Ok, I think I am starting to get the hang of this. So in Maple, structured types is like a pattern in Mathematica. To find some subexpression one needs to first define a structured type which match that subexpression, and then use  select(type,.....).
This works well so far (but it is not as easy as setting up a pattern).
But one small problem is that select() starts looking at the operands of the expression to look for a match.
So if the whole expression itself matches the structured type, it will not detect the whole expression, since select goes over each operand, missing that the whole thing actually matches the type.
May be an example helps shows what I mean. I want to find if an expression has cos(anything)*sin(anything) so I made a structured type for this
mytype_3 :=  ''`*`'( {'specfunc'(cos),'specfunc'(sin)})';
btw, I do not know if I should use `&*` or '`*`' but that is a side point, I'll try to find this out.
Now I want to use the above to check if expression has the same "structured type", or "pattern". The expression is expr:=cos(x)*sin(x); clearly it matches it. But since select looks at the operands, it will only see cos(x) by itself, and then sin(x) by itself and hence not find the structured type.
type(expr,mytype_3);  # true
select(type, expr, mytype_3); # does not work, does not find it.
Since I am doing this in code, and I do not know what the expression is, I think I have to now do the following
if type(expr,mytype_3) then
   print("The whole expression is a match! nothing to do. no need to use select");
fi;
Which is OK. I can do this, But it will be nice if there was a way to have select (or another function like it) starts at the top level before looking at the operands?
How do others handle such cases? does the above sound like an OK solution to this?
I am a research scholar in mathematics
I am currently working on fluid mechanics
I wish to obtain the solution given in the research article
I am uploading the pdf containing problem.
In the paper they mentioned that " Shooting method" is used.
Please anyone help me regarding this topic
File : 1.pdf
I am learning how to use select with my own types defined, to find parts of expression. This is instead of using patmach.
For example, given   3+x^2*sin(x) and then I want to find any POLYNIMAL*sin function, if present. So I did the following
expr_1:=3+x^2*sin(x):
mytype_1 := `&*`( polynom(And(algebraic, satisfies(u -> not has(u, I))),x),specfunc('sin')):
select( z->type(z,mytype_1),expr_1);
Which works. Maple returned
The problem is that if I change the order of multiplication, and also at same time change the polynomial by adding one more term, it no longer works!
I have no idea why. It seems Maple rememebrs something.  Here is a screen shot, followed by plain text code.
code
expr_1:=3+(1+x)*sin(x):
expr_1:=3+sin(x)*(1+x):
#change polynomial but keep same order, it works
expr_2:=3+(1+x+x^2)*sin(x):
select( z->type(z,mytype_1),expr_2);
#change order BUT keep same polynomial, it works
expr_3:=3+sin(x)*(1+x+x^2):
select(z->type(z, mytype_1),expr_3);
#keep same order as above, but change polynomial, now it does not works
expr_4:=3+sin(x)*(1+x+x^2+x^4):
select(z->type(z, mytype_1),expr_4);
#keep same order as first one  but change polynomial, it does not work
expr_5:=3+(1+x+x^2+x^4)*sin(x):
select(z->type(z, mytype_1),expr_5);
#keep same order as first one but change polynomial back to what it was, now it works
expr_6:=3+(1+x)*sin(x):
select(z->type(z, mytype_1),expr_6);
What Am I doing wrong?
Maple 2021.1
I have  an expression made of a sum of different terms from which I want to extract all terms of a specific form.
A typical expression and the functions I want to extract is given in the attached file.
You will see in the example that the terms in the expression can be
  • a constant
  • a continuous function of t
  • a piecewise function like
    something*piecewise(a(t) < 0, A(t), a(t) < 1, B(t), ...)
    something*piecewise(t < 0, A(t), t < 1, B(t), ...)
The functions I want to extract are only those of this latter form .
MyExpr.mw
PS: all the situations I have to manage contain expressions of the form of the prototype expression given in the attached file.
       Nothing more general than this.
This worksheet displays an ellipsoid internally tangent to the four sides of a tetrahedron.
The tetrahedron is a special case: it has a horizontal base with vertices A,B and C and its fourth vertex E is on the z axis.
