Hi, with Units[Simple] package loaded, I tried to differentiate a few functions using D[n] but it does not work. problem.mw
a := proc (x, y) options operator, arrow; exp(x*y) end proc
proc (x, y) options operator, arrow; exp(y*x) end proc
D[1](a)
proc (x, y) options operator, arrow; y*exp(y*x) end proc
D[2](a)
proc (x, y) options operator, arrow; x*exp(y*x) end proc
retart
retart
"with(Units[Simple]):"
proc (x, y) options operator, arrow; Units:-Simple:-exp(Units:-Simple:-`*`(x, y)) end proc
D[1](a)
Error, (in tools/gensym) too many levels of recursion
D[2](a)
Download problem.mw
Hi! I've got a set of subsets S with Abeing the i-subset. I need to sum up all the x's in all the Ai's. How can this be achieved?
(ex):
sum( { {a, b, c}, {a, b, d} } )= 2a+2b+c+d
Hey I’m trying to define the antiderivative for a function:
g(x) = 1
G(x) = int(g(x),x)
When I then type:
G(x) and press enter Maple gives me G(x) = x which of course is correct
But I can’t type:
G(5)
Then it gives me the error message:
Error, (in int) integration range or variable must be specified in the second argument, got 5
How to fix this?
I know I can type G(x) = x manually but I’m not interested in doing so, because in my document I’m going to have a lot of antiderivatives.
I have a student who then she uses tools/assistent/import data and then the file then Maple claims the Excel file is empty? She uses Maple 2021.2. File works on other my and other student computers.
I would like to perform the following expansion up to an arbitrary order. The dots refer to higher-order terms. All the coefficients are symmetric except for the first one.
Thank you very much!
To Maple support:
I was investigating this pde from a different forum.
I noticed that when using an expanded version of the pde, Maple hangs. Without expanding the PDE, Maple gives an answer in 2 seconds.
Why does expanding the PDE makes a difference? I do not have an earlier version of Maple on my new PC to check if this is a new issue or not.
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1230 and is the same as the version installed in this computer, created 2022, April 21, 9:8 hours Pacific Time.`
pde1:=VectorCalculus:-Laplacian(u(r,theta),'polar'[r,theta]);
pde1_expanded:=expand(pde1);
bc  := u(1,theta)=sin(theta)^4,u(3,theta)=1;
pdsolve([pde1=0,bc],u(r,theta))
(diff(u(r, theta), r)+r*(diff(diff(u(r, theta), r), r))+(diff(diff(u(r, theta), theta), theta))/r)/r
(diff(u(r, theta), r))/r+diff(diff(u(r, theta), r), r)+(diff(diff(u(r, theta), theta), theta))/r^2
u(1, theta) = sin(theta)^4, u(3, theta) = 1
u(r, theta) = (1/52480)*((328*r^6-26568*r^2)*ln(3)*cos(2*theta)+(-r^8+6561)*ln(3)*cos(4*theta)+19680*(ln(3)+(5/3)*ln(r))*r^4)/(ln(3)*r^4)
pdsolve([pde1_expanded=0,bc],u(r,theta)); #HANGS, Waited more than 40 minutes.
Download hangs_pde.mw
DirectSearch finds nonexisting roots....     DirectSearch_finds_nonexisting_roots.mw
plot([cos(x), 0.001*x*x],x=-40..40,y=0..2)     ### test function plot
eq:= cos(x)= 0.001*x*x;     ###   float
cos(x) = 0.1e-2*x^2
use RealDomain in solve(eq,x,explicit) end use   ## lacking some of the roots
-7.793210110, 7.793210110, -11.11953559, 11.11953559, -4.734809278, 4.734809278, -1.568336644, 1.568336644
use RealDomain in solve(eq,x) end use
fsolve(eq,x=-30)
-31.17938383
plot([cos(x), 0.001*x*x],x=-32..-31,y=0.9..1)
fsolve(eq,x=-32..-30);  fsolve(eq,x=-31.7..-31.4)
-31.17938383
-31.52634294
with(DirectSearch)
[BoundedObjective, CompromiseProgramming, DataFit, ExponentialWeightedSum, GlobalOptima, GlobalSearch, Minimax, ModifiedTchebycheff, Search, SolveEquations, WeightedProduct, WeightedSum]
eq;
SolveEquations(eq,AllSolutions):
cos(x) = 0.1e-2*x^2
interface(rtablesize=90);
SolveEquations(eq, AllSolutions)
90
Matrix(%id = 4800942722)
DirectSearch finds nonexisting roots!!!
