`))->convert(ic,list),
    local o;
    DEBUG();
    o:=Object(A,ode,':-ic'=ic);
# and now
foo(diff(y(x),x)=1)
Now the debugger window shows at the line above just before calling the object constructor. This is what happens next
But if I click continue it does not produce an error and actually works. (in my main application, with similar setup, it gives an exception).
If I can figure why debugger gives this error, may be that will help me figure my more complicated setup.  I know if I do not use coerce, the debugger error goes away. Here is a version without coerce, and it works
A:=module()
   option object;
   export ode,ic;
   export ModuleCopy::static:=proc(_self, proto::A, ode::`=`, { ic::list(`=`):=[] })
        print("ode=",ode);
        print("ic=",ic);
end module;
                  A := Object<<2457889631168>>
foo:=proc(ode::`=`, { ic::list(`=`):=[]})
    local o;
    DEBUG();
#now do
foo(diff(y(x),x)=1)
Now the debugger window comes up, but now see the difference:
No error!  even though  `ic` was [] in this case also, like the first example.
So for now, I will remove all the coerce code just to get my application to work again even though I like it, but it seems to cause a problem.
question: What the first example above given an error in the debugger?
Notice this error only shows up when using a module of type object
Update
This is just to confirm that removing the coerce API and replacing it back as it was with traditional optional arguments as in the second example above the exception went away.  My code is way too large to post here, but that is the only difference I have.  I think there is a problem using coerce with Object constructor calling somewhere.  But I am OK now, and able to continue work.
Given a graph G say and a positive integer k
I am in look out how to remove
 edge-disjoint copies of G in G^k
That is edge disjoint copies of G into its power graph all possible ways
Again it is the maximum number of copies I means
Keeping this particular way can someone help kind help please
I will surely acknowledge it
G into to GraphPower(G,k)
First 288 289 290 291 292 293 294 Last Page 290 of 2431