However I have failed when trying to display an internally tangent ellipsoid in any other tetrahedron.
Will any tetrahedron support one or more internally tangent ellipsoids?
If so, are there conditions restricting the location of the mutual points of tangency?
Ellipsoid_in_a_tetrahedron.mw
How to obtain a dual branch solution in Maple.
Is there any specific method is there to get these type of solutions.
I have attached the document.
Link [copyright material removed by moderator]
I'm trying to construct an iterative procedure al1(f,x0) where f is a function, x0 is an initial estimate.
Now for example by defining f:= x-> 4*x^4-4*x^2 and inputting x0=0.75 and N=10 i should be able to check that my procedure calculates 1 correctly.
f := x -> 4*x^4 - 4*x^2;
f1 := D(f);
f2 := D(f1);
x0 := 0.75;
Digits := 100;
tol := 10.^(-15);
al1:= proc(f,x0)
local y, z, s, i, fs, a, de;
s := x0:
a[0]:=x0;
for i from 1 to 10
while abs(fs)>tol and de>tol do
y := evalf(s- f(s)/f1(s)):
s:=evalf(y-f(y)/f1(y)):
fs:=evalf(f(s)):
a[i]:=s:
de:=abs(evalf(a[i]-a[i-1])):
return n, s, fs, de;
> n, s, fs, de := al1(f, 0.75);
Error, (in al1) cannot determine if this expression is true or false: 0.1000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-14 < abs(fs) and 0.1000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-14 < de
The code i've written so far is incorrect but i'm not sure where i'm going wrong. Would you be able to give me some pointers?
Hi !
Sorry but there is a bug in the "combine" command when combining double summations.
 Maple 2017,2018 and 2020 all give me a wrong answer. I have an old version of Maple which gives the correct answer.
I have put an example in the attached file.
bugcombine.mw
Best regards
Réjean
Hello. looking for the numerical or analytical solution of the attached file and at the needed expression or value of lambda for different values of the involved parameter?
Help_numerically_solution.mw
I need the non-dimensional form of PDE with given non-dimensional variables. I have attached a worksheet please check it.
Thank you nondimensional.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/nondimensional.mw .
Download nondimensional.mw
hello dear friends
i want to solve an equation about adding three cosine term which are constrained:
cos(2 pi(x+y-2z))+cos(2 pi(y+z-2x))+cos(2 pi(z+x-2y))=0
with constraint 0<x<1,x<y<1,y<z<1
can some one please guide me?
i wrote this command but it did not work:
solve({cos(2*Pi*(x+y-2*z))+cos(2*Pi*(y+z-2*x))+cos(2*Pi*(z+x-2*y)) = 0, 0 <= x, x <= 1, y <= 1, z <= 1, x < y, y < z}, [x, y, z], explicit)
Hi MaplePrimes team,
Does Maple have a step detection command for a given step function f(x)?
The command has to return a list of jump detections in a given range [xmin... xmax].
For example, can Maple find the following jump detections:
Figure 1 (trivial case): f(x) = floor(x)
where it is easy to guess the list of step detections: [x1 = 1, x2 = 2, x3 = 3, …, xn = n]
Figure 2: g(x) = 2 + floor(x + 5*sin x)
a little more difficult.
Thank you in advance.
Guy.
Maple 2021.1/Windows 10.
When entering 2d expressions into the bottom line of a worksheet, i.e. at the bottom of the window, I can't see the underscores used to indicate bracketing.
A workaround is to use ^J to get another input prompt at the bottom of the window.
Is there some way to get a bigger margin at the bottom of the window?
Cheers,
Steve.
In Maple 2020, the following line works fine:
Statistics:-HeatMap(Matrix(128,(i,j)->modp(binomial(i,j),2)),color=["White","Black"]);
With Maple 2021, I get
Interestingly, the exported PNG is better with Maple 2021 (not blurry as in Maple 2020). However, there is an alignment problem with the axes. And it appears in Maple, before exporting. Bug?
(Maple 2020/2021 on Windows 10)
First 398 399 400 401 402 403 404 Last Page 400 of 2432