Dr. Ali GÜZEL
Download DirectSearch_finds_nonexisting_roots.mw
How do I get the plot of P(t) and C(t) and also a table with the values of P(t) for each t? Itried but I couldn't...
restart; beta := 0.7e-2; Lambda := 0.2e-4; `ρ__o` := 0.3e-2; lambda := 0.8e-1; h := 0.1e-1; n := 100
Error,
for i from 0 to n-1 do P[i+1] := (1+h*(`ρ__o`-beta)/Lambda)*P(i)+h*lambda*C(i); C[i+1] := h*beta*P(i)/Lambda+(-h*lambda+1)*C(i) end do:
seq(i, i = 0 .. 30); seq(P[i], i = 0 .. 30)
Error,
with(plots); with(DEtools); p1 := plot([P(t)], t = 0 .. 100, [[P(0) = 1]], scene = [t, P(t)], thickness = 2, linecolor = red, stepsize = .1); p2 := plot([C(T)], t = 0 .. 100, [[C(0) = beta/(Lambda*lambda)]], scene = [t, C(t)], thickness = 2, linecolor = red, stepsize = .1); display([p1, p2])
Download System_Recursive_Equations.mw
Thank!!!
How can I add more terms, in taylor approximation of odes.
Attached the code well written for only second order approximatiom, how can i get the fourth order approximation in taylor expansion to approximate an IVP
taylor_fourth_order.mw
thank you
Backspacing at the end of a few math containers on one row will shift them upwards beyond the top screen out of view and out of existence.  Your last chance of retrieval is when you can still see the bottom half portions of the letters/equations before you need to go to the first point and press enter to bring them down.  Once they're out of view, there's no chance to bring back what you wrote - the assignments are still valid.  Also note CRTL-Z will not bring them back.
This worksheet displays an intersection between two spheres based on a test which seems unrelated to the display.
How can this be explained?
Intersecting_spheres.mw
Using the hide command after displaying a plot in MapleFlow2022 prevents that plot from being moved.
If you create another plot, then both plots are movable until you use the hide command again, at which point you need to create another plot to allow plots to be positioned.
I am writing an arrow procedure and will like to know if there is a way to implement the following
bj := (G, y) ->  (`@`(seq((t -> u -> v -> G(u, t) - v)(args[1 + nargs - i]), i = 1 .. nargs - 2)))(y)
bj(F, y, a, b, c, d);
v:=[p, q, r, s]
the output
My question is, how can I replace the v with each element of the list to get the following as output
F(F(F(F(y,a)-p),b)-q,c)-r,d)-s
Aany suggestion will be highly appreciated
Here is a Maple 2020 worksheet that ran fine on Maple 2020, but runs slower on Maple 2022, especially when plots[display] is used it seems to take much longer?
with(NumberTheory);
NULL;
NULL;
theta := [14.134725, 21.022039, 25.010858, 30.424876, 32.935062, 37.586178, 40.918719, 43.327073, 48.00515, 49.773832, 52.970321, 56.446248, 59.347044, 60.831779, 65.112544, 67.079811, 69.546402, 72.067158, 75.704691, 77.144840, 79.337375, 82.91038, 84.735493, 87.425273, 88.809111, 92.491899, 94.651344, 95.870634, 98.831194];
y[1] := x -> -2*sqrt(x)*cos(theta[1]*ln(x) - argument(0.5 + theta[1]*I))/(abs(0.5 + theta[1]*I)*ln(x));
y[1] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[1\
  ]*ln(x)-argument(.5+I*theta[1]))/(abs(.5+I*theta[1])*ln(x))
   end proc
plot(y[1](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 14.134725*i');
y[2] := x -> -2*sqrt(x)*cos(theta[2]*ln(x) - argument(0.5 + theta[2]*I))/(abs(0.5 + theta[2]*I)*ln(x));
y[2] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[2\
  ]*ln(x)-argument(.5+I*theta[2]))/(abs(.5+I*theta[2])*ln(x))
   end proc
plot(y[2](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 21.022040*i');
y[3] := x -> -2*sqrt(x)*cos(theta[3]*ln(x) - argument(0.5 + theta[3]*I))/(abs(0.5 + theta[3]*I)*ln(x));
y[3] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[3\
  ]*ln(x)-argument(.5+I*theta[3]))/(abs(.5+I*theta[3])*ln(x))
   end proc
plot(y[3](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 25.00858*i');
y[4] := x -> -2*sqrt(x)*cos(theta[4]*ln(x) - argument(0.5 + theta[4]*I))/(abs(0.5 + theta[4]*I)*ln(x));
y[4] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[4\
  ]*ln(x)-argument(.5+I*theta[4]))/(abs(.5+I*theta[4])*ln(x))
   end proc
plot(y[4](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 30.424876*i');
y[5] := x -> -2*sqrt(x)*cos(theta[5]*ln(x) - argument(0.5 + theta[5]*I))/(abs(0.5 + theta[5]*I)*ln(x));
y[5] := proc (x) options operator, arrow; -2*sqrt(x)*cos(theta[5\
  ]*ln(x)-argument(.5+I*theta[5]))/(abs(.5+I*theta[5])*ln(x))
   end proc
plot(y[5](x), x = 20 .. 100, title = 'Fig1*(S &G theta) = 1/2 + 32.93502*i');
T[1] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[1]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[1] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[1])*ln(x)))/n, n = 1 ..
   trunc(ln(100)/ln(2))+1)) end proc
plot(T[1](x), x = 20 .. 100, title = 'T[1]');
T[2] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[2]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[2] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[2])*ln(x)))/n, n = 1 ..
plot(T[2](x), x = 20 .. 100, title = 'T[2]');
T[3] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[3]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[3] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[3])*ln(x)))/n, n = 1 ..
plot(T[3](x), x = 20 .. 100, title = 'T[3]');
T[4] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[3]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[4] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
plot(T[4](x), x = 20 .. 100, title = 'T[4]');
T[5] := x -> -2*sum(Moebius(n)*Re(Ei((0.5 + theta[5]*I)*ln(x)))/n, n = 1 .. trunc(ln(100)/ln(2)) + 1);
T[5] := proc (x) options operator, arrow; -2*(sum(NumberTheory:-\
  Moebius(n)*Re(Ei((.5+I*theta[5])*ln(x)))/n, n = 1 ..
plot(T[5](x), x = 20 .. 100, title = 'T[5]');
f10 := x -> Li(x) - 2*sum(Re(Ei((1/2 + theta[n]*I)*ln(x))), n = 1 .. 10) - ln(2) + int(1/(t*(t^2 - 1)*ln(t)), t = x .. infinity);
f10 := proc (x) options operator, arrow; Li(x)-2*(sum(Re(Ei((1/2\
  +I*theta[n])*ln(x))), n = 1 .. 10))-ln(2)+int(1/(t*(t^2-1)*ln(\
  t)), t = x .. infinity) end proc
R10 := x -> sum(Moebius(l)*f10(x^(1/l))/l, l = 1 .. 8);
R10 := proc (x) options operator, arrow; sum(NumberTheory:-Moebi\
  us(l)*f10(x^(1/l))/l, l = 1 .. 8) end proc
plot1 := plot(R10(x), x = 2 .. 100);
plot2 := plot(pi(x), x = 2 .. 100);
display([plot1, plot2]);
f29 := x -> Li(x) - 2*sum(Re(Ei((1/2 + theta[n]*I)*ln(x))), n = 1 .. 29) - ln(2) + int(1/(t*(t^2 - 1)*ln(t)), t = x .. infinity);
f29 := proc (x) options operator, arrow; Li(x)-2*(sum(Re(Ei((1/2\
  +I*theta[n])*ln(x))), n = 1 .. 29))-ln(2)+int(1/(t*(t^2-1)*ln(\
R29 := x -> sum(Moebius(l)*f29(x^(1/l))/l, l = 1 .. 8);
R29 := proc (x) options operator, arrow; sum(NumberTheory:-Moebi\
  us(l)*f29(x^(1/l))/l, l = 1 .. 8) end proc
plot3 := plot(R29(x), x = 2 .. 100);
NULL;
display([plot1, plot2, plot3]);
R29(100);
R10(100);
pi(100);
                          25.25165721
                          25.28503922
                               25
RR10 := x -> sum(Moebius(l)*f10(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2)) + 1);
RR10 := proc (x) options operator, arrow; sum(NumberTheory:-Moeb\
  ius(l)*f10(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2))+1) end
   proc
RR10(1000);
pi(1000);
                          168.1328341
                              168
RR29 := x -> sum(Moebius(l)*f29(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2)) + 1);
RR29 := proc (x) options operator, arrow; sum(NumberTheory:-Moeb\
  ius(l)*f29(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2))+1) end
   proc
RR29(1000);
                          167.6113955
P1 := plot(RR29(x), x = 880 .. 930);
P2 := plot(pi(x), x = 880 .. 930);
display([P1, P2]);
f0 := x -> Li(x) - ln(2) + int(1/(t*(t^2 + 1)*ln(t)), t = x .. infinity);
f0 := proc (x) options operator, arrow; Li(x)-ln(2)+int(1/(t*(t^\
  2+1)*ln(t)), t = x .. infinity) end proc
RR0 := x -> sum(Moebius(l)*f0(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2)) + 1);
RR0 := proc (x) options operator, arrow; sum(NumberTheory:-Moebi\
  us(l)*f0(x^(1/l))/l, l = 1 .. trunc(ln(1000)/ln(2))+1) end proc
P3 := plot(RR0(x), x = 880 .. 930);
NULL;
display([P1, P2, P3]);
P4 := plot(RR10(x), x = 880 .. 930);
display([P1, P2, P3, P4], color = [green, blue, purple, yellow]);
evalf(Li(2)), evalf(ln(2));
                   1.045163780, 0.6931471806
evalf(li(2));
                             li(2)
evalf(Ei(2));
                          4.954234356
evalf(Int(1/ln(t), t = 0 .. 2));
                        Float(undefined)
evalf(Ei(ln(2)));
                          1.045163780
Li(1000.);
                          177.6096580
isprime, [$ (1 .. 100)];
isprime, [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16,
  17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32,
  33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48,
  49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64,
  65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80,
  81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96,
  97, 98, 99, 100]
nops(select(isprime, [$ (1 .. 100)]));
                               25
theta[1];
                           14.134725
evalf(Ei((1/2 + theta[1]*I)*ln(x)));
             Ei((0.5000000000 + 14.134725 I) ln(x))
evalf(Ei(ln(1/2 + theta[1]*I)));
                  4.386989035 + 6.632175089 I
plot(Li(x), x = 0 .. 5);
First 319 320 321 322 323 324 325 Last Page 321 of 2431
